M SERIES CONNECTORS
RATCHET COUPLING
Introduction
This catalogue gives the complete description of LEMO M series connectors. M series connectors are lightweight triplestart ratchet coupling type connectors designed for avionics, aerospace, military, security, motorsport and heavy duty applications.
The LEMO manufacturing programme has been extended to almost 40 series divided into 7 product families with specific
mating and environmental characteristics. Each series includes a wide variety of plug, socket and coupler models, available in contact configurations adapted to all round cables. Watertight models are also available. Since LEMO connectors
are perfectly screened and designed to guarantee very low resistance to shell electrical continuity, they are particularly adapted
to applications where electromagnetic compatibility (EMC) is important.
Technical Characteristics
Materials and Treatments
Component
Shell
material code
X
Surface treatment (µm)
Notes
chrome
nickel
gold
Cu Ni Cr Cu Ni Cu Ni Au
Material (Standard)
C
Brass (UNS C 38500)
Aluminium alloy (AA 6262A or AA 6023)
Brass (UNS C 38500)
Bronze (UNS C 54400) or special brass
Brass (UNS C 38500)
Special PEEK
Brass (UNS C 38500)
Brass (UNS C 34500)
Cu-Be or special steel
PEEK
Silicone
FPM/FKM (Viton®)
Epoxy (Araldite® or Stycast®)
Fluorosilicone
Stainless steel
Outer shell
Conical nut
Earthing crown
Coupling nut
Ratchet
Hexagonal nut
Male crimp contact
Female crimp contact
Clips
Insulator
O-ring
Sealing resin
Cable rear seal
Spring
0.5
0.5
3
3
0.3 –
5
0.3 –
5
– 0.5
– 0.5 3
– 0.5 3
– 0.5 3
– 0.5 3
5
– 0.5
– 0.5
without treatment
3
3
1.5
1.0
1.5
1)
1)
Notes: standards for surface treatment are as follows: chrome-plated FS QQ-C-320B; nickel-plated FS QQ-N-290A or MIL DTL 32119; gold-plated ISO 27874.
1) anthracite colour.
Environmental performance
Characteristics
Operating temperature (mated)
Ingress protection index
Fungus
Flammability
Fluid contamination 1)
Sand and dust 2)
Lightning strike
Altitude-low temp 3)
Salt fog 4)
Thermal shock
Altitude immersion
Air leakage 5)
Humidity
Value
- 55°C/+200° C
IP 68 (at 2 m, 15Hr)
Satisfied - by material analysis
60 sec. front and back face
Fuels, gasoline, hydraulic oils, solvents, de-icing
6 hr, 55° C, blowing < 150 µm dust
10 K amps - 6 times
-65° C; 40’000 feet and 400 VAC
Alum. shell (slight pitting after 48 Hr), Brass shell (500 Hr)
5 cycles : -65° C to +150° C
No moisture on contacts
< 10-7 mbar. l/sec (Helium)
21 days at 95%
IEC international
MIL-spec tests
IEC 60529
IEC 60512-6 test 11f
IEC 60512-11-4
IEC 60512-7 14 b
IEC 60068-2
MIL-STD 810F-508.5
EIA-364-104A
MIL-STD-810F method 504
MIL-STD 810F-510.4
EIA-364-75
EIA-364-105A
EIA-364-26
EIA-364-32 test condition IV
EIA-364-03
MIL-STD-1344 method 1008.1
EIA-364-31 method IV
Note:
1) Connectors immersed at both 70°C and 25°C according to specification. Connectors are then inspected, no visual signs of damage seen.
Fuels: Kerosene, JP4, (Nato F40) at 70°C +/- 2°C. Gasoline: ASTM 4814. Hydraulic oils: Mineral oil based MIL-H-5606.
Solvents: Isopropanol. De-icing fluids: 25% ethylene glycol.
2) No signs of damage, connectors opened and closed without difficulty. Dust or sand was not inside connector.
3) Wired mated connectors = no voltage breakdown, shell to all contacts (connected together) w/400 VAC after 1 hour at 65° C
at 40’000 feet altitude.
4) Corrosion resistance. Inspection: salt deposits shall be removed by gentle wash in running water with light brushing using soft brush.
Aluminium Shell (material code: X) max: 96 hours. Brass shell (material code: C) over 500 hours.
5) Only for vacuumtight model (HE•)
www.lemo.com
1
Electrical performance
Characteristics
Value
Insulation resist. (at ambient temp.) 6)
Dielectric withstanding volt. (sea level)
Contact resistance
Current rating
Shell to shell conductivity
Shielding effectiveness, low frequency
Shielding effectiveness, high frequency
IEC international
> 1012 Ω, > 1010 Ω (after humidity)
See table page 16-17
See table below 7)
See insulator configuration page 16-17
< 1.5mΩ
≥ 80 dB up to 1GHz
≥ 70 dB (3GHz), ≥ 58 dB (6GHz), ≥ 40 dB (10GHz)
IEC 60512-2 test 3a
IEC 60512-2 test 4a
IEC 60512-2 test 2a
IEC 60512-3 test 5a
IEC 60512-2-6
MIL-spec tests
EIA-364-21
EIA-364-20
EIA-364-06
EIA-364-83
EIA-364-66
EIA-364-66
Note: 6) After humidity test: 21 days at 95% RH according to IEC 60068-2. Insulation resistance measured between the contacts and contact/shell.
Contact resistance 7)
IEC 60512-2 test 2a
0.5
≤ 8.7
0.7
0.9
1.3
≤ 6.1 ≤ 4.8 ≤ 3.6
Value
øA
(mm)
mΩ
Notes: 7) after 5000 mating cycles and the salt spray test according to IEC 60512-6 test 11 f.
Mechanical performance
Characteristics
Endurance
Gunfire vibration
Vibration-Sine 8)
Vibration-Random
Shock
Acceleration
Contact retention
Torque
Value
IEC international
3000 cycles
25 to 2000 Hz, 3 axis (Apache helicopter)
30 g, 3 axis, 12 hr
50-2000 Hz, 37.8 g rms-3 axes; 4h amb
300 g - 3 msec
50 g acceleration
> 22 N (ø 0.7mm), > 30N (ø 0.9 mm)
See table below
IEC 60512-5 test 9a
IEC 60512-6-4
IEC 60512-6-3
MIL-spec tests
EIA-364-09
MIL-STD-810F method 519.5
MIL-STD-202 method 204-G
EIA-364-28 test cond. V letter I
EIA-364-27 condition D
MIL-STD-1344 - 2011-1, A
IEC 60512-8 test 15a
Note: 8) Amplitude: 30G. Frequency: 10 to 2000 Hz. Time per axis: 4 hours (X, Y, Z). No signal discontinuity above 1 µs.
Series
Coupling torque
tightning (N.cm)
Coupling torque
untightning (N.cm)
Series
0M
1M
2M
3M
4
10
5
11
14
29
TM
4M
LM
5M
Coupling torque
tightning (N.cm)
26
26
48 9)
91 9)
Coupling torque
untightning (N.cm)
30
25
43
54
Note: 9) Higher contact density = larger torque force.
2
www.lemo.com
M Series
The M Series connector offers a new innovative design for avionics, aerospace, military, security, motorsport and heavy
duty applications.
Made of high-strength aluminium, this connector is one of the lightest and most compact of the LEMO product line.
A one-grip ratchet screw system enables quick and secure coupling of the connectors. The arctic grip makes it easy to manipulate the connector while wearing gloves or when the connector is located in a difficult to access area.
Features
– Ratchet-coupling mechanism
– Compact design for space savings
– Oil and fuel resistant
– 360° screening for full EMC shielding
– Colour coding / keying
– Scoop proof
– Threaded for MIL-DTL-38999L backshell
– Quick mating: less than 3/4 turn to seat
– Lightweight
– High vibration and shock resistance
– Sealed to IP68 when mated
– Reverse sex configuration
– Pin configuration from 2 to 114 contacts
Metal housing models (page 5)
Straight plugs
FM
Free sockets
Fixed sockets
EG
PB
FM
EG
PV
PM
PV
PM
PV
PH
PF
PH
PB
FM
EC
FG
EC
FG
ED
FG
ED
PB
PF
PE
USB models
Watertight model (unmated)
Straight plugs
FM
www.lemo.com
FG
Fixed sockets
EG
Fixed socket
EG
HE
3
Part Numbering System
FM N . 1M . 305 . X
L
C
FG N . 1M . 305 . X
L
C M
Free socket
PM N . 1M . 305 . X
L M T
Fixed socket
HE N . 1M . 305 . X
L
Plug
N
P
Model: (page 5)
Variant:
T = Mold stop
P = Potted
M = MIL-DTL-38999L shell thread
Alignment key: (page 15)
Contact: (page 18)
Series: (page 5)
Insulator: L = PEEK
Insert configuration: (page 16)
Housing: (page 17)
Part Number Example
Straight plug:
FMN.1M.305.XLC = straight plug with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated
aluminium alloy, PEEK insulator, male crimp contacts.
Straight plug:
FGN.1M.305.XLCM = straight plug with key (N), arctic grip, 1M series, multipole type with 5 contacts, outer shell in anthracite
nickel-plated aluminium alloy, PEEK insulator, male crimp contacts and with MIL-DTL-38999L thread for additional backshell
(not supplied).
Free socket:
PMN.1M.305.XLMT = free socket with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated
aluminium alloy, PEEK insulator, female crimp contacts and mold stop.
Fixed socket:
HEN.1M.305.XLNP = fixed socket, nut fixing, with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite
nickel-plated aluminium alloy, PEEK insulator, female print contacts, watertight.
Part Section Showing Internal Components
Fixed socket
1
2
3
4
5
6
4
outer shell
o-ring
hexagonal nut
insulator
female contact
earthing crown
5
4
6
3
2
1
1
3
2
7
5
6
Straight plug
4
1
2
3
4
5
6
7
outer shell
insulator
male contact
rear seal
tightening screw
ratchet mechanism
spring
www.lemo.com
FM● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X)
with knurled grip
Reference
Ls/Lr
øA
øC
P
øD
øB
X
Dimensions (mm)
Model
Series
A
B
C
D
Ls
Lr
P
X
FM●
FM●
FM●
FM●
FM●
FM●
FM●
FM●
0M
1M
2M
3M
TM
4M
LM
5M
13.1
14.6
17.6
19.6
22.5
25.0
28.5
34.0
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
8.0
9.7
13.0
15.0
16.7
19.5
22.7
28.5
24.1
24.1
24.5
24.5
28.6
28.6
28.6
28.6
24.1
24.1
24.5
24.5
28.6
28.6
28.6
28.6
3.9
3.9
3.9
3.9
3.4
3.4
3.4
3.4
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: FMN.1M.305.XLC
Note: Ls = standard gender, Lr = reverse gender
with knurled grip and mold stop
Reference
Ls/Lr
øC
øD
øF
øB
X
øA
P
M
Dimensions (mm)
Model
Series
A
B
C
D
F
Ls
Lr
M
P
X
FM●
FM●
FM●
FM●
FM●
FM●
FM●
FM●
0M
1M
2M
3M
TM
4M
LM
5M
13.1
14.6
17.6
19.6
22.5
25.0
28.5
34.0
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
8.0
9.7
13.0
15.0
16.7
19.5
22.7
28.5
10.7
12.4
15.5
17.5
19.8
22.6
25.8
31.4
27.1
27.1
27.5
27.5
31.6
31.6
31.6
31.6
27.1
27.1
27.5
27.5
31.6
31.6
31.6
31.6
9.7
9.7
10.1
10.1
10.6
10.6
10.6
10.6
3.9
3.9
3.9
3.9
3.4
3.4
3.4
3.4
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
1.5
Part number example: FMN.1M.305.XLCT
with knurled grip and MIL-DTL-38999L shell thread
Dimensions (mm)
Reference
Ls/Lr
øA
P
øC
e
9
Model
Series
A
C
e
Ls
Lr
P
Code1)
FM●
FM●
FM●
FM●
FM●
FM●
FM●
1M
2M
3M
TM
4M
LM
5M
14.6
17.6
19.6
22.5
25.0
28.5
34.0
14.2
17.2
19.2
22.0
24.5
28.0
33.5
M12x1.0
M15x1.0
M18x1.0
M18x1.0
M22x1.0
M25x1.0
M31x1.0
26.4
26.4
26.4
30.0
30.0
30.0
30.0
26.4
26.4
26.4
30.0
30.0
30.0
30.0
3.9
3.9
3.9
3.4
3.4
3.4
3.4
A
B
C
C
D
E
G
Part number example: FMN.1M.305.XLCM
Note: Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code
(backshell not supplied)
www.lemo.com
5
FG● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X)
with arctic grip
Reference
Ls/Lr
øA
øC
øD
øB
P
Dimensions (mm)
Model
Series
A
B
C
D
Ls
Lr
P
X
FG●
FG●
FG●
FG●
FG●
FG●
FG●
FG●
0M
1M
2M
3M
TM
4M
LM
5M
14.4
15.9
18.9
20.9
23.4
25.9
29.4
34.9
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
8.0
9.7
13.0
15.0
16.7
19.5
22.7
28.5
24.1
24.1
24.5
24.5
28.6
28.6
28.6
28.6
24.1
24.1
24.5
24.5
28.6
28.6
28.6
28.6
3.9
3.9
3.9
3.9
3.4
3.4
3.4
3.4
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: FGN.1M.305.XLC
X
with arctic grip and mold stop
Reference
Ls/Lr
øA
øC
P
øD
øF
øB
M
Dimensions (mm)
Model
Series
A
B
C
D
F
Ls
Lr
M
P
X
FG●
FG●
FG●
FG●
FG●
FG●
FG●
FG●
0M
1M
2M
3M
TM
4M
LM
5M
14.4
15.9
18.9
20.9
23.4
25.9
29.4
34.9
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
8.0
9.7
13.0
15.0
16.7
19.5
22.7
28.5
10.7
12.4
15.5
17.5
19.8
22.6
25.8
31.4
27.1
27.1
27.5
27.5
31.6
31.6
31.6
31.6
27.1
27.1
27.5
27.5
31.6
31.6
31.6
31.6
9.7
9.7
10.1
10.1
10.6
10.6
10.6
10.6
3.9
3.9
3.9
3.9
3.4
3.4
3.4
3.4
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: FGN.1M.305.XLCT
X
1.5
with arctic grip and MIL-DTL-38999L shell thread
Dimensions (mm)
Reference
Ls/Lr
øA
P
øC
e
9
Model
Series
A
C
e
Ls
Lr
P
Code1)
FG●
FG●
FG●
FG●
FG●
FG●
FG●
1M
2M
3M
TM
4M
LM
5M
15.9
18.9
20.9
23.4
25.9
29.4
34.9
14.2
17.2
19.2
22.0
24.5
28.0
33.5
M12x1.0
M15x1.0
M18x1.0
M18x1.0
M22x1.0
M25x1.0
M31x1.0
26.4
26.4
26.4
30.0
30.0
30.0
30.0
26.4
26.4
26.4
30.0
30.0
30.0
30.0
3.9
3.9
3.9
3.4
3.4
3.4
3.4
A
B
C
C
D
E
G
Part number example: FGN.1M.305.XLCM
6
www.lemo.com
EG● Fixed socket, nut fixing, key (N)
Dimensions (mm)
Reference
Ls/Lr
S1
e
øC
P
Series
C
D
e
E
Ls
Lr
P
S1
S2
EG●
EG●
EG●
EG●
EG●
EG●
EG●
EG●
0M
1M
2M
3M
TM
4M
LM
5M
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
6.8
6.8
6.8
6.8
9.4
9.4
9.4
9.4
M9x0.6
M11x1.0
M14x1.0
M16x1.0
M18x1.0
M21x1.0
M24x1.0
M30x1.0
5.0
4.5
4.5
4.0
4.0
4.0
4.0
4.0
18.1
18.1
18.1
18.1
19.8
19.8
19.8
19.8
18.1
18.1
18.1
18.1
21.7
21.7
21.7
21.7
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
8.2
9.5
12.5
14.5
16.5
19.5
22.5
28.5
11.0
13.0
17.0
19.0
22.0
25.0
30.0
36.0
Part number example: EGN.1M.305.XLM
D
S2
Model
E maxi
Panel cut-out (page 23).
or keys (P, R, S, T, U, V, W and X) for printed circuit
Dimensions (mm)
Reference
Ls/Lr
G
S2
P
e
øC
S1
4.5
Series
C
D
e
E
G
Ls
Lr
P
S1
S2
EG●
EG●
EG●
EG●
EG●
EG●
EG●
EG●
0M
1M
2M
3M
TM
4M
LM
5M
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
6.8
6.8
6.8
6.8
9.4
9.4
9.4
9.4
M9x0.6
M11x1.0
M14x1.0
M16x1.0
M18x1.0
M21x1.0
M24x1.0
M30x1.0
5.0
4.5
4.5
4.0
4.0
4.0
4.0
4.0
16.8
16.8
16.8
16.8
18.9
18.9
18.9
18.9
18.1
18.1
18.1
18.1
19.8
19.8
19.8
19.8
18.1
18.1
18.1
18.1
21.7
21.7
21.7
21.7
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
8.2
9.5
12.5
14.5
16.5
19.5
22.5
28.5
11.0
13.0
17.0
19.0
22.0
25.0
30.0
36.0
Part number example: EGN.1M.305.XLN
D
E maxi
5.6
Model
Panel cut-out (page 23). PCB drilling pattern (page 24).
EC● Fixed socket with two nuts, key (N)
Reference
Ls/Lr
S1
e
øA
P
øB
øC
S3
Dimensions (mm)
Model
Series
A
EC●
EC●
EC●
EC●
EC●
EC●
EC●
EC●
0M
1M
2M
3M
TM
4M
LM
5M
17
18
21
23
27
29
33
38
B
C
4.72 18.2
5.95 19.2
8.95 21.5
10.95 25.0
12.30 28.0
13.95 34.0
17.95 36.0
22.90 41.0
E
e
G
Ls
Lr
P S1 S2 S3
5.0
5.0
4.0
4.0
2.5
2.5
2.5
2.5
M13x0.75
M14x1.00
M17x1.00
M19x1.00
M22x1.00
M24x1.00
M28x1.00
M33x1.00
16.8
16.8
16.8
16.8
18.9
18.9
18.9
18.9
18.1
18.1
18.1
18.1
19.8
19.8
19.8
19.8
18.1
18.1
18.1
18.1
21.7
21.7
21.7
21.7
5.3 11.5 14.0 16.0
5.3 12.5 16.0 17.0
5.3 15.5 18.0 19.0
5.3 17.5 20.0 22.0
7.9 20.5 23.0 25.0
7.9 22.5 25.0 30.0
7.9 26.5 29.0 32.0
7.9 31.5 34.0 37.0
Part number example: ECN.1M.305.XLM
E maxi
S2
G
This model is not IP68 (no panel sealing).
www.lemo.com
7
Reference
S3
Ls/Lr
S1
e
øA
P
øB
øC
5.6
E maxi
4.5
Dimensions (mm)
Model
Series
A
EC●
EC●
EC●
EC●
EC●
EC●
EC●
EC●
0M
1M
2M
3M
TM
4M
LM
5M
17
18
21
23
27
29
33
38
B
C
4.72 18.2
5.95 19.2
8.95 21.5
10.95 25.0
12.30 28.0
13.95 34.0
17.95 36.0
22.90 41.0
E
e
G
Ls
Lr
P S1 S2 S3
5.0
5.0
4.0
4.0
2.5
2.5
2.5
2.5
M13x0.75
M14x1.00
M17x1.00
M19x1.00
M22x1.00
M24x1.00
M28x1.00
M33x1.00
16.8
16.8
16.8
16.8
18.9
18.9
18.9
18.9
18.1
18.1
18.1
18.1
19.8
19.8
19.8
19.8
18.1
18.1
18.1
18.1
21.7
21.7
21.7
21.7
5.3 11.5 14.0 16.0
5.3 12.5 16.0 17.0
5.3 15.5 18.0 19.0
5.3 17.5 20.0 22.0
7.9 20.5 23.0 25.0
7.9 22.5 25.0 30.0
7.9 26.5 29.0 32.0
7.9 31.5 34.0 37.0
Part number example: ECN.1M.305.XLN
S2
G
ED● Fixed socket with square flange, key (N)
Reference
Ls/Lr
K
P
øB
øC
øA
N
H
Dimensions (mm)
Model
Series
A
B
C
G
H
K
Ls
Lr
N
P
V
ED●
ED●
ED●
ED●
ED●
ED●
ED●
ED●
0M
1M
2M
3M
TM
4M
LM
5M
20.6
23.8
26.9
29.0
31.4
34.6
38.0
43.7
4.72
5.95
8.95
10.95
12.30
13.95
17.95
22.90
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
12.8
12.8
12.8
12.8
14.5
14.5
14.5
14.5
11.0
12.9
15.1
16.6
18.3
20.6
23.0
27.0
1.5
1.5
1.5
1.5
2.0
2.0
2.0
2.0
18.1
18.1
18.1
18.1
19.8
19.8
19.8
19.8
18.1
18.1
18.1
18.1
21.7
21.7
21.7
21.7
16.0
18.4
20.6
22.1
23.8
26.1
28.5
32.5
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
2.7
3.3
3.3
3.3
3.3
3.3
3.3
3.3
Part number example: EDN.1M.305.XLM
øV
G
Reference
Ls/Lr
N
K
øA
P
øB
øC
5.6
4.5
H
øV
Dimensions (mm)
Model
Series
A
B
C
G
H
K
Ls
Lr
N
P
V
ED●
ED●
ED●
ED●
ED●
ED●
ED●
ED●
0M
1M
2M
3M
TM
4M
LM
5M
20.6
23.8
26.9
29.0
31.4
34.6
38.0
43.7
4.72
5.95
8.95
10.95
12.30
13.95
17.95
22.90
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
12.8
12.8
12.8
12.8
14.5
14.5
14.5
14.5
11.0
12.9
15.1
16.6
18.3
20.6
23.0
27.0
1.5
1.5
1.5
1.5
2.0
2.0
2.0
2.0
18.1
18.1
18.1
18.1
19.8
19.8
19.8
19.8
18.1
18.1
18.1
18.1
21.7
21.7
21.7
21.7
16.0
18.4
20.6
22.1
23.8
26.1
28.5
32.5
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
2.7
3.3
3.3
3.3
3.3
3.3
3.3
3.3
Part number example: EDN.1M.305.XLN
G
8
www.lemo.com
PE● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V,
W and X) with mold stop (back panel mounting)
Reference
L
e
E maxi
X
øA
øD
øF
øB
øC
P
S1
M
Dimensions (mm)
Model
Series
A
PE●
PE●
PE●
PE●
PE●
PE●
PE●
PE●
0M
1M
2M
3M
TM
4M
LM
5M
17
18
21
23
27
29
33
38
B
C
D
E
8.8 16.8 8.0
10.5 17.8 9.7
14.0 20.8 13.0
16.0 22.8 15.0
17.9 25.8 16.7
20.7 27.8 19.5
23.9 31.8 22.7
29.7 36.8 28.5
e
Ls
5.0 M13x0.75
5.0 M14x1.00
5.0 M17x1.00
5.0 M19x1.00
4.0 M22x1.00
4.0 M24x1.00
4.0 M28x1.00
4.0 M33x1.00
Lr
M
P
R
S1 S2
25.6 25.6 9.7 5.3 13.8 11.5
25.6 25.6 9.7 5.3 13.8 12.5
26.0 26.0 10.1 5.3 13.8 15.5
26.0 26.0 10.1 5.3 13.8 17.5
29.5 30.1 10.6 7.9 16.9 20.5
29.5 30.1 10.6 7.9 16.9 22.5
29.5 30.1 10.6 7.9 16.9 26.5
29.5 30.1 10.6 7.9 16.9 31.5
14
16
18
25
29
34
Part number example: PEN.1M.305.XLMT
S2
R
1.5
Note: this model is only available with mold stop. The dimensions «F» and «X» are
the same as the PB● models. Ls = standard gender, Lr = reverse gender.
PF●
or keys (P, R, S, T, U, V, W and X) with mold stop
Reference
Ss/Sr
K
øA
N
G
P
øC
øD
øF
øB
øE
M
Dimensions (mm)
Model
Series
A
B
C
D
PF●
PF●
PF●
PF●
PF●
PF●
PF●
PF●
0M
1M
2M
3M
TM
4M
LM
5M
20.6
23.8
26.9
29.0
31.4
34.6
38.0
47.0
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
8.0
9.7
13.0
15.0
16.7
19.5
22.7
28.5
E
F
10.7 10.7
12.4 12.4
15.5 15.5
17.5 17.5
19.8 19.8
22.6 22.6
25.8 25.8
33.0 31.4
G
H
K
12.8
12.8
12.8
12.8
14.5
14.5
14.5
14.5
11.0
12.9
15.1
16.6
18.3
20.6
23.0
29.4
1.5
1.5
1.5
1.5
2.0
2.0
2.0
2.0
N
Ss
Sr
V
16.0 11.3 11.3
18.4 11.3 11.3
20.6 11.7 11.7
22.1 11.7 11.7
23.8 13.0 13.6
26.1 13.0 13.6
28.5 13.0 13.6
37.0 13.0 13.6
2.7
3.3
3.3
3.3
3.3
3.3
3.3
3.3
Part number example: PFN.1M.305.XLMT
X
øV
H
1.5
Note: this model is only available with mold stop. The dimensions «M», «P» and «X»
are the same as the PB● models. Ss = standard gender, Sr = reverse gender.
PF●
Fixed socket with square flange, key (N) or keys (P, R, S,
T, U, V, W and X) with MIL-DTL-38999L shell thread
Dimensions (mm)
Reference
Ss/Sr
N
K
øA
G
P
øC
e
øE
9
Model
Series
A
C
e
E
G
H
K
N
Ss
PF●
PF●
PF●
PF●
PF●
PF●
PF●
1M
2M
3M
TM
4M
LM
5M
23.8
26.9
29.0
31.4
34.6
38.0
47.0
14.2
17.2
19.2
22.0
24.5
28.0
33.5
M12x1.0
M15x1.0
M18x1.0
M18x1.0
M22x1.0
M25x1.0
M31x1.0
12.4
15.5
17.5
19.8
22.6
25.8
33.0
12.8
12.8
12.8
14.5
14.5
14.5
14.5
12.9
15.1
16.6
18.3
20.6
23.0
29.4
1.5
1.5
1.5
2.0
2.0
2.0
2.0
18.4
20.6
22.1
23.8
26.1
28.5
37.0
12.2
12.2
12.2
11.7
11.7
11.7
11.7
Sr Code1)
12.2
12.2
12.2
13.6
13.6
13.6
13.6
A
B
C
C
D
E
G
Part number example: PFN.1M.305.XLMM
H
ø 3.3
Note: Ss = standard gender, Sr = reverse gender. 1) MIL-DTL-38999L shell size code
www.lemo.com
9
PB● Fixed socket with antivibration flange, key (N)
or keys (P, R, S, T, U, V, W and X), 2 holes fixing
Reference
P
Ss/Sr
2
øD
øB
H
øC
X
A
N
Dimensions (mm)
Model
Series
A
B
C
D
PB●
PB●
PB●
PB●
PB●
PB●
PB●
PB●
0M
1M
2M
3M
TM
4M
LM
5M
27.0
29.0
32.0
35.0
38.5
41.0
44.0
51.0
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
14.5
16.5
19.5
21.5
24.5
27.5
30.5
37.5
G
8.0 8.3
9.7 8.3
13.0 8.3
15.0 8.3
16.7 11.0
19.5 11.0
22.7 11.0
28.5 11.0
H
N
P
Ss
Sr
X
21.4
23.4
26.4
29.0
32.5
35.0
38.0
45.0
16.0
18.0
21.0
23.0
26.0
29.0
32.0
39.0
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
15.3
15.3
15.7
15.7
15.2
15.2
15.2
15.2
15.3
15.3
15.7
15.7
17.1
17.1
17.1
17.1
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: PBN.1M.305.XLM
3.3
G
PB● Fixed socket with antivibration flange, key (N) or keys
(P, R, S, T, U, V, W and X), 2 holes fixing with mold stop
Reference
P
Ss/Sr
2
N
A
øC
øD
øB
H
øF
M
Dimensions (mm)
Model
Series
A
B
C
D
PB●
PB●
PB●
PB●
PB●
PB●
PB●
PB●
0M
1M
2M
3M
TM
4M
LM
5M
27.0
29.0
32.0
35.0
38.5
41.0
44.0
51.0
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
14.5
16.5
19.5
21.5
24.5
27.5
30.5
37.5
F
G
8.0 10.7 8.3
9.7 12.4 8.3
13.0 15.5 8.3
15.0 17.5 8.3
16.7 19.8 11.0
19.5 22.6 11.0
22.7 25.8 11.0
28.5 31.4 11.0
H
M
N
P
Ss
Sr
X
21.4
23.4
26.4
29.0
32.5
35.0
38.0
45.0
9.7
9.7
10.1
10.1
10.6
10.6
10.6
10.6
16
18
21
23
26
29
32
39
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
18.3
18.3
18.7
18.7
18.2
18.2
18.2
18.2
18.3
18.3
18.7
18.7
18.2
18.2
18.2
18.2
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: PBN.1M.305.XLMT
X
1.5
3.3
G
Reference
P
Ss/Sr
2
e
øC
H
9
A
N
Dimensions (mm)
Model
Series
A
C
e
G
H
N
P
Ss
PB●
PB●
PB●
PB●
PB●
PB●
PB●
1M
2M
3M
TM
4M
LM
5M
29.0
32.0
35.0
38.5
41.0
44.0
51.0
16.5
19.5
21.5
24.5
27.5
30.5
37.5
M12x1.0
M15x1.0
M18x1.0
M18x1.0
M22x1.0
M25x1.0
M31x1.0
8.3
8.3
8.3
11.0
11.0
11.0
11.0
23.4
26.4
29.0
32.5
35.0
38.0
45.0
18.0
21.0
23.0
26.0
29.0
32.0
39.0
5.3
5.3
5.3
7.9
7.9
7.9
7.9
17.2
17.2
17.2
16.2
16.2
16.2
16.2
Sr Code1)
17.2
17.2
17.2
17.1
17.1
17.1
17.1
A
B
C
C
D
E
G
Part number example: PBN.1M.305.XLMM
3.3
10
G
www.lemo.com
PV● Fixed socket with antivibration square flange, key (N)
Reference
øD
øC
2
øB
øC
P
Ss/Sr
øA
N
Model
Series
A
B
C
PV●
PV●
PV●
PV●
PV●
PV●
PV●
PV●
0M
1M
2M
3M
TM
4M
LM
5M
26.9
31.4
34.6
38.0
40.3
43.7
47.1
54.9
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
14.5
16.5
19.5
21.5
24.5
27.5
30.5
37.5
D
G
H
8.0 8.3 15.1
9.7 8.3 18.3
13.0 8.3 20.6
15.0 8.3 23.0
16.7 11.0 24.6
19.5 11.0 27.0
22.7 11.0 29.4
28.5 11.0 34.9
N
P
Ss
Sr
V
X
20.6
23.8
26.1
28.5
30.1
32.5
34.9
40.4
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
15.3
15.3
15.7
15.7
15.2
15.2
15.2
15.2
15.3
15.3
15.7
15.7
17.1
17.1
17.1
17.1
2.7
3.3
3.3
3.3
3.3
3.3
3.3
3.3
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: PVN.1M.305.XLM
X
H
Dimensions (mm)
øV
G
Reference
P
Ss/Sr
øA
N
2
øC
øD
øF
øB
øC
M
Dimensions (mm)
Model
Series
A
B
C
PV●
PV●
PV●
PV●
PV●
PV●
PV●
PV●
0M
1M
2M
3M
TM
4M
LM
5M
26.9
31.4
34.6
38.0
40.3
43.7
47.1
54.9
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
14.5
16.5
19.5
21.5
24.5
27.5
30.5
37.5
D
F
G
8.0 10.7 8.3
9.7 12.4 8.3
13.0 15.5 8.3
15.0 17.5 8.3
16.7 19.8 11.0
19.5 22.6 11.0
22.7 25.8 11.0
28.5 31.4 11.0
H
M
N
P
Ss Sr
X
15.1
18.3
20.6
23.0
24.6
27.0
29.4
34.9
9.7
9.7
10.1
10.1
10.6
10.6
10.6
10.6
20.6
23.8
26.1
28.5
30.1
32.5
34.9
40.4
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
18.3 18.3
18.3 18.3
18.7 18.7
18.7 18.7
18.2 18.2
18.2 18.2
18.2 18.2
18.2 18.2
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: PVN.1M.305.XLMT
X
1.5
øV
H
G
The dimension «V» is the same as the PV● models without mold stop.
Reference
P
Ss/Sr
2
e
9
øC
øA
øC
N
Dimensions (mm)
Model
Series
A
C
e
PV●
PV●
PV●
PV●
PV●
PV●
PV●
1M
2M
3M
TM
4M
LM
5M
31.4
34.6
38.0
40.3
43.7
47.1
54.9
16.5
19.5
21.5
24.5
27.5
30.5
37.5
M12x1.0
M15x1.0
M18x1.0
M18x1.0
M22x1.0
M25x1.0
M31x1.0
G
H
8.3 18.3
8.3 20.6
8.3 23.0
11.0 24.6
11.0 27.0
11.0 29.4
11.0 34.9
N
P
Ss
Sr
23.8
26.1
28.5
30.1
32.5
34.9
40.4
5.3
5.3
5.3
7.9
7.9
7.9
7.9
17.2
17.2
17.2
16.2
16.2
16.2
16.2
17.2
17.2
17.2
17.1
17.1
17.1
17.1
V Code1)
3.3
3.3
3.3
3.3
3.3
3.3
3.3
A
B
C
C
D
E
G
Part number example: PVN.1M.305.XLMM
H
www.lemo.com
øV
G
11
PM● Free socket, key (N) or keys (P, R, S, T, U, V, W and X)
with knurled grip
Reference
Ls/Lr
øA
øC
P
øD
øB
X
Dimensions (mm)
Model
Series
A
B
C
D
Ls
Lr
P
X
PM●
PM●
PM●
PM●
PM●
PM●
PM●
PM●
0M
1M
2M
3M
TM
4M
LM
5M
13.1
14.6
17.6
19.6
22.5
25.0
28.5
34.0
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
8.0
9.7
13.0
15.0
16.7
19.5
22.7
28.5
25.6
25.6
26.0
26.0
28.2
28.2
28.2
28.2
25.6
25.6
26.0
26.0
30.1
30.1
30.1
30.1
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: PMN.1M.305.XLM
Reference
Ls/Lr
øA
øC
P
øD
øF
øB
M
Dimensions (mm)
Model
Series
A
B
C
D
F
Ls
Lr
M
P
X
PM●
PM●
PM●
PM●
PM●
PM●
PM●
PM●
0M
1M
2M
3M
TM
4M
LM
5M
13.1
14.6
17.6
19.6
22.5
25.0
28.5
34.0
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
8.0
9.7
13.0
15.0
16.7
19.5
22.7
28.5
10.7
12.4
15.5
17.5
19.8
22.6
25.8
31.4
28.6
28.6
29.0
29.0
31.2
31.2
31.2
31.2
28.6
28.6
29.0
29.0
31.2
31.2
31.2
31.2
9.7
9.7
10.1
10.1
10.6
10.6
10.6
10.6
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: PMN.1M.305.XLMT
X
1.5
PH● Free socket, key (N) or keys (P, R, S, T, U, V, W and X)
with arctic grip
Reference
Ls/Lr
øA
P
øC
øD
øB
X
Dimensions (mm)
Model
Series
A
B
C
D
Ls
Lr
P
X
PH●
PH●
PH●
PH●
PH●
PH●
PH●
PH●
0M
1M
2M
3M
TM
4M
LM
5M
14.4
15.9
18.9
20.9
23.4
25.9
29.4
34.9
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
8.0
9.7
13.0
15.0
16.7
19.5
22.7
28.5
25.6
25.6
26.0
26.0
28.2
28.2
28.2
28.2
25.6
25.6
26.0
26.0
30.1
30.1
30.1
30.1
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: PHN.1M.305.XLM
12
www.lemo.com
Reference
Ls/Lr
øA
øC
P
øD
øF
øB
M
Dimensions (mm)
Model
Series
A
B
C
D
F
Ls
Lr
M
P
X
PH●
PH●
PH●
PH●
PH●
PH●
PH●
PH●
0M
1M
2M
3M
TM
4M
LM
5M
14.4
15.9
18.9
20.9
23.4
25.9
29.4
34.9
8.8
10.5
14.0
16.0
17.9
20.7
23.9
29.7
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
8.0
9.7
13.0
15.0
16.7
19.5
22.7
28.5
10.7
12.4
15.5
17.5
19.8
22.6
25.8
31.4
28.6
28.6
29.0
29.0
31.2
31.2
31.2
31.2
28.6
28.6
29.0
29.0
31.2
31.2
31.2
31.2
9.7
9.7
10.1
10.1
10.6
10.6
10.6
10.6
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
6.7
6.7
7.1
7.1
7.6
7.6
7.6
7.6
Part number example: PHN.1M.305.XLMT
X
1.5
HE● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W
and X) for printed circuit, watertight (back panel mounting)
Reference
Ls/Lr
3
e
H
E maxi
S2
øA
P
øC
S1
Dimensions (mm)
Model
Series
A
C
e
HE●
HE●
HE●
HE●
HE●
HE●
HE●
HE●
0M
1M
2M
3M
TM
4M
LM
5M
17
18
21
23
27
29
33
38
16.8
17.8
20.8
22.8
25.8
27.8
31.8
36.8
M13x0.75
M14x1.00
M17x1.00
M19x1.00
M22x1.00
M24x1.00
M28x1.00
M33x1.00
E
H
5.0 5.08
5.0 7.62
5.0 8.89
5.0 10.16
4.0 12.70
4.0 13.97
4.0 16.51
4.0 20.32
Ls
Lr
N
P
R
20.8
20.8
20.8
20.8
24.6
24.6
24.6
24.6
21.0
21.0
21.0
21.0
24.6
24.6
24.6
24.6
16.8
16.8
16.8
16.8
19.9
19.9
19.9
19.9
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
13.8
13.8
13.8
13.8
16.9
16.9
16.9
16.9
S1 S2
11.5
12.5
15.5
17.5
20.5
22.5
26.5
31.5
14
16
18
25
29
34
Part number example: HEN.1M.305.XLNP
R
N
www.lemo.com
13
USB models
FM● Straight plug, key (W) or key (R)
Part number
31.6
3.4
ø 28
FM•.LM.U2A.XPAT
ø 28.5
ø 22.7
ø 25.8
ø 23.9
10.6
1.5
7.6
FG● Straight plug, key (W) or key (R)
Part number
31.6
3.4
ø 28
FG•.LM.U2A.XPAT
ø 29.4
ø 22.7
ø 23.9
ø 25.8
10.6
1.5
7.6
EG● Fixed socket, female to female, nut fixing,
key (W) or key (R)
40.5
S 22.5
Part number
7.9
ø 28
M 24 x 1
EG•.LM.U2A.XPP
S 30
4 maxi
9.4
31
14
www.lemo.com
EG● Fixed socket, nut fixing, key (W) or key (R)
Part number
18.9
S 22.5
7.9
S 30
ø 28
M 24 x 1
EG•.LM.U2A.XPL
4 maxi
9.4
Alignment Key
Alignment Key and Polarized Keying System
M series connector model part numbers are composed of three letters. The LAST LETTER indicates the keys corresponding to a particular contact type.
For example, straight plugs with N, P, R, U or W keys, are fitted with male contacts; whereas with S, T, V or X keys, plugs
are fitted with female contacts. Sockets with N, P, R, U or W keys, are fitted with female contacts; whereas with S, T, V or
X keys, sockets are fitted with male contacts.
Angles
Nb
of keys
Colour
code
β
γ
165°
150°
130°
155°
135°
30°
60°
100°
50°
90°
Contact type
Plug
Socket
male
female
female
male
N
P
●●U
●●S
●●T
3
Model
β
0M to 3M
Model
Front view of a socket
Nb
of keys
γ
β
www.lemo.com
α
W
R
●●X
●● V
δ
γ
TM to 5M
5
blue
yellow
green
red
orange
Angles
Colour
code
α
β
γ
δ
95°
105°
100°
110°
115°
115°
125°
120°
35°
30°
40°
35°
25°
20°
20°
25°
blue
yellow
red
orange
Contact type
Plug
Socket
male
female
female
male
15
Multipole
AWG
Test voltage (kV rms)1)
Contact-contact
Contact-shell
Rated current (A)1)
Contact
type
Print (straight)2)
2
Crimp
3
ø A (mm)
1
Number of contacts
4
3
Reference
4
2
302
2
0.9
20-22-24
1.45
1.00
10.0
303
3
0.9
20-22-24
1.70
1.40
8.0
304
4
0.7
22-24-26
1.35
0.90
7.0
305
5
0.7
22-24-26
1.25
1.00
6.5
305
5
0.9
20-22-24
1.30
1.30
9.0
307
7
0.7
22-24-26
1.45
1.20
7.0
308
8
0.7
22-24-26
1.30
1.10
5.0
308
8
0.9
20-22-24
1.95
1.10
10.0
310
10
0.9
20-22-24
1.80
1.20
8.0
312
12
0.7
22-24-26
1.65
1.15
7.0
319
19
0.7
22-24-26
1.20
1.00
4.0
322
22
0.7
22-24-26
tbd
tbd
tbd
330
30
0.7
22-24-26
1.10
1.00
3.5
325
25
0.9
20-22-24
1.10
1.25
5.0
340
40
0.7
22-24-26
1.05
1.20
3.0
øA
1
Male crimp contacts
for plug
0M
1M
2M
3M
TM
Female crimp contacts
for sockets
Note: 1) Test voltage according to IEC 60512-2 test 4a. 2) For EG•, EC•, ED•, HE• socket.
16
www.lemo.com
Multipole
AWG
Contact-contact
Contact-shell
Rated current (A)1)
Contact
type
Print (straight)2)
2
Crimp
3
ø A (mm)
1
3
Number of contacts
4
2
Reference
4
340
40
0.7
22-24-26
1.20
1.35
3.5
348
48
0.7
22-24-26
1.10
1.35
3.0
355
55
0.9
20-22-24
tbd
tbd
tbd
368
68
0.7
22-24-26
1.40
1.65
2.5
U2A
4
1.20
0.95
n.a.
366
66
0.9
20-22-24
1.60
1.70
3.0
114
114
0.7
22-24-26
1.37
1.34
2.0
øA
1
Male crimp contacts
for plug
for sockets
4M
LM
3)
3)
Solder
5M
Note: 1) Test voltage according to IEC 60512-2 test 4a. 2) For EG•, EC•, ED•, HE• socket. 3) Front view.
Housings
Outer shell
Ref.
C
X
Material
Surface
treatment
Brass
Aluminium alloy
Chrome
Nickel1)
www.lemo.com
Note: 1) anthracite colour.
17
Contacts
Crimp contacts for plugs, free or fixed sockets
There are 2 forms of crimp barrels:
– per fig. 1, the standard design
– per fig. 2, with reduced crimp barrel for small conductors.
Fig. 1
Ref.
C
B
D
øA
øC
øA
øC
Contact type
M
P
N
øA
øC
øA
øC
Contact type
Ref.
Male crimp (fig. 1)
Male crimp (fig. 2)
Male straight print
Fig. 2
Female crimp (fig. 1)
Female crimp (fig. 2)
Female straight print
Dimension of crimp barrels
Contact
Type
0M
302-303
304-305
1M
305
307-308
2M
308-310
312-319
3M
322-330
TM
325
340
4M
340-348
LM
355
368
5M
366
114
Ref. contact type
ø A ø C Form
(mm) (mm) per fig.
Male
Female
Conductor
AWG
Section (mm2)
min. max. min. max.
Part number
For male contacts For female contacts
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
C
B
C
B
M
P
M
P
24
26
26
32
22
28
0.204
0.128
0.128
0.032
0.616
0.382
0.382
0.092
FGN.0M.560.ZZC
FGN.0M.561.ZZC
FGN.0M.555.ZZC
FGN.0M.556.ZZC
EGN.0M.660.ZZM
EGN.0M.661.ZZM
EGN.0M.655.ZZM
EGN.0M.656.ZZM
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
C
B
C
B
M
P
M
P
24
26
26
32
22
28
0.204
0.128
0.128
0.032
0.616
0.382
0.382
0.092
FGN.0M.560.ZZC
FGN.0M.561.ZZC
FGN.0M.555.ZZC
FGN.0M.556.ZZC
EGN.0M.660.ZZM
EGN.0M.661.ZZM
EGN.0M.655.ZZM
EGN.0M.656.ZZM
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
C
B
C
B
M
P
M
P
24
26
26
32
22
28
0.204
0.128
0.128
0.032
0.616
0.382
0.382
0.092
FGN.0M.560.ZZC
FGN.0M.561.ZZC
FGN.0M.555.ZZC
FGN.0M.556.ZZC
EGN.0M.660.ZZM
EGN.0M.661.ZZM
EGN.0M.655.ZZM
EGN.0M.656.ZZM
0.7
0.7
0.87
0.44
1
2
C
B
M
P
26
32
22
28
0.128 0.382
0.032 0.092
FGN.0M.555.ZZC
FGN.0M.556.ZZC
EGN.0M.655.ZZM
EGN.0M.656.ZZM
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
C
B
C
B
M
P
M
P
24
26
26
32
22
28
0.204
0.128
0.128
0.032
0.616
0.382
0.382
0.092
FGN.0M.560.ZZC
FGN.0M.561.ZZC
FGN.0M.555.ZZC
FGN.0M.556.ZZC
EGW.TM.660.ZZM
EGW.TM.661.ZZM
EGW.TM.655.ZZM
EGW.TM.656.ZZM
0.7
0.7
0.87
0.44
1
2
C
B
M
P
26
32
22
28
0.128 0.382
0.032 0.092
FGN.0M.555.ZZC
FGN.0M.556.ZZC
EGW.TM.655.ZZM
EGW.TM.656.ZZM
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
C
B
C
B
M
P
M
P
24
26
26
32
22
28
0.204
0.128
0.128
0.032
0.616
0.382
0.382
0.092
FGN.0M.560.ZZC
FGN.0M.561.ZZC
FGN.0M.555.ZZC
FGN.0M.556.ZZC
EGW.TM.660.ZZM
EGW.TM.661.ZZM
EGW.TM.655.ZZM
EGW.TM.656.ZZM
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
C
B
C
B
M
P
M
P
24
26
26
32
22
28
0.204
0.128
0.128
0.032
0.616
0.382
0.382
0.092
FGN.0M.560.ZZC
FGN.0M.561.ZZC
FGN.0M.555.ZZC
FGN.0M.556.ZZC
EGW.TM.660.ZZM
EGW.TM.661.ZZM
EGW.TM.655.ZZM
EGW.TM.656.ZZM
Note: according to IEC 60352-2 standard, it is strongly not recommended to crimp monostrand cables.
18
www.lemo.com
Accessories
BMF Blanking caps for plugs
Part number
L
N
øA
P
øC
X
sliding loop
BMF.0M.100.•AV
BMF.1M.100.•AV
BMF.2M.100.•AV
BMF.3M.100.•AV
BMF.TM.100.•AV
BMF.4M.100.•AV
BMF.LM.100.•AV
BMF.5M.100.•AV
A
13.1
14.6
17.6
19.6
22.5
25.0
28.5
34.0
Dimensions (mm)
C
L
N
P
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
24.6
24.6
24.6
24.6
31.1
31.1
31.1
31.1
85.0
85.0
85.0
120.0
120.0
120.0
150.0
150.0
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
X
6.0
6.0
6.0
6.0
10.0
10.0
10.0
10.0
Note: this cap is suitable for use with any alignment key configuration.
The position «•» of the part number indicates the housing material.
See page 17.
BGF Blanking caps for plugs
Part number
L
N
øA
P
øC
X
sliding loop
BGF.0M.100.•AV
BGF.1M.100.•AV
BGF.2M.100.•AV
BGF.3M.100.•AV
BGF.TM.100.•AV
BGF.4M.100.•AV
BGF.LM.100.•AV
BGF.5M.100.•AV
A
14.4
15.9
18.9
20.9
23.4
25.9
29.4
34.9
Dimensions (mm)
C
L
N
P
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
24.6
24.6
24.6
24.6
31.1
31.1
31.1
31.1
85.0
85.0
85.0
120.0
120.0
120.0
150.0
150.0
5.3
5.3
5.3
5.3
7.9
7.9
7.9
7.9
X
6.0
6.0
6.0
6.0
10.0
10.0
10.0
10.0
See page 17.
BME Blanking caps for fixed sockets
Part number
L
N
ø 3.5
øA
P
øC
X
BME.0M.200.•AZ
BME.1M.200.•AZ
BME.2M.200.•AZ
BME.3M.200.•AZ
BME.TM.200.•AZ
BME.4M.200.•AZ
BME.LM.200.•AZ
BME.5M.200.•AZ
A
13.1
14.6
17.6
19.6
22.5
25.0
28.5
34.0
Dimensions (mm)
C
L
N
P
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
23.4
23.4
23.4
23.4
31.0
31.0
31.0
31.0
85.0
85.0
85.0
120.0
120.0
120.0
150.0
150.0
3.9
3.9
3.9
3.9
3.4
3.4
3.4
3.4
X
6.0
6.0
6.0
6.0
10.0
10.0
10.0
10.0
See page 17.
www.lemo.com
19
BMF Blanking caps for free sockets
Part number
L
N
øA
P
øC
X
sliding loop
BMF.0M.200.•AZ
BMF.1M.200.•AZ
BMF.2M.200.•AZ
BMF.3M.200.•AZ
BMF.TM.200.•AZ
BMF.4M.200.•AZ
BMF.LM.200.•AZ
BMF.5M.200.•AZ
A
13.1
14.6
17.6
19.6
22.5
25.0
28.5
34.0
Dimensions (mm)
C
L
N
P
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
23.4
23.4
23.4
23.4
31.0
31.0
31.0
31.0
85.0
85.0
85.0
120.0
120.0
120.0
150.0
150.0
3.9
3.9
3.9
3.9
3.4
3.4
3.4
3.4
X
6.0
6.0
6.0
6.0
10.0
10.0
10.0
10.0
See page 17.
BGE Blanking caps for fixed sockets
Part number
L
N
øA
P
øC
X
ø 3.5
BGE.0M.200.•AZ
BGE.1M.200.•AZ
BGE.2M.200.•AZ
BGE.3M.200.•AZ
BGE.TM.200.•AZ
BGE.4M.200.•AZ
BGE.LM.200.•AZ
BGE.5M.200.•AZ
A
14.4
15.9
18.9
20.9
23.4
25.9
29.4
34.9
Dimensions (mm)
C
L
N
P
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
23.4
23.4
23.4
23.4
31.0
31.0
31.0
31.0
85.0
85.0
85.0
120.0
120.0
120.0
150.0
150.0
3.9
3.9
3.9
3.9
3.4
3.4
3.4
3.4
X
6.0
6.0
6.0
6.0
10.0
10.0
10.0
10.0
See page 17.
BGF Blanking caps for free sockets
Part number
L
N
sliding loop
øA
P
øC
X
BGF.0M.200.•AZ
BGF.1M.200.•AZ
BGF.2M.200.•AZ
BGF.3M.200.•AZ
BGF.TM.200.•AZ
BGF.4M.200.•AZ
BGF.LM.200.•AZ
BGF.5M.200.•AZ
A
14.4
15.9
18.9
20.9
23.4
25.9
29.4
34.9
Dimensions (mm)
C
L
N
P
12.7
14.2
17.2
19.2
22.0
24.5
28.0
33.5
23.4
23.4
23.4
23.4
31.0
31.0
31.0
31.0
85.0
85.0
85.0
120.0
120.0
120.0
150.0
150.0
3.9
3.9
3.9
3.9
3.4
3.4
3.4
3.4
X
6.0
6.0
6.0
6.0
10.0
10.0
10.0
10.0
See page 17.
www.lemo.com
GEA Hexagonal nuts for EC ● model
Part number
Series
A
0M
1M
2M
3M
TM
4M
LM
5M
GEA.0M.241.RL
GEA.0E.240.RL
GEA.2M.241.RL
GEA.3M.241.RL
GEA.TM.241.RL
GEA.4M.241.RL
GEA.LM.241.RL
GEA.5M.241.RL
L
øB
e
A
16
17
19
25
25
30
32
37
Dimensions (mm)
B
e
L
18.2
19.2
21.5
22.0
28.0
34.0
36.0
41.0
M13x0.75
M14x1.00
M17x1.00
M19x1.00
M22x1.00
M24x1.00
M28x1.00
M33x1.00
2.5
2.5
3.0
3.0
3.0
3.0
3.0
3.0
● Material: Nickel-plated aluminium alloy (anthracite colour)
GEA Hexagonal nuts for EG ● model
Part number
Series
A
GEA.0S.240.RL
GEA.1M.240.RL
GEA.0E.240.RL
GEA.1E.240.RL
GEA.3S.240.RL
GEA.4M.240.RL
GEA.3E.240.RL
GEA.5M.240.RL
L
øB
e
0M
1M
2M
3M
TM
4M
LM
5M
A
11
13
17
19
22
25
30
36
Dimensions (mm)
B
e
L
12.4
14.5
19.2
21.5
25.0
28.0
34.0
40.5
M9x0.60
M11x1.00
M14x1.00
M16x1.00
M18x1.00
M21x1.00
M24x1.00
M30x1.00
2.0
2.5
2.5
3.0
3.0
4.0
5.0
5.0
GEC Conical nut for models HE ●, EC ●, PE ●
Part number
Series
A
L
øB
e
GEC.0M.240.RN
GEC.0E.240.RN
GEC.2M.240.RN
GEC.3M.240.RN
GEC.TM.240.RN
GEC.4M.240.RN
GEC.LM.240.RN
GEC.5M.240.RN
0M
1M
2M
3M
TM
4M
LM
5M
A
14
16
18
25
29
34
Dimensions (mm)
B
e
L
17
18
21
23
27
29
33
38
M13x0.75
M14x1.00
M17x1.00
M19x1.00
M22x1.00
M24x1.00
M28x1.00
M33x1.00
3.2
3.0
3.2
3.2
5.0
5.0
5.0
5.0
Straight boot
BEFORE HEATING
Elbow boot
Heatshrink boot
BEFORE HEATING
Part number
Supplier
Straight
AFTER HEATING
AFTER HEATING
Raychem®
202A111-25/86
202A121-25/86
202A142-25/86
Series
Cable ø
min.
(mm)
0M-2M
2M-4M
4M-5M
3.8
5.3
7.4
Elbow 90°
222A111-25/86
222A121-25/86
222A142-25/86
Note:
request modified elastomer resistant to fluids with hot melt sealant.
www.lemo.com
21
Tooling
DCE Positioners for crimp contacts
Type
0M
Contact
Positioners part number
ø A ø C Form
(mm) (mm) per fig.
302-303
304-305
male
female
1M
These positioners are suitable for use with both manual and
pneumatic crimping tools according to the MIL-C-22520/7-01 standard.
307-308
2M
Fig. 1
øA
øA
øC
øC
305
308-310
312-319
3M
322-330
TM
325
340
Fig. 2
øA
4M
340-348
LM
355
øC
368
øA
øC
5M
366
114
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
0.7
0.7
0.87
0.44
1
2
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
0.7
0.7
0.87
0.44
1
2
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
0.9
0.9
0.7
0.7
1.10
0.87
0.87
0.44
1
2
1
2
DCE.91.090.5MVC DCE.91.090.3MVM
DCE.91.070.5MVC DCE.91.070.3MVM
DCE.91.090.5MVC DCE.91.09T.5MVM
DCE.91.070.5MVC DCE.91.07T.5MVM
Note: a wide variation of strand number and diameter combinations are quoted as being AWG, some of which do not have a large enough cross section
to guarantee a crimp as per either MIL-C-22520/1-01 or /7-01.
Our technical department is at your disposal to study and propose a solution to all your applications.
DCF Extractors for crimp contacts
Contact
ø
0.9
0.7
Part number
DCF.93.090.4LT
DCF.93.070.4LT
Note: this model is used for male and female contacts.
22
www.lemo.com
Panel Cut-out
Cut-outs
Mounting nut torque (on panel)
EG● -EC● -HE● -PE●
Series
øA
+ 0.1
0M
1M
2M
3M
TM
4M
LM
5M
B
+ 0.1
EG●
øA
B
EC● /HE● /PE●
øA
B
Series
Torque (Nm)
0M
1M
2M
3M
TM
4M
LM
5M
1.0
1.5
2.0
2.5
4.0
5.0
6.5
8.0
9.1
11.1
14.1
16.1
18.1
21.1
24.1
30.1
8.3
9.6
12.6
14.6
16.6
19.6
22.6
28.6
13.1
14.1
17.1
19.1
22.1
24.1
28.1
33.1
11.6
12.6
15.6
17.6
20.6
22.6
26.6
31.6
øA
ED●
B
H
øA
PV●
B
H
øA
PF●
B
H
5.1
6.1
9.1
11.1
12.5
14.1
18.1
23.2
M2.5
M3.0
M3.0
M3.0
M3.0
M3.0
M3.0
M3.0
11.0
12.9
15.1
16.4
18.3
20.6
23.0
27.0
14.8
16.8
19.8
21.8
24.8
27.8
30.8
37.8
M2.5
M3.0
M3.0
M3.0
M3.0
M3.0
M3.0
M3.0
15.1
18.3
20.6
23.0
24.6
27.0
25.4
34.9
10.8
12.5
15.6
18.1
19.9
22.7
25.9
33.1
M2.5
M3.0
M3.0
M3.0
M3.0
M3.0
M3.0
M3.0
11.0
12.9
15.1
16.6
18.3
20.6
23.0
29.4
øA
PB●
B
H
14.8
16.8
19.8
21.8
24.8
27.8
30.8
37.8
M3.0
M3.0
M3.0
M3.0
M3.0
M3.0
M3.0
M3.0
21.4
23.4
26.4
29.0
32.5
35.0
38.0
45.0
Cut-outs
ED● -PV● -PF●
Series
+ 0.1
H
øA
+ 0.1
H
B
0M
1M
2M
3M
TM
4M
LM
5M
Cut-outs
PB●
øA
+ 0.1
H 0
+ 0.1
Series
B
www.lemo.com
0M
1M
2M
3M
TM
4M
LM
5M
23
Fixed socket with straight print contact
For HE● models
For EG● , EC● and ED● models
+0.1
4xø1
+0.1
4xø1
72
+0.1
90°
5.08
45°
ø 2.8
+0.1
ø 2.3
12
0°
5.08
ø 2.2
0M.305
0M.304
4xø1
5.08
0M.303
+0.1
4xø1
5.08
0M.302
ø 2.5
4xø1
1M.307
5 x ø 0.8
ø 3.7
+0.1
6'
1°2
+0.1
7 x ø 0.8
+0.1
8 x ø 0.8
8 x ø 0.8
15°
4xø1
+0.1
ø 6.7
19 x ø 0.8
+0.1
TM.325
4xø1
11°15'
+0.1
4xø1
+0.1
40°
+0.1
24°
ø 9.8
+0.1
ø 5.8
10.16
ø9
ø 5.7
4xø1
2.2
4.45
10.16
ø5
ø 8.8
25°
22°
43
+0.1
30
+0.1
36°
30
45
4xø1
+0.1
ø 6.5
3M.330
22°30'
12°52'
5°
90°
8.89
ø 6.2
12 x ø 0.8
3M.322
22°30' 4 x ø 1
ø 2.8
4
+0.1
4xø1
2M.319
45°
+0.1
ø 2.15
45
10 x ø 0.8
45
+0.1
2M.312
22°30' 4 x ø 1
+0.1
2M.310
4xø1
7.62
7.62
5 x ø 0.8
+0.1
2M.308
1M.308
4xø1
30°
60
ø 3.4
72
+0.1
4xø1
+0.1
4 x ø 0.8
ø 6.4
1M.305
+0.1
3 x ø 0.8
ø 3.5
+0.1
ø 3.8
2 x ø 0.8
22 x ø 0.8
30 x ø 0.8
+0.1
TM.340
3.23
+0.1
25 x ø 0.8
2.6
+0.1
4M.348
4M.340
8°10'55''
40 x ø 0.8
+0.1
'49
21
13.97
ø 11.9
+0.1
48 x ø 0.8
24
ø 8.5
45
ø 1.9
22°30'
ø 5.2
12°
16
24
+0.1
ø 7.94
12.7
9°
27°4
1'3
2
18°
40 x ø 0.8
4xø1
120
6'
ø 11.64
2
51°
ø 6.8
27°
41
'3
1 8°
9°
+0.1
ø 10.2
2''
4xø1
ø 4.24
ø 3.4
60
+0.1
www.lemo.com
LM.355
LM.368
6°40’
7°30’
10°35’18’’
5’’
’3
4xø1
18°
4xø1
+0.1
5M.366
5M.114
10°
16.51
ø15.5
ø8
ø11.75
ø 4.25
27°
41
’30
+0.1
68 x ø 0.8
+0.1
5°
6°12’25’’
4xø1
0’’
4’5
°2
12
’49
21
+0.1
8°10’55’’
18°57'
66 x ø 0.8
20.7
20.32
ø 17.1
ø 13.5
ø 9.9
ø 6.3
ø 2.7
20.32
ø14.96
ø19.84
ø 10.08
27°41'30''
+0.1
4xø1
12
0°
6°55'30''
ø 5.6
°26
51
1
°5
13
13°51’
16.51
ø15.3
ø11.1
ø 2.8
ø 6.9
55 x ø 0.8
1
+0.1
9°
8°
51°25’30’’
36°
21
°1
°20
13
+0.1
114 x ø 0.8
24°
+ 0.1
40°
www.lemo.com
25
Assembly instructions for plugs and sockets
2
1
2
1
FG●
PH●
PB●
1.
L ± 0.5
First place the heatshrink boot ➀ over
the cable. Strip the cable according
to dimensions of the table, then widen
the shield.
1
T ± 0.2
Cable preparation
Series
L
S
T
0M to 5M
3.5
Note : dimensions are in mm.
S ± 0.5
2.
2
Crimp
2
Crimp
Cable termination
2.1 With shielded cables, widen and pull the shield all the way to the back.
Fix the appropriate positioner onto the crimping tool and set the selector to the number corresponding to the AWG of the conductor used as
indicated on the positioner label.
Fit the conductor into the contact ➁; make sure it is visible through the
contact’s inspection hole.
Slide the conductor-contact assembly into the open crimping tool; make
sure that the contact is pushed fully into the positioner. Close the tool.
Remove from crimping tool and check that conductor is secure in
contact and shows in inspection hole.
2.2 Arrange the conductor-contact assemblies according to the markings,
into the rear cable seal.
Push them deeply into the insulator, using tweezers if necessary;
check that all the contacts are correctly located in the insulator: 1)
by verifying the alignment of the contacts at the front of the insulator
and 2) by gently pulling on each conductor.
Verification should also be made using the appropriate retention testing tool.
2.3 Bring the shield around the rear of connector.
Secure it with a band-it tie-wrap (not furnished) to fix the shield in place.
Cut off the possible shield surplus.
Steel tie-wrap band (~3 mm wide)
2.4 Put the heatshrink boot in place and heat gently until it retracts.
Heat
26
Heat
www.lemo.com
Assembly instructions for plugs and sockets (with optional mold stop)
1
FG●
PH●
1
PB●
1.
L ± 0.5
Cable preparation
Strip the cable according to dimensions of the table, then widen the shield.
T ± 0.2
Series
L
S
T
0M to 5M
3.5
S ± 0.5
2.
1
Crimp
1
Crimp
Cable termination
Fit the conductor into the contact ➀; make sure it is visible through the
2.3 Bring the shield around the rear of connector until the mold stop.
Overmolding
2.4 Custom overmold cable assembly.
Overmolding
www.lemo.com
27
Notes
28
www.lemo.com
Product safety notice
PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND
INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION.
IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS
SITUATIONS.
1. SHOCK AND FIRE HAZARD
Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue
(such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock.
Mated components should never be disconnected while live as this may result in an exposed electric arc and local
overheating, resulting in possible damage to components.
2. HANDLING
Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect
components should be rejected or returned to the factory for verification.
Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used
during installation and / or assembly in order to obtain safe and reliable performance.
3. USE
Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general
conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to
eliminate all risk of transmission of such voltages to any exposed metal part of the connector.
4. TEST AND OPERATING VOLTAGES
The maximum admissible operating voltage depends upon the national or international standards in force for the
application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the
catalog however these may be influenced by PC board design and / or wiring harnesses.
The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the
test duration is 1 minute.
5. CE MARKING
CE marking
means that the appliance or equipment bearing it complies with the protection requirements of one or
several European safety directives.
CE marking
applies to complete products or equipment, but not to electromechanical components, such as
connectors.
6. PRODUCT IMPROVEMENTS
The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior
notification.
Data subject to change
No reproduction or use without express permission of editorial or pictorial content, in any manner.
LEMO reserve the right at all times to modify and improve specifications without any notification.
www.lemo.com
29
LEMO HEADQUARTERS
SWITZERLAND
LEMO SA
Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens
Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com
SUBSIDIARIES
AUSTRIA
LEMO Elektronik GesmbH
Lemböckgasse 49/E6-3
1230 Wien
Tel: (+43 1) 914 23 20 0
Fax:(+43 1) 914 23 20 11
sales@lemo.at
NETHERLANDS / BELGIUM
LEMO Connectors Benelux
De Trompet 1060
1967 DA Heemskerk
Tel. (+31) 251 25 78 20
Fax (+31) 251 25 78 21
info@lemo.nl
CHINA
LEMO Trading (Shanghai) Co., Ltd
LEMO Electronics (Shanghai) Co., Ltd
5th Floor, Block 6, City of ELITE,
1000 Jinhai Road, Pudong
Shanghai, China 201206
Tel: (+86 21) 5899 7721
Fax: (+86 21) 5899 7727
cn.sales@lemo.com
NORWAY / ICELAND
LEMO Norway A/S
Stanseveien 6B
0975 Oslo
Tel: (+47) 22 91 70 40
Fax: (+47) 22 91 70 41
info-no@lemo.com
DENMARK
LEMO Denmark A/S
Gammel Mosevej 46
2820 Gentofte
Tel: (+45) 45 20 44 00
Fax: (+45) 45 20 44 01
info-dk@lemo.com
FRANCE
LEMO France Sàrl
24/28 Avenue Graham Bell
Bâtiment Balthus 4
Bussy Saint Georges
77607 Marne la Vallée Cedex 3
Tel: (+33 1) 60 94 60 94
Fax: (+33 1) 60 94 60 90
info-fr@lemo.com
GERMANY
LEMO Elektronik GmbH
Hanns-Schwindt-Str. 6
81829 München
Tel: (+49 89) 42 77 03
Fax: (+49 89) 420 21 92
info@lemo.de
HONG KONG
LEMO Hong Kong Ltd
Unit 1207, 12/F, Corporation Square,
8 Lam Lok Street, Kowloon Bay,
Kowloon - Hong Kong
Tel: (+852) 2174 0468
Fax: (+852) 2174 0492
hk.sales@lemo.com
HUNGARY
REDEL Elektronika Kft
Nagysándor József u. 6-12
1201 Budapest
Tel: (+36 1) 421 47 10
Fax: (+36 1) 421 47 57
redelemo@lemo.hu
ITALY
LEMO Italia srl
Viale Lunigiana 25
20125 Milano
Tel: (+39 02) 66 71 10 46
Fax: (+39 02) 66 71 10 66
sales.it@lemo.com
JAPAN
LEMO Japan Ltd
2-7-22, Mita,
Minato-ku, Tokyo, 108-0073
Tel: (+81 3) 54 46 55 10
Fax: (+81 3) 54 46 55 11
lemoinfo@lemo.co.jp
LEMO
SINGAPORE
LEMO Asia Pte Ltd
4 Leng Kee Road,
#06-09 SiS Building
Singapore 159088
Tel: (+65) 6476 0672
Fax: (+65) 6474 0672
sg.sales@lemo.com
SPAIN / PORTUGAL
IBERLEMO S.A.
Brasil, 45, 08402 Granollers
Barcelona
Tel: (+34 93) 860 44 20
Fax: (+34 93) 879 10 77
info-es@lemo.com
Madrid Office
Antonio López, 96, 28019 Madrid
Tel: (+34 91) 469 99 19
Fax: (+34 91) 469 99 59
SWEDEN / FINLAND
LEMO Nordic AB
Mariehällsvägen 39A
168 65 Bromma
Tel: (+46 8) 635 60 60
Fax: (+46 8) 635 60 61
info-se@lemo.com
SWITZERLAND
LEMO Verkauf AG
Grundstrasse 22 B
6343 Rotkreuz
Tel: (+41 41) 790 49 40
Fax: (+41 41) 790 49 43
ch.sales@lemo.com
UNITED KINGDOM
LEMO UK Ltd
12-20 North Street
Worthing
West Sussex, BN11 1DU
Tel: (+44 1903) 23 45 43
Fax: (+44 1903) 20 62 31
lemouk@lemo.com
USA
LEMO USA Inc
P.O. Box 2408
Rohnert Park, CA 94927-2408
Tel: (+1 707) 578 88 11
(+1 800) 444 53 66
Fax:(+1 707) 578 08 69
info@lemousa.com
DISTRIBUTORS
AUSTRALIA, BRAZIL, CANADA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL,
NEW ZEALAND, PAKISTAN, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA,
TAIWAN, TURKEY, UKRAINE
www.lemo.com
© CAT.MM.LEN.P0811 - Updated June, 19th 2012
LEMO
