HGG.1T.305.CLLPV
HGG.1T.305.CLLPV
    LEMO(雷莫)
    LEMO - HGG.1T.305.CLLPV - Circular Connector, 1T Series, Panel Mount Receptacle, 5 Contacts, Solder ...
HGG.1T.305.CLLPV 数据手册
HGG.1T.305.CLLPV www.lemo.com SUMMARY # Wires Low 5 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Series 1T Termination type Female solder IP rating 68 Cable Ø 1.30 - 8.50 mm Status active Image is for illustrative purpose only Download Request a quote Catalog Alternative part Matching parts FGG.1T.305.CLAC50 TECHNICAL DETAILS Mechanics Shell Style/Model HG*: Fixed socket, nut fixing, watertight or vacuumtight Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Variant PV : Watertight / Vacuum-tested Weight 6.30 g Performance Configuration T.305 : 5 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 9 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest (contact-shell): 1150 V (AC), 1630 V (DC) Vtest (contact-contact): 1250 V (AC), 1770 V (DC) Others Endurance (Shell): >3000 mating cycles Temp (min / max): -20°C / +80°C Humidity (max): 1000 hr IP Rating: 68 DRAWINGS Draws Dimensions A B E L M N S1 S2 e mm. 15.5 16 6 26 1.8 21.5 10.5 14 M12x1.0 in. 0.61 0.63 0.24 1.02 0.07 0.85 0.41 0.55 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 RECOMMENDED BY LEMO Tools None Cables CMN.05.T22.051PGCE PVC GREY CMN.05.T22.051PNCE PVC Black CMN.05.T22.051QGZE TPR (medical) Grey CMN.05.T28.029PGCE PVC GREY CMN.05.T22.051PGZE Grey CMN.05.T22.051PNZE CMN.05.T28.029PGZE CMN.05.T28.029PNCE Grey PVC Black 005 050 PVC Black 050 090 PVC Black 050 140 PVC Grey 150 250 PVC Grey CMN.05.T28.029PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
HGG.1T.305.CLLPV 价格&库存
很抱歉,暂时无法提供与“HGG.1T.305.CLLPV”相匹配的价格&库存,您可以联系我们找货
