HGG.0T.305.CLLPV
www.lemo.com
SUMMARY
# Wires
Low
5
High
Coax
Triax
Quad
Fiber
Fluidic
Series
0T
Termination type
Female solder
IP rating
68
Cable Ø
1.00 - 6.50 mm
Status
active
Image is for illustrative purpose only
Download
Request a quote
Catalog
Alternative part
Matching parts
FGG.0T.305.CLAC50
TECHNICAL DETAILS
Mechanics
Shell Style/Model
HG*: Fixed socket, nut fixing, watertight or vacuumtight
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces
Variant
PV : Watertight / Vacuum-tested
Weight
4.78 g
Performance
Configuration
T.305 : 5 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
6.5 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Solid Conductor: 0.34 mm^2 (AWG 22)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
R (max): 6.1 mOhm
Vtest (contact-shell): 700 V (AC), 1000 V (DC)
Vtest (contact-contact): 1000 V (AC), 1400 V (DC)
Others
Endurance (Shell): >3000 mating cycles
Temp (min / max): -20°C / +80°C
Humidity (max): 1000 hr
IP Rating: 68
DRAWINGS
Draws
Dimensions
A
B
E
L
M
N
S1
S2
e
mm.
12
12.5
6.5
22
1.5
18.5
8.2
11
M9x0.6
in.
0.47
0.49
0.26
0.87
0.06
0.73
0.32
0.43
2/3
RECOMMENDED BY LEMO
Tools
None
Cables
CMN.05.T22.051PGCE
PVC
GREY
CMN.05.T22.051PNCE
PVC
Black
CMN.05.T22.051QGZE
TPR (medical)
Grey
CMN.05.T28.029PGCE
PVC
GREY
CMN.05.T22.051PGZE
Grey
CMN.05.T22.051PNZE
CMN.05.T28.029PGZE
CMN.05.T28.029PNCE
Grey
PVC
Black
005 050
PVC
Black
050 090
PVC
Black
050 140
PVC
Grey
150 250
PVC
Grey
CMN.05.T28.029PNZE
3/3
很抱歉,暂时无法提供与“HGG.0T.305.CLLPV”相匹配的价格&库存,您可以联系我们找货
