EGG.3T.330.CLL
EGG.3T.330.CLL
    LEMO(雷莫)
    LEMO - EGG.3T.330.CLL - Circular Connector, 3T Series, Panel Mount Receptacle, 30 Contacts, Solder S...
EGG.3T.330.CLL 数据手册
EGG.3T.330.CLL www.lemo.com SUMMARY # Wires Low 30 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Series 3T Termination type Female solder IP rating 68 Cable Ø 2.60 - 15.00 mm Status active Image is for illustrative purpose only Download Request a quote Catalog Alternative part Matching parts FGG.3T.330.CLAC11 TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying 1 key (alpha=0; plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Variant Weight 18.68 g Performance Configuration T.330 : 30 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 3.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 700 V (AC), 990 V (DC) Vtest (contact-contact): 800 V (AC), 1130 V (DC) Others Endurance (Shell): >3000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr IP Rating: 68 DRAWINGS Draws Dimensions A B E L M N S1 S2 e mm. 23.5 25.1 9.6 30.1 2.5 25 16.5 22 M18x1.0 in. 0.93 0.99 0.38 1.19 0.10 0.98 0.65 0.87 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools None Cables CMN.30.T22.087PGCE PVC CMN.30.T22.087PGZE CMN.30.T22.087PNCE GREY Grey PVC Black CMN.30.T22.087PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EGG.3T.330.CLL 价格&库存
很抱歉,暂时无法提供与“EGG.3T.330.CLL”相匹配的价格&库存,您可以联系我们找货
EGG.3T.330.CLL
  • 25+1155.1460525+150.13416
EGG.3T.330.CLL
  • 1+834.36704
  • 5+817.68408
  • 10+793.15949
库存:13
