EGG.1T.304.CLL
www.lemo.com
SUMMARY
# Wires
Low
4
High
Coax
Triax
Quad
Fiber
Fluidic
Series
1T
Termination type
Female solder
IP rating
68
Cable Ø
0.00 - 0.00 mm
Matching parts
FGG.1T.304.CLAC50
Status
active
Image is for illustrative purpose only
Download
Request a quote
Catalog
Alternative part
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FGG*: Straight plug, cable collet and nut for fitting a bend relief, POM outer shell
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces
Cable Fixing
: 0 - 0 mm
Variant
Weight
6.14 g
Performance
Configuration
T.304 : 4 Low Voltage
Insulator
Rated Current
10 Amps
Specifications
Contact Type: Solder
Vtest: 1450 V (DC)1000 V (AC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Temp (min / max): -55°C / +200°C
Humidity (max): 144 hr
Climatical Category: 50/175/21
Shielding (min): 75 dB (10 MHz)
Shielding (min): 40 dB (1 GHz)
IP Rating: 68
DRAWINGS
Draws
Dimensions
A
B
C
E
L
M
N
e
mm.
15.5
10.6
12.1
6
22.2
1.8
18.5
M12x1.0
in.
0,61
0,42
0,48
0,24
0,87
0,07
0,73
RECOMMENDED BY LEMO
Tools
None
Cables
2/3
CMN.04.T22.047PGCE
PVC
CMN.04.T22.047PGZE
CMN.04.T22.047PNCE
GREY
Grey
PVC
Black
CMN.04.T22.047QGC
TPR
Grey
CMN.04.T22.048QGZE
TPR (medical)
Grey
CMN.04.T28.031PGCE
PVC
GREY
CMN.04.T22.047PNZE
CMN.04.T28.031PGZE
CMN.04.T28.031PNCE
Grey
PVC
Black
CMN.04.T28.031QGC
TPR
Grey
004 041
PVC
Grey
004 050
PVC
Black
004 080
PVC
Grey
004 220
PVC
Black
004 221
PVC
Black
004 260
PTFE
White
004 280
PVC
Black
040 080
PVC
Black
040 086
PVC
Blue
040 140
PVC
Black
040 240
PTFE
White
040 260
PVC
Black
080 080
PVC
Grey
080 082
PVC
Red
080 084
PVC
Black
140 240
PVC
Black
140 250
PVC
Grey
417 920
PVC
Grey
CTR.75.030.121870G
PVC
Grey
CMN.04.T28.031PNZE
3/3
很抱歉,暂时无法提供与“EGG.1T.304.CLL”相匹配的价格&库存,您可以联系我们找货
