EXG.1B.310.HLN
www.lemo.com
SUMMARY
# Wires
Low voltage
10
Image is for illustrative purpose only
Series
1B
Termination type
Female print PCB
IP rating
50
AWG wire size
34.00 - 28.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FGG.1B.310.CLAD42
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EX*: Elbow receptacle for printed circuit with two nuts (solder or screw fixing, back panel
mounting)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
PPS (Polyphenylene) shell, other pieces nickel plated [SAE AMS QQ N 290] brass
Weight
14.49 g
Performance
Configuration
1B.310/EXG : 10 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
1.5 Amps
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.5 mm (0.02in)
R (max): 8.7 mOhm
Test voltage contact-contact : 1 kV rms
Test voltage contact-body shell : 1 kV rms
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
B
D
E
H
I
K
L
M
N
S3
e
mm.
14
15
16.6
7.5
7.5
14
13.3
27
3.5
12.6
13
M11x0.5
in.
0,55
0,59
0,65
0,30
0,30
0,55
0,52
1,06
0,14
0,50
0,51
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.65.120.AZ
2/3
3/3
很抱歉,暂时无法提供与“EXG.1B.310.HLN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1042.821881+134.43986
