FPG.0B.303.CLAD52Z
FPG.0B.303.CLAD52Z
    LEMO(雷莫)
    LEMO - FPG.0B.303.CLAD52Z - Circular Connector, 0B Series, Right Angle Cable Mount Plug, 3 Contacts,...
FPG.0B.303.CLAD52Z 数据手册
FPG.0B.303.CLAD52Z www.lemo.com SUMMARY # Wires Low voltage 3 Image is for illustrative purpose only Series 0B Termination type Male solder IP rating 50 AWG wire size 28.00 - 20.00 Cable Ø 4.30 - 5.20 mm Status active Matching parts EGG.0B.303.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FP*: Elbow (90°) plug with cable collet for bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 10.71 g Performance Configuration 0B.303 : 3 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 8 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 1.0 mm (0.039in) Max. Solid Conductor: 0.56 mm^2 (AWG 20) Max. Stranded Conductor: 0.56 mm^2 (AWG 20) R (max): 4.8 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 900 V (AC), 1270 V (DC) Vtest (contact-contact): 1200 V (AC), 1700 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A H L M S1 S2 S3 mm. 9.5 21.8 30 20 8 7 8 in. 0,37 0,86 1,18 0,79 0,31 0,28 0,31 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.0B.ZZZ.PA070 Cables 130240 PVC Black 130250 PVC Grey 30260 PVC Black 3220 PVC Black 60080 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FPG.0B.303.CLAD52Z 价格&库存
很抱歉,暂时无法提供与“FPG.0B.303.CLAD52Z”相匹配的价格&库存,您可以联系我们找货
FPG.0B.303.CLAD52Z
  • 1+613.949021+79.41082
