EGG.2T.310.CLL
EGG.2T.310.CLL
    LEMO(雷莫)
    LEMO - EGG.2T.310.CLL - Circular Connector, 2T Series, Panel Mount Receptacle, 10 Contacts, Solder S...
EGG.2T.310.CLL 数据手册
EGG.2T.310.CLL www.lemo.com SUMMARY # Wires Low 10 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Series 2T Termination type Female solder IP rating 68 Cable Ø 1.30 - 10.50 mm Status active Image is for illustrative purpose only Download Request a quote Catalog Alternative part Matching parts FGG.2T.310.CLAC50 TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying 1 key (alpha=0; plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Variant Weight 9.43 g Performance Configuration T.310 : 10 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 8 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest (contact-shell): 1300 V (AC), 1840 V (DC) Vtest (contact-contact): 1450 V (AC), 2050 V (DC) Others Endurance (Shell): >3000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr IP Rating: 68 DRAWINGS Draws Dimensions A B E L M N S1 S2 e mm. 18.5 19.6 7.5 26.5 1.8 24.6 13.5 17 M15x1.0 in. 0.73 0.77 0.30 1.04 0.07 0.97 0.53 0.67 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools None Cables CMN.10.T22.068PGCE PVC GREY CMN.10.T28.052PGCE PVC GREY CMN.10.T28.053QGZE TPR (medical) Grey CMN.10.T22.068PGZE CMN.10.T22.068PNCE Grey PVC Black TPR (medical) Grey CMN.10.T22.068PNZE CMN.10.T22.068QGC CMN.10.T22.068QGZE CMN.10.T28.052PGZE CMN.10.T28.052PNCE Grey PVC Black 110 220 PVC Black 110 240 PTFE White 110 260 PTFE White 110 280 PVC Black 210 140 PVC Grey 210 240 PVC Black 210 250 PVC Grey 210 260 PVC Black CMN.10.T28.052PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EGG.2T.310.CLL 价格&库存
很抱歉,暂时无法提供与“EGG.2T.310.CLL”相匹配的价格&库存,您可以联系我们找货
EGG.2T.310.CLL
    库存:10
