EGN.0M.303.XLM
EGN.0M.303.XLM
    LEMO(雷莫)
EGN.0M.303.XLM 数据手册
M SERIES CONNECTORS RATCHET COUPLING ® ® Introduction This catalogue gives the complete description of LEMO M series connectors. M series connectors are lightweight triplestart ratchet coupling type connectors designed for avionics, aerospace, military, security, motorsport and heavy duty applications. The LEMO manufacturing programme has been extended to almost 40 series divided into 7 product families with specific mating and environmental characteristics. Each series includes a wide variety of plug, socket and coupler models, available in contact configurations adapted to all round cables. Watertight models are also available. Since LEMO connectors are perfectly screened and designed to guarantee very low resistance to shell electrical continuity, they are particularly adapted to applications where electromagnetic compatibility (EMC) is important. Technical Characteristics Materials and Treatments Component Shell material code X Material (Standard) chrome Cu Ni Cr C Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Bronze (UNS C 54400) or special brass Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Special PEEK Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Brass (UNS C 34500) Bronze (UNS C 54400) Cu-Be or special steel PEEK FPM/FKM (Viton®) Epoxy (Araldite® or Stycast®) Fluorosilicone Stainless steel Outer shell Conical nut Earthing crown Coupling nut Ratchet Hexagonal nut Male crimp contact Female crimp contact Clips Insulator O-ring and gaskets Sealing resin Cable rear seal Spring 0.5 – 0.5 3 – 3 – – – – – – – – – – – – – – 0.3 – 0.3 Surface treatment (µm) Notes nickel gold Cu Ni Cu Ni Au – – – – 5 – – – – anodized – – – 0.5 – 0.5 3 – – 0.5 3 – – 0.5 3 – – 0.5 3 – anodized natural – – – 0.5 – – – 0.5 without treatment – – – – – – – – – – – – – – – – 1.5 – – – – 3 3 1.0 1.5 1) Notes: standards for surface treatment are as follows: chrome-plated FS QQ-C-320B; nickel-plated FS QQ-N-290A or MIL-C-26074C; gold-plated ISO 4523. 1) anthracite colour. Environmental performance Characteristics Operating temperature (mated) Ingress protection index Fungus Flammability Fluid contamination 1) Sand and dust 2) Lightning strike Altitude-low temp 3) Salt fog 4) Thermal shock Altitude immersion Air leakage 5) Humidity Value - 55°C/+200° C IP 68 (at 2 m, 15 hr) Satisfied - by material analysis 60 sec. front and back face Fuels, gasoline, hydraulic oils, solvents, de-icing 6 hr, 55° C, blowing < 150 µm dust 10 K amps - 6 times -65° C; 40’000 feet and 400 VAC Alum. shell (slight pitting after 48 h), Brass shell (500 h) 5 cycles : -65° C to +150° C No moisture on contacts < 10-7 mbar. l/sec (Helium) 21 days at 95% IEC international MIL-spec tests IEC 60529 IEC 60512-6 test 11f IEC 60512-11-4 IEC 60512-7 14 b IEC 60068-2 MIL-STD 810F-508.5 EIA-364-104A MIL-STD-810F method 504 MIL-STD 810F-510.4 EIA-364-75 EIA-364-105A EIA-364-26 EIA-364-32 test condition IV EIA-364-03 MIL-STD-1344 method 1008.1 EIA-364-31 method IV Note: 1) Connectors immersed at both 70°C and 25°C according to specification. Connectors are then inspected, no visual signs of damage seen. Fuels: Kerosene, JP4, (Nato F40) at 70°C +/- 2°C. Gasoline: ASTM 4814. Hydraulic oils: Mineral oil based MIL-H-5606. Solvents: Isopropanol. De-icing fluids: 25% ethylene glycol. 2) No signs of damage, connectors opened and closed without difficulty. Dust or sand was not inside connector. 3) Wired mated connectors = no voltage breakdown, shell to all contacts (connected together) w/400 VAC after 1 hour at 65° C at 40’000 feet altitude. 4) Corrosion resistance. Inspection: salt deposits shall be removed by gentle wash in running water with light brushing using soft brush. Aluminium Shell (material code: X) max: 96 hours. Brass shell (material code: C) over 500 hours. 5) Only for vacuumtight model (HE•) www.lemo.com 1 ® ® Electrical performance Characteristics Value Insulation resist. (at ambient temp.) 6) Dielectric withstanding volt. (sea level) Contact resistance Current rating Shell to shell conductivity Shielding effectiveness, low frequency Shielding effectiveness, high frequency IEC international > 1012 Ω, > 1010 Ω (after humidity) See table page 15-16 See table below 7) See insulator configuration page 15-16 < 1.5mΩ ≥ 80 dB up to 1GHz ≥ 70 dB (3GHz), ≥ 58 dB (6GHz), ≥ 40 dB (10GHz) IEC 60512-2 test 3a IEC 60512-2 test 4a IEC 60512-2 test 2a IEC 60512-3 test 5a IEC 60512-2-6 MIL-spec tests EIA-364-21 EIA-364-20 EIA-364-06 EIA-364-83 EIA-364-66 EIA-364-66 Note: 6) After humidity test: 21 days at 95% RH according to IEC 60068-2. Insulation resistance measured between the contacts and contact/shell. Contact resistance 7) IEC 60512-2 test 2a 0.5 ≤ 8.7 0.7 0.9 1.3 ≤ 6.1 ≤ 4.8 ≤ 3.6 Value øA (mm) mΩ Notes: 7) after 5000 mating cycles and the salt spray test according to IEC 60512-6 test 11 f. Mechanical performance Characteristics Endurance Gunfire vibration Vibration-Sine 8) Vibration-Random Shock Acceleration Contact retention Torque Value IEC international 3000 cycles (1000 cycles for 5M series) 25 to 2000 Hz, 3 axis (Apache helicopter) 30 g, 3 axis, 12 hr 50-2000 Hz, 37.8 g rms-3 axes; 4h amb 300 g - 3 msec 50 g acceleration > 22 N (ø 0.7mm), > 30N (ø 0.9 mm) See table below IEC 60512-5 test 9a IEC 60512-6-4 IEC 60512-6-3 MIL-spec tests EIA-364-09 MIL-STD-810F method 519.5 MIL-STD-202 method 204-G EIA-364-28 test cond. V letter I EIA-364-27 condition D MIL-STD-1344 - 2011-1, A IEC 60512-8 test 15a Note: 8) Amplitude: 30G. Frequency: 10 to 2000 Hz. Time per axis: 4 hours (X, Y, Z). No signal discontinuity above 1 µs. Series Coupling torque tightning (N.cm) Coupling torque untightning (N.cm) Series Coupling torque tightning (N.cm) Coupling torque untightning (N.cm) 0M 1M 2M 3M 4 10 20 34 5 11 14 29 TM 4M LM 5M tbc tbc 48 91 9) tbc tbc 43 54 Note: 9) Higher value due to very high contact density 2 www.lemo.com ® ® M Series The M Series connector offers a new innovative design for avionics, aerospace, military, security, motorsport and heavy duty applications. Made of high-strength aluminium, this connector is one of the lightest and most compact of the LEMO product line. A one-grip ratchet screw system enables quick and secure coupling of the connectors. The arctic grip makes it easy to manipulate the connector while wearing gloves or when the connector is located in a difficult to access area. Features – Ratchet-coupling mechanism – Compact design for space savings – Oil and fuel resistant – 360° screening for full EMC shielding – Colour coding / keying – Scoop proof – Threaded for MIL-DTL-38999L backshell – Quick mating: less than 3/4 turn to seat – Lightweight – High vibration and shock resistance – Sealed to IP68 when mated – Reverse sex configuration – Pin configuration from 2 to 114 contacts Metal housing models (page 5) Straight plugs FM Free sockets Fixed sockets EG PB FM EG PV PM PV PM PV PH PF PH PB FM EC FG EC FG ED PB PE PF Watertight model (unmated) Fixed socket FG ED HE www.lemo.com 3 ® ® Part Numbering System FM N . 1M . 305 . X L C FG N . 1M . 305 . X L C M Free socket PM N . 1M . 305 . X L M T Fixed socket HE N . 1M . 305 . X L Plug N P Model: (page 5) Variant: T = Mold stop P = Potted M = MIL-DTL-38999L shell thread Alignment key: (page 14) Contact: (page 17) Series: (page 5) Insulator: L = PEEK Insert configuration: (page 15) Housing: (page 16) Part Number Example Straight plug: FMN.1M.305.XLC = straight plug with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts. Straight plug: FGN.1M.305.XLCM = straight plug with key (N), arctic grip, 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts and with MIL-DTL-38999L thread for additional backshell (not supplied). Free socket: PMN.1M.305.XLMT = free socket with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female crimp contacts and mold stop. Fixed socket: HEN.1M.305.XLNP = fixed socket, nut fixing, with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female print contacts, watertight. Part Section Showing Internal Components Fixed socket 1 2 3 4 5 6 4 outer shell o-ring hexagonal nut insulator female contact earthing crown 5 4 6 3 2 1 1 3 2 7 5 6 Straight plug 4 1 2 3 4 5 6 7 outer shell insulator male contact rear seal tightening screw ratchet mechanism spring www.lemo.com ® ® Metal housing models FM● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip Reference Ls/Lr øA øC P øD øB X Dimensions (mm) Model Series A B C D Ls Lr P X FM● FM● FM● FM● FM● FM● FM● FM● 0M 1M 2M 3M TM 4M LM 5M 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 24.1 24.1 24.5 24.5 28.6 28.6 28.6 28.6 24.1 24.1 24.5 24.5 28.6 28.6 28.6 28.6 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: FMN.1M.305.XLC Note: Ls = standard gender, Lr = reverse gender FM● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip and mold stop Reference Ls/Lr øC øD øF øB X øA P M Dimensions (mm) Model Series A B C D F Ls Lr M P X FM● FM● FM● FM● FM● FM● FM● FM● 0M 1M 2M 3M TM 4M LM 5M 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 10.7 12.4 15.5 17.5 19.8 22.6 25.8 31.4 27.1 27.1 27.5 27.5 31.6 31.6 31.6 31.6 27.1 27.1 27.5 27.5 31.6 31.6 31.6 31.6 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 1.5 Part number example: FMN.1M.305.XLCT Note: Ls = standard gender, Lr = reverse gender FM● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Dimensions (mm) Reference Ls/Lr øA P øC e 9 Model Series A C e Ls Lr P Code1) FM● FM● FM● FM● FM● FM● FM● 1M 2M 3M TM 4M LM 5M 14.6 17.6 19.6 22.5 25.0 28.5 34.0 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 26.4 26.4 26.4 30.0 30.0 30.0 30.0 26.4 26.4 26.4 30.0 30.0 30.0 30.0 3.9 3.9 3.9 3.4 3.4 3.4 3.4 A B C C D E G Part number example: FMN.1M.305.XLCM Note: Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied) www.lemo.com 5 ® ® FG● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip Reference Ls/Lr øA øC øD øB P Dimensions (mm) Model Series A B C D Ls Lr P X FG● FG● FG● FG● FG● FG● FG● FG● 0M 1M 2M 3M TM 4M LM 5M 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 24.1 24.1 24.5 24.5 28.6 28.6 28.6 28.6 24.1 24.1 24.5 24.5 28.6 28.6 28.6 28.6 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: FGN.1M.305.XLC X Note: Ls = standard gender, Lr = reverse gender FG● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip and mold stop Reference Ls/Lr øA øC P øD øF øB M Dimensions (mm) Model Series A B C D F Ls Lr M P X FG● FG● FG● FG● FG● FG● FG● FG● 0M 1M 2M 3M TM 4M LM 5M 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 10.7 12.4 15.5 17.5 19.8 22.6 25.8 31.4 27.1 27.1 27.5 27.5 31.6 31.6 31.6 31.6 27.1 27.1 27.5 27.5 31.6 31.6 31.6 31.6 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: FGN.1M.305.XLCT X 1.5 Note: Ls = standard gender, Lr = reverse gender FG● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip and with MIL-DTL-38999L shell thread Dimensions (mm) Reference Ls/Lr øA P øC e 9 Model Series A C e Ls Lr P Code1) FG● FG● FG● FG● FG● FG● FG● 1M 2M 3M TM 4M LM 5M 15.9 18.9 20.9 23.4 25.9 29.4 34.9 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 26.4 26.4 26.4 30.0 30.0 30.0 30.0 26.4 26.4 26.4 30.0 30.0 30.0 30.0 3.9 3.9 3.9 3.4 3.4 3.4 3.4 A B C C D E G Part number example: FGN.1M.305.XLCM Note: Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied) 6 www.lemo.com ® ® EG● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W and X) Dimensions (mm) Reference Ls/Lr S1 e øC P Series C D e E Ls Lr P S1 S2 EG● EG● EG● EG● EG● EG● EG● EG● 0M 1M 2M 3M TM 4M LM 5M 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 6.8 6.8 6.8 6.8 9.4 9.4 9.4 9.4 M9x0.6 M11x1.0 M14x1.0 M16x1.0 M18x1.0 M21x1.0 M24x1.0 M30x1.0 5.0 4.5 4.5 4.0 4.0 4.0 4.0 4.0 18.1 18.1 18.1 18.1 19.8 19.8 19.8 19.8 18.1 18.1 18.1 18.1 21.7 21.7 21.7 21.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 8.2 9.5 12.5 14.5 16.5 19.5 22.5 28.5 11.0 13.0 17.0 19.0 22.0 25.0 30.0 36.0 Part number example: EGN.1M.305.XLM D S2 Model E maxi Panel cut-out (page 22). Note: Ls = standard gender, Lr = reverse gender EG● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W and X) for printed circuit Dimensions (mm) Reference Ls/Lr G S2 P e øC S1 4.5 Series C D e E G Ls Lr P S1 S2 EG● EG● EG● EG● EG● EG● EG● EG● 0M 1M 2M 3M TM 4M LM 5M 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 6.8 6.8 6.8 6.8 9.4 9.4 9.4 9.4 M9x0.6 M11x1.0 M14x1.0 M16x1.0 M18x1.0 M21x1.0 M24x1.0 M30x1.0 5.0 4.5 4.5 4.0 4.0 4.0 4.0 4.0 16.8 16.8 16.8 16.8 18.9 18.9 18.9 18.9 18.1 18.1 18.1 18.1 19.8 19.8 19.8 19.8 18.1 18.1 18.1 18.1 21.7 21.7 21.7 21.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 8.2 9.5 12.5 14.5 16.5 19.5 22.5 28.5 11.0 13.0 17.0 19.0 22.0 25.0 30.0 36.0 Part number example: EGN.1M.305.XLN D E maxi 5.6 Model Panel cut-out (page 22). Note: Ls = standard gender, Lr = reverse gender EC● Fixed socket with two nuts, key (N) or keys (P, R, S, T, U, V, W and X) Reference Ls/Lr S1 e E maxi G S2 øA P øB øC S3 Dimensions (mm) Model Series A EC● EC● EC● EC● EC● EC● EC● EC● 0M 1M 2M 3M TM 4M LM 5M 17 18 21 23 27 29 33 38 B C 4.72 18.2 5.95 19.2 8.95 21.5 10.95 25.0 12.30 28.0 13.95 34.0 17.95 36.0 22.90 41.0 E e G Ls Lr P S1 S2 S3 5.0 5.0 4.0 4.0 2.5 2.5 2.5 2.5 M13x0.75 M14x1.00 M17x1.00 M19x1.00 M22x1.00 M24x1.00 M28x1.00 M33x1.00 16.8 16.8 16.8 16.8 18.9 18.9 18.9 18.9 18.1 18.1 18.1 18.1 19.8 19.8 19.8 19.8 18.1 18.1 18.1 18.1 21.7 21.7 21.7 21.7 5.3 11.5 14.0 16.0 5.3 12.5 16.0 17.0 5.3 15.5 18.0 19.0 5.3 17.5 20.0 22.0 7.9 20.5 23.0 25.0 7.9 22.5 25.0 30.0 7.9 26.5 29.0 32.0 7.9 31.5 34.0 37.0 Part number example: ECN.1M.305.XLM Panel cut-out (page 22). Note: Ls = standard gender, Lr = reverse gender www.lemo.com 7 ® ® EC● Fixed socket with two nuts, key (N) or keys (P, R, S, T, U, V, W and X) for printed circuit Reference S3 Ls/Lr S1 e øA P øB øC 5.6 E maxi 4.5 Dimensions (mm) Model Series A EC● EC● EC● EC● EC● EC● EC● EC● 0M 1M 2M 3M TM 4M LM 5M 17 18 21 23 27 29 33 38 B C 4.72 18.2 5.95 19.2 8.95 21.5 10.95 25.0 12.30 28.0 13.95 34.0 17.95 36.0 22.90 41.0 E e G Ls Lr P S1 S2 S3 5.0 5.0 4.0 4.0 2.5 2.5 2.5 2.5 M13x0.75 M14x1.00 M17x1.00 M19x1.00 M22x1.00 M24x1.00 M28x1.00 M33x1.00 16.8 16.8 16.8 16.8 18.9 18.9 18.9 18.9 18.1 18.1 18.1 18.1 19.8 19.8 19.8 19.8 18.1 18.1 18.1 18.1 21.7 21.7 21.7 21.7 5.3 11.5 14.0 16.0 5.3 12.5 16.0 17.0 5.3 15.5 18.0 19.0 5.3 17.5 20.0 22.0 7.9 20.5 23.0 25.0 7.9 22.5 25.0 30.0 7.9 26.5 29.0 32.0 7.9 31.5 34.0 37.0 Part number example: ECN.1M.305.XLN S2 Panel cut-out (page 22). G Note: Ls = standard gender, Lr = reverse gender ED● Fixed socket with square flange, key (N) or keys (P, R, S, T, U, V, W and X) Reference Ls/Lr K P øB øC øA N H Dimensions (mm) Model Series A B C G H K Ls Lr N P V ED● ED● ED● ED● ED● ED● ED● ED● 0M 1M 2M 3M TM 4M LM 5M 20.6 23.8 26.9 29.0 31.4 34.6 38.0 43.7 4.72 5.95 8.95 10.95 12.30 13.95 17.95 22.90 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 12.8 12.8 12.8 12.8 14.5 14.5 14.5 14.5 11.0 12.9 15.1 16.6 18.3 20.6 23.0 27.0 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 18.1 18.1 18.1 18.1 19.8 19.8 19.8 19.8 18.1 18.1 18.1 18.1 21.7 21.7 21.7 21.7 16.0 18.4 20.6 22.1 23.8 26.1 28.5 32.5 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Part number example: EDN.1M.305.XLM øV G Panel cut-out (page 22). Note: Ls = standard gender, Lr = reverse gender ED● Fixed socket with square flange, key (N) or keys (P, R, S, T, U, V, W and X) for printed circuit Reference Ls/Lr N K øA P øB øC 5.6 4.5 H øV Dimensions (mm) Model Series A B C G H K Ls Lr N P V ED● ED● ED● ED● ED● ED● ED● ED● 0M 1M 2M 3M TM 4M LM 5M 20.6 23.8 26.9 29.0 31.4 34.6 38.0 43.7 4.72 5.95 8.95 10.95 12.30 13.95 17.95 22.90 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 12.8 12.8 12.8 12.8 14.5 14.5 14.5 14.5 11.0 12.9 15.1 16.6 18.3 20.6 23.0 27.0 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 18.1 18.1 18.1 18.1 19.8 19.8 19.8 19.8 18.1 18.1 18.1 18.1 21.7 21.7 21.7 21.7 16.0 18.4 20.6 22.1 23.8 26.1 28.5 32.5 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Part number example: EDN.1M.305.XLN G Panel cut-out (page 22). Note: Ls = standard gender, Lr = reverse gender 8 www.lemo.com ® ® PE● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W and X) and mold stop (back panel mounting) Reference L e E maxi X øA øD øF øB øC P S1 M Dimensions (mm) Model Series A PE● PE● PE● PE● PE● PE● PE● PE● 0M 1M 2M 3M TM 4M LM 5M 17 18 21 23 27 29 33 38 B C D E 8.8 16.8 8.0 10.5 17.8 9.7 14.0 20.8 13.0 16.0 22.8 15.0 17.9 25.8 16.7 20.7 27.8 19.5 23.9 31.8 22.7 29.7 36.8 28.5 e Ls 5.0 M13x0.75 5.0 M14x1.00 5.0 M17x1.00 5.0 M19x1.00 4.0 M22x1.00 4.0 M24x1.00 4.0 M28x1.00 4.0 M33x1.00 Lr M P R S1 S2 25.6 25.6 9.7 5.3 13.8 11.5 25.6 25.6 9.7 5.3 13.8 12.5 26.0 26.0 10.1 5.3 13.8 15.5 26.0 26.0 10.1 5.3 13.8 17.5 29.5 30.1 10.6 7.9 16.9 20.5 29.5 30.1 10.6 7.9 16.9 22.5 29.5 30.1 10.6 7.9 16.9 26.5 29.5 30.1 10.6 7.9 16.9 31.5 14 16 18 20 23 25 29 34 Part number example: PEN.1M.305.XLMT S2 Panel cut-out (page 22). R 1.5 Note: this model is only available with mold stop. The dimensions «F» and «X» are the same as the PB● models. Ls = standard gender, Lr = reverse gender. PF● Fixed socket with square flange, key (N) or keys (P, R, S, T, U, V, W and X) and mold stop Reference Ss/Sr K øA N G P øC øD øF øB øE M Dimensions (mm) Model Series A B C D PF● PF● PF● PF● PF● PF● PF● PF● 0M 1M 2M 3M TM 4M LM 5M 20.6 23.8 26.9 29.0 31.4 34.6 38.0 47.0 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 E F 10.7 10.7 12.4 12.4 15.5 15.5 17.5 17.5 19.8 19.8 22.6 22.6 25.8 25.8 33.0 31.4 G H K 12.8 12.8 12.8 12.8 14.5 14.5 14.5 14.5 11.0 12.9 15.1 16.6 18.3 20.6 23.0 29.4 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 N Ss Sr V 16.0 11.3 11.3 18.4 11.3 11.3 20.6 11.7 11.7 22.1 11.7 11.7 23.8 13.0 13.6 26.1 13.0 13.6 28.5 13.0 13.6 37.0 13.0 13.6 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Part number example: PFN.1M.305.XLMT X øV H Panel cut-out (page 22). 1.5 Note: this model is only available with mold stop. The dimensions «M», «P» and «X» are the same as the PB● models. Ss = standard gender, Sr = reverse gender. PF● Fixed socket with square flange, key (N) or keys (P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Dimensions (mm) Reference Ss/Sr N K øA G P øC e øE 9 Model Series A C e E G H K N Ss PF● PF● PF● PF● PF● PF● PF● 1M 2M 3M TM 4M LM 5M 23.8 26.9 29.0 31.4 34.6 38.0 47.0 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 12.4 15.5 17.5 19.8 22.6 25.8 33.0 12.8 12.8 12.8 14.5 14.5 14.5 14.5 12.9 15.1 16.6 18.3 20.6 23.0 29.4 1.5 1.5 1.5 2.0 2.0 2.0 2.0 18.4 20.6 22.1 23.8 26.1 28.5 37.0 12.2 12.2 12.2 11.7 11.7 11.7 11.7 Sr Code1) 12.2 12.2 12.2 13.6 13.6 13.6 13.6 A B C C D E G Part number example: PFN.1M.305.XLMM H ø 3.3 Panel cut-out (page 22). Note: Ss = standard gender, Sr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied) www.lemo.com 9 ® ® PB● Fixed socket with antivibration flange, key (N) or keys (P, R, S, T, U, V, W and X), 2 holes fixing Reference P Ss/Sr 2 øD øB H øC X A N Dimensions (mm) Model Series A B C D PB● PB● PB● PB● PB● PB● PB● PB● 0M 1M 2M 3M TM 4M LM 5M 27.0 29.0 32.0 35.0 38.5 41.0 44.0 51.0 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 14.5 16.5 19.5 21.5 24.5 27.5 30.5 37.5 G 8.0 8.3 9.7 8.3 13.0 8.3 15.0 8.3 16.7 11.0 19.5 11.0 22.7 11.0 28.5 11.0 H N P Ss Sr X 21.4 23.4 26.4 29.0 32.5 35.0 38.0 45.0 16.0 18.0 21.0 23.0 26.0 29.0 32.0 39.0 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 15.3 15.3 15.7 15.7 15.2 15.2 15.2 15.2 15.3 15.3 15.7 15.7 17.1 17.1 17.1 17.1 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PBN.1M.305.XLM 3.3 Panel cut-out (page 22). G Note: Ss = standard gender, Sr = reverse gender PB● Fixed socket with antivibration flange, key (N) or keys (P, R, S, T, U, V, W and X), 2 holes fixing and mold stop Reference P Ss/Sr 2 N A øC øD øB H øF M Dimensions (mm) Model Series A B C D PB● PB● PB● PB● PB● PB● PB● PB● 0M 1M 2M 3M TM 4M LM 5M 27.0 29.0 32.0 35.0 38.5 41.0 44.0 51.0 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 14.5 16.5 19.5 21.5 24.5 27.5 30.5 37.5 F G 8.0 10.7 8.3 9.7 12.4 8.3 13.0 15.5 8.3 15.0 17.5 8.3 16.7 19.8 11.0 19.5 22.6 11.0 22.7 25.8 11.0 28.5 31.4 11.0 H M N P Ss Sr X 21.4 23.4 26.4 29.0 32.5 35.0 38.0 45.0 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 16 18 21 23 26 29 32 39 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 18.3 18.3 18.7 18.7 18.2 18.2 18.2 18.2 18.3 18.3 18.7 18.7 18.2 18.2 18.2 18.2 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PBN.1M.305.XLMT X 1.5 3.3 Panel cut-out (page 22). G Note: Ss = standard gender, Sr = reverse gender PB● Fixed socket with antivibration flange, key (N) or keys (P, R, S, T, U, V, W and X), 2 holes fixing with MIL-DTL-38999L shell thread Reference P Ss/Sr 2 e øC H 9 A N Dimensions (mm) Model Series A C e G H N P Ss PB● PB● PB● PB● PB● PB● PB● 1M 2M 3M TM 4M LM 5M 29.0 32.0 35.0 38.5 41.0 44.0 51.0 16.5 19.5 21.5 24.5 27.5 30.5 37.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 8.3 8.3 8.3 11.0 11.0 11.0 11.0 23.4 26.4 29.0 32.5 35.0 38.0 45.0 18.0 21.0 23.0 26.0 29.0 32.0 39.0 5.3 5.3 5.3 7.9 7.9 7.9 7.9 17.2 17.2 17.2 16.2 16.2 16.2 16.2 Sr Code1) 17.2 17.2 17.2 17.1 17.1 17.1 17.1 A B C C D E G Part number example: PBN.1M.305.XLMM Panel cut-out (page 22). 3.3 10 G Note: Ss = standard gender, Sr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied) www.lemo.com ® ® PV● Fixed socket with antivibration square flange, key (N) or keys (P, R, S, T, U, V, W and X) Reference øD øC 2 øB øC P Ss/Sr øA N Model Series A B C PV● PV● PV● PV● PV● PV● PV● PV● 0M 1M 2M 3M TM 4M LM 5M 26.9 31.4 34.6 38.0 40.3 43.7 47.1 54.9 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 14.5 16.5 19.5 21.5 24.5 27.5 30.5 37.5 D G H 8.0 8.3 15.1 9.7 8.3 18.3 13.0 8.3 20.6 15.0 8.3 23.0 16.7 11.0 24.6 19.5 11.0 27.0 22.7 11.0 29.4 28.5 11.0 34.9 N P Ss Sr V X 20.6 23.8 26.1 28.5 30.1 32.5 34.9 40.4 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 15.3 15.3 15.7 15.7 15.2 15.2 15.2 15.2 15.3 15.3 15.7 15.7 17.1 17.1 17.1 17.1 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PVN.1M.305.XLM X H Dimensions (mm) øV G Panel cut-out (page 22). Note: Ss = standard gender, Sr = reverse gender PV● Fixed socket with antivibration square flange, key (N) or keys (P, R, S, T, U, V, W and X) and mold stop Reference P Ss/Sr øA N 2 øC øD øF øB øC M Dimensions (mm) Model Series A B C PV● PV● PV● PV● PV● PV● PV● PV● 0M 1M 2M 3M TM 4M LM 5M 26.9 31.4 34.6 38.0 40.3 43.7 47.1 54.9 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 14.5 16.5 19.5 21.5 24.5 27.5 30.5 37.5 D F G 8.0 10.7 8.3 9.7 12.4 8.3 13.0 15.5 8.3 15.0 17.5 8.3 16.7 19.8 11.0 19.5 22.6 11.0 22.7 25.8 11.0 28.5 31.4 11.0 H M N P Ss Sr X 15.1 18.3 20.6 23.0 24.6 27.0 29.4 34.9 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 20.6 23.8 26.1 28.5 30.1 32.5 34.9 40.4 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 18.3 18.3 18.3 18.3 18.7 18.7 18.7 18.7 18.2 18.2 18.2 18.2 18.2 18.2 18.2 18.2 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PVN.1M.305.XLMT X 1.5 øV H Panel cut-out (page 22). G Note: Ss = standard gender, Sr = reverse gender. The dimension «V» is the same as the PV● models without mold stop. PV● Fixed socket with antivibration square flange, key (N) or keys (P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Reference P Ss/Sr 2 e 9 øC øA øC N Dimensions (mm) Model Series A C e PV● PV● PV● PV● PV● PV● PV● 1M 2M 3M TM 4M LM 5M 31.4 34.6 38.0 40.3 43.7 47.1 54.9 16.5 19.5 21.5 24.5 27.5 30.5 37.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 G H 8.3 18.3 8.3 20.6 8.3 23.0 11.0 24.6 11.0 27.0 11.0 29.4 11.0 34.9 N P Ss Sr 23.8 26.1 28.5 30.1 32.5 34.9 40.4 5.3 5.3 5.3 7.9 7.9 7.9 7.9 17.2 17.2 17.2 16.2 16.2 16.2 16.2 17.2 17.2 17.2 17.1 17.1 17.1 17.1 V Code1) 3.3 3.3 3.3 3.3 3.3 3.3 3.3 A B C C D E G Part number example: PVN.1M.305.XLMM Panel cut-out (page 22). H www.lemo.com øV G Note: Ss = standard gender, Sr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied) 11 ® ® PM● Free socket, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip Reference Ls/Lr øA øC P øD øB X Dimensions (mm) Model Series A B C D Ls Lr P X PM● PM● PM● PM● PM● PM● PM● PM● 0M 1M 2M 3M TM 4M LM 5M 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 25.6 25.6 26.0 26.0 28.2 28.2 28.2 28.2 25.6 25.6 26.0 26.0 30.1 30.1 30.1 30.1 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PMN.1M.305.XLM Panel cut-out (page 22). Note: Ls = standard gender, Lr = reverse gender PM● Free socket, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip and mold stop Reference Ls/Lr øA øC P øD øF øB M Dimensions (mm) Model Series A B C D F Ls Lr M P X PM● PM● PM● PM● PM● PM● PM● PM● 0M 1M 2M 3M TM 4M LM 5M 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 10.7 12.4 15.5 17.5 19.8 22.6 25.8 31.4 28.6 28.6 29.0 29.0 31.2 31.2 31.2 31.2 28.6 28.6 29.0 29.0 31.2 31.2 31.2 31.2 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PMN.1M.305.XLMT X 1.5 Panel cut-out (page 22). Note: Ls = standard gender, Lr = reverse gender PH● Free socket, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip Reference Ls/Lr øA P øC øD øB X Dimensions (mm) Model Series A B C D Ls Lr P X PH● PH● PH● PH● PH● PH● PH● PH● 0M 1M 2M 3M TM 4M LM 5M 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 25.6 25.6 26.0 26.0 28.2 28.2 28.2 28.2 25.6 25.6 26.0 26.0 30.1 30.1 30.1 30.1 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PHN.1M.305.XLM Panel cut-out (page 22). Note: Ls = standard gender, Lr = reverse gender 12 www.lemo.com ® ® PH● Free socket, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip and mold stop Reference Ls/Lr øA øC P øD øF øB M Dimensions (mm) Model Series A B C D F Ls Lr M P X PH● PH● PH● PH● PH● PH● PH● PH● 0M 1M 2M 3M TM 4M LM 5M 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 10.7 12.4 15.5 17.5 19.8 22.6 25.8 31.4 28.6 28.6 29.0 29.0 31.2 31.2 31.2 31.2 28.6 28.6 29.0 29.0 31.2 31.2 31.2 31.2 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PHN.1M.305.XLMT X 1.5 Panel cut-out (page 22). Note: Ls = standard gender, Lr = reverse gender Watertight model (unmated) HE● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W and X) for printed circuit, watertight (back panel mounting) Reference Ls/Lr 3 e H E maxi R N S2 øA P øC S1 Dimensions (mm) Model Series A C e HE● HE● HE● HE● HE● HE● HE● HE● 0M 1M 2M 3M TM 4M LM 5M 17 18 21 23 27 29 33 38 16.8 17.8 20.8 22.8 25.8 27.8 31.8 36.8 M13x0.75 M14x1.00 M17x1.00 M19x1.00 M22x1.00 M24x1.00 M28x1.00 M33x1.00 E H 5.0 5.08 5.0 7.62 5.0 8.89 5.0 10.16 4.0 12.70 4.0 13.97 4.0 16.51 4.0 20.32 Ls Lr N P R 20.8 20.8 20.8 20.8 24.6 24.6 24.6 24.6 21.0 21.0 21.0 21.0 24.6 24.6 24.6 24.6 16.8 16.8 16.8 16.8 19.9 19.9 19.9 19.9 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 13.8 13.8 13.8 13.8 16.9 16.9 16.9 16.9 S1 S2 11.5 12.5 15.5 17.5 20.5 22.5 26.5 31.5 14 16 18 20 23 25 29 34 Part number example: HEN.1M.305.XLNP Panel cut-out (page 22). PCB drilling pattern (page 23). Note: Ls = standard gender, Lr = reverse gender www.lemo.com 13 ® ® Alignment Key Alignment Key and Polarized Keying System M series connector model part numbers are composed of three letters. The LAST LETTER indicates the keys corresponding to a particular contact type. For example, straight plugs with N, P, R, U or W keys, are fitted with male contacts; whereas with S, T, V or X keys, plugs are fitted with female contacts. Sockets with N, P, R, U or W keys, are fitted with female contacts; whereas with S, T, V or X keys, sockets are fitted with male contacts. Angles Nb of keys N P ●●U ●●S ●●T 3 Model Nb of keys ●● ●● γ β γ 165° 150° 130° 155° 135° 30° 60° 100° 50° 90° α β W R ●●X ●● V ●● δ γ TM to 5M Front view of a socket 14 Colour code Contact type Plug Socket male female female male β 0M to 3M Model Front view of a socket ●● 5 blue yellow green red orange Angles Colour code α β γ δ 95° 105° 100° 110° 115° 115° 125° 120° 35° 30° 40° 35° 25° 20° 20° 25° blue yellow red orange Contact type Plug Socket male female female male www.lemo.com ® ® Insert configuration Multipole AWG Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Rated current (A)1) Contact type Print (straight)2) 2 Crimp 3 ø A (mm) 1 Number of contacts 4 3 Reference 4 2 302 2 0.9 ● ● 20-22-24 1.45 1.00 10.0 303 3 0.9 ● ● 20-22-24 1.70 1.40 8.0 304 4 0.7 ● ● 22-24-26 1.35 0.90 7.0 305 5 0.7 ● ● 22-24-26 1.25 1.00 6.5 305 5 0.9 ● ● 20-22-24 1.30 1.30 9.0 307 7 0.7 ● ● 22-24-26 1.45 1.20 7.0 308 8 0.7 ● ● 22-24-26 1.30 1.10 5.0 308 8 0.9 ● ● 20-22-24 1.95 1.10 10.0 310 10 0.9 ● ● 20-22-24 1.80 1.20 8.0 312 12 0.7 ● ● 22-24-26 1.65 1.15 7.0 319 19 0.7 ● ● 22-24-26 1.20 1.00 4.0 322 22 0.7 ● ● 22-24-26 330 30 0.7 ● ● 22-24-26 1.10 1.00 3.5 325 25 0.9 ● ● 20-22-24 340 40 0.7 ● ● 22-24-26 øA 1 Male crimp contacts for plug 0M 1M 2M 3M TM Female crimp contacts for sockets Note: 1) Test voltage according to IEC 60512-2 test 4a. 2) For EG•, EC•, ED•, HE• socket. www.lemo.com 15 ® ® Female crimp contacts for sockets 4M 340 40 0.7 ● ● 22-24-26 348 48 0.7 ● ● 22-24-26 355 55 0.9 ● ● 20-22-24 368 68 0.7 ● ● 22-24-26 366 66 0.9 ● ● 20-22-24 114 114 0.7 ● ● 22-24-26 Rated current (A)1) Male crimp contacts for plug Test voltage (kV rms)1) Contact-shell AWG Contact type Print (straight)2) 2 Crimp 3 ø A (mm) 1 3 Number of contacts 4 2 Reference 4 øA 1 Test voltage (kV rms)1) Contact-contact Multipole 1.37 1.34 2.0 LM 5M Note: 1) Test voltage according to IEC 60512-2 test 4a. 2) For EG•, EC•, ED•, HE• socket. Housings Outer shell Ref. C X 16 Material Surface treatment Brass Aluminium alloy Chrome Nickel1) Note: 1) anthracite colour. www.lemo.com ® ® Contacts Crimp contacts for plugs, free or fixed sockets There are 2 forms of crimp barrels: – per fig. 1, the standard design – per fig. 2, with reduced crimp barrel for small conductors. Fig. 1 øC øA øC Contact type Ref. C B D øA M P N øA øC øA øC Contact type Ref. Male crimp (fig. 1) Male crimp (fig. 2) Male straight print Fig. 2 Female crimp (fig. 1) Female crimp (fig. 2) Female straight print Dimension of crimp barrels Contact Type 0M 302-303 304-305 1M 305 307-308 2M 308-310 312-319 3M 322-330 TM 325 340 4M 340-348 LM 355 368 5M 366 114 Ref. contact type ø A ø C Form (mm) (mm) per fig. Male Female Conductor AWG Section (mm2) min. max. min. max. Part number For male contacts For female contacts 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 C B C B M P M P 24 26 26 32 20 22 22 28 0.204 0.128 0.128 0.032 0.616 0.382 0.382 0.092 FGN.0M.560.ZZC FGN.0M.561.ZZC FGN.0M.555.ZZC FGN.0M.556.ZZC EGN.0M.660.ZZM EGN.0M.661.ZZM EGN.0M.655.ZZM EGN.0M.656.ZZM 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 C B C B M P M P 24 26 26 32 20 22 22 28 0.204 0.128 0.128 0.032 0.616 0.382 0.382 0.092 FGN.0M.560.ZZC FGN.0M.561.ZZC FGN.0M.555.ZZC FGN.0M.556.ZZC EGN.0M.660.ZZM EGN.0M.661.ZZM EGN.0M.655.ZZM EGN.0M.656.ZZM 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 C B C B M P M P 24 26 26 32 20 22 22 28 0.204 0.128 0.128 0.032 0.616 0.382 0.382 0.092 FGN.0M.560.ZZC FGN.0M.561.ZZC FGN.0M.555.ZZC FGN.0M.556.ZZC EGN.0M.660.ZZM EGN.0M.661.ZZM EGN.0M.655.ZZM EGN.0M.656.ZZM 0.7 0.7 0.87 0.44 1 2 C B M P 26 32 22 28 0.128 0.382 0.032 0.092 FGN.0M.555.ZZC FGN.0M.556.ZZC EGN.0M.655.ZZM EGN.0M.656.ZZM 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 C B C B M P M P 24 26 26 32 20 22 22 28 0.204 0.128 0.128 0.032 0.616 0.382 0.382 0.092 FGN.0M.560.ZZC FGN.0M.561.ZZC FGN.0M.555.ZZC FGN.0M.556.ZZC EGW.TM.660.ZZM EGW.TM.661.ZZM EGW.TM.655.ZZM EGW.TM.656.ZZM 0.7 0.7 0.87 0.44 1 2 C B M P 26 32 22 28 0.128 0.382 0.032 0.092 FGN.0M.555.ZZC FGN.0M.556.ZZC EGW.TM.655.ZZM EGW.TM.656.ZZM 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 C B C B M P M P 24 26 26 32 20 22 22 28 0.204 0.128 0.128 0.032 0.616 0.382 0.382 0.092 FGN.0M.560.ZZC FGN.0M.561.ZZC FGN.0M.555.ZZC FGN.0M.556.ZZC EGW.TM.660.ZZM EGW.TM.661.ZZM EGW.TM.655.ZZM EGW.TM.656.ZZM 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 C B C B M P M P 24 26 26 32 20 22 22 28 0.204 0.128 0.128 0.032 0.616 0.382 0.382 0.092 FGN.0M.560.ZZC FGN.0M.561.ZZC FGN.0M.555.ZZC FGN.0M.556.ZZC EGW.TM.660.ZZM EGW.TM.661.ZZM EGW.TM.655.ZZM EGW.TM.656.ZZM Note: according to IEC 60352-2 standard, it is strongly not recommended to crimp monostrand cables. www.lemo.com 17 ® ® Accessories BMF Blanking caps for plugs L Part number N øA P øC X sliding loop BMF.0M.100.XAV BMF.1M.100.XAV BMF.2M.100.XAV BMF.3M.100.XAV BMF.TM.100.XAV BMF.4M.100.XAV BMF.LM.100.XAV BMF.5M.100.XAV A 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 Dimensions (mm) C L N P 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 24.6 24.6 24.6 24.6 31.1 31.1 31.1 31.1 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 X 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 Note: this cap is suitable for use with any alignment key configuration. BGF Blanking caps for plugs L Part number N øA P øC X sliding loop BGF.0M.100.XAV BGF.1M.100.XAV BGF.2M.100.XAV BGF.3M.100.XAV BGF.TM.100.XAV BGF.4M.100.XAV BGF.LM.100.XAV BGF.5M.100.XAV A 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 Dimensions (mm) C L N P 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 24.6 24.6 24.6 24.6 31.1 31.1 31.1 31.1 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 X 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 Note: this cap is suitable for use with any alignment key configuration. BME Blanking caps for fixed sockets L Part number N ø 3.5 øA P øC X BME.0M.200.XAZ BME.1M.200.XAZ BME.2M.200.XAZ BME.3M.200.XAZ BME.TM.200.XAZ BME.4M.200.XAZ BME.LM.200.XAZ BME.5M.200.XAZ A 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 Dimensions (mm) C L N P 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 23.4 23.4 23.4 23.4 31.0 31.0 31.0 31.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 X 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 Note: this cap is suitable for use with any alignment key configuration. 18 www.lemo.com ® ® BMF Blanking caps for free sockets L Part number N øA P øC X sliding loop BMF.0M.200.XAZ BMF.1M.200.XAZ BMF.2M.200.XAZ BMF.3M.200.XAZ BMF.TM.200.XAZ BMF.4M.200.XAZ BMF.LM.200.XAZ BMF.5M.200.XAZ A 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 Dimensions (mm) C L N P 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 23.4 23.4 23.4 23.4 31.0 31.0 31.0 31.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 X 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 Note: this cap is suitable for use with any alignment key configuration. BGE Blanking caps for fixed sockets L Part number N øA P øC X ø 3.5 BGE.0M.200.XAZ BGE.1M.200.XAZ BGE.2M.200.XAZ BGE.3M.200.XAZ BGE.TM.200.XAZ BGE.4M.200.XAZ BGE.LM.200.XAZ BGE.5M.200.XAZ A 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 Dimensions (mm) C L N P 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 23.4 23.4 23.4 23.4 31.0 31.0 31.0 31.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 X 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 Note: this cap is suitable for use with any alignment key configuration. BGF Blanking caps for free sockets L Part number N sliding loop øA P øC X BGF.0M.200.XAZ BGF.1M.200.XAZ BGF.2M.200.XAZ BGF.3M.200.XAZ BGF.TM.200.XAZ BGF.4M.200.XAZ BGF.LM.200.XAZ BGF.5M.200.XAZ A 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 Dimensions (mm) C L N P 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 23.4 23.4 23.4 23.4 31.0 31.0 31.0 31.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 X 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 Note: this cap is suitable for use with any alignment key configuration. www.lemo.com 19 ® ® GEA Hexagonal nuts for EC ● model Part number A 0M 1M 2M 3M TM 4M LM 5M GEA.0M.241.RL GEA.0E.240.RL GEA.2M.241.RL GEA.3M.241.RL GEA.TM.241.RL GEA.4M.241.RL GEA.LM.241.RL GEA.5M.241.RL L øB e Series A 16 17 19 25 25 30 32 37 Dimensions (mm) B e L 18.2 19.2 21.5 22.0 28.0 34.0 36.0 41.0 M13x0.75 M14x1.00 M17x1.00 M19x1.00 M22x1.00 M24x1.00 M28x1.00 M33x1.00 2.5 2.5 3.0 3.0 3.0 3.0 3.0 3.0 ● Material: Nickel-plated brass (3 µm) GEA Hexagonal nuts for EG ● model Part number A GEA.0S.240.RL GEA.1M.240.RL GEA.0E.240.RL GEA.1E.240.RL GEA.3S.240.RL GEA.4M.240.RL GEA.3S.240.RL GEA.5M.240.RL L øB e Series 0M 1M 2M 3M TM 4M LM 5M A 11 13 17 19 22 25 30 36 Dimensions (mm) B e L 12.4 14.5 19.2 21.5 25.0 28.0 34.0 40.5 M9x0.60 M11x1.00 M14x1.00 M16x1.00 M18x1.00 M21x1.00 M24x1.00 M30x1.00 2.0 2.5 2.5 3.0 3.0 4.0 5.0 5.0 ● Material: Nickel-plated brass (3 µm) GEC Conical nut for models HE ●, EC ●, PE ● Part number Series A L øB e GEC.0M.240.RN GEC.0E.240.RN GEC.2M.240.RN GEC.3M.240.RN GEC.TM.240.RN GEC.4M.240.RN GEC.LM.240.RN GEC.5M.240.RN 0M 1M 2M 3M TM 4M LM 5M A 14 16 18 20 23 25 29 34 Dimensions (mm) B e L 17 18 21 23 27 29 33 38 M13x0.75 M14x1.00 M17x1.00 M19x1.00 M22x1.00 M24x1.00 M28x1.00 M33x1.00 3.2 3.0 3.2 3.2 5.0 5.0 5.0 5.0 ● Material: Anodized aluminium alloy Straight boot BEFORE HEATING Elbow boot Heatshrink boot BEFORE HEATING Part number Supplier Straight AFTER HEATING AFTER HEATING Raychem® 202A111-25/86 202A121-25/86 202A142-25/86 Series Cable ø min. (mm) 0M-2M 2M-4M 4M-5M 3.8 5.3 7.4 Elbow 90° 222A111-25/86 222A121-25/86 222A142-25/86 Note: request modified elastomer resistant to fluids with hot melt sealant. 20 www.lemo.com ® ® Tooling DCE Positioners for crimp contacts Type 0M Contact Positioners part number ø A ø C Form (mm) (mm) per fig. For male contacts For female contacts 302-303 304-305 male female 1M These positioners are suitable for use with both manual and pneumatic crimping tools according to the MIL-C-22520/7-01 standard. 307-308 2M Fig. 1 øA øA øC øC 305 308-310 312-319 3M 322-330 TM 325 340 Fig. 2 øA 4M 340-348 LM 355 øC 368 øA øC 5M 366 114 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 0.7 0.7 0.87 0.44 1 2 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 0.7 0.7 0.87 0.44 1 2 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 0.9 0.9 0.7 0.7 1.10 0.87 0.87 0.44 1 2 1 2 DCE.91.090.5MVC DCE.91.090.3MVM DCE.91.070.5MVC DCE.91.070.3MVM DCE.91.090.5MVC DCE.91.090.3MVM DCE.91.070.5MVC DCE.91.070.3MVM DCE.91.090.5MVC DCE.91.090.3MVM DCE.91.070.5MVC DCE.91.070.3MVM DCE.91.070.5MVC DCE.91.070.3MVM DCE.91.090.5MVC DCE.91.09T.5MVM DCE.91.070.5MVC DCE.91.07T.5MVM DCE.91.070.5MVC DCE.91.07T.5MVM DCE.91.090.5MVC DCE.91.09T.5MVM DCE.91.070.5MVC DCE.91.07T.5MVM DCE.91.090.5MVC DCE.91.09T.5MVM DCE.91.070.5MVC DCE.91.07T.5MVM Note: a wide variation of strand number and diameter combinations are quoted as being AWG, some of which do not have a large enough cross section to guarantee a crimp as per either MIL-C-22520/1-01 or /7-01. Our technical department is at your disposal to study and propose a solution to all your applications. DCF Extractors for crimp contacts Contact ø 0.9 0.7 Part number DCF.93.090.4LT DCF.93.070.4LT Note: this model is used for male and female contacts. www.lemo.com 21 ® ® Panel Cut-out Panel cut-outs ED● -PV● -PF● PB● + 0.1 0 øA + 0.1 0 + 0.1 0 øA H øA B + 0.1 0 + 0.1 0 + 0.1 0 H H EG● -EC● -HE● -PE● + 0.1 0 B B Cut-outs Series 0M 1M 2M 3M TM 4M LM 5M EG● øA B EC● øA B HE● øA B PE● øA B øA ED● B H øA PB● B H øA PV● B H øA PF● B H 9.1 11.1 14.1 16.1 18.1 21.1 24.1 30.1 13.1 14.1 17.1 19.1 22.1 24.1 28.1 33.1 13.1 14.1 17.1 19.1 22.1 24.1 28.1 33.1 13.1 14.1 17.1 19.1 22.1 24.1 28.1 33.1 5.1 6.1 9.1 11.1 12.5 14.1 18.1 23.2 M2.5 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 11.0 12.9 15.1 16.4 18.3 20.6 23.0 27.0 14.8 16.8 19.8 21.8 24.8 27.8 30.8 37.8 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 21.4 23.4 26.4 29.0 32.5 35.0 38.0 45.0 14.8 16.8 19.8 21.8 24.8 27.8 30.8 37.8 M2.5 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 15.1 18.3 20.6 23.0 24.6 27.0 25.4 34.9 10.8 12.5 15.6 18.1 19.9 22.7 25.9 33.1 M2.5 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 11.0 12.9 15.1 16.6 18.3 20.6 23.0 29.4 8.3 9.6 12.6 14.6 16.6 19.6 22.6 28.6 11.6 12.6 15.6 17.6 20.6 22.6 26.6 31.6 11.6 12.6 15.6 17.6 20.6 22.6 26.6 31.6 11.6 12.6 15.6 17.6 20.6 22.6 26.6 31.6 Mounting nut torque (on panel) Series Torque (Nm) Series Torque (Nm) 0M 1M 2M 3M 1.0 1.5 2.0 2.5 TM 4M LM 5M 4.0 5.0 6.5 8.0 22 www.lemo.com ® ® PCB drilling pattern Fixed socket with straight print contact (HE● ) 4xø1 ° 72 +0.1 0 90° 5.08 +0.1 0 ø 2.8 45° 4xø1 5.08 ø 2.3 12 0° 5.08 ø 2.2 0M.305 0M.304 +0.1 0 4xø1 ø 2.5 0M.303 +0.1 0 4xø1 5.08 0M.302 1M.307 5 x ø 0.8 ° ø 3.7 +0.1 0 5 6' 1°2 +0.1 0 7 x ø 0.8 +0.1 0 8 x ø 0.8 ° 15° 4xø1 +0.1 0 ø 6.7 19 x ø 0.8 +0.1 0 TM.325 11°15' +0.1 0 4xø1 4xø1 +0.1 0 40° +0.1 0 24° ' ø 9.8 +0.1 0 12.7 ø 5.8 11.43 ø9 ø 5.7 4xø1 2.2 11.43 ø5 ø 8.8 25° 22° 43 ' +0.1 0 +0.1 0 ° 60 ° 30 +0.1 0 36° 30 45 4xø1 +0.1 0 ø 6.5 3M.330 22°30' 12°52' 5° 90° 8.89 ø 6.3 12 x ø 0.8 3M.322 22°30' 4 x ø 1 ø 2.8 4 +0.1 0 4xø1 ° 2M.319 45° +0.1 0 ø 2.19 ° 45 10 x ø 0.8 45 +0.1 0 8 x ø 0.8 2M.312 22°30' 4 x ø 1 +0.1 0 8.89 2M.310 4xø1 7.62 7.62 5 x ø 0.8 +0.1 0 2M.308 1M.308 4xø1 30° 60 ø 3.4 ° 72 +0.1 0 7.62 4xø1 +0.1 0 8.89 4 x ø 0.8 ø 6.4 1M.305 +0.1 0 8.89 3 x ø 0.8 ø 3.5 +0.1 0 ø 3.8 2 x ø 0.8 22 x ø 0.8 30 x ø 0.8 +0.1 0 TM.340 2.6 +0.1 0 25 x ø 0.8 4M.340 +0.1 0 4M.348 8°10'55'' 40 x ø 0.8 +0.1 0 '' '49 21 13.97 ø 11.9 +0.1 0 48 x ø 0.8 www.lemo.com ø 8.5 45 ° ø 1.9 22°30' ø 5.2 12° 16 ° 24 ° +0.1 0 13.97 ø 7.94 12.7 9° 27°4 1'3 2 18° 40 x ø 0.8 4xø1 120 ° 6' ø 11.64 2 51° '' ø 6.8 27° 41 '3 18° 9° +0.1 0 ø 10.2 2'' 4xø1 ø 4.24 ° ø 3.4 60 +0.1 0 23 ® LM.355 LM.368 6°40’ 7°30’ 10°35’18’’ 5’’ ’3 4xø1 18° 4xø1 +0.1 0 ’’ 5M.366 5M.114 10° 16.51 ø15.5 ø8 ø11.75 ø 4.25 27° 41 ’30 +0.1 0 68 x ø 0.8 +0.1 0 5° 6°12’25’’ 4xø1 0’’ 4’5 °2 12 ’’ ’49 21 +0.1 0 8°10’55’’ +0.1 0 27°41'30'' 18°57' 66 x ø 0.8 20.7 20.32 ø 17.1 ø 13.5 ø 9.9 20.32 ø19.84 ø14.96 ø 10.08 16 ° 4xø1 12 0° 6°55'30'' ø 5.6 ' °26 51 ' 1 °5 13 13°51’ 16.51 ø15.3 ø11.1 ø 2.8 ø 6.9 55 x ø 0.8 1 +0.1 0 9° 8° 51°25’30’’ 36° 21 °1 0 ° 15 ’ °20 13 ø 2.7 ® +0.1 0 114 x ø 0.8 24° + 0.1 0 40° 24 www.lemo.com ® ® Product safety notice PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION. IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS SITUATIONS. 1. SHOCK AND FIRE HAZARD Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue (such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock. Mated components should never be disconnected while live as this may result in an exposed electric arc and local overheating, resulting in possible damage to components. 2. HANDLING Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect components should be rejected or returned to the factory for verification. Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used during installation and / or assembly in order to obtain safe and reliable performance. 3. USE Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to eliminate all risk of transmission of such voltages to any exposed metal part of the connector. 4. TEST AND OPERATING VOLTAGES The maximum admissible operating voltage depends upon the national or international standards in force for the application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the catalog however these may be influenced by PC board design and / or wiring harnesses. The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the test duration is 1 minute. 5. CE MARKING CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. 6. PRODUCT IMPROVEMENTS The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior notification. Data subject to change No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO reserve the right at all times to modify and improve specifications without any notification. www.lemo.com LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: (+43 1) 914 23 20 0 Fax:(+43 1) 914 23 20 11 sales@lemo.at NETHERLANDS / BELGIUM LEMO Connectors Benelux De Trompet 2108 1967 DC Heemskerk Tel. (+31) 251 25 78 20 Fax (+31) 251 25 78 21 info@lemo.nl CHINA LEMO Trading (Shanghai) Co., Ltd LEMO Electronics (Shanghai) Co., Ltd 5th Floor, Block 6, City of ELITE, 1000 Jinhai Road, Pudong Shanghai, China 201206 Tel: (+86 21) 5899 7721 Fax: (+86 21) 5899 7727 cn.sales@lemo.com NORWAY / ICELAND LEMO Norway A/S Stanseveien 6B 0975 Oslo Tel: (+47) 22 91 70 40 Fax: (+47) 22 91 70 41 info-no@lemo.com DENMARK LEMO Denmark A/S Gammel Mosevej 46 2820 Gentofte Tel: (+45) 45 20 44 00 Fax: (+45) 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: (+33 1) 60 94 60 94 Fax: (+33 1) 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: (+49 89) 42 77 03 Fax: (+49 89) 420 21 92 info@lemo.de HONG KONG LEMO Hong Kong Ltd Room 33. 7th Floor HITEC, 1 Trademart Drive Kowloon Bay - Hong Kong Tel: (+852) 2174 0468 Fax: (+852) 2174 0492 hk.sales@lemo.com HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: (+36 1) 421 47 10 Fax: (+36 1) 421 47 57 redelemo@lemo.hu ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: (+39 02) 66 71 10 46 Fax: (+39 02) 66 71 10 66 sales.it@lemo.com JAPAN LEMO Japan Ltd 4-10-3, Takaido Higashi, Suginami-ku, Tokyo, 168-0072 Tel: (+81 3) 53 44 39 33 Fax: (+81 3) 53 44 39 35 lemoinfo@lemo.co.jp LEMO SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: (+65) 6476 0672 Fax: (+65) 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO S.A. Brasil, 45, 08402 Granollers Barcelona Tel: (+34 93) 860 44 20 Fax: (+34 93) 879 10 77 info-es@lemo.com Madrid Office Antonio López, 96, 28019 Madrid Tel: (+34 91) 469 99 19 Fax: (+34 91) 469 99 59 SWEDEN / FINLAND LEMO Nordic AB Mariehällsvägen 39A 168 65 Bromma Tel: (+46 8) 635 60 60 Fax: (+46 8) 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B 6343 Rotkreuz Tel: (+41 41) 790 49 40 Fax: (+41 41) 790 49 43 ch.sales@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street Worthing West Sussex, BN11 1DU Tel: (+44 1903) 23 45 43 Fax: (+44 1903) 20 62 31 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: (+1 707) 578 88 11 (+1 800) 444 53 66 Fax:(+1 707) 578 08 69 info@lemousa.com DISTRIBUTORS AUSTRALIA, BRAZIL, CANADA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PAKISTAN, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA, TAIWAN, TURKEY, UKRAINE www.lemo.com © CAT.MM.LEN.P0811 - Pdf updated 02.08.2011 LEMO
EGN.0M.303.XLM 价格&库存
很抱歉,暂时无法提供与“EGN.0M.303.XLM”相匹配的价格&库存,您可以联系我们找货
EGN.0M.303.XLM
    库存:10
