EPL.0S.303.HLN
www.lemo.com
SUMMARY
# Wires
Low voltage
3
Image is for illustrative purpose only
Series
0S
Termination type
Female print 90° PCB
IP rating
50
AWG wire size
32.00 - 24.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FFA.0S.303.CLAC32
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EPL*: Elbow receptacle for printed circuit (solder or screw fixing)
Keying
Hermaphroditic keying (half moon insert) with female pin 1
Housing Material
PPS (Polyphenylene) shell, other pieces nickel plated [SAE AMS QQ N 290] brass
Weight
9.50 g
Performance
Configuration
0S.303 : 3 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.7 mm (0.028in)
R (max): 6.1 mOhm
Test Voltage(kV rms) 1.2
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +220°C
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
D
H
I
K
L
N
mm.
9
14.5
6.9
12.7
13.2
25
11.6
in.
0,35
0,57
0,27
0,50
0,52
0,98
0,46
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.0S.M09.4
2/2
很抱歉,暂时无法提供与“EPL.0S.303.HLN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+221.63835500+28.67231
