EZG.00.302.NLN
www.lemo.com
SUMMARY
# Wires
Low voltage
2
Image is for illustrative purpose only
Series
00
Termination type
Female print PCB
IP rating
50
AWG wire size
34.00 - 28.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FGG.00.302.CLAD35Z
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EZ*: Straight receptacle for printed circuit
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces
Weight
3.34 g
Performance
Configuration
00.302 : 2 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
3.5 Amps
Specifications
Contact Type: Print (straight)
Vtest (contact-shell): 950 V (AC), 1340 V (DC)
Vtest (contact-contact): 1000 V (AC), 1400 V (DC)
Others
Salt Spray Corrosion: >144 hr
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
DRAWINGS
Dimensions
A
B
H
K
N
mm.
6.8
7
5.08
7
14
in.
0,27
0,28
0,20
0,28
0,55
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“EZG.00.302.NLN”相匹配的价格&库存,您可以联系我们找货
