FGG.1T.305.CLAC60Z
www.lemo.com
SUMMARY
# Wires
Low
5
High
Coax
Triax
Quad
Fiber
Fluidic
Series
1T
Termination type
Male solder
IP rating
68
Cable Ø
5.60 - 6.00 mm
Status
active
Image is for illustrative purpose only
Download
Request a quote
Catalog
Alternative part
Matching parts
EGG.1T.305.CLL
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet and nut for fitting a bend relief
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces
Variant
Z : Nut for fitting a bend relief
Weight
17.03 g
Performance
Configuration
T.305 : 5 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
9 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Solid Conductor: 0.34 mm^2 (AWG 22)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
R (max): 4.8 mOhm
Vtest (contact-shell): 1150 V (AC), 1630 V (DC)
Vtest (contact-contact): 1250 V (AC), 1770 V (DC)
Others
Endurance (Shell): >3000 mating cycles
Temp (min / max): -55°C / +200°C
Humidity (max): 1000 hr
IP Rating: 68
DRAWINGS
Draws
Dimensions
A
L
M
S1
S2
mm.
12
45
34
11
9
in.
0.47
1.77
1.34
0.43
0.35
RECOMMENDED BY LEMO
2/3
Tools
None
Cables
3/3
很抱歉,暂时无法提供与“FGG.1T.305.CLAC60Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+468.99757
- 5+450.22142
- 10+431.46610
- 25+422.08323
