HGG.0T.309.CLLPV
www.lemo.com
SUMMARY
# Wires
Low
9
High
Coax
Triax
Quad
Fiber
Fluidic
Series
0T
Termination type
Female solder
IP rating
68
Cable Ø
1.00 - 6.50 mm
Status
active
Image is for illustrative purpose only
Download
Request a quote
Catalog
Alternative part
Matching parts
FGG.0T.309.CLAC50
TECHNICAL DETAILS
Mechanics
Shell Style/Model
HG*: Fixed socket, nut fixing, watertight or vacuumtight
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces
Variant
PV : Watertight / Vacuum-tested
Weight
4.77 g
Performance
Configuration
T.309 : 9 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.5 mm (0.02in)
Bucket Dia.: 0.45 mm (0.018in)
Max. Solid Conductor: 0.09 mm^2 (AWG 28)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Max. Stranded Conductor: 0.09 mm^2 (AWG 28)
R (max): 8.7 mOhm
Vtest (contact-shell): 500 V (AC), 710 V (DC)
Vtest (contact-contact): 600 V (AC), 850 V (DC)
Others
Endurance (Shell): >3000 mating cycles
Temp (min / max): -20°C / +80°C
Humidity (max): 1000 hr
IP Rating: 68
DRAWINGS
Draws
Dimensions
A
B
E
L
M
N
S1
S2
e
mm.
12
12.5
6.5
22
1.5
18.5
8.2
11
M9x0.6
in.
0.47
0.49
0.26
0.87
0.06
0.73
0.32
0.43
2/3
RECOMMENDED BY LEMO
Tools
None
Cables
CMN.09.T28.051PGCE
PVC
GREY
CMN.09.T28.051QGZE
TPR (medical)
Grey
CMN.09.T28.050CNQZ
CMN.09.T28.051PGZE
CMN.09.T28.051PNCE
Grey
PVC
Black
CMN.09.T28.051PNZE
3/3
很抱歉,暂时无法提供与“HGG.0T.309.CLLPV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+581.03218
- 5+557.79373
- 10+534.54515
- 25+522.93099
