FGG.0T.303.CLAC45Z
FGG.0T.303.CLAC45Z
    LEMO(雷莫)
    LEMO - FGG.0T.303.CLAC45Z - Circular Connector, 0T Series, Cable Mount Plug, 3 Contacts, Solder Pin,...
FGG.0T.303.CLAC45Z 数据手册
FGG.0T.303.CLAC45Z www.lemo.com SUMMARY # Wires Low voltage 3 Image is for illustrative purpose only Series 0T Termination type Male solder IP rating 68 AWG wire size 28.00 - 20.00 Cable Ø 4.10 - 4.50 mm Status active Matching parts EGG.0T.303.CLL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Performance Configuration T.303 : 3 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 8 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 1.0 mm (0.039in) Max. Solid Conductor: 0.56 mm^2 (AWG 20) Max. Stranded Conductor: 0.56 mm^2 (AWG 20) R (max): 4.8 mOhm Vtest (contact-shell): 900 V (AC), 1270 V (DC) Vtest (contact-contact): 1200 V (AC), 1700 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): >3000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 9.5 38 28 7.5 7 in. 0,37 1,50 1,10 0,30 0,28 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 130250 PVC Grey 30260 PVC Black 3280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.0T.303.CLAC45Z 价格&库存
很抱歉,暂时无法提供与“FGG.0T.303.CLAC45Z”相匹配的价格&库存,您可以联系我们找货
