FGG.0T.304.CLAC45Z
FGG.0T.304.CLAC45Z
    LEMO(雷莫)
    LEMO - FGG.0T.304.CLAC45Z - Circular Connector, 0T Series, Cable Mount Plug, 4 Contacts, Solder Pin,...
FGG.0T.304.CLAC45Z 数据手册
FGG.0T.304.CLAC45Z www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 0T Termination type Male solder IP rating 68 AWG wire size 30.00 - 22.00 Cable Ø 4.10 - 4.50 mm Status active Matching parts EGG.0T.304.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 8.16 g Performance Configuration T.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-contact): 850 V (AC), 1200 V (DC) Vtest (contact-shell): 700 V (AC), 1000 V (DC) Others Endurance (Shell): >3000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 9.5 38 28 7.5 7 in. 0,37 1,50 1,10 0,30 0,28 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 4280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.0T.304.CLAC45Z 价格&库存
很抱歉,暂时无法提供与“FGG.0T.304.CLAC45Z”相匹配的价格&库存,您可以联系我们找货
