FGG.1T.314.CLAC60Z
FGG.1T.314.CLAC60Z
    LEMO(雷莫)
    LEMO - FGG.1T.314.CLAC60Z - Circular Connector, 1T Series, Cable Mount Plug, 14 Contacts, Solder Pin...
FGG.1T.314.CLAC60Z 数据手册
FGG.1K.314.CLAK75Z www.lemo.com SUMMARY # Wires Low 14 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Image is for illustrative purpose only Download Request a quote Catalog Series Termination type Male solder IP rating 68 Cable Ø 7.10 - 7.50 mm Matching parts EGG.1K.314.CLL Status active Alternative part TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug with oversize cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Cable Fixing K75: 7.1 - 7.5 mm Variant Z : Nut for fitting a bend relief Performance Configuration Insulator L: PEEK (UL 94 / V-0/3.2, depends on material thickness) Rated Current 2 Amps Specifications Contact Type: Solder Max. Matings: 5000 Contact Dia.: 0.5 mm (0.02in) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Bucket Dia.: 0.45 mm (0.018in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.09 mm^2 (AWG 28) R (max): 8.7 mOhm Vtest (contact-shell): 1200 V (AC), 1700 V (DC) Vtest (contact-contact): 800 V (AC), 1130 V (DC) Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr Climatical Category: 50/175/21 Shielding (min): 95 dB (10 MHz) Shielding (min): 80 dB (1 GHz) IP Rating: 68 DRAWINGS Draws Dimensions A L M S2 mm. 13 42 28 9 in. 0,51 1,65 1,10 0,35 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools Spanner wrench: DCD.1E.008.PA090 Caps: BFG.1K.100.NAS Cables LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1T.314.CLAC60Z 价格&库存
很抱歉,暂时无法提供与“FGG.1T.314.CLAC60Z”相匹配的价格&库存,您可以联系我们找货
