EPG.1B.303.HLN
EPG.1B.303.HLN
    LEMO(雷莫)
    EPG.1B.303.HLN
EPG.1B.303.HLN 数据手册
® ® Acceptable cable diameters Series 00 0B 1B 2B 3B 4B 5B C type collet min. max. – – – – – – – – – – – – – – D type collet min. max. 1.1 1.5 3.1 4.1 5.1 9.1 9.6 3.4 5.5 7.5 9.7 11.7 16.0 25.0 Cable diameter range (mm) K type collet L type collet min. max. min. max. – – – – – – – – – – – – – – – – – – – – – – – – – – – – M type collet min. max. – – 2.2 1.5 4.1 5.1 – – – 3.0 4.0 5.0 9.0 – With heatshrink boot min. max. – – – – – – – – – – – – – – ® @@@@@@@@e? @@@@@@@@e? @@@@@@@@e? @@@@@@@@e?@@@@@@@@ @@@@@@@@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@g @@g @@g @@g @@g @@g @@@@@@@@ @@@@@@@@ Type @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ ?@@@@@@@@ ?@@@@@@@@ ® ?@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@@@@@@@ ?@@@@@@@@ Reference Number of contacts ø A (mm) Solder Crimp Print (straight) Print (elbow) Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Test voltage (kV rms)1) Contact-shell Rated current (A)1) Male crimp contacts Female crimp contacts 00 0B 1B ● First choice alternative ● Special order alternative Crimp contact 302 2 0.5 ● ● ● ● 1.00 0.95 1.15 1.20 5.0 303 3 0.5 ● ● ● ● 0.80 0.95 1.35 1.10 3.0 304 4 0.5 ● ● ● ● 0.80 0.65 1.05 1.05 2.0 302 2 0.9 ● ● ● ● 1.30 1.05 1.45 1.20 10.02) 303 3 0.9 ● ● ● ● 1.20 0.90 1.70 1.60 8.02) 304 4 0.7 ● ● ● ● 0.85 0.70 1.35 1.10 7.02) 305 5 0.7 ● ● ● ● 1.00 0.70 1.25 1.20 6.52) 306 6 0.5 ● ● ● ● 0.85 0.65 1.40 1.20 2.5 307 7 0.5 ● ● ● ● 0.80 0.70 1.40 1.20 2.5 309 9 0.5 ● ● ● ● 0.60 0.50 1.00 0.85 2.0 302 2 1.3 ● ● ● ● 1.50 1.35 1.70 1.45 15.03) 303 3 1.3 ● ● ● ● 1.30 1.55 1.60 1.85 304 4 0.9 ● ● ● ● 1.35 1.45 1.70 1.80 10.02) 305 5 0.9 ● ● ● ● 1.25 1.15 1.30 1.55 9.02) 306 6 0.7 ● ● ● ● 1.05 1.20 1.35 1.45 7.02) 307 7 0.7 ● ● ● ● 0.95 1.05 1.45 1.45 7.02) 308 8 0.7 ● ● ● ● 0.95 1.15 1.30 1.30 5.0 310 10 0.5 ● ● ● ● 0.90 1.50 1.20 1.80 2.5 314 14 0.5 ● ● ● ● 0.80 1.20 0.95 1.60 2.0 316 16 0.5 ● ● ● ● 0.80 1.25 0.95 1.60 1.5 Female solder contacts øA Male solder contacts Solder contact Contact type Note: 1) 2) 3) Test voltage (kV rms)1) Contact-contact øA Multipole 12.0 see calculation method, caution and suggested standard. rated current = 6A for socket with elbow (90°) contact for printed circuit. rated current = 12A for socket with elbow (90°) contact for printed circuit. ® ® øA Multipole Number of contacts ø A (mm) Solder Crimp Print (straight) Print (elbow) Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Female crimp contacts 2B 2 2.0 ● ● ● ● 2.10 1.75 2.85 2.70 30.03) 303 3 1.6 ● ● ● ● 2.40 1.85 1.90 1.90 17.03) 304 4 1.3 ● ● ● ● 1.85 1.85 2.20 2.20 15.03) 305 5 1.3 ● ● ● ● 1.75 1.60 2.15 2.15 14.03) 306 6 1.3 ● ● ● ● 1.35 1.45 2.00 2.35 12.0 307 7 1.3 ● ● ● ● 1.75 1.60 1.95 2.15 11.0 308 8 0.9 ● ● ● ● 1.50 1.25 1.95 1.95 10.02) 310 10 0.9 ● ● ● ● 1.45 1.30 1.80 2.10 8.02) 312 12 0.7 ● ● ● ● 1.25 1.35 1.65 2.00 7.02) 314 14 0.7 ● ● ● ● 1.15 1.35 1.55 1.95 6.52) 316 16 0.7 ● ● ● ● 0.95 1.25 1.55 1.75 6.0 318 18 0.7 ● ● ● ● 0.85 1.20 1.45 2.10 5.5 319 19 0.7 ● ● ● ● 0.95 1.25 1.55 1.65 5.0 326 26 0.5 ● ● ● – 0.95 1.30 1.20 1.80 2.0 332 32 0.5 ● ● ● – 0.80 0.95 1.60 1.5 ● First choice alternative ● Special order alternative Note: 1) 2) 3) 1.2 Rated current (A)1) Reference Male crimp contacts Crimp contact 302 Female solder contacts øA Male solder contacts Solder contact Contact type see calculation method, caution and suggested standard. rated current = 6A for socket with elbow (90°) contact for printed circuit. rated current = 12A for socket with elbow (90°) contact for printed circuit. ® ® Number of contacts ø A (mm) Solder Crimp Print (straight) Print (elbow) Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Test voltage (kV rms)1) Contact-contact Female crimp contacts 3B 2 3.0 ● ● ● – 2.10 1.55 2.30 1.80 50.0 303 3 2.0 ● ● ● – 1.90 1.50 3.20 2.65 25.0 304 4 2.0 ● ● ● – 1.45 1.25 2.50 2.20 19.0 305 5 1.6 ● ● ● – 1.90 1.25 2.40 1.75 19.0 306 6 1.6 ● ● ● – 1.60 1.15 1.90 1.80 17.0 307 7 1.6 ● ● ● – 1.70 1.25 2.00 2.05 15.0 308 8 1.3 ● ● ● ● 1.65 1.15 1.85 1.75 13.0 309 8 1 1.3 2.0 ● ● ● – 1.35 1.35 1.05 1.05 1.10 1.05 1.10 1.05 6.0 15.0 310 10 1.3 ● ● ● ● 1.25 0.90 1.50 1.80 12.0 312 12 0.9 ● ● ● ● 1.45 1.00 1.65 1.85 9.0 314 14 0.9 ● ● ● ● 1.20 1.20 1.80 1.65 9.02) 316 16 0.9 ● ● ● ● 1.20 0.85 1.80 1.50 8.0 318 18 0.9 ● ● ● ● 1.20 1.05 1.85 1.60 7.0 320 20 0.7 ● ● ● ● 1.00 0.90 1.35 1.55 6.0 322 22 0.7 ● ● ● ● 1.00 0.90 1.70 1.45 5.5 324 24 0.7 ● ● ● ● 0.95 0.80 1.35 1.35 4.0 326 26 0.7 ● ● ● ● 0.95 0.70 1.50 1.30 4.0 330 30 0.7 ● ● ● ● 0.80 0.70 1.35 1.20 3.5 ● First choice alternative ● Special order alternative Note: 1) 2) Rated current (A)1) Reference Male crimp contacts Crimp contact 302 Female solder contacts øA Male solder contacts Solder contact Contact type Test voltage (kV rms)1) Contact-shell øA Multipole see calculation method, caution and suggested standard. rated current = 6A for socket with elbow (90°) contact for printed circuit. ® ® øA Multipole Number of contacts ø A (mm) Solder Crimp Print (straight) Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Rated current (A)1) Female crimp contacts 4B ● First choice alternative ● Special order alternative Note: 1) Crimp contact Reference Male crimp contacts Solder contact 304 4 3.0 ● ● ● 2.10 1.50 1.80 1.20 30.0 306 6 2.0 ● ● ● 2.00 1.75 2.75 2.40 24.0 307 7 2.0 ● ● ● 2.00 1.80 1.50 1.35 20.0 310 10 1.6 ● ● ● 1.85 1.30 1.90 1.95 17.0 312 12 1.3 ● ● ● 1.45 1.60 1.90 1.85 12.0 316 16 0.9 ● ● ● 1.35 1.50 2.30 2.10 10.0 320 20 0.9 ● ● ● 1.35 1.00 1.05 0.95 8.0 324 24 0.9 ● ● ● 1.20 1.45 1.80 2.05 7.0 330 30 0.9 ● ● ● 0.95 0.85 1.75 1.45 5.0 340 40 0.7 ● ● ● 0.95 1.00 1.35 1.30 2.0 Female solder contacts øA Male solder contacts Contact type see calculation method, caution and suggested standard. ® ® øA Multipole Number of contacts ø A (mm) Solder Crimp Print (straight) Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Rated current (A)1) Female crimp contacts 5B ● First choice alternative ● Special order alternative Note: 1) Crimp contact Reference Male crimp contacts Solder contact 302 2 6.0 ● – – 3.60 2.95 – – 50.0 304 4 4.0 ● ● ● 2.95 2.65 3.20 2.40 35.0 310 10 3.0 ● ● ● 2.35 2.30 2.65 3.20 20.0 314 14 2.0 ● ● ● 2.35 2.00 2.85 2.95 18.0 316 16 2.0 ● ● ● 1.85 1.95 2.45 3.05 12.0 320 20 1.6 ● ● ● 1.90 1.70 2.20 2.40 10.0 330 30 1.3 ● ● ● 1.45 1.60 2.05 2.45 8.0 340 40 1.3 ● ● ● 1.30 1.45 2.00 1.95 7.0 348 48 1.3 ● ● ● 1.20 1.10 2.00 1.55 6.0 350 50 0.9 ● ● ● 1.30 1.60 1.20 1.45 6.0 354 54 0.9 ● ● ● 1.15 1.55 2.00 2.10 5.0 364 64 0.9 ● ● ● 1.30 1.55 1.35 1.85 3.0 Female solder contacts øA Male solder contacts Contact type see calculation method, caution and suggested standard. ® ® @@@@@@@@e? @@@@@@@@e? @@@@@@@@e? @@@@@@@@e?@@@@@@@@ @@@@@@@@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@g @@g @@g @@g @@g @@g @@@@@@@@ @@@@@@@@ Housings @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ ?@@@@@@@@ ?@@@@@@@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@@@@@@@ ?@@@@@@@@ Surface treatment Material Ref. C N K S T U L H G P P R X Brass Brass Brass Stainless steel Stainless steel Stainless steel1) Aluminium alloy2) PPS3)/brass PEEK4) PA.65) PSU6) PPSU7) Avional8) Outer shell and collet nut Latch sleeve and earthing crown Note chrome nickel black chrome without treatment without treatment without treatment anodized without treat./Ni without treatment without treatment without treatment without treatment nickel nickel nickel nickel nickel-plated brass stainless steel stainless steel nickel-plated brass nickel-plated brass nickel-plated brass nickel-plated brass nickel-plated brass nickel-plated brass nickel-plated brass ● ● ● ● ● ● ● ● ● ● ● ● ● @@@@@@@@e? @@@@@@@@e? @@@@@@@@e? @@@@@@@@e?@@@@@@@@ @@@@@@@@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@g @@g @@g @@g @@g @@g @@@@@@@@ @@@@@@@@ Material Ref. L Y PEEK PEEK ?@@@@@@@@ ?@@@@@@@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@@@@@@@ ?@@@@@@@@ 1) 2) @@ @@ @@ @@ @@ @@ @@ @@ ?@@@@@@@@ ?@@@@@@@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@@@@@@@ ?@@@@@@@@ Contacts for plugs, free or fixed sockets Male solder Male crimp (fig. 1)1) Male crimp (fig. 2)1) Male crimp (fig. 2)1) Female solder Ref. M P U N V Female crimp (fig. 1)1) Female crimp (fig. 2)1) Female crimp (fig. 2)1) Female straight print Female elbow print Contacts for couplers, plug with socket and bridge plug A C E Contact type Male - Female Male - Male Male - Male - Female Contacts Dimension of crimp barrels Contact Contact type Note: 1) there are two forms of crimp barrels. Please consult adjacent table for contact selection. Ref. Insulators Note: for solder or print contacts. only for crimp contacts. For the type 3B.309; 4B.304; 4B.307; 4B.320; 5B.304 and 5B.350 the reference shall be «L» instead of «Y». @@g @@g @@g @@g @@g @@g @@@@@@@@ @@@@@@@@ A C B G L ● Special order alternative 1) 2) @@ @@ @@ @@ @@ @@ @@ @@ Contact type ● First choice alternative Note @@@@@@@@e? @@@@@@@@e? @@@@@@@@e? @@@@@@@@e?@@@@@@@@ @@@@@@@@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ Ref. Note: 1) the other metallic parts are in stainless steel. 2) the «variant» position of the reference is used to specify the anodized colour. 3) only available for elbow (90°) sockets for printed circuit of the B and S series. 4) only available for FGG and ENG models of the B series. 5) only for CFF and CRG bridge plugs. 6) only available for ENY and FGY models of the B series. For the colour, see the «variant» position. 7) only available for ENY and FGY models of the B series. 8) anthracite colour. 0.5 0.7 0.9 1.3 Ref. Contact type 1.6 F L Female - Female - Male Female - Male 2.0 Note: the first contact type mentioned is always the one at the flange end. Ref. contact type ø A ø C Form (mm) (mm) per fig. 3.0 4.0 0.45 0.80 0.45 1.10 0.80 0.45 1.40 1.10 0.80 1.90 1.40 2.40 1.90 2.90 4.00 1 1 2 1 2 2 1 2 2 1 2 1 2 1 1 Male Female C C B C B G C B G C B C B C C M M P M P U M P U M P M P M M Conductor AWG Section (mm2) min. max. min. max. 32 26 32 24 26 32 20 24 26 18 22 16 18 14 12 28 22 28 20 22 28 18 20 22 14 18 12 14 10 10 0.035 0.140 0.035 0.250 0.140 0.035 0.500 0.250 0.140 1.000 0.340 1.500 1.000 2.500 4.000 0.09 0.34 0.09 0.50 0.34 0.09 1.00 0.50 0.34 1.50 1.00 2.50 1.50 4.00 6.00 ® @@@@@@@@e? @@@@@@@@e? @@@@@@@@e? @@@@@@@@e?@@@@@@@@ @@@@@@@@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@g @@g @@g @@g @@g @@g @@@@@@@@ @@@@@@@@ Collets @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ ?@@@@@@@@ ?@@@@@@@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@@@@@@@ ?@@@@@@@@ øB øA D and M type collets Reference 00 0B 1B 2B 3B Collet ø Cable ø Part number of the reducer 2) Part number of the reducing cone 2) Part number of the collet nut Type ø øA øB max. min. Part number of the collet 1) D D D D D 17 22 27 30 35 1.7 2.2 2.7 3.1 3.5 – – – 2.8 2.8 1.6 2.1 2.6 3.0 3.4 1.1 1.6 2.1 2.5 2.9 FGG.00.717.DN FGG.00.722.DN FGG.00.727.DN FGG.00.730.DN FGG.00.735.DN – – – – – – – – – – FGG.00.130.LC FGG.00.130.LC FGG.00.130.LC FGG.00.130.LC FGG.00.130.LC D D D D D 21 31 42 52 56 2.1 3.1 4.2 5.2 5.6 – – – 4.7 4.7 2.0 3.0 4.0 5.0 5.5 1.5 2.1 3.1 4.1 5.1 FGG.0B.721.DN FGG.0B.731.DN FGG.0B.742.DN FGG.0B.752.DN FGG.0B.756.DN 3) – – – – – – – – – – FGG.0B.130.LC FGG.0B.130.LC FGG.0B.130.LC FGG.0B.130.LC FGG.0B.132.LC M M D D D D D 27 31 42 52 62 72 76 2.7 3.1 4.2 5.2 6.2 7.2 7.6 – – – – – 6.7 6.7 2.6 3.0 4.0 5.0 6.0 7.0 7.5 2.2 2.6 3.1 4.1 5.1 6.1 7.1 FFC.00.727.CN FFC.00.731.CN FGG.1B.742.DN FGG.1B.752.DN FGG.1B.762.DN FGG.1B.772.DN FGG.1B.776.DN 3) FGG.1B.138.LN FGG.1B.138.LN – – – – FGG.1B.158.LN FGG.1B.158.LN – – – – – – FGG.1B.130.LC FGG.1B.130.LC FGG.1B.130.LC FGG.1B.130.LC FGG.1B.130.LC FGG.1B.130.LC FGG.1B.132.LC M M M D D D D D D 21 31 42 52 62 72 82 92 99 2.1 3.1 4.2 5.2 6.2 7.2 8.2 9.2 9.9 – – – – – – – 8.6 8.6 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0 9.7 1.5 2.1 3.1 4.1 5.1 6.1 7.1 8.1 9.1 FGG.0B.721.DN FGG.0B.731.DN FGG.0B.742.DN FGG.2B.752.DN FGG.2B.762.DN FGG.2B.772.DN FGG.2B.782.DN FGG.2B.792.DN FGG.2B.799.DN 3) FGG.2B.138.LN FGG.2B.138.LN FGG.2B.138.LN – – – – – – FGG.2B.158.LN FGG.2B.158.LN FGG.2B.158.LN – – – – – – FGG.2B.130.LC FGG.2B.130.LC FGG.2B.130.LC FGG.2B.130.LC FGG.2B.130.LC FGG.2B.130.LC FGG.2B.130.LC FGG.2B.130.LC FGG.2B.132.LC M D D D D D D D 52 62 72 82 92 10 11 12 5.2 6.2 7.2 8.2 9.2 10.2 11.2 11.9 – – – – – – 10.2 10.2 5.0 6.0 7.0 8.0 9.0 10.0 11.0 11.7 4.1 5.1 6.1 7.1 8.1 9.1 10.1 11.1 FGG.1B.752.DN FGG.3B.762.DN FGG.3B.772.DN FGG.3B.782.DN FGG.3B.792.DN FGG.3B.710.DN FGG.3B.711.DN FGG.3B.712.DN 3) FGG.3B.138.LN – – – – – – – FGG.3B.158.LN – – – – – – – FGG.3B.130.LC FGG.3B.130.LC FGG.3B.130.LC FGG.3B.130.LC FGG.3B.130.LC FGG.3B.130.LC FGG.3B.130.LC FGG.3B.132.LC Note: 1) for ordering collets separately. 2) for ordering an M type collet, a reducer and its reducing cone should also be ordered. 3) these collets cannot be used for connector models with nut for fitting a bend relief. All dimensions are in millimetres. ® ® ® øB øA D and M type collets Reference 4B 5B Collet ø Cable ø Part number of the collet 1) Part number of the reducer 2) Part number of the reducing cone 2) Part number of the collet nut Type ø øA øB max. min. M M M M D D D D D 62 72 82 92 10 12 13 15 16 6.2 7.2 8.2 9.2 10.8 12.3 13.8 15.3 16.3 – – – 8.6 – – 12.5 12.5 12.5 6.0 7.0 8.0 9.0 10.5 12.0 13.5 15.0 16.0 5.1 6.1 7.1 8.1 9.1 10.6 12.1 13.6 15.1 FGG.2B.762.DN FGG.2B.772.DN FGG.2B.782.DN FGG.2B.792.DN FGG.4B.710.DN FGG.4B.712.DN FGG.4B.713.DN FGG.4B.715.DN FGG.4B.716.DN 3) FGG.4B.138.LN FGG.4B.138.LN FGG.4B.138.LN FGG.4B.138.LN – – – – – FGG.4B.158.LN FGG.4B.158.LN FGG.4B.158.LN FGG.4B.158.LN – – – – – FGG.4B.130.LC FGG.4B.130.LC FGG.4B.130.LC FGG.4B.130.LC FGG.4B.130.LC FGG.4B.130.LC FGG.4B.130.LC FGG.4B.130.LC FGG.4B.132.LC D D D D D D D D 11 13 15 17 19 21 23 25 11.8 13.8 15.8 17.8 19.8 21.8 23.8 25.3 – – – – – – 21.8 21.8 11.5 13.5 15.5 17.5 19.5 21.5 23.5 25.0 9.6 11.6 13.6 15.6 17.6 19.6 21.6 23.6 FGG.5B.711.DN FGG.5B.713.DN FGG.5B.715.DN FGG.5B.717.DN 3) FGG.5B.719.DN 3) FGG.5B.721.DN 3) FGG.5B.723.DN 3) FGG.5B.725.DN 3) – – – – – – – – – – – – – – – – FGG.5B.130.LC FGG.5B.130.LC FGG.5B.130.LC FGG.5B.130.LC FGG.5B.130.LC FGG.5B.130.LC FGG.5B.130.LC FGG.5B.132.LC Note: 1) for ordering collet separately. 2) for ordering an M type collet, a reducer and its reducing cone should also be ordered. 3) these collets cannot be used for connector models with collet nut for fitting a bend relief. Bend relief collet nut and bend relief Reference Part number of the collet nut Bend relief to be used 1) 17 to 35 FFM.00.131.LC GMA.00.●●●.●● GMB.00.●●●.●● D 21 to 52 FFM.0B.130.LC GMA.0B.●●●.●● M D 27 and 31 42 to 72 FFM.1B.130.LC FFM.1B.130.LC GMA.1B.●●●.●● GMA.1B.●●●.●● M M D 21 and 31 42 52 to 92 FFM.2B.132.LC FFM.2B.130.LC FFM.2B.130.LC GMA.0B.●●●.●● GMA.2B.●●●.●● GMA.2B.●●●.●● M D 52 62 to 11 FFM.3B.131.LC FFM.3B.130.LC GMA.1B.●●●.●● GMA.3B.●●●.●● M M D 62 and 72 82 and 92 10 to 15 FFM.4B.132.LC FFM.4B.130.LC FFM.4B.130.LC GMA.2B.●●●.●● GMA.4B.●●●.●● GMA.4B.●●●.●● D 11 to 15 FFM.5B.130.LC GMA.4B.●●●.●● Type ø 00 D 0B 1B 2B 3B 4B 5B Note: 1) the bend relief is to be ordered separately. All dimensions are in millimetres. ® @@@@@@@@e? @@@@@@@@e? @@@@@@@@e? @@@@@@@@e?@@@@@@@@ @@@@@@@@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@ @@ @@ @@ @@ @@ @@ @@ @@g @@g @@g @@g @@g @@g @@@@@@@@ @@@@@@@@ ® Variant @@ @@ @@ @@ @@ @@ @@ @@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@@@@@@@ ?@@@@@@@@ ?@@@@@@@@ ?@@@@@@@@ Colour of the bridge plug shells and connectors shell made of plastic material Anodized colour The «variant» position of the reference is used to specify the colour of the shell according to the table below. The «variant» position of the reference is used to specify the anodized colour according to the table below. Ref. A B1) G1) Colour blue white grey Ref. J M N Colour yellow brown black Ref. R S V Colour red orange green Note: 1) PSU connector shells are only available in white or grey colours. The variant position is also used to indicate epoxy filling of watertight and vacuumtight socket models, the reference P is used. Part number for connector with standard collet nut Ref. A J N Anodized colour blue yellow black Ref. R T V Anodized colour red natural green Part number for connector with collet nut for bend relief Ref. L X Anodized colour black natural Note: other anodizing colours are available for connectors with collet nut for bend relief. Please consult us. ® ® Alignment Key and Polarized Keying System β δ γ Y 3 α Front view of a socket Model ●● 5 β γ δ – – 00 0B 1B 0° 30° 60° – – – – 45° – – – – – 0° 30° 60° 90° 135° 145° 155° 45° 70° 80° 110° – – 0° 30° 60° 90° 135° 145° 155° 45° 70° 80° – – – 0° 30° α 45° 60° γ 95° 120° β 145° 37.5° α 52.5° γ 70° – – β 112.5° γ 100° Series 00 0B 1B α β γ δ – – – – – – – – – – – – Contact type Note 2B 3B 0° 30° 45° 60° 95° 120° 145° 37.5° 52.5° 70° – 126° 102° 4B 5B 0° 0° 30° 30° 45° 45° 60° 60° 95° 95° 120° 120° 145° 145° 37.5° 37.5° 52.5° 52.5° 70° 70° – – – – – – Plug Socket Coupler 1) male male male male male male male female female female female female female female female female female female male male male male male-female male-female male-female male-female male-female male-female male-female female-male female-male female-male female-male male female – Series ● ● ● ● ● ● ● ● ● ● ● ●2) Contact type 2B 3B 4B 5B Plug Socket Coupler 1) α β γ δ – – – – – – – – – – – – 95° 115° 20° 30° male female male-female Note β Nb of keys α Series Angles 1 2 2 2 2 2 2 2 2 2 2 ●● Angles G A ●●B ●●C ●●D ●●E ●●F ●●J ●●K ●●L ●●M ●● Series Angles α Nb of keys Angles Front view of a socket Model B series connector model part numbers are composed of three letters. The LAST LETTER indicates the key position and the contact type (male or female). For example, straight plugs with «G» key or A, B, C, D, E, F, R or Y keys, are fitted with male contacts, whereas with J, K, L, M keys, plugs are fitted with female contacts. Sockets with «G» key or A, B, C, D, E, F, R or Y keys, are fitted with female contacts; whereas with J, K, L, M keys, sockets are fitted with male contacts. γ R δ ●● Note: FTG, FGY, ENY models are not available with all the keys. Please consult pages corresponding to these models. For R●● and S●● models see explanations. 1) the first contact type mentioned is always the one at the flange end. 2) only FGY and ENY models are available. ● First choice alternative ● Special order alternative ● ® @@@@@@@@e? @@@@@@@@e? @@@@@@@@e? @@@@@@@@e?@@@@@@@@ @@@@@@@@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@h? @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@ @@g @@g @@g @@g @@g @@g @@@@@@@@ @@@@@@@@ ?@@@@@@@@ ?@@@@@@@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@ ?@@@@@@@@ ?@@@@@@@@ Models - Series FGG Straight plug, key (G) or keys (A…M and R), cable collet Reference ~L øA ~M S2 S1 Model Series FGG FGG FGG FGG FGG FGG FGG 001) 0B 1B 2B 3B 4B 5B Dimensions (mm) A L 6.4 28.5 9.5 36.0 12.0 43.0 15.0 50.0 18.0 58.0 25.0 75.0 35.0 103.0 M S1 S2 20.5 26.0 32.0 38.0 43.0 57.0 78.0 5.5 8.0 10.0 13.0 15.0 21.0 31.0 5 7 9 12 14 20 30 Note: 1) the surface design of the 00 series is different. FGG Straight plug, key (G) or keys (A…M), cable collet and nut for fitting a bend relief Reference ~L øA ~M S2 S1 Dimensions (mm) Model Series A L M S1 S2 FGG FGG FGG FGG FGG FGG 001) 0B 1B 2B 3B 4B 6.4 9.5 12.0 15.0 18.0 25.0 27.5 35.0 42.0 48.0 56.5 71.0 18.5 25.0 33.0 36.0 41.5 53.0 5.5 8.0 10.0 13.0 15.0 21.0 5 7 9 12 15 20 Note: 1) the surface design of the 00 series is different. The bend relief must be ordered separately. FCG Straight plug, key (G) or keys (A…L and R), cable collet and safety locking ring Reference ~L øA ~M S2 Dimensions (mm) Model Series A L M S1 S2 FCG FCG FCG 1B 4B 5B 12 25 35 43 75 103 32 57 78 10 21 31 9 20 30 S1 FFG Straight plug, non-latching, key (G) or keys (A…M), cable collet Reference ~L øA ~M S2 S1 Dimensions (mm) Model Series A L M S1 S2 FFG FFG FFG FFG FFG 0B 1B 2B 3B 4B 9.5 12.0 15.0 18.0 25.0 36 43 49 58 75 26 32 37 43 57 8 10 13 15 21 7 9 12 14 20 ® ® ® FNG Straight plug, key (G) or keys (A…M and R), cable collet and lanyard release Reference ~L B N øA ~M Dimensions (mm) Model Series A FNG FNG FNG FNG FNG FNG 0B 1B 2B 3B 4B 5B 9.5 12.0 15.0 18.0 25.0 35.0 B L 19.4 28.5 19.4 43.0 22.6 49.0 25.6 58.0 35.2 75.0 47.0 103.0 M N S1 S2 20.5 32.0 37.0 43.0 57.0 78.0 140 140 160 190 230 300 8 10 13 15 21 31 7 9 12 14 20 30 Note: cable material: stainless steel with PVC sheath. The outer shell of the FNG.0B model is similar to the FMG.0B model. S2 S1 FEG Straight plug, key (G) or keys (A…L), cable collet, front seal and nut for fitting a bend relief (IP 54 protection index when mated) Reference ~L øA ~M Model Series FEG FEG FEG 1B 2B 3B Dimensions (mm) A L M 13.5 42.0 33.0 16.5 48.0 36.0 19.0 56.5 41.5 S1 S2 10 13 15 9 12 15 Note: the bend relief must be ordered separately. S2 S1 FDG Straight plug, long version, key (G) or keys (A…L), cable collet Reference ~L Model Series A L M S1 S2 FDG FDG 1B 2B 12 15 68 79 57 67 10 13 9 12 øA ~M Dimensions (mm) S1 FYG Straight plug, conical shell, key (G) or keys (A…M), cable collet Reference Dimensions (mm) ~L ~M øA S2 S2 S1 Model Series A L M S1 S2 FYG 0B 15.5 36 26 8 7 ® ® FZG Straight plug for remote handling, key (G) or keys (A…L and R), cable collet Reference ~L øA ~M S2 S1 Dimensions (mm) Model Series A L M N S1 S2 S3 FZG FZG FZG FZG 2B 3B 4B 5B 20 22 30 40 49 58 75 103 37 43 57 78 15 18 25 35 13 15 21 31 12 14 20 30 15 18 25 35 S3 N FIG Straight plug for remote handling, key (G) or keys (A…L and R), special alignment mark, knurled handling surface, cable collet ~L Reference ~M S3 Model Series A L M N S1 S2 S3 FIG FIG FIG FIG 2B 3B 4B 5B 20 22 30 40 49 58 75 103 37 43 57 78 17.5 21.5 28.5 41.0 13 15 21 31 12 14 20 30 15 18 25 35 øA N FWG Fixed plug, nut fixing, key (G) or keys (A…L) L maxi N S3 Reference øA M e Model Series FWG FWG 1B 2B Dimensions (mm) A B e E L M N1) S1 FBG Fixed plug, nut fixing, round flange, key (G) or keys (A…L and R), screw fixing L maxi øG M E maxi øA e Reference øH S3 18.0 16.0 M12x1.0 3.0 24.9 17 24.8 10.5 14 19.5 19.5 M15x1.0 5.2 28.6 18 27.3 13.5 17 Note: 1) maximum length with crimp contacts S1 E maxi øB S1 øB S2 Dimensions (mm) Dimensions (mm) Model Series A B e FBG 5B 54 40 M35x1.0 E G H L M 9 3 47 61.5 44.5 ® FAG Fixed plug, non-latching, nut fixing, key (G) or keys (A…M and R) Reference L maxi Dimensions (mm) Model Series A B e E L M FAG FAG FAG FAG FAG FAG FAG 00 0B 1B 2B 3B 4B 5B 8 10 14 18 22 28 40 10.3 12.5 16.0 19.5 25.2 32.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 2.0 3.5 7.0 7.0 8.0 8.0 7.0 16.9 21.1 24.9 28.6 32.1 36.6 47.4 9.0 11.2 12.5 13.8 17.0 20.5 28.0 N1) S1 S3 15.5 19.8 23.3 26.8 30.3 34.8 43.8 9 11 14 17 22 30 – N øA M e øB S3 E maxi S1 6.3 8.2 10.5 13.5 16.5 23.5 33.5 Note: 1) maximum length with crimp contacts. The 5B series is delivered without locking washer or tapered washer and with a round nut. FHG Elbow (90°) plug, key (G) or keys (A…M and R), cable collet L S1 Reference ~H øA M S3 S2 D Model Series FHG FHG FHG FHG FHG FHG FHG 001) 0B 1B 2B 3B 4B 5B Dimensions (mm) A D 7.7 5.2 11.0 6.5 13.5 8.0 16.5 9.0 19.0 10.0 26.0 15.0 36.0 21.0 H L M S1 S2 S3 18 23 28 34 37 52 74 24.5 30.0 36.0 41.5 50.0 67.0 90.0 16.5 20.0 25.0 29.5 35.0 49.0 65.0 7 9 11 14 17 22 32 5 7 9 12 14 20 30 5.5 8.0 10.0 13.0 15.0 21.0 31.0 Note: 1) the surface design of the 00 series is different. FMG Elbow (90°) plug, key (G) or keys (A…M), cable collet and lanyard release L S1 ~H øA M Reference Dimensions (mm) S3 S2 Model Series A B H L M N FMG 0B 11 17 26 31.6 21.6 140 S1 S2 S3 10 7 8 Note: cable material: stainless steel with PVC sheath B N FKG Elbow (90°) plug for remote handling, key (G) or keys (A…L), special alignment mark, knurled handling surface, cable collet L S1 M ~H Reference S4 S3 S2 N Dimensions (mm) Model Series A H L M FKG FKG 3B 4B 25 51 37 52 50 67 35 49 N S1 S2 S3 S4 21.0 17 28.5 22 14 20 15 21 21 28 Note: dimension D is the same as for the FHG model. øA ® ® ® EGG Fixed socket, nut fixing, key (G) or keys (A…M and R) Reference L maxi N M øA e øB S3 S1 E maxi Dimensions (mm) Model Series A B e E L M EGG EGG EGG EGG EGG EGG EGG 00 0B 1B 2B 3B 4B 5B 8 10 14 18 22 28 40 10.3 12.5 16.0 19.5 25.0 32.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 5.5 7.0 7.5 8.5 11.5 12.0 11.0 15.5 20.7 23.0 26.7 30.7 35.7 43.5 1.0 1.2 1.5 1.8 2.0 2.5 3.0 N1) S1 13.7 19.1 21.1 24.6 28.1 32.6 39.6 6.3 8.2 10.5 13.5 16.5 23.5 33.5 S3 9 11 14 17 22 30 – Note: 1) maximum length with crimp contacts. The 5B series is delivered with a tapered washer and a round nut. ENG Fixed socket with earthing tag, nut fixing, key (G) or keys (A…M) L maxi Reference Dimensions (mm) N M øA e øB S3 E maxi S1 Model Series A B e E L M ENG ENG ENG ENG ENG 0B 1B2) 2B 3B 4B 10 14 18 22 28 12.5 16.0 19.5 25.0 32.0 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 7.0 7.5 8.5 11.5 12.0 20.7 23.0 26.7 30.7 35.7 1.2 1.5 1.8 2.0 2.5 Note: 1) 2) N1) S1 19.1 21.1 24.6 28.1 32.6 8.2 10.5 13.5 16.5 23.5 S3 11 14 17 22 30 maximum length with crimp contacts. for the 1B series the earthing tag is on the upper side. EKG Fixed socket, nut fixing, key (G) or keys (A…L and R), special alignment mark on the front L maxi N Reference øA e øB Dimensions (mm) M S3 E maxi S1 Model Series A B e E L M EKG EKG EKG EKG 2B 3B 4B 5B 18 22 28 40 19.5 25.0 32.0 40.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 8.5 11.5 12.0 11.0 26.7 30.7 35.7 43.5 1.8 2.0 2.5 3.0 N1) S1 24.6 28.1 32.6 39.6 13.5 16.5 23.5 33.5 Note: 1) maximum length with crimp contacts. The 5B series is delivered with a tapered washer and a round nut. ESG Fixed socket with two round nuts, key (G) or keys (A…L), long threaded shell (back panel mounting) L maxi N 3.2 mini øA e øB M E maxi S1 Reference Model Series ESG ESG 00 1B Dimensions (mm) A B e E L 9.5 9 M7x0.5 4.0 15.5 14.0 14 M12x1.0 8.0 23.0 Note: 1) maximum length with crimp contacts. M N1) S1 2 2 13.7 – 21.1 10.5 S3 17 22 30 – ® ® EHG Fixed socket, nut fixing, key (G) or keys (A…M and R), and protruding shell L maxi Reference N Model Series A B e E L M N1) EHG EHG EHG EHG EHG EHG 00 0B 1B 2B 3B 5B 8.8 10.0 14.0 18.0 22.0 40.0 10.3 12.5 16.0 19.5 25.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M35x1.0 2.0 2.5 4.2 5.2 4.2 2.5 15.5 19.5 21.7 22.7 30.7 43.5 8.5 12.5 12.0 12.5 12.5 28.5 13.7 19.1 20.8 24.3 27.8 40.3 S1 S3 øA M e øB S3 Dimensions (mm) E maxi S1 6.3 8.2 10.5 13.5 16.5 33.5 9 11 14 17 22 – Note: 1) maximum length with crimp contacts. The 5B series is delivered without locking washer or tapered washer and with a round nut. EJG Fixed socket, press or adhesive fit, key (G) or keys (A…M) L maxi Reference N øA øB M Model Series EJG EJG EJG 0B 1B 2B Dimensions (mm) A B L 9.2 8.35 20.7 12.5 11.20 23.0 16.5 14.00 26.7 M N1) 1.5 1.5 1.5 19.1 21.1 24.6 Note: 1) maximum length with crimp contacts. EBG Fixed socket, nut fixing, round flange, key (G) or keys (A…L and R), screw fixing (back panel mounting) Reference L maxi N Dimensions (mm) Model Series A EBG 5B 41 B e E H L M N1) S4 M e 34 43.5 5.0 39.6 37 S4 E maxi M 3 (4 x 90°) 54 M35x1.0 4.0 Note: 1) maximum length with crimp contacts. øA øB H EEG Fixed socket, nut fixing, key (G) or keys (A…M and R) (back panel mounting) L maxi Reference N P e M S2 E maxi øA øB S1 Dimensions (mm) Model Series A B e E L M N1) EEG EEG EEG EEG EEG EEG 00 0B 1B 2B 3B 5B 10 12 16 20 24 41 9.5 12.5 16.0 20.0 25.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M35x1.0 2.3 2.4 6.0 3.0 5.0 13.5 15.5 20.7 23.0 26.7 30.7 43.5 2.5 2.5 3.5 3.5 4.5 5.0 13.7 6.0 6.3 7.5 19.1 6.3 8.2 9.0 21.1 11.0 10.5 13.0 24.6 9.0 13.5 15.0 28.1 12.0 16.5 20.0 39.6 19.5 33.5 38.0 P Note: 1) maximum length with crimp contacts. The 3B and 5B series are delivered with a conical nut. The 5B series is delivered without locking washer or tapered washer. S1 S2 ® ® EFG Fixed socket, nut fixing, key (G) or keys (A…M), with two flats on the shell and O-ring (back panel mounting) L maxi N P øA Reference e øB M Model Series EFG 0B Dimensions (mm) N1) P S2 12 12.5 M9x0.6 5.5 20.7 2.5 19.1 9 8 A B e E L M Note: 1) maximum length with crimp contacts. E maxi S2 ECG Fixed socket with two nuts, key (G) or keys (A…M and R) (back panel mounting) Reference L maxi N øA M e øB S3 S1 E maxi Dimensions (mm) Model Series A B e E L M N1) S1 S3 ECG ECG ECG ECG ECG ECG ECG 00 0B 1B 2B 3B 4B 5B 10 12 16 20 24 30 41 9.5 12.5 16.0 20.0 25.0 32.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 4.3 5.5 6.0 6.5 9.0 10.0 9.0 13.7 20.7 23.0 26.7 30.7 35.7 43.5 2.5 2.5 3.5 3.5 4.5 4.5 5.0 13.7 19.1 21.1 24.6 28.1 32.6 39.6 6.3 8.2 10.5 13.5 16.5 23.5 33.5 9 11 14 17 22 30 – Note: 1) maximum length with crimp contacts. The 3B, 4B and 5B series are delivered with a conical nut. The 5B series is delivered with a tapered washer and a round nut. ECG Fixed socket with two nuts, key (G) or keys (A…F and R) and straight contact for printed circuit (back panel mounting) Reference L N M øA e øB S3 S1 E maxi Dimensions (mm) Model Series A B ECG ECG ECG ECG ECG ECG ECG 00 0B 1B 2B 3B 4B 5B 10 12 16 20 24 30 41 9.5 12.5 16.0 20.0 25.0 32.0 40.0 e E M7x0.5 4.3 M9x0.6 5.5 M12x1.0 6.0 M15x1.0 6.5 M18x1.0 9.0 M25x1.0 10.0 M35x1.0 9.0 M N S1 S3 2.5 2.5 3.5 3.5 4.5 4.5 5.0 13.7 16.4 19.8 21.8 25.8 29.8 36.8 6.3 8.2 10.5 13.5 16.5 23.5 33.5 9 11 14 17 22 30 – Note: this contact type is available for E●● socket models fitted with female contacts. Length «L» depends on the number of contacts. The 5B series is delivered with a tapered washer and a round nut. The 3B, 4B and 5B series are delivered with a conical nut. ECG Fixed socket with two nuts, key (G) or keys (A…F) with elbow (90°) contact for printed circuit (back panel mounting) Reference N M 20 mini E maxi 2 øB S1 e S3 øA L Dimensions (mm) Model Series A ECG ECG ECG ECG 0B 1B 2B 3B 12 16 20 24 B e E 12.5 M9x0.6 2.4 16.0 M12x1.0 6.0 20.0 M15x1.0 6.5 25.0 M18x1.0 9.0 M 2.5 3.5 3.5 4.5 N S1 max 18.3 8.2 20.3 10.5 22.3 13.5 25.8 16.5 S3 11 14 17 22 Note: this female contact type is available for all back panel mounting socket models. Length «L» depends on the number of contacts, see PCB drilling pattern. For male contacts, sockets are available upon request, with J, K or L keys. The 3B series is delivered with a conical nut. ® ® EZG Straight socket for printed circuit, key (G) or keys (A, B) Reference B 3 Model Series A B H K N EZG 00 6.8 7 5.08 7 14 H N ø 0.5 øA ø 0.7 Dimensions (mm) K EZG Straight socket for printed circuit, key (G) or keys (A…F) Reference Dimensions (mm) Model Series A EZG EZG EZG 0B 1B 2B 9 11 14 B H K N 8 8 9 15.0 19.0 22.5 L H N øA M 1.6 B 10 7.62 12 7.62 15 10.16 Note: Length «L» depends on the number of contacts. K EYG Fixed socket for printed circuit, nut fixing, key (G) or keys (A…F) (back panel mounting) Reference N L 9 P B S1 M 1.6 M 7.62 Model Series EYG EYG 0B 1B Dimensions (mm) A B C e E M N P 12 10 12.5 M9x0.6 2.6 2.5 15 6 8.2 14 12 16.0 M11x0.5 5.0 3.5 19 10 – øA e øC Note: Length «L» depends on the number of contacts. E maxi XPF Fixed socket, nut fixing, long shell, keys (F) for printed circuit (back panel mounting) N L Reference P 5.08 R E maxi Model Series XPF 0B Dimensions (mm) A B e E M N P R 12 11 M9x0.6 1.5 2.5 19 5 4 Note: Length «L» depends on the number of contacts. øA e øB M 1 S1 ® ® Elbow (90°) sockets for printed circuit These socket models are fixed onto the printed circuit either by soldering the four pins, or with 4 screws (M1.6) replacing the pins. EXG sockets are 2 nut fixing and are recommended in cases where a flexible printed circuit is used. Technical Characteristics Types Materials and Treatment Component Surface treat. (µm) Material Cu PPS Brass Brass Bronze PEEK Bronze 1) Housing Series Metallic parts Earthing crown Insulator Female contact Type 0.5 0.5 0.5 0.5 Ni – 3 3 3 – 3 Au – – – 1.5 1) not Note: used for all sizes. The surface treatment standards are as follows: – Nickel: FS QQ-N-290A. – Gold: ISO 4523 1 1 302 0B, 1B 2 2 1 2 1 303 0B, 1B 3 2 3 Electrical 1 4 3 2 3 1 4 2 3 Model Series EPG-XBG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG 00 0B 0B 0B 0B 0B 0B 1B 1B 1B 1B 1B 1B 1B 1B 1B Types 1 2 305 0B, 1B 1 5 4 2 3 0B, 1B 306 6 5 4 1 2 3 5 3 4 1 6 3 4 5 2 1 0B, 1B 7 307 2 3 1B 6 5 4 2 3 4 1 7 1 1B 6 2 7 5 4 8 308 1 2 7 3 8 6 4 5 10 310 1 8 2 9 7 3 10 6 4 5 5 3 4 9 8 6 7 6 5 302-303-304 302 303 304 305 306 307 302 303 304 305 306 307 308 310 314 Rated current (A) 304 0B, 1B Test voltage (kV rms)1) Contact-shell 2 Test voltage (kV rms)1) Contact-contact 1 1.00 1.45 1.70 1.30 1.25 1.25 1.00 1.70 1.60 1.70 1.30 1.35 1.45 1.30 1.00 1.00 1.00 1.20 1.60 1.10 1.20 1.20 1.00 1.45 1.85 1.80 1.55 1.45 1.45 1.30 1.00 1.30 2.0 4.5 4.5 4.5 4.5 2.5 2.0 4.5 4.5 4.5 4.5 4.5 2.0 2.0 1.5 1.0 Note: 1) see calculation method, caution and suggested standard. øA 5.08 EPG Elbow (90°) socket for printed circuit, key (G) or keys (A, B) Reference L EPG.00.302.NLN EPG.00.303.NLN EPG.00.304.NLN K 3 H I N ø 0.7 D A D 6.8 11 Dimensions (mm) H I K 3.5 7 7 L N 17.5 7 ® ® EPG Elbow (90°) socket for printed circuit, key (G) or keys (A…F) (solder or screw fixing) 2.54 7.62 Reference øA EPG.0B.302.HLN EPG.0B.303.HLN EPG.0B.304.HLN EPG.0B.305.HLN EPG.0B.306.HLN EPG.0B.307.HLN EPG.1B.302.HLN EPG.1B.303.HLN EPG.1B.304.HLN EPG.1B.305.HLN EPG.1B.306.HLN EPG.1B.307.HLN EPG.1B.308.HLN EPG.1B.310.HLN L N 3 H I K ø 0.7 M 1.6 D ø 0.7 2.54 A 9 D Dimensions (mm) H I K L N 14.5 6.9 12.7 13.2 25 11.6 11 16.5 7.7 14.0 13.2 27 12.6 Note: to replace the 4 ground pins by 4 screws (M1.6) add an «S» to the end of the part number. (e.g.: EPG.0B.307.HLNS) øA 12.7 EPG Elbow (90°) socket for printed circuit, key (G) or keys (A…F) (solder or screw fixing) L N Reference K EPG.1B.314.NLN D 11 21 Dimensions (mm) H I K L 7.7 14.3 19 N 36 15.4 Note: to replace the 4 ground pins by 4 screws (M1.6) add an «S» to the end of the part number. (e.g.: EPG.1B.314.NLNS) H I 3 A ø 0.7 ø 0.6 M 1.6 D XBG Elbow (90°) socket fixing nut for printed circuit, key (G) or keys (A, B) (back panel mounting) K 5.08 e M Reference XBG.00.302.NLN XBG.00.303.NLN XBG.00.304.NLN L P 3 H I øA N ø 0.7 E maxi D A D e Dimensions (mm) E H I K L 10 11.5 7x0.5 1.8 3.5 7 M N P 7 17.5 2.5 7 9 ® ® EXG Elbow (90°) socket for printed circuit with two nuts, key (G) or keys (A…F) (solder or screw fixing) (back panel mounting) 7.62 Reference K L S3 3 øB H I e M ø 0.7 M 1.6 E maxi D 2.54 øA N EXG.0B.302.HLN EXG.0B.303.HLN EXG.0B.304.HLN EXG.0B.305.HLN EXG.0B.306.HLN EXG.0B.307.HLN EXG.1B.302.HLN EXG.1B.303.HLN EXG.1B.304.HLN EXG.1B.305.HLN EXG.1B.306.HLN EXG.1B.307.HLN EXG.1B.308.HLN EXG.1B.310.HLN A B D e Dimensions (mm) E H I K L M N S3 12 12.5 14.5 M9x0.6 6.0 6.9 12.7 13.2 25 2.5 10.5 11 14 15.0 16.5 M11x0.5 7.5 7.7 14.0 13.2 27 3.5 14.0 13 Note: to replace the 4 ground pins by 4 screws (M1.6) add an «S» to the end of the part number. (e.g.: EXG.0B.307.HLNS). PHG Free socket, key (G) or keys (A…M and R), cable collet Reference øA ~L S2 S1 Dimensions (mm) Model Series A L S1 S2 PHG PHG PHG PHG PHG PHG PHG 001) 6.4 9.5 12.5 16.5 19.0 24.4 34.2 27.0 35.5 40.5 47.0 56.0 73.0 99.0 5.5 8.0 10.0 13.0 15.0 21.0 31.0 5 7 9 12 14 20 30 0B 1B 2B 3B 4B 5B Note: 1) the surface design of the 00 series is different. PHG Free socket, key (G) or keys (A…M), cable collet and nut for fitting a bend relief Reference øA ~L S2 Dimensions (mm) Model Series A L S1 S2 PHG PHG PHG PHG PHG PHG 001) 6.4 9.5 12.5 16.5 19.0 24.4 26.0 34.5 39.5 46.0 54.5 69.0 5.5 8.0 10.0 13.0 15.0 21.0 5 7 9 12 15 20 0B 1B 2B 3B 4B S1 Note: 1) the surface design of the 00 series is different. The bend relief must be ordered separately. ® ® PNG Free socket, nut fixing, key (G) or keys (A…L and R), cable collet with lanyard release Reference B N øA ~L Dimensions (mm) Model Series A B L N S1 S2 PNG PNG PNG PNG PNG 1B 2B 3B 4B 5B 12.5 16.5 19.0 26.0 36.0 20.0 24.2 26.6 36.2 48.0 40.5 47.0 56.0 73.0 99.0 140 160 190 230 300 10 13 15 21 31 9 12 14 20 30 Note: cable material: stainless steel with PVC sheath S2 S1 PKG Fixed socket, nut fixing, key (G) or keys (A…M and R), cable collet Reference ~L S3 S2 øB e øA M Dimensions (mm) Model Series A B e E L M S1 S2 S3 PKG PKG PKG PKG PKG PKG PKG 00 0B 1B 2B 3B 4B 5B 8 10 14 18 22 28 40 10.3 12.5 16.0 19.5 25.0 32.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 6.5 7.0 7.5 8.5 11.5 12.0 11.0 27.0 35.5 40.5 47.0 56.0 73.0 99.0 1.0 1.2 1.5 1.8 2.0 2.5 3.0 6.3 8.2 10.5 13.5 16.5 23.5 33.5 5 7 9 12 14 20 30 9 11 14 17 22 30 – S1 E maxi Note: the 5B series is delivered with a tapered washer and a round nut. PFG Fixed socket, with two nuts, key (G) or keys (A…M and R), cable collet (back panel mounting) Reference ~L M S2 øA e øB S3 S 1 E maxi Dimensions (mm) Model Series A B e E L M S1 S2 S3 PFG PFG PFG PFG PFG PFG PFG 00 0B 1B 2B 3B 4B 5B 8 12 16 20 24 30 41 10.3 12.5 16.0 20.0 25.0 32.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 5.3 5.0 5.0 6.5 9.0 11.0 10.0 27.0 35.5 40.5 47.0 56.0 73.0 99.0 2.5 2.5 3.5 3.5 4.5 4.5 5.0 6.3 8.2 10.5 13.5 16.5 23.5 33.5 5 7 9 12 14 20 30 9 11 14 17 22 30 – Note: the 3B, 4B and 5B series are delivered with a conical nut. The 5B series is delivered with a tapered washer and a round nut. PEG Fixed socket, nut fixing, key (G) or keys (A…L), cable collet (back panel mounting) Reference ~L P S2 E maxi Model Series A PEG PEG 3B 4B 24 32 B e E L M S1 56 73 4.5 16.5 5.0 23.5 S2 S4 P 14 20 20 27 12 20 S4 øA M e øB S1 Dimensions (mm) 22 M18x1.0 5.0 34 M25x1.0 12.5 Note: the 4B series has an o-ring on the flange. ® ® R ● ● Fixed coupler, nut fixing, key (G) or keys (A and J) at the flange end and keys (J, K or M) at the other end M E maxi S1 e øA S3 G Reference G Model RGG RGG 1) RGG 2) RJG RGJ RAK RGM RGG 2) RJG RGJ RJG RGJ RGJ RGJ G RJG J G RGJ J A RAK K G Dimensions (mm) Series Type 0B 0B female – female female – female male – female female – male female – male female – male female – female male – female female – male male – female female – male female – male female – male 0B 1B 1B 2B 3B 4B A B e E L M S1 S3 12 13.8 M10x0.75 12 13.8 M10x0.75 8.0 34 2.0 8.0 43 2.0 9.0 12 9.0 12 12 13.8 M10x0.75 8.0 34 2.0 9.0 12 16 19.5 M14x1.00 8.5 47 2.5 12.5 17 16 19.5 M14x1.00 8.5 39 2.5 12.5 17 20 21.8 M16x1.00 12.0 44 4.0 15.0 19 25 27.5 M20x1.00 32.0 53 4.0 18.5 24 34 32.0 M25x1.00 50.0 65 4.0 23.5 30 Note: 1) only available with two contacts. 2) only available with three contacts. For this fixed coupler, the first contact type mentioned is always the one at the flange end. On request, these couplers can be produced in other series, with other keys. RGM M Contacts øB L Models with microswitch Some sockets are available fitted with a microswitch. The microswitch is independent from the electrical contacts of the socket. The introduction of a plug into the socket activates the microswitch. EMG Fixed socket, nut fixing, microswitch, key (G) or keys (A…L) Reference Dimensions (mm) L M 1 2 øA e øB S3 3 S1 E maxi Series EMG EMG 0B 1B A B e E 10 12.5 M9x0.6 5.5 14 16.0 M12x1.0 7.0 L 35 38 M S1 S3 1.2 8.2 11 1.5 10.5 14 Note: only available with 2 or 3 contacts (type 302, 303), in 0B series Only available with 3 or 6 contacts (type 303, 306), in 1B series. For the microswitch: maximum operating voltage: 270 Veff/Vdc, rated current: 8.5A/0.5A. EMG Fixed socket, with two nuts, microswitch, key (G) or keys (A…L) L maxi S3 S1 Model M øA e 2 øB 3 Reference Dimensions (mm) 1 Model Series EMG 2B A B e E L M S1 S3 E maxi 2 3 1 20 19.5 M15x1.0 2.2 26.7 3.5 13.5 17 Note: for the microswitch: maximum operating voltage: 250 Veff/Vdc, rated current: 7A/0.25A. ® ® Bridge plug The LEMO audio-video connector system consists of two sockets, with or without microswitch, a bridge plug with or without output monitoring and a plug with or without bend relief. This system is already widely used in telecommunication equipment and in radio and television broadcasting centres. The connectors of this system are fully compatible with all other connector models of the same series and type. However, when designing systems it should be considered that the distance between the assembled nut-fixing models should correspond to that between the outputs of the bridge plug. In order to provide the user with a coding system, the bridge plug housing, the double panel washers and the bend reliefs are available in nine colours. Technical Characteristics Mechanical and Climatical Characteristics Electrical Value Standard Characteristics Contact resistance > 1000 cycles IEC 60512-5 test 9a maximum 90° C Endurance Working temperature Value < 6 mΩ 0.5 0.5 3 3 – 0.3 Rated current (A) Insulator Male contact Female contact 3 3 Test voltage (kV rms) 1) 2) Metallic parts – 0.5 0.5 Audio-Stereo Polyamide Brass Brass PEEK Brass Bronze Audio-Mono Cu Ni Cr Au Plastic housing 0B 0B 0B 0B 0B 1B 1B 1B 1B ● ● ● ● – ● ● – – – – – – ● – – ● ● 1.05 1.05 0.80 0.80 0.40 1.25 1.25 0.80 0.80 4 4 4 4 2 5 5 3 3 Characteristics Surface treat. (µm) Material – – – – 1.0 – 1.5 Note: the surface treatment standards are as follows: – Nickel: FS QQ-N-290A – Chrome: FS QQ-C-320B – Gold: ISO 4523 CFF.0B.302.PLCG CRG.0B.302.PLEG CFF.0B.303.PLCG CRG.0B.303.PLEG CRG.0B.306.PLEG CFF.1B.303.PLCG CRG.1B.303.PLEG CFF.1B.306.PLCG CRG.1B.306.PLEG IEC 60512-2 test 2a Series Materials and Treatment Component Standard Note: the last letter of the part number indicates the colour of the housing. Ex. G (standard) is grey. To obtain another colour, replace this letter by the letter corresponding to the selected colour. 1) see calculation method, caution and suggested standard. 2) lowest measured value; contact to contact or contact to shell. CFF Bridge plug with two non-latching plugs CRG Bridge plug with two non-latching plugs, and monitoring socket, key (G) or keys (A…M) M maxi A 1) N B H Reference L maxi Dimensions (mm) Model Series A B CFF-CRG CFF-CRG 0B 1B 13.5 15.0 14 20 H L M N 27.5 37.2 27.2 22.5 35.0 42.0 31.0 22.0 Note: 1) sockets are to be mounted with the keys mounted on the opposite side. ® ® Plugs with parallel sockets These plug models have been designed to divide one or more signals originating from the same source to two different points. They are used in various fields of application, particularly in audio signal transmission. FTG Straight plug, key (G) and two parallel sockets Reference FTG.0B.302.PLFG FTG.0B.303.PLFG FTG.0B.304.PLFG Technical Characteristics 27.8 12 24 Model FTG.0B.302.PLFG FTG.0B.303.PLFG FTG.0B.304.PLFG Nominal current (A) 15 Test voltage (kV rms) 1) 2) 37.8 Number of contacts Electrical 2 3 4 1.05 0.80 0.80 4 4 3 Materials and Treatment Component 3 2 2 1 4 2 3 Plastic housing Metallic parts 1 1 2 3 2 1 1 2 Type 302 2 Type 303 Surface treat. (µm) Cu Ni Cr Au 1 1 Material 3 4 1 3 2 1 4 2 3 Type 304 Insulator Male contact Female contact Polyamide Brass Special brass PEEK Brass Bronze – 0.5 0.5 3 3 0.5 0.5 3 3 – 0.3 – – – Note: 1) see calculation method, caution and suggested standard. 2) lowest measured value; contact to contact or contact to shell. The surface treatment standards are as follows: – Nickel: FS QQ-N-290A – Chrome: FS QQ-C-320B – Gold: ISO 4523 – 1.0 – 1.5 ® ® Plastic housing models FGG, FGY, ENG and ENY plug and socket models are available with the outer shell and collet nut made with various insulating materials. These connectors are particularly recommended for all applications requiring maximum electrical insulation when mated. The design, including a latch sleeve and a metal earthing crown, guarantees EMC screening efficiency to meet most requirements. Technical Characteristics Mechanical and Climatical Characteristics Value PSU PEEK Colour Endurance Humidity Temperature range Sterilization resistance 1) Resistance to solvents Standard PPSU natural (beige) > 5000 cycles white or grey cream – > 5000 cycles > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C – - 50° C/+250° C - 50° C/+150° C - 50° C/+180° C – > 200 cycles ~20 cycles > 100 cycles IEC 60601-1 § 44.7 very good limited good – Note: 1) Steam sterilization FGG Straight plug, key (G or J), cable collet, PEEK outer shell Reference ~L øA ~M Model Series FGG FGG FGG 1B 3B 4B Dimensions (mm) A L M 13.5 43.0 32.0 19.0 62.0 47.0 26.0 78.5 60.5 S2 10 15 20 Note: model also available with a nut for fitting a bend relief S2 FGY Straight plug, keys (Y), cable collet and PSU or PPSU outer shell Reference ~L Model Series FGY FGY 2B 3B A L M 16.5 50.5 39.5 19.0 58.0 43.0 S2 13 15 øA ~M Dimensions (mm) S2 FGY Straight plug, keys (Y), cable collet and PSU or PPSU outer shell and nut for fitting a bend relief Reference ~L øA ~M S2 Model Series FGY FGY 2B 3B Dimensions (mm) A L M 16.5 49.5 38.5 19.0 56.5 41.5 S2 13 15 Note: the bend relief must be ordered separately. ® ® ENG Fixed socket with earthing tag, nut fixing, key (G or J), PEEK outer shell L maxi N øA e øB Reference Dimensions (mm) M S3 E maxi S1 Model Series ENG ENG ENG 1B 3B 4B A B e E L M N1) S1 S3 14 16.0 M12x1.0 7.5 23.0 1.5 21.1 10.5 14 22 25.0 M18x1.0 11.5 30.7 2.0 28.1 16.5 22 28 32.0 M25x1.0 12.0 35.7 2.5 32.6 23.5 30 Note: 1) maximum length with crimp contacts. ENY Fixed socket with earthing tag, nut fixing, keys (Y), PSU or PPSU outer shell L maxi N M øA e øB S3 E maxi S1 Note: other models with plastic outer shell are available on request. Reference Model Series ENY ENY 2B 3B Dimensions (mm) A B e E L M N1) S1 S3 18 19.5 M15x1.0 8.5 26.7 1.8 24.6 13.5 17 22 25.0 M18x1.0 11.5 30.7 2.0 28.1 16.5 22 Note: 1) maximum length with crimp contacts. ® ® Watertight or vacuumtight models YHG, HGG, HCG, HNG, HHG, HMG and S●● plug, socket or coupler models allow the device on which they are fitted to reach a protection index of IP68 as per IEC 60529. They are fully compatible with plugs of the same series and are widely used for portable radios, military, laboratory equipment, aviation, etc. These models are identified by a letter «P» at the end of the reference. Most of these models are also available in a vacuumtight version. Such models are identified by an additional letter «V» at the end of the part number (certificate on request). Epoxy resin is used to seal these models. Please refer to the chapter on selecting watertight connectors. Part number example: Watertight socket: HGG.1B.306.CLLP Vacuumtight socket: HGG.1B.306.CLLPV Technical Characteristics Mechanical and Climatical Charateristics Value Endurance Humidity Temperature range Salt spray corrosion test Protection index (mated) Climatical category Leakage rate (He)1) 00 0B 1B 2B 3B 4B 5B Maximum operating pressure2) Standard > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 20° C/+80° C > 144h IEC 60512-6 test 11f IP 68 IEC 60529 20/80/21 IEC 60068-1 < 10-6 mbar.l.s-1 IEC 60512-7 test 14b 60 bars 60 bars 60 bars 40 bars IEC 60512-7 test 14d 30 bars 15 bars 5 bars Note: 1) only for vacuumtight models. 2) this value corresponds to the maximum allowed pressure difference for the assembled socket. YHG Fixed plug, nut fixing, non-latching, key (G) or keys (A…M) L maxi Reference øA M e øB S3 S1 E maxi Dimensions (mm) Model Series A YHG YHG YHG YHG 0B 1B 2B 3B 14.0 16.0 19.5 22.0 B e E 12.5 M9x0.6 2.5 16.0 M12x1.0 4.5 19.5 M15x1.0 4.0 25.2 M18x1.0 5.0 L 21.2 25.0 31.5 34.0 M S1 14.6 8.2 16.4 10.2 18.2 13.5 22.4 16.5 S3 11 14 17 22 Note: this model does not include an O-ring behind the flange, it ensures only IP61 protection index. Consequently, it is not vacuumtight. Watertightness (when mated) is only ensured with HHG and HCG sockets. HGG Fixed socket, nut fixing, key (G) or keys (A…M and R), watertight or vacuumtight Reference L maxi øA M e øB S3 E maxi S1 Dimensions (mm) Model Series A B HGG HGG HGG HGG HGG HGG HGG 00 0B 1B 2B 3B 4B 5B 11 13 18 20 25 34 45 10.3 12.5 16.0 19.5 25.0 32.0 40.0 e E L M M7x0.5 8.0 18.3 1.5 M9x0.6 7.0 20.7 3.0 M12x1.0 7.0 26.0 4.5 M15x1.0 8.0 29.7 4.0 M18x1.0 11.5 36.2 4.0 M25x1.0 11.0 44.7 4.0 M35x1.0 11.0 51.7 5.0 S1 S3 – 8.2 10.5 13.5 16.5 23.5 33.5 9 11 14 17 22 30 – Note: the 5B series is delivered with a tapered washer and a round nut. ® ® HNG Fixed socket, nut fixing, with earthing tag, key (G) or keys (A…M), watertight or vacuumtight L maxi S3 M øA e øB Reference E maxi Model Series HNG 0B Dimensions (mm) A B e 13 12.5 M9x0.6 E L M S1 S3 7 20.7 3 8.2 11 S1 HHG Fixed socket, nut fixing, key (G) or keys (A…M), watertight or vacuumtight (watertight when mated) Reference L maxi M øA e øB S3 E maxi Dimensions (mm) Model Series A HHG HHG HHG HHG 0B 1B 2B 3B 13 18 22 25 B e E 12.5 M9x0.6 7.0 16.0 M12x1.0 7.0 19.5 M15x1.0 8.0 25.2 M18x1.0 11.5 L 23.7 29.7 33.7 41.4 M S1 4.8 8.2 5.2 10.5 6.0 13.5 7.2 16.5 S3 11 14 17 22 S1 HCG Fixed socket, nut fixing, key (G) or keys (A…M), watertight or vacuumtight (watertight when mated) (back panel mounting) Reference Dimensions (mm) L maxi P Series HCG HCG HCG 0B 1B 2B A B C e e1 E F L M P e øA e1 HEG Fixed socket, nut fixing, key (G) or keys (A…M), watertight or vacuumtight (back panel mounting) Reference L maxi P e E maxi Dimensions (mm) Model Series A B e E L HEG 2B 20 20 M15x1.0 5.4 33.7 M P S1 3.5 9.6 13.5 S2 M øA S2 S1 S1 18 18 12.0 M14x1.0 M9x0.6 3.9 1.0 23.7 3.5 7.5 12.5 20 20 14.5 M16x1.0 M12x1.0 6.2 2.0 29.7 3.5 10.0 14.5 24 24 17.5 M19x1.0 M14x1.0 6.7 1.5 33.7 3.5 11.3 17.0 E maxi S1 øB øB øC Model M F maxi 15 ® ® HMG Fixed socket with earthing tag, nut fixing, key (G) or keys (A…M), watertight or vacuumtight (back panel mounting) Reference Dimensions (mm) L maxi P S1 øA e øB M Model Series A B e E L M HMG HMG HMG 0B 1B 3B 12 16 24 13 M9x0.6 4.7 20.7 18 M12x1.0 5.5 26.0 25 M18x1.0 7.5 36.2 P S1 2.5 9.0 8.2 3.5 11.0 10.5 4.5 13.6 16.5 Note: the 3B series is delivered with a conical nut. E maxi S ● ● Fixed coupler, nut fixing, key (G) or keys (A, B, J, K and L) at the flange end and key (G) or keys (A, B, J, K and L) at the other end, watertight or vacuumtight L S1 øA M e øB S3 E maxi Reference J G SGJ J G SJG K A SKA B SLB L A K SAK B SBL L Model SGJ SJG SGJ SJG SGJ SJG SGJ SJG SAK SBL SAK SBL SGJ SJG SGJ SJG SKA SLB SAK SBL Series 0B 1B 2B 3B 4B 5B Contacts Type female – male male – female female – male male – female female – male male – female female – male male – female female – male female – male female – male female – male female – male male – female female – male male – female male – female male – female female – male female – male Dimensions (mm) A B e E L M S1 S3 14 13.8 M10x0.75 17 34 2.0 9.0 12 17 16.0 M12x1.00 28 39 2.5 10.5 14 20 21.8 M16x1.00 25 44 4.0 15.0 19 25 27.1 M20x1.00 30 53 4.0 18.5 24 34 32.0 M25x1.00 50 65 4.0 23.5 30 45 40.0 M35x1.00 58 80 5.0 33.5 – Note: for this fixed coupler, the first contact type mentioned is always the one at the flange end. On request these couplers can be produced in other series, with other keys. The 5B series is delivered with a round nut. ® ® Threaded-fixing models The 00 multipole series includes two threaded-fixing plug models. These plugs can be mated with sockets with a threaded front end (XRB or ESG). Plugs include an O-ring guaranteeing an IP64 protection index when mated. FVG Straight plug, key (G) or keys (A, B), cable collet, threaded-fixing øA ~M Model Series A L M S1 S2 FVG 00 9 28.5 24 5 5 Note: to be ordered with nut for fitting a bend relief to obtain the rating IP 64. S2 FVB Straight plug, keys (B), threaded-fixing for special cable crimping L Reference øA M Dimensions (mm) Model Series A L M FVB 00 9 20 15.4 Note: after assembly the special bend relief GMF.00.018.D● (to be ordered separately) is to be fitted. XRB Elbow (90°) socket fixing nut for printed circuit, keys (B), short shell, threaded-fixing (back panel mounting) 2.05 5.5 = = 1.2 Reference L P Dimensions (mm) Model Series A e E I L M P XRB 00 10 M7x0.5 1.8 7 14 2.5 7 e I Note: 1) minimum length of free thread to ensure mating. 3 øA 2.5 mini 1) M 2 x M 1.4 E maxi ESG Fixed socket with two round nuts, key (G), or keys (A, B), long threaded shell (back panel mounting) L maxi N 3.2 mini 1) e øA M øB S1 Dimensions (mm) Reference ~L E maxi Reference Dimensions (mm) Model Series A B ESG 00 9.5 9 e E M7x0.5 4.2 L M N 15.5 2 13.7 Note: 1) minimum length of free thread to ensure mating.
EPG.1B.303.HLN 价格&库存
很抱歉,暂时无法提供与“EPG.1B.303.HLN”相匹配的价格&库存,您可以联系我们找货
