FGG.2T.310.CLAC85Z
FGG.2T.310.CLAC85Z
    LEMO(雷莫)
    LEMO - FGG.2T.310.CLAC85Z - Circular Connector, 2T Series, Cable Mount Plug, 10 Contacts, Solder Pin...
FGG.2T.310.CLAC85Z 数据手册
FGG.2T.310.CLAC85Z www.lemo.com SUMMARY # Wires Low 10 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Series 2T Termination type Male solder IP rating 68 Cable Ø 8.10 - 8.50 mm Status active Image is for illustrative purpose only Download Request a quote Catalog Alternative part Matching parts EGG.2T.310.CLL TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0; plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 29.90 g Performance Configuration T.310 : 10 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 8 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest (contact-shell): 1300 V (AC), 1840 V (DC) Vtest (contact-contact): 1450 V (AC), 2050 V (DC) Others Endurance (Shell): >3000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr IP Rating: 68 DRAWINGS Draws Dimensions A L M S1 S2 mm. 15 54 42 14 12 in. 0.59 2.13 1.65 0.55 0.47 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools None Cables LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.2T.310.CLAC85Z 价格&库存
很抱歉,暂时无法提供与“FGG.2T.310.CLAC85Z”相匹配的价格&库存,您可以联系我们找货
FGG.2T.310.CLAC85Z
  • 1+838.94913
  • 5+805.39575
  • 10+771.84236
  • 25+754.91988
库存:14
