FGG.3T.330.CLAC11Z
FGG.3T.330.CLAC11Z
    LEMO(雷莫)
    LEMO - FGG.3T.330.CLAC11Z - Circular Connector, 3T Series, Cable Mount Plug, 30 Contacts, Solder Pin...
FGG.3T.330.CLAC11Z 数据手册
FGG.3T.330.CLAC11Z www.lemo.com SUMMARY # Wires Low 30 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Series 3T Termination type Male solder IP rating 68 Cable Ø 10.10 - 10.50 mm Status active Image is for illustrative purpose only Download Request a quote Catalog Alternative part Matching parts EGG.3T.330.CLL TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0; plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 46.39 g Performance Configuration T.330 : 30 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 3.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 700 V (AC), 990 V (DC) Vtest (contact-contact): 800 V (AC), 1130 V (DC) Others Endurance (Shell): >3000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr IP Rating: 68 DRAWINGS Draws Dimensions A L M S1 S2 mm. 18.8 62 47 16 15 in. 0.74 2.44 1.85 0.63 0.59 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools None Cables LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.3T.330.CLAC11Z 价格&库存
很抱歉,暂时无法提供与“FGG.3T.330.CLAC11Z”相匹配的价格&库存,您可以联系我们找货
