EGG.2T.319.CLL
www.lemo.com
SUMMARY
# Wires
Low
19
High
Coax
Triax
Quad
Fiber
Fluidic
Series
2T
Termination type
Female solder
IP rating
68
Cable Ø
1.30 - 10.50 mm
Status
active
Image is for illustrative purpose only
Download
Request a quote
Catalog
Alternative part
Matching parts
FGG.2T.319.CLAC50
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EG*: Fixed receptacle, nut fixing
Keying
1 key (alpha=0; plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces
Variant
Weight
9.96 g
Performance
Configuration
T.319 : 19 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
5 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Solid Conductor: 0.34 mm^2 (AWG 22)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
R (max): 6.1 mOhm
Vtest (contact-shell): 1250 V (AC), 1770 V (DC)
Vtest (contact-contact): 950 V (AC), 1340 V (DC)
Others
Endurance (Shell): >3000 mating cycles
Temp (min / max): -55°C / +200°C
Humidity (max): 1000 hr
IP Rating: 68
DRAWINGS
Draws
Dimensions
A
B
E
L
M
N
S1
S2
e
mm.
18.5
19.6
7.5
26.5
1.8
24.6
13.5
17
M15x1.0
in.
0.73
0.77
0.30
1.04
0.07
0.97
0.53
0.67
RECOMMENDED BY LEMO
2/3
Tools
None
Cables
CMN.19.T22.079QGZE
TPR (medical)
Grey
CMN.19.T22.080PGCE
PVC
GREY
CMN.19.T22.080PGZE
CMN.19.T22.080PNCE
Grey
PVC
Black
CMN.19.T22.080PNZE
3/3
很抱歉,暂时无法提供与“EGG.2T.319.CLL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+503.19661
- 5+493.12643
- 10+478.32837
- 国内价格 香港价格
- 1+1074.595661+138.34103
- 10+931.3139710+119.89527
