MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
H5 series
Low profile with 5mm height
Wide temperature range of -40 °C to +105°C
H5 105 C
1808
Endurance:+105°C 1,000 hours
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C
Rated Voltage Range
6.3~50 V dc
Capacitance Tolerance
±20%(M)
Leakage Current
I≤0.01CV or 3μA, whichever is greater.
Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V)
(at 20°C,120Hz)
Rated Voltage(V dc )
6.3
10
16
25
35
50
0.28
0.24
0.20
0.14
0.12
0.10
6.3
10
16
25
35
50
5
4
(at 20°C after 2 minutes)
Dissipation Factor (tanδ)
tanδ (max.)
Low Temperature
Characteristics
(Max. Impedance Ratio)
3
Z(-25°C)/Z(+20°C)
8
Z(-40°C)/Z(+20°C)
(at 20°C,120Hz)
2
3
(at120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20°C after the rated voltage is applied for
1,000 hours at 105°C.
Endurance
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 500 hours at
105°C without voltage applied.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 4~ Ø 6.3)
ØD
4
5
6.3
Ød
0.45
0.45
0.45
F
ØD'
L'
1.5
2.0
2.5
Ø D+0.5max.
L+1.5max.
Radial Type
Sleeve(Black)
PART NUMBERING SYSTEM
E
H5 1H
M 3R3 C05 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
WV(Vdc)
6.3 to 16
25 to 35
50
50/60
120
1k
10k-100k
0.80
0.80
0.80
1.00
1.00
1.00
1.30
1.20
1.15
1.50
1.20
1.20
The endurance of capacitors is shortened with internal heating produced by ripple current
at the rate of halving the lifetime with every 5 °C rise. When long life performance is required
in actual use, the rms ripple current has to be reduced.
82
H5 series
STANDARD RATINGS
WV
(V dc )
6.3(0J)
10(1A)
16(1C)
25(1E)
35(1V)
50(1H)
Cap
(µF)
Size
ΦDxL(mm)
tanδ
Rated ripple current
(mArms/105°C,120Hz)
Part Number
22
4×5
0.28
23
EH50JM220C05OT
33
5×5
0.28
30
EH50JM330D05OT
47
5×5
0.28
37
EH50JM470D05OT
100
6.3×5
0.28
57
EH50JM101E05OT
10
4×5
0.24
EH51AM100C05OT
22
5×5
0.24
28
EH51AM220D05OT
33
5×5
0.24
34
EH51AM330D05OT
47
6.3×5
0.24
52
EH51AM470E05OT
4.7
4×5
0.20
15
EH51CM4R7C05OT
10
4×5
0.20
23
EH51CM100C05OT
22
5×5
0.20
31
EH51CM220D05OT
33
6.3×5
0.20
48
EH51CM330E05OT
47
6.3×5
0.20
56
EH51CM470E05OT
4.7
4×5
0.14
15
EH51EM4R7C05OT
10
5×5
0.14
22
EH51EM100D05OT
22
6.3×5
0.14
44
EH51EM220E05OT
33
6.3×5
0.14
48
EH51EM330E05OT
3.3
4×5
0.12
13
EH51VM3R3C05OT
4.7
4×5
0.12
17
EH51VM4R7C05OT
10
5×5
0.12
24
EH51VM100D05OT
22
6.3×5
0.12
48
EH51VM220E05OT
0.1
4×5
0.10
1
EH51HMR10C05OT
0.22
4×5
0.10
2
EH51HMR22C05OT
0.33
4×5
0.10
3
EH51HMR33C05OT
0.47
4×5
0.10
4
EH51HMR47C05OT
1
4×5
0.10
8
EH51HM010C05OT
2.2
4×5
0.10
13
EH51HM2R2C05OT
3.3
4×5
0.10
14
EH51HM3R3C05OT
4.7
5×5
0.10
18
EH51HM4R7D05OT
10
6.3×5
0.10
28
EH51HM100E05OT
83
很抱歉,暂时无法提供与“EH51EM100D05OT”相匹配的价格&库存,您可以联系我们找货
