ELL1EM470D11C33T
ELL1EM470D11C33T
    AISHI(艾华集团)
    插件,D5xL11mm
    47UF ±20% 25V 桔红色 PET
ELL1EM470D11C33T 数据手册
CUSTOMER: DATE: July 07,2020 SPECIFICATION DESCRIPTION: Aluminium Electrolytic Capacitors AISHI P/N: ELL1EM470D11C33T SERIES: LL ITEM: 25 V 47 μF (Φ 5 × 11 ) CUSTOMER P/N: No.: CRS-JD-2007279 APPROVED BY Please Return One Copy with Your Approval 承认后请寄回一份 PREPARED BY CHECKED BY APPROVED BY 变更记录 Change Records 编号 No. 更改原因 Explanation of changes 更改内容 Content 修订人 Reviser 生效日期 Effective date CRS-JD-2007279 新建 新建 陈娟 2020/07/07 CUSTOMER SERIES LL DATE 2020/07/07 FIG-1 TABLE-1 No . 1 Customer Part No. Aishi Part No. ELL1EM470D11C33T Tolerance on Rated Surge Capacitance Rated Voltage Voltage (μF) Capacitance (Vdc) (Vdc) (%) 47 -20,+20 25 32 Operating Temp. Range (℃) Tanδ (120Hz) (Max) Leakage Current (μA)(2min.) -40~+105 0.14 2.35 Max Ripple Endurance Current Dimensions (mm) (mArms) at 105℃ at 105℃ (Hours) ΦD L α d F 120Hz 76 2000 5 11 2 0.5 2.0 Appearance Drawing No. FIG-1 1 概述 SCOPE 本承认书规定了LL系列径向引线引出铝电解电容器的技术规范,本技术规范条文解释权归本公司所有。 This specification covers“LL series” miniature single-ended aluminium electrolytic capacitors,AISHI reserves the right of final interpretation for this technical specification. 2 参考标准 APPLICABLE SPECIFICATION 本承认书参考JIS-C-5101-1和 JIS-C-5101-4制定。 This specification consulted the institute of JIS-C-5101-1 and JIS-C-5101-4. 3 工作温度范围 OPERATING TEMPERATURE RANGE 工作温度范围是电容器在施加额定工作电压条件下,可以长期可靠工作的环境温度范围。 -40℃~+105℃(6.3 VDC~100 VDC) Operating temperature range is the range of ambient temperature at which the capacitor can be operated continuously at rated voltage. -40℃~+105℃ 6.3V.DC~100V.DC 4 测试环境 CONDITION OF TEST 如果没有其他规定,标准的测试、检验环境条件如下所示: 环境温度:15℃~35℃ 相对湿度:45%~75% 大气压力:86kPa~106kPa 如果对测试结果有异议,可以在以下条件测试: 环境温度:20±1℃ 相对湿度:60%~67% 大气压力:86kPa~106kPa Unless otherwise specified, the standard range of atmospheric conditions for making measurements and tests are as follows: Ambient temperature :15℃ to 35℃ Relative humidity :45% to 75% Air pressure:86kPa to 106kPa If there may be doubt on the results, measurements shall be made within the following limits: Ambient temperature :20±1℃ Relative humidity :60% to 67% Air pressure :86kPa to 106kPa File Description Component P/N LL Approval Sheet Version 01 Page STANDARD MANUAL 1 5 产品特性 PRODUCT CHARACTERISTICS 5.1电气特性 Electrical Characteristics 序号 No. 项目 Item 测试方法 Test method 5.1.1 额定工作电压 Rated voltage 5.1.2 电容量 Capacitance 5.1.3 损失角正切值 Dissipation factor 性能 Performance 电压:直流电压值+交流电压峰值≤额定电压 Voltage: DC voltage + peak ripple voltage ≤ Rated voltage 见表1 See TABLE-1 测试频率:120Hz(±20%) 测试电路:串联等效 测试电压:0.5Vrms以下+1.5~ 2.0VDC Measuring frequency: 120Hz±20% Measuring circuit: Series equivalent circuit Measuring voltage: 0.5Vrms or less +1.5 to 2.0 VDC 容量偏差 : -20%~+20% Capacitance tolerance: -20%~+20% 测试条件与5.1.2电容量测试相同。 DF见表1 DF: See TABLE-1 Testing conditions are the same as 5.1.2 for capacitance. 6.3V~100V: 在电容器两端施加额定工作电压,并串联 I≤0.002CV或0.4μA, 1000±100Ω电阻,在施加规定时间电压后,测 取较大值(2分钟后)。 量漏电流。 6.3V~100V: I≤0.002CV or 0.4μA Whichever is 测试电路如下图: greater ( after 2 min). The rated voltage shall be applied across the capacitor and its protective resistor shall be I:漏电流(μA) 1000±100Ω. The leakage current shall then be C:容量(μF) measured after an electrification period of V:额定工作电压(V) schedule time.Measurement circuit: I:Leakage current(μA) C:Capacitance(μF) V:Rated voltage (V) 5.1.4 漏电流 Leakage current Rs: Protective resistor(1000±100Ω) DC ammeter DC voltmeter S1: Switch S2: Protective switch for an ammeter File Description Component P/N LL Approval Sheet Version 01 Page STANDARD MANUAL 2 阶段 温度 时间 1 20±2℃ -- 2 2h 3 20±2℃ 4 5.1.5 15min. 2h 阶段1:测量容量和阻抗(|z| 20℃ 120Hz±20%); 阶段2:电容器恒温贮存2小时,在热平衡状态测 温度特性 阻抗(|z|- 25, -40℃ 120Hz±20%); Temperature 阶段4:电容器恒温贮存2小时,在热平衡状态测 characteristic 电容量。 Step 1: Capacitance and impedance shall be measured. (|z| 20℃ 120Hz±20%); Step 2: After the capacitor being stored for 2 hours,impedance shall be measured at thermal stability. (|z|-25,-40℃ 120Hz±20%); Step 4:After the capacitor being stored for 105℃ 2 hours, capacitance shall be measured. The measurement shall be made at thermal stability. 施加表1所列浪涌电压,充电30±5秒,放电 5.5±0.5分钟作为一个周期,共进行1000次。 测试温度:15℃-35℃ 然后在标准大气条件下放置达到热稳定,测试各 Application of DC surge Voltage stated at TABLE-1. 1000 times of charging for 30±5 sec., discharging with a period of 5.5±0.5 min.. Test temperature: 15℃-35℃ And the capacitor shall be stored under standard atmospheric conditions to obtain thermal stability, after which measurements shall be made. 5.1.6 阶段2: 阻抗值与阶段1阻抗值相比,不大于表2要求; 阶段4: 容量变化应在初值的±20%范围内。 Step 2: Impedance value ratio to the value at step 1 shall be not more than the value given in TABLE-2. Step 4: Variation of capacitance Within ±20% of the initial value. 容量变化:在初始值的±20%以内。损耗角正切值不大于 表1规定值的200%。 漏电流:满足5.1.4要求。 Capacitance change:Within±20% of the initial value Dissipation factor: Not more than 200% of the specified value in TABLE-1. Leakage current: To satisfy No. 5.1.4 . 耐浪涌电压 Test circuit Surge test Note: This requirement is applicable only to instantaneous over voltage which may be applied to terminals of capacitor, therefore, not applicable to such over voltages as often applied. File Description Component P/N LL Approval Sheet Version 01 Page STANDARD MANUAL 3 5.2 机械特性 Mechanical Performance 序号 No. 项目 Item 测试方法 Test method 特性 Performance 端子抗拉强度: 沿电容器端子引线方向施加拉力(如下表),10±1秒。 引线直径Φ 0.45 0.5 拉力N 0.6 5 0.8 10 1.0 20 端子抗弯强度: 在电容器引线施加固定重力(如下表),然后将电容体弯折90°后回到原 位,再向相反方向弯折90°后回到原位。 测量电容器应无接触不良、开 路或短路,无可见机械损伤。 When the capacitor is measured, there shall be no intermittent contacts, or open or short-circuiting. There shall be no visible mechanical damage. 上述过程在5秒内完成。 5.2.1 端子强度 Terminal strength 引线直径Φ 拉力N 0.45 0.5 2.5 0.6 0.8 5 1.0 10 Tensile strength of terminal: A static load (stated in the table above) shall be applied to the terminal in the axial direction and acting in a direction away from the body for 10±1 sec.. Bending strength of terminal: Hang the specified dead weight (stated in the table above), then bend the body through 90°, return to the original position. Next bend it in opposite direction through 90° with the same speed, again return to the original position. Complete this operation in about 5 sec.. 5.2.2 5.2.3 依据JISC 5101-1 4.17试验。 在3个互相垂直的方向分别施加2小时振动,共6小时。 频率:10-55Hz 振幅峰-峰值:1.5mm. 振动试验 振速:1分钟内振速10~55~10Hz Resistance to To comply with JIS C 5101-1 4.17 Direction and duration of vibration: vibration 3 orthogonal directions mutually each for 2h , Total 6h. Vibration frequency range :10-55Hz. Peak to peak amplitude: 1.5mm Sweep rate :10 to 55 to 10Hz in about 1 min. 依据JISC 5101-1 4.15进行试验。 焊锡温度:235±5℃ 浸入时间:2±0.5秒 To comply with JISC 5101-1 4.15 可焊性 Solderability Temperature of solder: 235±5℃ Dipping time: 2±0.5sec. This specification shall be met after the capacitors are stored under standard atmospheric conditions for 6 months. File Description Component P/N LL Approval Sheet Version 01 Page STANDARD MANUAL 测量电容器应无接触不良开路 或短路,无可见机械损伤。 When the capacitor is measured there shall be no intermittent contacts, or open or short circuiting。 There shall be no visible mechanical damage. 浸入焊锡的引线表面积约90% 以上应附着新锡。 At least 90% of circumferential surface of the dipping portion of terminal shall be covered with new solder. 4 5.3 耐久性测试 Endurance Performance 序号 No. 5.3.1 5.3.2 项目 Item 测试方法 Test method 焊槽法: 焊锡温度:260±5℃ 浸入时间:10±1秒 电 路 板 :1.6mm Solder bath method Solder bath temperature : 260±5℃ 耐焊接热 Immersion time : 10±1sec. Resistance to soldering Printed wiring board: 1.6mm heat 稳态湿热 Resistance to damp heat (steady state) 特性 Performance 容量变化:在初始值±10%范围内。 损失角正切值:不大于表1规定值。 漏电流:满足5.1.4要求。 外观:无异状。 Variation of capacitance: Within ±10% of the initial value. Dissipation factor: Not more than the specified value in TABLE-1. Leakage current: To satisfy No. 5.1.4 . Appearance: No remarkable abnormality. 依据JISC 5101-1 4.22进行试验。 试验温度:40±2℃ 试验时间:240±8h 相对湿度:90~95% 试验后,电容器在标准大气条件下1~2 小时,然后测试参数。 容量变化:在初始值±10%范围内。 损失角正切值:不大于表1规定值。 漏电流:满足5.1.4要求。 外观:无异状。 Variation of capacitance: Within ±10% of the initial value. Dissipation factor: Test time : 240±8h Relative humidity: 90~95% After completion of test, the capacitor shall be subjected to standard atmospheric conditions for 1 to 2 hours, after which measurements shall be made. Not more than the specified value in TABLE-1. Leakage current: To satisfy No. 5.1.4 . Appearance: No remarkable abnormality. 1. 试验温度:105±2℃,施加额定电压和 额定纹波电流。 Application of the rated voltage and the rated ripple current, Test temperature:105±2℃. 5.3.3 高温负荷试验 Load life test File Description Component P/N 容量变化:在初始值±20%范围内。 损耗角正切值:不大于表1规定值的200%。 漏电流:满足5.1.4要求。 外观:无异状。 Variation of capacitance: Within ±20% of the initial value. 2. 试验时间:参照TABLE-1寿命要求。 Dissipation factor: Not more than 200% of the specified value in TABLETesting time: refer to TABLE-1 life 1. requirements. Leakage current: To satisfy No. 5.1.4 . Appearance: No remarkable abnormality. LL Version Approval Sheet 01 Page STANDARD MANUAL 5 h,至少恢复16小时后。 容量变化:初始值±20%范围内。 在105±2℃环境下无负荷贮存 The capacitors are stored without voltage load at 105±2℃ 损耗角正切值:不大于表1规定值的200% 。 for 漏电流:满足5.1.4规定值的200%。 h and then resumed 16 hours. 外观:无异状。 5.3.4 高温贮存试 验 Shelf life test Variation of capacitance: Within ±20% of the value before test. Dissipation factor: Not more than 200% of the specified value in TABLE-1. Leakage current: Not more than 200% of the specified value in No. 5.1.4 . Appearance: No remarkable abnormality. 上述过程中应无引线、铝箔等散射,无火 花产生。 The safety vent is actuated under the test conditions, thereby preventing 在电容器两极施加反向直流电压,其中通过的电流为1A,在测 terminals, metal pieces, etc, of the 防爆试验 试时防爆装置应能在30分钟内动作。 capacitor from scattering due to burst, Safety vent DC Application test: the case from separating from the seal The capacitor shall be subjected to a reverse DC voltage. packing, or the capacitor from The current flowing through the capacitor shall be 1A. If the vent does work with the voltage applied for 30 minutes, the test producing flame. is considered to be passed. 以下试验只适用于铝壳直径≥Φ8产品。 The following tests only apply to those products with vent products at diameter≥Φ8 with vent. 5.3.5 ※ TABLE-2:阻抗比 Max. Impedance Ratio 额定电压 Rated voltage (v) 6.3 10 16 25 35 50 63 100 |z|-25℃ /|z|20℃ 4 3 3 2 2 2 2 2 |z|-40℃ /|z|20℃ 8 6 6 4 4 3 3 3 ※ TABLE-3:纹波电流频率因子 RIPPLE CURRENT FREQUENCY COEFFICIENT Freq.(Hz) 50(60) 120 1k 10k 100k Cap.
ELL1EM470D11C33T 价格&库存
很抱歉,暂时无法提供与“ELL1EM470D11C33T”相匹配的价格&库存,您可以联系我们找货
