ERS1HM222M25OT
ERS1HM222M25OT
    AISHI(艾华集团)
    插件,D18xL25mm
    2200UF ±20% 50V
ERS1HM222M25OT 数据手册
| 11'1 II~ Ir!'t .'I~):I'':].川UM ELECTROLYTIC CAPACITORS AiSH~ RS series 噩噩 • High performance , high reliability . l口w impadanca , high rippla currant , long lifa • Endurance: +1 05'C 4 ,000-1 0 ,000 hours • RoHS Compliant • SPECIFICATIONS lωm. ca脑gory Temperature Charactørlatlcs Ra nge -40同时 05'C RatedVol恒ge Range 6.3-120Vd. CapacilanωTolaranω 士 20%(M) laa阳ga 1.:50.01 CVor 3μA , whiche内,er is greater. Whe障, 1:Max.leakage current (IIA), C:Nominal capacitance Currant (at20'C ,120Hz) 阳 R atadVol 口创It同 匈 a 伊@叫(Vd g 由eφ) 叫 [阳 叫 M 6町{叫 Oissipetion Faclor (饱nð) 1佣 o 河16 6.3 部 25 阴 5o Rated voltage (V) 臼 63 (at 20'C after2 minute8) 8ωo 河1 ∞ :河120 :旦 阳一芒… M 巨2 一0.19 … 0 16二 L~:.叫1 ~.;0.12 川二 0.10川9 口斗口8' 口 η wh 惘 en noml阳 na 副Ic俑泊p 阳 挝c蚓lt a 忧tancωe excωee 时 ds 钊1 ,0 ∞ ∞ 0 阳 0 IIF, Rated Voltage(Vdc) low Tamperature 臼 35 (~F),V: 8.3 10 16 25 add 0.02 tωo the value above for each 1, 000 1l F Increase. 35 50 83 80 100 , (at 20'C ,120Hz) 120 : Characteris苗。s (Max.lmp创ance Ratio) Z( -2S'C)/Z( +20'C) 4 Z( -4 0'C)/Z(+20'C) 8 3 i 6 2 4 i 3 3 , 6 i Tha spacifications listød ba low sha 11 ba mat whan tha 臼pacitors ara rastorad to 20'C aftar OC voltaga plus 帽tad rippla cu寸ant is appl iad for a spaci币4月riod ofti …--tip-ic.;……………丁 Loadll白(hou古} ……! Ola Capacltan饵 Cha叼e 量:t 20% ofthe Inltlal value (6.3 , 10V: 孟:t 30%) [.. _._. .....;..~,~::-.1_O_v: .. j 贷-120V i ØD";8.3 : 4 ,000 5 , 000 D.F. (tanð) :5: 200% ofthe initialspecified v回 lue ØO=8& 10 6 ,000 7 , 000 LaakagaCur晴 nt ~Tha initial spacifiad valua ;iõ ., ....S.:Õ'OÕ..... ,.. '1( Endurance '''øo The following specifications shall be satisfiad when the 105' C for 1, 000 hours. … Shelf Life c回pacitors ú'.s' i:ooo'" are rastored to 20'。回fter leaving tham under no load at γ ……………………………...………………,…… 「 Capacitance Changø 量土 20% ofthø initial valua (6.3 , 10咿:仕 30%) D.F. (tanð) 量200% oftha initialspecifiad valuø Leakage Cur阳nt ~200% ofthe initialspaci而edvalue DIMENSIONS[mm] @ah ←-里冒"但 • (at 120Hz) 时::tO.5 (Ø5 -ø 18) 4mln. • PART NUMBERING SYSTEM E RS 1H Tt t 81田ve Cod e: 'C' for 阿生主旦旦I Tenmlnal code Siza ∞de capaci饱n面目>da capacl回n国 tolaran曲目>da vo阳啕e ∞de Ser1es∞de E些塑旦旦旦旦 • RATED RIPPLE CURRENT MULTIP Ll ERS Frequency correction factor for ri pple current ι证时? 120 1k 10k 100k Cap.
ERS1HM222M25OT 价格&库存
很抱歉,暂时无法提供与“ERS1HM222M25OT”相匹配的价格&库存,您可以联系我们找货
