| 11'1
I r!'t
ELECTROLYTIC CAPACITORS
RHseri
• High frequency, low impedance
• Endurance: +10S.C 2 ,000-3 ,000 hours
• RoHS Compliant
SPECIFICATIONS
Charactørlatlcs
Temperature Ra nge
-400 Vdc)
-25-+1 05.C(450 Vdc)
160-450 Vdc
(at
1.:50.02CVor
whichever is greater.
1: Max.leakage current (IIA),C:Nominal capacitance
Current
Rated Voltage(Vdc)
160: 200 : 250
350 : 400
Rated voltage (V)
(aI20. C after2 minules)
450 :
Dissipation Factor
(max.)
: 0.12 : 0.12 : 0.12 : 0.15 : 0.15 : 0.20 :
RatedVoltage(Vdc)
Characteristics
Ratio)
160: 200 : 250
Z( -25.C)fZ( +20'C)
3
Z( -4 0'C)fZ( +20'C)
4
(at 20.C,120Hz)
350 : 400 : 450 :
5
6
7
---- ---- ---- ---- ---- ---- ---- ---- ------l----------;
(at 120Hz)
The following specifications shall be satisfied when the capacitors are
current is appl ied for a
period of time at 105.C.
Changø
Endurance
ofthe inilial value
plus the
Case Oia.
Load
D.F.
Leakage Currenl
,s The initial specified value
10
3 ,000
The following specification8 8hall Þe satisfied when the capacitors are restored to 20.C aftar exp08ing Ihem for 1,000 hours
at
Shalf Life
Capacitance Change
.:5:1:20%
D.F. (tanð)
"200% ofthe Inltlal speclfled value
of the initial value
Leakage Current
"200% ofthe initialspecified value
DIMENSIONS[mm]
AE RJ·
4min.
PART NUMBERING SYSTEM
E
RH 2G
TTL
Slzecode
RATED RIPPLE CURRENT MULTIP Ll ERS
Frequency correctlon factor for rl pple current
shortened with intemal heating
c urrenl at Ihe rate of hlllving I he lifet ime wit h every 5.C rise. When long life
performance is required in actual use, t he rms ripple current
reduced.
129/130
|Ai5Hi
RH series
STANDARD RATINGS
wv
Cap
2
Size
CÞDxL(mm)
tanð
6.3'11
0.12
6.3'11
0.12
s
4
r --··
''--ao
r
0.12
Rated rlpple current
Cap
(IIF)
{mArma/1 OS'C, 1 OOkH z)
Size
CÞDxL(mm)
v+2-enu…
2.2
121
3.3
nw-AM
4.7
nv-
100
12.5"25
0.12
220
1 6"30
0.12
5'11
0.12
4.7
10
22
33
200(20)
47
0.12
0.15
91
10.12
0.15
156
0.15
332
!;:2|:1:|;2
22
. 1.........: .
at4ln4
1 0" 12
0.12
1 0" 16
0.12
10"20
0.12
238
10"20
0.12
319
12.5"20
0.12
385
12.5"20
0.12
405
100
16"25
0.12
120
16"25
0.12
150
16"25
0.12
12.5"35
0.12
16"30
0.12
6.3'11
0.12
32
68
f..
12.5'40
0.15
-.1.- …… -.1.-
100
f..
0.15
……… -.1.- ……
-.1.-
150
0.15
12.5*50
0.15
22 *31
120
1.
0.12
59
6.3'11
0.12
77
3.3
6" 12
0.12
4.7
6" 12
0.12
10"20
0.12
244
47
12 .5"2 5
0.12
423
0.12
472
.. 1..
0.20
27
0.20
350(2V)
4.7
::i
47
6" 12
10.45
4 50( 2W}
0.15
698
1
686
781
1
0.20
1
1
0.20
1
82
f..
6" 12
0.15
0.15
118
120
1 0" 16
0.15
153
150
12.5*45
1 0.20
1
769
830
886
……… -.1.- ……·… -.1.- ……………………………+
0.20
100
18'40
22*46
0.15
1
1 0.20
68
1 0" 12
16"30
0.20
1 0.20
12.5*40
1 0.20 1
1...........................+..............+
18'30
1 0.20
0.15
0.15
338
""-ma
56
0.12
0.12
2.2
.. 1.......
22
47
m
935
59
124
22
956
96
6.3'11
mm-m
864
0.15
948
2.2
56
59
8'12
10
0.12
47
(mArma/10S'C,100kHz)
……i…J …… 8.12………l…0.15
160(2C)
rlpple current
tanð
853
0.20
924
0.20
1128
0.20
1354
0.20
1537
很抱歉,暂时无法提供与“ERH2GM220W20OTS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 75+1.3099875+0.16378
- 200+1.30386200+0.16301
- 750+1.30383750+0.16301
- 2000+1.303802000+0.16301
- 7500+1.303777500+0.16300
