FN2020-1-06
FN2020-1-06
    SCHAFFNER(夏弗纳)
    FN2020-1-06
FN2020-1-06 数据手册
DATASHEET Single-Stage Filters FN 2020 General Purpose EMI Filter Rated currents from 1 to 60 A High differential-mode attenuation Approvals Optional medical version (B type) Optional safety version (A type) Features and benefits FN 2020 filters are designed for easy and fast chassis mounting FN 2020 filters are also available as B versions without Y-capacitors for medical applications as well as A version with low capacitance for safety critical applications with necessity for low leakage currents All filters provide a general purpose conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior FN 2020 filters can be used to cover a broad range of usage and they offer a good size/amperage ratio FN 2020 filters are also available as two- stage filters (FN 2060, FN 2070 series) for more noisy environment Technical specifications Operating voltage Operating frequency Rated currents High potential test voltage Temperature range (operation and storage) Flammability corresponding to Design corresponding to MTBF @ 40°C/230V (Mil-HB-217F) Various terminal options allow you to select the desired connection style 110/250 VAC, 50/60 Hz dc to 400 Hz 1 to 60 A @ 40 °C max. P –> PE 2000 VAC for 2 sec P –> N 1100 VDC for 2 sec (30 and 60 A types) P –> N 760 VAC for 2 sec (1 to 20 A types) P –> PE 2500 VAC for 2 sec (B types) -25 °C to +100 °C (25/100/21) UL 94 V-2 or better UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 1,250,000 hours 1,750,000 hours (B types) Typical applications Electrical and electronic equipment Consumer goods Household equipment Medical equipment Office automation equipment Datacom equipment Typical electrical schematic EMC/EMI Products Schaffner Group Datasheets 2014 Filter selection table Filter* Rated current Leakage current** Inductance [A] [mA] 3 (3.45) @ 40 °C (25 °C) @ 230 VAC/50 Hz [mH] [μF] [nF] [kΩ] 0.74 2.5 0.15 4.7 1000 0.74 0.8 0.74 0.65 0.87 0.67 FN 2020-6-.. 6 (6.9) 0.74 12 (13.8) 0.74 FN 2020-10-.. 10 (11.5) FN 2020-16-.. 16 (18.4) FN 2020-12-.. FN 2020-20-.. FN 2020-30-08 FN 2020-60-24 FN 2020A-1-.. FN 2020A-3-.. FN 2020A-6-.. 0.74 60 (69) 0.87 1 (1.15) 0.074 6 (6.9) 0.074 12 (13.8) 0.074 3 (3.45) FN 2020A-10-.. 10 (11.5) FN 2020A-16-.. 16 (18.4) FN 2020A-12-.. 0.74 20 (23) 30 (34.5) 6 (6.9) 0.002 12 (13.8) 0.002 FN 2020B-10-.. 10 (11.5) FN 2020B-16-.. 16 (18.4) FN 2020B-12-.. FN 2020B-20-.. FN 2020B-30-08 FN 2020B-60-24 4.7 1000 -06 -07 1000 -06 -07 10 220 12 0.15 0.47 1000 -06 -07 80 1 0.15 0.47 1000 -06 -07 80 0.7 0.15 0.47 1000 -06 -07 0.15 0.15 0.15 0.47 0.47 0.47 470 -06 1000 0.47 1000 1 1.5 0.47 220 0.47 -06 1000 0.15 0.47 -24 1000 0.6 -08 -08 -06 -06 470 -07 -07 210 470 1100 80 -07 85 85 -08 -08 -24 140 210 470 1100 12 0.15 1000 -06 -07 80 1 0.15 1000 -06 -07 80 0.7 0.15 1000 -06 -07 85 0.002 0.65 0.002 0.67 0.15 0.15 0.15 1000 1000 -06 1000 0.6 0.15 1000 1 1.5 220 0.47 -06 -06 -06 470 -07 -07 85 -08 -08 -24 Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym 16 and 20 A types 80 -07 Typical filter attenuation 6 to 12 A types 85 140 1.5 10 ** To compile a complete part number, please replace the -.. with the required I/O connection style (e.g. FN 2020-30-08, FN 2020B-10-06). ** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. 1 and 3 A types 85 1 0.47 -06 -07 1000 0.8 0.002 -06 4.7 0.002 60 (69) 4.7 1000 80 80 0.15 2.5 0.002 0.15 4.7 80 0.6 0.002 20 (23) 30 (34.5) 0.15 0.15 Weight [g] -07 0.7 0.67 FN 2020B-6-.. -06 -07 0.074 0.002 3 (3.45) -07 -06 0.65 1 (1.15) FN 2020B-3-.. -06 1000 0.074 FN 2020B-1-.. 1000 4.7 0.8 0.074 4.7 connections 0.15 0.074 60 (69) FN 2020A-60-24 30 (34.5) 0.15 Input/Output R 1 2.5 0.074 FN 2020A-30-08 12 0.074 20 (23) FN 2020A-20-.. Resistance Cy 1 (1.15) FN 2020-3-.. Capacitance Cx FN 2020-1-.. L 30 and 60 A types 140 210 470 1100 EMC/EMI Products Schaffner Group Datasheets Mechanical data Connection style -06, 1 to12 A types Connection style -06, 16 and 20 A types Connection style -07, 1 to 12 A types (same dimensions as style -06) Connection style -07, 16 A types (same dimensions as style -06) Connection style -08, 20 A types Connection style -08, 30 A types Connection style -24 B E Q I H G A F D J N K L M C 2014 EMC/EMI Products Schaffner Group Datasheets 2014 Dimensions 1A 3A 6A 10 A 12 A A 64 64 64 64 64 C 29.3 29.3 29.3 29.3 29.3 E 32.5 32.5 32.5 32.5 32.5 B D F G H 35 43.5 54 21 9.3 35 43.5 54 21 9.3 35 35 43.5 43.5 54 54 21 21 9.3 9.3 54 21 Connection style -06 N Connection style -07 O P AWG type wire Wire length Connection style -08 6.3 x 0.8 8.3 21.8 AWG 20 140 6.3 x 0.8 8.3 21.8 AWG 20 140 6.3 0.7 0.7 6.3 x 0.8 6.3 x 0.8 8.3 21.8 AWG 18 140 8.3 21.8 AWG 18 N Connection style -24 N Q All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m / EN 22768-m Please visit www.schaffner.com to find more details on filter connections. 140 21 56 75 103 27 25 99.5 95 6.3 0.7 5.3 6.3 0.7 6.3 x 0.8 6.3 x 0.8 8.3 8.3 AWG 16 AWG 16 21.8 140 5.3 6.3 0.7 32.4 4.4 6 0.9 ±0.5 ±0.3 10.1 ±0.5 42.25 20.8 ±0.5 ±0.5 ±0.2 15.5 19.3 ±0.5 40 19.9 5.3 6.3 61 84.5 ±1 20.1 5.3 0.7 49.8 94 ±1 21.8 5.3 6.3 44.5 64.8 57.6 ±1 19.6 5.3 0.7 45.4 ±1 ±0.5 145.9 ±1 12.4 5.3 6.3 30.3 105 ±1 57.5 ±1 12.3 K M 29.3 Tolerances 10.8 15.3 L 113.5 ±1 54 60 A 9.3 15.3 21.8 85 50.5 15.3 21.8 71 43.5 15.3 21.8 30 A 46.6 15.3 21.8 20 A 35 I J 16 A 4.4 ±0.5 ±0.5 6 1.2 6.3 x 0.8 ±0.5 14 ±0.5 140 +5 M4 M4 M6 51 ±0.2
FN2020-1-06 价格&库存
很抱歉,暂时无法提供与“FN2020-1-06”相匹配的价格&库存,您可以联系我们找货
