FN2090B-20-08
FN2090B-20-08
    SCHAFFNER(夏弗纳)
FN2090B-20-08 数据手册
DATASHEET Two-Stage Filters FN 2090 Multi-stage AC/DC EMI Filter with Excellent Attenuation Performance Rated currents from 1 to 30 A Approvals Two-stage filter Very high differential and common-mode attenuation Optional medical versions (B type) Optional safety versions (A type) Optional enhanced performance versions Optional overvoltage protection (Z type) Features and benefits FN 2090 two-stage filters are designed for easy and fast chassis mounting. Performance indicators The FN 2090 filters are also available as B versions with no Y-capacitors for medical applications as well as A versions with low capacitance for safety critical applications with a requirement for low leakage currents. FN 2090 filters offers an optimized filter range for enhanced performance AC and DC applications , in same compact size (KK, LL, NN types) All filters provide an exceptional conducted attenuation performance, based on chokes with high permeable core material and excellent thermal behaviour. FN 2090 two-stage filters are designed for noisy applications requiring excellent filter performance. Technical specifications Rated voltage* Operating frequency Rated currents High potential test voltage 250 VAC, 50/60 Hz; 250 VDC DC to 400 Hz 1 to 30 A @ 40°C max. P –> PE 2000 VAC for 2 sec (equiv. cap PE 2550 VDC for 2 sec (equiv. cap >88 nF) P –> PE 2500 VAC for 2 sec (B types) P –> N 1100 VDC for 2 sec Temperature range (operation and storage) Certified to -25°C to +100°C (25/100/21) Flammability corresponding to Surge pulse protection (Z type) UL 94 V-2 or better MTBF @ 40°C/230 V (Mil-HB-217F) 1,300,000 hours (1 to 10 A types) 1,100,000 hours (12 A types) 517,000 hours (16 and 30 A types) UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (applies to AC and DC applications) Helps compliance to IEC61000-4-5 (Differential Mode only) *maximum RMS operating voltage at rated frequency or the maximum DC operating voltage The higher inductivity versus amperage offers increased attenuation performance with the same form factor compared to FN 2060 and FN 2080 filter series. All FN 2090 filters can be delivered with optional surge pulse protection (Z type). FN 2090 filters are also available as singlestage filters (FN 2030 series). Various terminal options allow you to select the desired connection style. Typical applications Electrical and electronic equipment Consumer goods Household equipment Building automation Industrial applications Machinery Medical equipment Electronic data processing equipment Office automation and datacom equipment Various noisy applications requiring high filter performance Typical electrical schematic (optional) Z Cx R L Cx L Cx P(DC+) P'(DC+') N(DC-) N'(DC-') PE Cy1 LINE Cy2 LOAD 2 EMC/EMI Products Schaffner Group Datasheets 15 Mar 2019 Filter selection table Filter* Rated current Leakage current** Inductance Resistance Input/Output @ 40°C (25°C) @ 250V AC/50 Hz L Cx Capacitance Cy1 Cy2 R connections Weight (@ 120V AC/60 Hz) [A] [mA] [mH] [μF] [nF] [nF] [kΩ] FN 2090-1-.. 1 (1.1) 0.45 (0.26) 20 0.22 2.2 1.0 680 -06 -07 73 FN 2090-3-.. 3 (3.4) 0.45 (0.26) 14 0.33 2.2 1.0 470 -06 -07 158 FN 2090-4-.. 4 (4.5) 0.45 (0.26) 14 0.33 2.2 1.0 470 -06 -07 176 FN 2090-6-.. 6 (6.7) 0.61 (0.35) 8 0.47 3.3 1.0 330 -06 -07 191 330 FN 2090-8-.. [g] 8 (8.9) 0.61 (0.35) 8 0.47 3.3 1.0 330 -06 -07 FN 2090-10-.. 10 (11.2) 0.61 (0.35) 8 0.47 3.3 1.0 330 -06 -07 369 FN 2090-12-.. 12 (13.4) 0.93 (0.54) 4 1 10 1.0 220 -06 -07 391 FN 2090-16-.. 16 (17.9) 0.93 (0.54) 4 1 10 1.0 220 -06 -07 425 FN 2090-20-.. 20 (22.4) 0.93 (0.54) 2.7 1 10 1.0 220 -06 FN 2090-30-08 30 (33.5) 0.93 (0.54) 1.5 1 10 1.0 220 FN 2090 A-1-.. 1 (1.1) 0.13 (0.07) 20 0.22 0.47 0.47 680 -06 -07 73 FN 2090 A-3-.. 3 (3.4) 0.13 (0.07) 14 0.33 0.47 0.47 470 -06 -07 158 FN 2090 A-4-.. 4 (4.5) 0.13 (0.07) 14 0.33 0.47 0.47 470 -06 -07 176 FN 2090 A-6-.. 6 (6.7) 0.13 (0.07) 8 0.47 0.47 0.47 330 -06 -07 191 330 FN 2090 A-8-.. -08 530 -08 548 8 (8.9) 0.13 (0.07) 8 0.47 0.47 0.47 330 -06 -07 FN 2090 A-10-.. 10 (11.2) 0.13 (0.07) 8 0.47 0.47 0.47 330 -06 -07 369 FN 2090 A-12-.. 12 (13.4) 0.13 (0.07) 4 1 0.47 0.47 220 -06 -07 391 FN 2090 A-16-.. 16 (17.9) 0.13 (0.07) 4 1 0.47 0.47 220 -06 -07 FN 2090 A-20-.. 20 (22.4) 0.13 (0.07) 2.7 1 0.47 0.47 220 -06 FN 2090 B-1-.. 1 (1.1) 0.00 20 0.22 680 -06 -07 73 FN 2090 B-3-.. 3 (3.4) 0.00 14 0.33 470 -06 -07 158 FN 2090 B-4-.. 4 (4.5) 0.00 14 0.33 470 -06 -07 176 FN 2090 B-6-.. 6 (6.7) 0.00 8 0.47 330 -06 -07 191 FN 2090 B-8-.. 425 -08 530 8 (8.9) 0.00 8 0.47 330 -06 -07 330 FN 2090 B-10-.. 10 (11.2) 0.00 8 0.47 330 -06 -07 369 FN 2090 B-12-.. 12 (13.4) 0.00 4 1 220 -06 -07 391 FN 2090 B-16-.. 16 (17.9) 0.00 4 1 220 -06 -07 FN 2090 B-20-.. 20 (22.4) 0.00 2.7 1 220 -06 FN 2090 B-30-08 30 (33.5) 0.00 1.5 1 220 425 -08 530 -08 548 Enhanced performance FN 2090 KK-1-06 1 (1.15) 3.46 (1.99) 20 0.22 22 22 680 -06 95 FN 2090 NN-3-06 3 (3.4) 15.71 (9.05) 14 0.33 100 100 470 -06 200 FN 2090 NN-4-06 4 (4.5) 15.71 (9.05) 14 0.33 100 100 470 -06 210 FN 2090 NN-6-06 6 (6.7) 15.71 (9.05) 8 0.47 100 100 330 -06 220 FN 2090 NN-8-06 8 (8.9) 15.71 (9.05) 8 0.47 100 100 330 -06 340 FN 2090 LL-10-06 10 (11.2) 5.18 (2.98) 8 0.47 33 33 330 -06 470 FN 2090 LL-12-06 12 (13.4) 5.18 (2.98) 4 1 33 33 220 -06 500 FN 2090 LL-16-06 16 (17.9) 5.18 (2.98) 4 1 33 33 220 -06 20 (23) 5.18 (2.98) 2.7 1 33 33 220 -06 30 (33.5) 5.18 (2.98) 1.5 1 33 33 220 FN 2090 LL-20-.. FN 2090 LL-30-08 530 -08 580 -08 600 ** To compile a complete part number, please replace the -.. with the required I/O connection style. ** For surge pulse protection, please add Z (e.g. FN 2090Z-10-06, FN 2090BZ-20-08). The different letters code the used Cy values in the filter type (A = 0.47nF; K = 22nF; L = 33nF; N = 100nF; as the FN2090 is a dual stage filter each letter stands for one stage of Cy) ** Maximum leakage under usual AC operating conditions (acc. IEC 60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Leakage current for DC application is 0 mA 3 Schaffner Group EMC/EMI Products Typical filter attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym Standard Types 1 to 4 A types 6 to 10 A types 12 to 20 A types 30 A types 12 to 20 A types 30 A types Enhanced Performance Types 1 to 4 A types 6 to 10 A types Datasheets 15 Mar 2019 4 EMC/EMI Products Schaffner Group Datasheets 15 Mar 2019 Product selector Mechanical data Connection style -06, 1 A types Connection style -06, 3 to 20 A types Connection style -07, 1 A types (same dimensions as style -06) Connection style -07, 3 to 20 A types (same dimensions as style -06) Connection style -08, 20 and 30 A types 5 Schaffner Group EMC/EMI Products Datasheets 15 Mar 2019 Dimensions 1A 3A 4A 6A 8A 10 A 12 A 16 A 20 A 30 A Tolerances A 71 85 85 85 113.5 ±1 113.5 ±1 113.5 ±1 113.5 ±1 113.5 ±1 113.5 ±1 ±0.5 B 46.6 54 54 54 57.5 ±1 57.5 ±1 57.5 ±1 57.5 ±1 57.5 ±1 57.5 ±1 ±0.5 C 22.3 30.3 30.3 30.3 45.4 ±1 45.4 ±1 45.4 ±1 45.4 ±1 45.4 ±1 45.4 ±1 ±0.5 D 50.5 64.8 64.8 64.8 94 ±1 94 ±1 94 ±1 94 ±1 94 ±1 94 ±1 ±0.5 E 44.5 49.8 49.8 49.8 56 56 56 56 56 56 ±0.5 F 61 75 75 75 103 103 103 103 103 103 ±0.3 G 21 27 27 27 25 25 25 25 25 25 ±0.2 H 10.8 12.3 12.3 12.3 12.4 12.4 12.4 12.4 12.4 12.4 ±0.5 I 16.8 20.8 20.8 20.8 32.4 32.4 32.4 32.4 32.4 32.4 ±0.5 J 25.25 19.9 19.9 19.9 15.5 15.5 15.5 15.5 15.5 15.5 ±0.5 K 5.3 5.3 5.3 5.3 4.4 4.4 4.4 4.4 4.4 4.4 L 6.3 6.3 6.3 6.3 6 6 6 6 6 6 M 0.7 0.7 0.7 0.7 1 1 1 1 1 1 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 ±0.3 Connection style -06 N Connection style -07 O 8.3 8.3 8.3 8.3 8.4 8.4 8.4 8.4 ±0.5 P 14 14.9 14.9 14.9 18 18 18 18 ±0.5 AWG type wire AWG 20 AWG 20 AWG 20 AWG 18 AWG 18 AWG 18 AWG 16 AWG 16 Wire length 140 140 140 140 140 140 140 140 +5 Connection style -08 N M4 M4 Recommended torque (Nm) 1.2 - 1.3 1.2 - 1.3 Earth terminal 1.5 - 1.7 1.5 - 1.7 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. 6 Schaffner Group EMC/EMI Products Datasheets 15 Mar 2019 Headquarters, global innovation and development Sales and application centers Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 info@schaffner.com China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai T +86 21 3813 9500 cschina@schaffner.com www.schaffner.com.cn Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 10 567 2855 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstorg 1 114 42 Stockholm T +46 8 5050 2425 swedensales@schaffner.com www.schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com India Schaffner India Pvt. Ltd REGUS WORLD TRADE CENTRE WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore T +91 80 67935355 indiasales@schaffner.com To find your local partner within Schaffner‘s global network: www.schaffner.com © 2018 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifications are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) T +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. Taiju-Seimei Sangenjaya Bldg. 1-32-12, Kamiuma, Setagaya-ku 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp Singapore Schaffner EMC Pte Ltd. #05-09, Kg Ubi Ind. Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 switzerlandsales@schaffner.com Taiwan R.O.C. Schaffner EMV Ltd. 20 Floor-2, No 97, Section 1, XinTai 5th Road 22175 XiZhi District New Taipei City 22175 T +886 2 2697 5500 F +886 2 2697 5533 taiwansales@schaffner.com www.schaffner.com.tw Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 5 Ashville Way, Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com USA Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffnerusa.com Schaffner North America 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 Schaffner North America 823 Fairview Road 24382 Wytheville, Virginia T +1 276 228 7943 F +1 276 228 7258
FN2090B-20-08 价格&库存
很抱歉,暂时无法提供与“FN2090B-20-08”相匹配的价格&库存,您可以联系我们找货
FN2090B-20-08
    • 1+544.08240
    • 30+519.00480
