FN389B-6/22
FN389B-6/22
    SCHAFFNER(夏弗纳)
    Module
FN389B-6/22 数据手册
By April 2005 Versatile power entry module FN 380 • • • • Up to 6A current ratings IEC 950-compliant (twin fuse configurations only) For one or two fuses (Ø5 x 20 or Ø6.3 x 32mm) General-purpose application • • • • Nennstrom bis 6A IEC 950 konform (nur Konfigurationen mit zwei Sicherungen) Für eine oder zwei Sicherungen (Ø5 x 20mm oder Ø6,3 x 32mm) Universeller Einsatz • Courants de service pouvant atteindre 6A • Conforme à CEI 950 (uniquement pour les configurations à deux fusibles) • Pour un ou deux fusibles (Ø5 x 20mm ou Ø6,3 x 32mm) • Applications universelles Filter selection table Approvals Choose the family FN xxx with the required body style and features, and add -?? to determine current rating. Example: FN 388-2 is a horizontal screw-mounting filter for twin fuses, rated for 2A, with mini fast-on outputs. Family FN FN FN FN 380 382 386 388 Current ratings A at 40°C (25°) -?? -?? -?? -?? /.. /.. /.. /.. EN 133200 IEC 60939 Housing style For fuse(s) Weight 2 (2.4) 4 (4.8) 6 (7.2) Nbr. g -2 -2 -2 -2 -4 -4 -4 -4 -6 -6 -6 -6 1 2 1 2 55 55 55 60 For fuse(s) Weight Inductance L 0.7 Family mH 0.3 0.18 Current ratings A at 40°C (25°) Housing style 2 (2.4) 4 (4.8) 6 (7.2) Nbr. g -2 -2 -4 -4 -6 -6 2 2 65 70 FN 385 -?? /.. FN 389 -?? /.. Inductance L 2 mH 0.8 0.5 Additional specifications Filter type All standard types FN 389B types (medical) Capacitance Cx nF Cy nF 47 47 2.2 Maximum leakage Res. μA/phase R MΩ 190 2 1 Maximum operating volt. Operating frequency Hipot test voltage VAC Hz Hz PN¤E VAC 250 250 50/60 50/60 50 to 400 50 to 400 2000 2500 P¤N VDC 1100 1100 MTBF at 40°C, 230V, per Mil-HB-217F: 550,000 hours B types are optional 87 Filter selection: additional specifications Ordering information: The filters of this family can be ordered as standard, fully mounted products (excluding the fuse) as follows: FN 389 & - 6 / x y fuse holder 1 = fuse 5Ø x 20 (FUSE-H EUR-1) 2 = fuse 6.3Ø x 32 (FUSE-H USA-1) rocker switch type 2 = 2-pole, dark (not illuminated) 250VAC (SWI-R 2D-1) Fuse holder description Fuse Holder Part no. Size 1 2 FUSE-H-EUR-1 FUSE-H-USA-1 5 x 20mm 6.3 x 32mm current rating (A) B = medical version (without Y caps) filter type Rocker switch description Rocker Part no. switch type Function 2-pole, dark 2-pole, illuminated, 100-250 VAC* 2 2-pole, dark (not illuminated) 250VAC Rated current: 6 (4)A/250V Rated current: 6 (2)A/250V 50,000 on-off operations 10,000 on-off operations • full illumination at 100VA • max. operating temperature for red: 65°C SWI-R 2D-1 Values in ( ) relate to the inductive current charge, cos γ = 0.65 * Attention: illuminated rocker switch only available on special request Electrical schematics ROCKER SWITCH 2-POLE FN 382/385/388/389 2xL Cx 2xCy M K H N E P L J G LINE LOAD ROCKER SWITCH 2-POLE FN 389B Cx R 2xL M K H L G N E P J LOAD LINE ROCKER SWITCH 2-POLE FN 380/386 Cx 2xL 2xCy M N E P L LINE See tables for component values 88 J G LOAD FN 380 insertion loss Per CISPR 17; A = 50Ω/50Ω sym, B = 50Ω/50Ω asym, C = 0.1Ω/100Ω sym, D = 100Ω/0.1Ω sym 2 amp types (FN 380/382/386/388) 4 amp types (FN 380/382/386/388) 4 amp types (FN 385/389) 6 amp types (FN 385/389) 6 amp types (FN 380/382/386/388) 2 amp types (FN 385/389) Mechanical data / electrical connection summary FN 380/82 A B C D F H M N P R S (1) FN 385 FN 386/88 32 FN 389 50 ± 0.3 ± 0.3 ± 0.1 ± 0.1 58 40 56.5 66.5 56.5 Tol. mm 66.5 5.5 Ø3.3 R≤2 55.9 (1) - 56.2 (2) 28.5 (2) 1) 0.8 - 2.0mm 55.9 + 0.2 -0 2) 2.1 - 3.2mm 56.2 + 0.2 -0 +0.2 –0 +0.2 –0 M3 90° Wall thickness 0.8mm to 2.0mm Thickness of mounting panels - Wall thickness 2.1mm to 3.2mm F FN 380, FN 382, FN 385 P M 0.08 2) N B 1) A D FN 386, FN 388, FN 389 G J H K L M Rear view C P F M H 0.08 B R S 2) N 1) C A D All dimensions in mm; 1 inch = 25.4mm 89
FN389B-6/22 价格&库存
很抱歉,暂时无法提供与“FN389B-6/22”相匹配的价格&库存,您可以联系我们找货
