FN9233UF2-1-06
FN9233UF2-1-06
    SCHAFFNER(夏弗纳)
    Module
FN9233UF2-1-06 数据手册
IEC Inlet Filters FN 9233 High Performance IEC Inlet Filter n Rated currents up to 15A Excellent attenuation performance n Optional medical versions (B type) according to IEC/EN 60601-1 n Snap-in versions (S and S1 type) n Hot inlet versions (HI type) Approvals n Technical specifications Maximum continuous operating voltage: Operating frequency: Rated currents: Approvals by rated current: High potential test voltage: Protection category: Temperature range (operation and storage): Design corresponding to: Flammability corresponding to: MTBF @ 40°C/230V (Mil-HB-217F): Typical electrical schematic 250VAC, 50/60Hz dc to 400Hz 1 to 15A @ 50°C 1 to 10A (ENEC, CQC) 1 to 15A (UL, CSA) P –> PE 2000VAC for 2 sec (standard types) P –> PE 2500VAC for 2 sec (B types) P –> N 1000VAC for 2 sec IP40 according to IEC 60529 -25°C to +85°C (25/85/21) UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 UL 94V-2 or better 2,540,000 hours Standard, R and B types Cx R 2xL 2xCy N N‘ PE PE P‘ P Load Line F2 types Cx 2xL Cx 2xCy N N‘ PE PE P‘ P Line Features and benefits Typical applications The FN 9233 IEC inlet filter combines an n n excellent IEC inlet and mains filter with performance, based on chokes with high equipment excellent filter attenuation in a small form saturation resistance and excellent thermal n Exceptional conducted attenuation Portable electrical and electronic Small to medium-sized machines and factor. Choosing the FN 9233 product line behavior. household equipment brings you the rapid availability of a standard n Rear/front or snap-in mounting. n filter associated with the necessary safety n Optional earth line choke see FN 9233E acceptances. Standard IEC connector filters data sheet. n Test and measurement equipment are a practical solution helping you to pass n n Medical equipment EMI system approval in a short time. A wide with the requirements of IEC/EN 60601-1 n Rack mounting equipment selection on amperage ratings, output for creepage and clearance, leakage connections, mounting possibilities and filters current and high potential testing. for medical applications are designed to offer n Wide mounting flanges available. you the desired solution. For types with n Different output connections offering Optional medical versions (B type) comply additional earth line choke please consult the maximum flexibility for assembly. FN 9233E data sheet. n Custom-specific versions are available on request. Load Single-phase power supplies, switch-mode power supplies > Components > FN 9233 Filter selection table Filter Rated current Leakage current* @ 50°C (25°C) @ 250VAC/50Hz Inductance L Cx1 Capacitance Cx2 Cy Resistance Output connections R FN 9233x-1-06 FN 9233x-3-06 FN 9233x-6-06 FN 9233x-8-06 FN 9233x-10-06 FN 9233x-12-06 FN 9233x-15-06 FN 9233x-12-06HI FN 9233x-15-06HI [A] 1 (1.2) 3 (3.5) 6 (7.2) 8 (10.6) 10 (11.6) 12 (12) 15 (15) 12 (12) 15 (15) [µA] 373 373 373 373 373 373 373 373 373 [mH] 22.5 4.6 1.6 0.9 0.45 0.27 0.2 0.27 0.2 FN 9233xR-1-06 FN 9233xR-3-06 FN 9233xR-6-06 FN 9233xR-8-06 FN 9233xR-10-06 FN 9233xR-12-06 FN 9233xR-15-06 FN 9233xR-12-06HI FN 9233xR-15-06HI 1 (1.2) 3 (3.5) 6 (7.2) 8 (10.6) 10 (11.6) 12 (12) 15 (15) 12 (12) 15 (15) 373 373 373 373 373 373 373 373 373 22.5 4.6 1.6 0.9 0.45 0.27 0.2 0.27 0.2 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 1000 1000 1000 1000 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -06 -06 -06 -06 37 37 37 37 37 37 37 37 37 FN 9233xB-1-06 FN 9233xB-3-06 FN 9233xB-6-06 FN 9233xB-8-06 FN 9233xB-10-06 FN 9233xB-12-06 FN 9233xB-15-06 FN 9233xB-12-06HI FN 9233xB-15-06HI 1 (1.2) 3 (3.5) 6 (7.2) 8 (10.6) 10 (11.6) 12 (12) 15 (15) 12 (12) 15 (15) 2 2 2 2 2 2 2 2 2 22.5 4.6 1.6 0.9 0.45 0.27 0.2 0.27 0.2 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 1000 1000 1000 1000 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -06 -06 -06 -06 37 37 37 37 37 37 37 37 37 FN 9233UF2-1-06 FN 9233UF2-3-06 FN 9233UF2-6-06 FN 9233UF2-8-06 FN 9233UF2-10-06 FN 9233UF2-12-06 FN 9233UF2-15-06 1 (1.2) 3 (3.5) 6 (7.2) 8 (10.6) 10 (11.6) 12 (12) 15 (15) 560 560 560 560 560 560 560 22.5 4.6 1.6 0.9 0.45 0.27 0.2 3.3 3.3 3.3 3.3 3.3 3.3 3.3 -06 -06 -06 -06 -06 -06 -06 46 46 46 46 46 46 46 * [µF] [µF] [nF] [kΩ] 0.1 2.2 -06 0.1 2.2 -06 0.1 2.2 -06 0.1 2.2 -06 0.1 2.2 -06 0.1 2.2 -06 0.1 2.2 -06 0.1 2.2 -06 0.1 2.2 -06 Weight 0.047 0.047 0.047 0.047 0.047 0.047 0.047 0.047 0.047 0.047 0.047 0.047 0.047 0.047 Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. [g] 37 37 37 37 37 37 37 37 37 > Components > FN 9233 Product selector FN 9233xx-yy-..HI-zz Snap-in range for S version only Blank: Snap-in range 0.7 to 1.5mm 20: Snap-in range 1.5 to 2.2mm Blank: Standard IEC inlet type C14 HI: Hot IEC inlet type C16 (12 and 15A types only) 06: Faston 6.3 x 0.8mm (spade/soldering) 1 to 15: Rated current Blank: Standard version R: Bleed resistor B: Medical version (with bleed resistor and without Y2-capacitor) F2: 2 X-capacitors and higher Y-capacitor value Blank: Standard housing with mounting flanges U: Housing with wider mounting flanges S: Snap-in version, snapper on vertical side S1: Snap-in version, snapper on horizontal side For example: FN 9233-15-06, FN 9233S1B-10-06-20, FN 9233R-12-06HI Typical filter attenuation Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym; C = 0.1Ω/100Ω sym; D = 100Ω/0.1Ω sym FN 9233: 1 and 3A types FN 9233: 6 to 10A types FN 9233: 12 and 15A types FN 9233UF2: 1 and 3A types FN 9233UF2: 6 to 10A types FN 9233UF2: 12 and 15A types > Components > FN 9233 Mechanical data FN 9233 FN 9233-HI IEC plug type C14 B 6.3 x 0.8 IEC plug type C16 B A C E A C J E H F G 6.3 x 0.8 S S H I D J F G FN 9233S D I FN 9233S1 B B 6.3 x 0.8 A C14 G A J E F D FN 9233U Installation B C14 6.3 x 0.8 S J E C H F G Panel cut out M N P C R D I A J E G I C14 6.3 x 0.8 T F D I > Components > FN 9233 Dimensions FN 9233 FN 9233U FN 9233UF2 FN 9233S FN 9233S1 FN 9233-HI A 48 51.85 51.85 29.9 29.9 48 B 22.5 25 25 22.4 22.4 22.5 C 40 ±0.2 40 ±0.2 40 ±0.2 40 ±0.2 D 38.4 38.25 46.8 38.4 38.4 38.4 E 27.8 27.8 27.8 27.8 27.8 27.8 F 5.5 5.5 5.5 5.5 5.5 5.5 G 20.1 20.1 20.1 20.1 20.1 20.1 H Ø3.3 Ø3.3 Ø3.3 Ø3.3 I 14 14.1 14 14 14 14 J 13.3 13.3 13.3 13.3 13.3 13.3 M R ≤ 3 R ≤ 3 R ≤ 3 R ≤ 1.5 R ≤ 1.5 R≤3 N 21.5 21.5 21.5 20.8 21.9 21.5 P 28.5 28.5 28.5 29.4 28.5 28.5 R M3 M3 M3 M3 S 90° 90° 90° 90° T* 0.7 - 1.5 0.7 - 1.5 T* 1.5 - 2.2 1.5 - 2.2 * For selecting the panel thickness, please refer to the filter selector table. All dimensions in mm; 1 inch = 25.4mm Tolerances according: ISO 2768-m / EN 22768-m Your local partner: To find your local partner within Schaffner’s global network, please go to www.schaffner.com May 2011 Headquarters and global innovation and development center Schaffner Group Nordstrasse 11 4542 Luterbach Switzerland T +41 32 681 66 26 F +41 32 681 66 30 info@schaffner.ch www.schaffner.com Sales and application centers China Schaffner EMC Ltd. Shanghai Building 11, Lane 1365 East Kangqiao Road Shanghai 201319 T +86 21 6813 9855 F +86 21 6813 9811 cschina@schaffner.com www.schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com Finland Schaffner Oy Tynninkuja 7 08700 Lohja T +358 19 35 72 71 F +358 19 32 66 10 finlandsales@schaffner.com France Schaffner EMC S.A.S. 112, Quai de Bezons 95103 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Italy Schaffner EMC S.r.l. Via Galileo Galilei, 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45/47 F +39 02 61 23 943 italysales@schaffner.com Japan Schaffner EMC K.K. Mitsui-Seimei Sangenjaya Bldg. 7F 1-32-12, Kamiuma, Setagaya-ku Tokyo 154-0011 T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 F +41 32 681 66 41 sales@schaffner.ch To find your local partner within Schaffner‘s global network, please go to Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 05-09 Kampong Ubi Industrial Estate T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com © 2011 Schaffner EMC. Specifications subject to change without notice. All trademarks recognized. Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de la Moraleja, Alcobendas 28109 Madrid T +34 618 176 133 spainsales@schaffner.com Taiwan Schaffner EMV Ltd. 6th Floor, No 413 Rui Guang Road Neihu District Taipei City 114 T +886 2 87525050 F+886 2 87518086 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muang P.O. Box 14 Lamphun 51000 T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way Molly Millars Lane Wokingham Berkshire RG41 2PL T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com www.schaffner.uk.com USA Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey 08837 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffner.com/us www.schaffner.com May 2011 Schaffner is an ISO-registered company. Its products are designed and manufactured under the strict quality and environmental requirements of the ISO 9001 and ISO 14001 standards. This document has been carefully checked. However, Schaffner does not assume any liability for errors or inaccuracies.
FN9233UF2-1-06 价格&库存
很抱歉,暂时无法提供与“FN9233UF2-1-06”相匹配的价格&库存,您可以联系我们找货
