FN2090-30-08
FN2090-30-08
    SCHAFFNER(夏弗纳)
    FN2090-30-08
FN2090-30-08 数据手册
DATASHEET Two-Stage Filters FN 2090 Multi-stage EMI Filter with Excellent Attenuation Performance Rated currents from 1 to 30 A Approvals Two-stage filter Very high differential and common-mode attenuation Optional medical versions (B type) Optional safety versions (A type) Optional overvoltage protection (Z type) Features and benefits FN 2090 two-stage filters are designed for easy and fast chassis mounting. Performance indicators The FN 2090 filters are also available as B versions with no Y-capacitors for medical applications as well as A versions with low capacitance for safety critical applications with a requirement for low leakage currents. All filters provide an exceptional conducted attenuation performance, based on chokes with high permeable core material and excellent thermal behavior. FN 2090 two-stage filters are designed for noisy applications requiring excellent filter performance. The higher inductivity versus amperage offers increased attenuation performance with the same form factor compared to FN 2060 and FN 2080 filter series. Technical specifications Operating voltage 110/250 VAC, 50/60 Hz Operating frequency dc to 400 Hz Rated currents 1 to 30 A @ 40°C max. High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 1100 VDC for 2 sec Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Flammability corresponding to UL 94 V-2 or better Surge pulse protection (optional) 2 kV, IEC 61000-4-5 MTBF @ 40°C/230 V (Mil-HB-217F) 1,300,000 hours (1 to 10 A types) 1,100,000 hours (12 A types) 517,000 hours (16 and 30 A types) Temperature range (operation and storage) -25°C to +100°C (25/100/21) All FN 2090 filters can be delivered with optional surge pulse protection. FN 2090 filters are also available as singlestage filters (FN 2030 series). Various terminal options allow you to select the desired connection style. Typical applications Electrical and electronic equipment Consumer goods Household equipment Building automation Industrial applications Machinery Medical equipment Electronic data processing equipment Office automation and datacom equipment Various noisy applications requiring high filter performance Typical electrical schematic 2 Schaffner Group EMC/EMI Products Datasheets 2016 Filter selection table Filter* Rated current Leakage current** Inductance @ 40°C (25°C) @ 230V AC/50 Hz L Cx Capacitance Cy Resistance Input/Output Cy1 R connections [A] [mA] [mH] [μF] [nF] FN 2090-1-.. 1 (1.1) 0.5 20 0.22 2.2 FN 2090-3-.. 3 (3.4) 0.5 14 0.33 2.2 FN 2090-4-.. 4 (4.5) 0.5 14 0.33 FN 2090-6-.. 6 (6.7) 0.67 8 0.47 FN 2090-8-.. 8 (8.9) 0.67 8 0.47 FN 2090-10-.. 10 (11.2) 0.67 8 FN 2090-12-.. 12 (13.4) 1.02 FN 2090-16-.. 16 (17.9) FN 2090-20-.. FN 2090-30-08 Weight [nF] [kΩ] 1.0 680 -06 -07 73 1.0 470 -06 -07 158 2.2 1.0 470 -06 -07 176 3.3 1.0 330 -06 -07 191 3.3 1.0 330 -06 -07 330 0.47 3.3 1.0 330 -06 -07 369 4 1 10 1.0 220 -06 -07 391 1.02 4 1 10 1.0 220 -06 -07 20 (22.4) 1.02 2.7 1 10 1.0 220 -06 30 (33.5) 1.02 1.5 1 10 1.0 220 [g] 425 -08 530 -08 548 FN 2090A-1-.. 1 (1.1) 0.08 20 0.22 0.47 0.47 680 -06 -07 73 FN 2090A-3-.. 3 (3.4) 0.08 14 0.33 0.47 0.47 470 -06 -07 158 FN 2090A-4-.. 4 (4.5) 0.08 14 0.33 0.47 0.47 470 -06 -07 176 FN 2090A-6-.. 6 (6.7) 0.08 8 0.47 0.47 0.47 330 -06 -07 191 8 (8.9) 0.08 8 0.47 0.47 0.47 330 -06 -07 330 FN 2090A-10-.. 10 (11.2) 0.08 8 0.47 0.47 0.47 330 -06 -07 369 FN 2090A-12-.. 12 (13.4) 0.08 4 1 0.47 0.47 220 -06 -07 391 FN 2090A-16-.. 16 (17.9) 0.08 4 1 0.47 0.47 220 -06 -07 425 FN 2090A-20-.. 20 (22.4) 0.08 2.7 1 0.47 0.47 220 -06 FN 2090A-8-.. -08 530 FN 2090B-1-.. 1 (1.1) 0.002 20 0.22 680 -06 -07 73 FN 2090B-3-.. 3 (3.4) 0.002 14 0.33 470 -06 -07 158 FN 2090B-4-.. 4 (4.5) 0.002 14 0.33 470 -06 -07 176 FN 2090B-6-.. 6 (6.7) 0.002 8 0.47 330 -06 -07 191 8 (8.9) 0.002 8 0.47 330 -06 -07 330 FN 2090B-10-.. 10 (11.2) 0.002 8 0.47 330 -06 -07 369 FN 2090B-12-.. 12 (13.4) 0.002 4 1 220 -06 -07 391 FN 2090B-16-.. 16 (17.9) 0.002 4 1 220 -06 -07 FN 2090B-20-.. 20 (22.4) 0.002 2.7 1 220 -06 FN 2090B-30-08 30 (33.5) 0.002 1.5 1 220 FN 2090B-8-.. ** To compile a complete part number, please replace the -.. with the required I/O connection style. ** For surge pulse protection, please add Z (e.g. FN 2090Z-10-06, FN 2090BZ-20-08). ** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Typical filter attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym 1 to 4 A types 6 to 10 A types 12 to 20 A types 30 A types 425 -08 530 -08 548 3 Schaffner Group EMC/EMI Products Datasheets 2016 Mechanical data Connection style -06, 1 A types Connection style -06, 3 to 20 A types Connection style -07, 1 A types (same dimensions as style -06) Connection style -07, 3 to 20 A types (same dimensions as style -06) Connection style -08, 20 and 30 A types 4 Schaffner Group EMC/EMI Products Datasheets 2016 Dimensions 1A 3A 4A 6A 8A 10 A 12 A 16 A 20 A 30 A Tolerances A 71 85 85 85 113.5 ±1 113.5 ±1 113.5 ±1 113.5 ±1 113.5 ±1 113.5 ±1 ±0.5 B 46.6 54 54 54 57.5 ±1 57.5 ±1 57.5 ±1 57.5 ±1 57.5 ±1 57.5 ±1 ±0.5 C 22.3 30.3 30.3 30.3 45.4 ±1 45.4 ±1 45.4 ±1 45.4 ±1 45.4 ±1 45.4 ±1 ±0.5 D 50.5 64.8 64.8 64.8 94 ±1 94 ±1 94 ±1 94 ±1 94 ±1 94 ±1 ±0.5 E 44.5 49.8 49.8 49.8 56 56 56 56 56 56 ±0.5 F 61 75 75 75 103 103 103 103 103 103 ±0.3 G 21 27 27 27 25 25 25 25 25 25 ±0.2 H 10.8 12.3 12.3 12.3 12.4 12.4 12.4 12.4 12.4 12.4 ±0.5 I 16.8 20.8 20.8 20.8 32.4 32.4 32.4 32.4 32.4 32.4 ±0.5 J 25.25 19.9 19.9 19.9 15.5 15.5 15.5 15.5 15.5 15.5 ±0.5 K 5.3 5.3 5.3 5.3 4.4 4.4 4.4 4.4 4.4 4.4 L 6.3 6.3 6.3 6.3 6 6 6 6 6 6 M 0.7 0.7 0.7 0.7 0.9 0.9 0.9 0.9 0.9 0.9 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 Connection style -06 N Connection style -07 O 8.3 8.3 8.3 8.3 8.4 8.4 8.4 8.4 ±0.5 P 14 14.9 14.9 14.9 18 18 18 18 ±0.5 AWG 20 AWG 20 AWG 20 AWG 18 AWG 18 AWG 18 AWG 16 AWG 16 140 140 140 140 140 140 140 140 AWG type wire Wire length Connection style -08 N All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. M4 M4 5 Schaffner Group EMC/EMI Products Headquarters, global innovation and development Sales and application centers Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 F +41 32 681 66 30 info@schaffner.com www.schaffner.com China Schaffner EMC Ltd. Shanghai T20-3, No 565 Chuangye Road Pudong New Area 201201 Shanghai T +86 21 3813 9500 F +86 21 3813 9501 / 02 cschina@schaffner.com www.schaffner.com.cn Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 19 35 72 71 finlandsales@schaffner.com France Schaffner EMC S.A.S. 112 Quai de Bezons Boîte postale 133 95100 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com India Schaffner India Pvt. Ltd Unit 59, Level, Mfar Greenheart 7 Manyata Tech Park, Hebbal Outer Ring Road 560045 Bangalore T +91 80 6781 9805 F +91 80 6781 9998 indiasales@schaffner.com To find your local partner within Schaffner‘s global network: www.schaffner.com © 2016 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifications are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Galileo Galilei 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45 /47 F +39 02 61 23 943 italysales@schaffner.com Japan Schaffner EMC K.K. 1-32-12, Kamiuma, Setagaya-ku 7F Mitsui-seimei Sangenjaya Bldg. 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Datasheets Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 switzerlandsales@schaffner.com Taiwan R.O.C. Schaffner EMV Ltd. 6 Floor, No. 413, Rui Guang Road 114 Neihu District Taipei City T +886 2 87525050 F +886 2 87518086 taiwansales@schaffner.com www.schaffner.tw Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way, Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com USA Schaffner EMC Inc. 52 Mayfield Avenue 08837 Edison, New Jersey T +1 800 367 5566 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffnerusa.com Schaffner North America 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 Schaffner North America 823 Fairview Road 24382 Wytheville, Virginia T +1 276 228 7943 F +1 276 228 7258 2016
FN2090-30-08 价格&库存
很抱歉,暂时无法提供与“FN2090-30-08”相匹配的价格&库存,您可以联系我们找货
FN2090-30-08
    • 10+643.28979
    • 20+630.42454
    • 40+617.81547
    库存:30
    FN2090-30-08
      • 1+781.01696
      • 3+765.40661
      • 5+742.43369
      库存:10
