FN2010N-30-08
FN2010N-30-08
    SCHAFFNER(夏弗纳)
    Power Line Filter General Purpose EMI 0Hz to 400Hz 30A 250VAC/250VDC Threaded Stud Chassis Mount
FN2010N-30-08 数据手册
DATASHEET Single-Stage Filters FN 2010 General Purpose AC/DC EMI Filter Rated currents from 1 to 60 A Approvals General purpose filtering performance Optional medical versions (B type) Optional safety versions (A type) Optional enhanced performance versions Optional DC optimized versions Features and benefits Performance indicators FN 2010 filters are designed for easy and fast chassis mounting FN 2010 filters are available as B versions without Ycapacitors for medical applications as well as A version with low capacitance for safety critical applications with necessity for low leakage currents FN 2010 filters are also available as enhanced performance and DC optimized versions. With higher attenuation in very compact housing (M, N1,N types) All filters provide a general purpose conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Technical specifications Rated voltage* Operating frequency Rated currents High potential test voltage FN 2010 filters can be used to cover a broad range of usage and they offer a good size/amperage ratio 250 VAC, 50/60 Hz; 250 VDC DC to 400 Hz Various terminal options allow you to select the desired connection style 1 to 60 A @ 40°C max. P –> PE 2000 VAC for 2 sec (equiv. cap PE 2550 VDC for 2 sec (equiv. cap >88 nF) P –> PE 2500 VAC for 2 sec (B types) P –> N 1100 VDC for 2 sec Typical applications Electrical and electronic equipment Consumer goods Temperature range (operation and storage) Certified to -25 °C to +100 °C (25/100/21) Flammability corresponding to MTBF @ 40°C/230 V (Mil-HB-217F) UL 94 V-2 or better Office automation equipment 1,250,000 hours 3,200,000 hours (B types) Datacom equipment UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (applies to AC and DC applications) *maximum RMS operating voltage at rated frequency or the maximum DC operating voltage Household equipment Medical equipment Typical electrical schematic 2 Schaffner Group EMC/EMI Products Datasheets 14 Mar 2019 Filter selection table Filter* Rated current Leakage current** Inductance @ 40°C (25°C) @ 250 VAC/50 Hz L Capacitance Cx Cy Resistance Input/Output R connections Weight (@ 120 VAC/60 Hz) [A] [mA] [mH] [μF] [nF] [kΩ] FN 2010-1-.. 1 (1.15) 0.66 (0.38) 12 0.1 4.7 1000 -06 -07 65 FN 2010-3-.. 3 (3.45) 0.66 (0.38) 2.5 0.1 4.7 1000 -06 -07 65 FN 2010-6-.. 6 (6.9) 0.66 (0.38) 1 0.1 4.7 1000 -06 -07 65 FN 2010-10-.. 10 (11.5) 0.66 (0.38) 0.8 0.1 4.7 1000 -06 -07 85 FN 2010-12-.. 12 (13.8) 0.66 (0.38) 0.7 0.1 4.7 1000 -06 -07 85 FN 2010-16-.. 16 (18.4) 0.66 (0.38) 0.7 0.1 4.7 1000 -06 -07 FN 2010-20-.. 20 (23) 0.66 (0.38) 0.6 0.1 4.7 1000 -06 -07 [g] 140 -08 210 FN 2010-30-08 30 (34.5) 0.79 (0.46) 0.7 0.47 10 1000 -08 470 FN 2010-60-24 60 (69) 0.79 (0.46) 1 1.5 10 330 -24 1100 FN 2010 A-1-.. 1 (1.15) 0.07 (0.04) 12 0.1 0.47 1000 -06 -07 65 FN 2010 A-3-.. 3 (3.45) 0.07 (0.04) 2.5 0.1 0.47 1000 -06 -07 65 FN 2010 A-6-.. 6 (6.9) 0.07 (0.04) 1 0.1 0.47 1000 -06 -07 65 FN 2010 A-10-.. 10 (11.5) 0.07 (0.04) 0.8 0.1 0.47 1000 -06 -07 85 FN 2010 A-12-.. 12 (13.8) 0.07 (0.04) 0.7 0.1 0.47 1000 -06 -07 85 FN 2010 A-16-.. 16 (18.4) 0.07 (0.04) 0.7 0.1 0.47 1000 -06 -07 140 -06 -07 FN 2010 A-20-.. 20 (23) 0.07 (0.04) 0.6 0.1 0.47 1000 FN 2010 A-30-08 30 (34.5) 0.07 (0.04) 0.7 0.47 0.47 1000 -08 470 FN 2010 A-60-24 60 (69) 0.07 (0.04) 1 1.5 0.47 330 -24 1100 FN 2010 B-1-.. 1 (1.15) 0.00 12 0.1 1000 -06 -07 65 FN 2010 B-3-.. 3 (3.45) 0.00 2.5 0.1 1000 -06 -07 65 FN 2010 B-6-.. 6 (6.9) 0.00 1 0.1 1000 -06 -07 65 FN 2010 B-10-.. 10 (11.5) 0.00 0.8 0.1 1000 -06 -07 85 FN 2010 B-12-.. 12 (13.8) 0.00 0.7 0.1 1000 -06 -07 85 FN 2010 B-16-.. 16 (18.4) 0.00 0.7 0.1 1000 -06 -07 140 -06 -07 FN 2010 B-20-.. -08 -08 210 20 (23) 0.00 0.6 0.1 1000 FN 2010 B-30-08 30 (34.5) 0.00 0.7 0.47 1000 -08 210 470 FN 2010 B-60-24 60 (69) 0.00 1 1.5 330 -24 1100 FN 2010 N1-1-06 1 (1.15) 5.34 (3.08) 12 0.1 68 1000 -06 70 FN 2010 N1-3-06 3 (3.45) 5.34 (3.08) 2.5 0.1 68 1000 -06 70 Enhanced performance FN 2010 N1-6-06 6 (6.9) 5.34 (3.08) 1 0.1 68 1000 -06 70 FN 2010 N1-10-06 10 (11.5) 5.34 (3.08) 0.8 0.1 68 1000 -06 85 FN 2010 N1-12-06 12 (13.8) 3.69 (2.13) 0.7 0.1 47 1000 -06 85 FN 2010 M-16-06 16 (18.4) 3.69 (2.13) 0.7 0.1 47 1000 -06 140 -06 FN 2010 M-20-.. 20 (23) 3.69 (2.13) 0.6 0.1 47 1000 FN 2010 N-30-08 30 (34.5) 7.85 (4.52) 0.7 0.47 100 1000 -08 -08 220 400 FN 2010 N-60-24 60 (69) 7.85 (4.52) 1 1.5 100 330 -24 1120 ** To compile a complete part number, please replace the -.. with the required I/O connection style (e.g. FN 2010-30-08, FN 2010B-10-06). The different letters code the used Cy values in the filter type (A = 0.47nF; M = 47nF; N1 = 47nF; N = 100nF) ** Maximum leakage under usual AC operating conditions (acc. IEC 60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. 3 Schaffner Group EMC/EMI Products Datasheets Typical filter attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym Standard types 1 and 3 A types 6 to 12 A types 16 and 20 A types 30 and 60 A types Enhanced performance types 1 A types 3 A types 6 A types 10 and 12 A types 16 A types 20 A types 30 A types 60 A types Product Selector 14 Mar 2019 4 Schaffner Group EMC/EMI Products Datasheets 14 Mar 2019 Mechanical data Connection style -06, 1 to 12 A types Connection style -06, 16 and 20 A types Connection style -07, 1 to 12 A types (same dimensions as style -06) Connection style -07, 16 and 20 A types (same dimensions as style -06) Connection style -08, 20 A types Connection style -08, 30 A types Connection style -24 5 Schaffner Group EMC/EMI Products Datasheets 14 Mar 2019 Dimensions 1A 3A 6A 10 A 12 A 16 A 20 A 30 A 60 A Tolerances A 64 64 64 64 64 71 85 113.5 ±1 105 ±1 ±0.5 B 35 35 35 35 35 46.6 54 57.5 ±1 145.9 ±1 ±0.5 C 24.3 24.3 24.3 29.3 29.3 29.3 30.3 45.4 ±1 57.6 ±1 ±0.5 D 43.5 43.5 43.5 43.5 43.5 50.5 64.8 94 ±1 84.5 ±1 ±0.5 E 32.5 32.5 32.5 32.5 32.5 44.5 49.8 56 99.5 ±0.5 F 54 54 54 54 54 61 75 103 95 ±0.3 G 21 21 21 21 21 21 27 25 40 ±0.2 H 9.3 9.3 9.3 9.3 9.3 10.8 12.3 12.4 19.6 ±0.5 I 15.3 15.3 15.3 15.3 15.3 19.3 20.8 32.4 10.1 ±0.5 J 21.8 21.8 21.8 21.8 21.8 20.1 19.9 15.5 42.25 ±0.5 K 5.3 5.3 5.3 5.3 5.3 5.3 5.3 4.4 4.4 L 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6 6 M 0.7 0.7 0.7 0.7 0.7 0.7 0.7 1 1.2 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 O 8.3 8.3 8.3 8.3 8.3 8.3 8.3 ±0.5 P 21.8 21.8 21.8 21.8 21.8 14 14.9 ±0.5 AWG type wire AWG 20 AWG 20 AWG 18 AWG 18 AWG 16 AWG 16 AWG 14 Wire length 140 140 140 140 140 140 140 ±0.3 Connection style -06 N Connection style -07 +5 Connection style -08 N M4 M4 Recommended torque (Nm) 1.2 - 1.3 1.2 - 1.3 Earth terminal 1.5 - 1.7 1.5 - 1.7 Connection style -24 N M6 Q 51 Recommended torque (Nm) 3.5 - 4 Earth Terminal 3.5 - 4 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connections. ±0.2 6 Schaffner Group EMC/EMI Products Datasheets 14 Mar 2019 Headquarters, global innovation and development Sales and application centers Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 info@schaffner.com China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai T +86 21 3813 9500 cschina@schaffner.com www.schaffner.com.cn Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 10 567 2855 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstorg 1 114 42 Stockholm T +46 8 5050 2425 swedensales@schaffner.com www.schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com India Schaffner India Pvt. Ltd REGUS WORLD TRADE CENTRE WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore T +91 80 67935355 indiasales@schaffner.com To find your local partner within Schaffner‘s global network: www.schaffner.com © 2018 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifications are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) T +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. Taiju-Seimei Sangenjaya Bldg. 1-32-12, Kamiuma, Setagaya-ku 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp Singapore Schaffner EMC Pte Ltd. #05-09, Kg Ubi Ind. Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 switzerlandsales@schaffner.com Taiwan R.O.C. Schaffner EMV Ltd. 20 Floor-2, No 97, Section 1, XinTai 5th Road 22175 XiZhi District New Taipei City 22175 T +886 2 2697 5500 F +886 2 2697 5533 taiwansales@schaffner.com www.schaffner.com.tw Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 5 Ashville Way, Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com USA Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffnerusa.com Schaffner North America 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 Schaffner North America 823 Fairview Road 24382 Wytheville, Virginia T +1 276 228 7943 F +1 276 228 7258
FN2010N-30-08
- 物料型号:FN 2010系列,包括多种额定电流版本,如1A、3A、6A等,直至60A。 - 器件简介:这些滤波器用于电气和电子设备,包括消费类商品、家用电器、医疗设备、办公自动化设备和数据通信设备等,提供通用的传导衰减性能。 - 引脚分配:文档提供了详细的连接风格和尺寸,例如-06、-07、-08和-24,以及推荐扭矩和接地终端信息。 - 参数特性:包括额定电压(250 VAC或250VDC)、工作频率(DC至400Hz)、额定电流(1至60A)、高电位测试电压、温度范围(-25°C至+100°C)等。 - 功能详解:FN 2010滤波器设计用于简易快速的机架安装,提供B版本(无Y电容器,适用于医疗应用)和A版本(低电容,适用于安全关键应用)。 - 应用信息:适用于广泛的使用范围,提供良好的尺寸/电流比,有多种端子选项可供选择。 - 封装信息:提供了详细的尺寸数据和公差,以及不同额定电流版本的物理尺寸。
FN2010N-30-08 价格&库存
很抱歉,暂时无法提供与“FN2010N-30-08”相匹配的价格&库存,您可以联系我们找货
