DATASHEET
IEC Inlet Filters FN9262
High Performance Power Entry Module with Fuses
Rated currents up to 10 A
Approvals & Compliances
Integrated dual fuse holder
Optional reduced leakage current versions (A/B
type)
Complies with IEC/EN 60601-1
Snap-in versions (S type)
High attenuation performance
NEW: Wire leads option
Performance indicators
The FN9262 power entry module combines an IEC
inlet, mains filter with very high filter attenuation
based on nanocrystalline material selection and fuses
in a small form factor. Choosing FN9262 product line
brings you rapid availability of a standard filter
associated with the necessary safety acceptances.
Standard IEC connector filters are a practical solution
helping you to pass EMI system approval in a short
time. A wide selection on amperage ratings,
mounting possibilities and filters for medical
applications (acc. to IEC 60601-1 with low leakage
current and high performance) are designed to offer
you the desired solution.
Features and Benefits
Exceptional conducted attenuation performance,
based on chokes with high saturation resistance
and excellent thermal behavior
Technical specifications
Operating voltage
Operating frequency
Rated currents
High potential test voltage
250 VAC, 50/60 Hz
DC to 400 Hz
1 to 10 A @ 40°C max.
P –> PE 2000 VAC for 2 sec (standard types)
P –> PE 2500 VAC for 2 sec (B types)
P –> N 760 VAC for 2 sec
FN9262B versions comply with the requirements of
1MOP acc. to IEC/EN 60601-1 for creepage and
clearance, leakage current and high potential
testing
Versions up to 10 A are available with fuse holder for
two fuses
Custom-specific versions are available on request
Protection category
Temperature range (operation and storage)
Design corresponding to
IP 40 according to IEC 60529
Flammability corresponding to
Inlet plastic: UL 94 V-0
Fuseholder plastic: UL 94 V-0
MTBF @ Rated amb. Temp./Voltage (MilHB-217F)
2,100,000 hours
Small to medium-sized machines and household
equipment
Fuse holder
2 fuses (Ø5 x 20 mm) (certified to IEC 60127-6)
Single-phase power supplies, switch-mode power
supplies
-25°C to +85°C (25/85/21)
UL 60939-3, CSA Std C22.2 No. 8-13, IEC/EN 60939-3,
GB/T 15287, GB/T 15288
Typical applications
Medical electrical devices (MD) and In-Vitro
Diagnostic (IVD) medical devices
Portable electrical and electronic equipment
Test and measurement equipment
Typical electrical schematic
2
Schaffner Group
EMC/EMI Products
Datasheets
05 Jan 2022
Filter selection table
Filter
Rated current
Leakage current*
Inductance**
@ 40°C
@ 250 VAC/50 Hz
L
Capacitance**
Cx
Cy
Resistor**
Output connections
Fuses***
Weight
R
(@ 120 VAC/60 Hz)
[A]
[mA]
[mH]
[μF]
[nF]
[kΩ]
[Qty]
[g]
FN9262v-1-yy-zz
1
0.31 (0.18)
40
0.22
2.2
1000
-06
-07
2
55
FN9262v-2-yy-zz
2
0.31 (0.18)
2.2
1000
-06
-07
2
55
FN9262v-4-yy-zz
4
0.31 (0.18)
7
0.22
2.2
1000
-06
-07
2
55
FN9262v-6-yy-zz
6
0.31 (0.18)
3
0.22
2.2
1000
-06
-07
2
55
FN9262v-10-yy-zz
10
0.31 (0.18)
1.15
0.22
2.2
1000
-06
-07
2
55
FN9262vA-1-yy-zz
1
0.07 (0.04)
40
0.22
0.47
1000
-06
-07
2
55
FN9262vA-2-yy-zz
2
0.07 (0.04)
0.47
1000
-06
-07
2
55
FN9262vA-4-yy-zz
4
0.07 (0.04)
7
0.22
0.47
1000
-06
-07
2
55
FN9262vA-6-yy-zz
6
0.07 (0.04)
3
0.22
0.47
1000
-06
-07
2
55
FN9262vA-10-yy-zz
10
0.07 (0.04)
1.15
0.22
0.47
1000
-06
-07
2
55
FN9262vB-1-yy-zz
1
0.00
40
0.22
1000
-06
-07
2
55
FN9262vB-2-yy-zz
2
0.00
1000
-06
-07
2
55
FN9262vB-4-yy-zz
4
0.00
7
0.22
1000
-06
-07
2
55
FN9262vB-6-yy-zz
6
0.00
3
0.22
1000
-06
-07
2
55
FN9262vB-10-yy-zz
10
0.00
1.15
0.22
1000
-06
-07
2
55
* Leakage current under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level.
** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10%
*** Fuses are not included in the filter and need to be selected according to application
Product selector
FN9262vw-xx-yy-zz
Snap-in range for S version only
Blank: Snap-in range0.6 to 1.5mm
20:
Snap-in range 1.6 to 2.5mm
30:
Snap-in range 2.6 to 3.5mm
06:
07:
Fast-on 6.3 x 0.8mm (spade/soldering)
Wire leads
1 to 10: Rated current
Blank:
A:
B:
Standard version
Safety version
Medical version (without Y-capacitor)
Blank:
S:
Standard housing with mounting flanges
Snap-in version, snapperon vertical side
For example: FN9262-1-06, FN9262SB-10-06
3
Schaffner Group
EMC/EMI Products
Typical filter attenuation
Per CISPR 17; DM (differential mode)=50 Ω/50 Ω sym; CM (common mode)=50 Ω/50 Ω asym
FN9262 Standard Type 1 A
FN9262A Type 1 A
FN9262B Type 1 A
FN9262 Standard Type 2 A
FN9262A Type 2 A
FN9262B Type 2 A
FN9262 Standard Type 4 A
FN9262A Type 4 A
FN9262B Type 4 A
FN9262 Standard Type 6 A
FN9262A Type 6 A
FN9262B Type 6 A
FN9262 Standard Type 10 A
FN9262A Type 10 A
FN9262B Type 10 A
Datasheets
05 Jan 2022
4
Schaffner Group
EMC/EMI Products
Datasheets
05 Jan 2022
Mechanical data
FN9262w-xx-06-zz
FN9262Sw-xx-06-zz
FN9262w-xx-07-zz
FN9262Sw-xx-07-zz
B
B
IEC PLUG TYPE C14
IEC PLUG TYPE C14
H
S
BU
J
AC J
E
Z
G
A
GNYE
F
D
BU
J
J
E
GNYE
BN
Z
BN
G
I
Panel cut out
D
F
I
Installation
For selecting the panel thickness, please refer to the filter selector
table.
Dimensions
FN9262vw-xx-06-zz
Fast-On
FN9262vw-xx-07-zz
Wire leads**
FN9262Sw-xx-06-zz
Fast-On
FN9262Sw-xx-07-zz
Wire leads**
Tolerances
A
46
46
34
34
±0.3
B
35
35
35
35
±0.3
C
36
36
D
41
50
41
50
E
27.8
27.8
27.8
27.8
+0.3/-0
F
5.5
5.5
5.5
5.5
±0.3
G
32
32
32
32
+0.3/-0
H
Ø3.2
Ø3.2
I
14±0.5
160±5**
14±0.5
160±5**
J
12.5
7.8
12.5
7.8
M
R ≤3.5
R ≤3.5
R ≤3.5
R ≤3.5
N
33 +0.3/-0
33 +0.3/-0
33 +0.2/-0
33 +0.2/-0
P
29 ±0.3
29 ±0.3
29.5 ±0.2
29.5 ±0.2
R*
M3
M3
S
90°
Z
±0.3
±0.1
90°
6
*Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm
** 1 A - 6 A - AWG18; 10 A - AWG16
All dimensions in mm; 1 inch = 25.4 mm / Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on filter connections.
6
5
Schaffner Group
EMC/EMI Products
Accessories
Power Cor
Cord
d with angled LLock
ocking
ing Syst
System
em C13
Locking system for standardized IEC C14 inlet filter
No accidental disconnection
Rated current up to 15 A
Fits any Schaffner IEC C14 inlet filter
Retrofit for any IEC C14 inlet
Various power line plucs for international usage
Datasheet PDF >
IL 13P IEC C13 R
Re
ewir
wireable
eable Angled Connec
Connecttors with LLock
ocking
ing Syst
System
em
Various power line plugs for international usage
Datasheet PDF >
IL 13P IEC C13 R
Re
ewir
wireable
eable Connec
ocking
ing Syst
System
em
Guards against accidental disconnection
Requires no other equipment or special inlets to
secure it
Rewireable - offering total flexibility when
assembling cables
Fits any Schaffner IEC C14 inlet Filter
Can be retrofitted
LSZH - Low smoke zero halogen
Datasheet PDF >
Datasheets
05 Jan 2022
6
Schaffner Group
EMC/EMI Products
Datasheets
05 Jan 2022
Headquarters, global
innovation and development
Sales and application centers
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542 Luterbach
T +41 32 681 66 26
info@schaffner.com
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road,
Pudong district
201201 Shanghai
T +86 21 3813 9500
cschina@schaffner.com
www.schaffner.com.cn
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E
El Soto de Moraleja, Alcobendas
28109 Madrid
T +34 917 912 900
F +34 917 912 901
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstorg 1
114 42 Stockholm
T +46 8 5050 2425
swedensales@schaffner.com
www.schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875 Bezons
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
germanysales@schaffner.com
India
Schaffner India Pvt. Ltd
REGUS WORLD TRADE CENTRE
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055 Bangalore
T +91 80 67935355
indiasales@schaffner.com
To find your local partner within Schaffner‘s
global network: www.schaffner.com
© 2021 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published specifications are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never
be operated outside their published
specifications. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900 Monza (MB)
T +39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
Taiju-Seimei Sangenjaya Bldg.
1-32-12, Kamiuma, Setagaya-ku
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
#05-09, Kg Ubi Ind. Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542 Luterbach
T +41 32 681 66 88
T +41 32 681 66 26
switzerlandsales@schaffner.com
Taiwan
Schaffner EMV Ltd.
20 Floor-2, No 97, Section 1, XinTai 5th Road
22175 XiZhi District New Taipei City 22175
T +886 2 2697 5500
F +886 2 2697 5533
taiwansales@schaffner.com
www.schaffner.com.tw
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
1, Oakmede Place
Binfield
RG42 4JF Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
www.schaffnerusa.com
很抱歉,暂时无法提供与“FN9262B-4-07”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+160.89840
- 200+62.27280
- 500+60.08040
- 1000+59.00040
