FN258-30/07
FN258-30/07
    SCHAFFNER(夏弗纳)
FN258-30/07 数据手册
DATASHEET 3-Phase Filters FN 258 Book-style EMC/RFI Filter for Inverters and Power Drive Systems Industry standard EMC solution for three-phase PDS filtering Approvals Slim space-saving book-style housing Solid safety connector blocks or optional wire output connections Excellent attenuation performance HV versions for up to 690 VAC HVIT versions for IT distribution networks P/L versions with low leakage current UL/CSA: FN 258 up to 180 A (ex. -180-07) Features and benefits Performance indicators FN 258 range of filters provides state-of- the-art EMI attenuation based on an innovative multi-stage filter topology. They help to ensure compliance with Class A or even Class B limits The slim book-style shape allows a convenient and space-saving installation next to inverters and motor drives With 480 VAC rating and filter modules from 7 to 250 A, FN 258 are ready for the most diverse applications worldwide FN 258 HV filters up to 130 A are designed for 690 VAC distribution networks FN 258 HVIT filters up to 130 A meet the special requirements for the application in industrial 690 VAC IT distribution networks Technical specifications Maximum continuous operating voltage 3x 480/277 VAC (FN 258, FN 258 L, FN 258 P) 3x 690/400 VAC (FN 258 HV, FN 258 HVIT ) Rated currents Operating frequency High potential test voltage 7 to 250 A @50°C (480 V filters) dc to 60 Hz P –> E 2650 VDC for 2 sec (480 V filters) P –> P 2100 VDC for 2 sec (480 V filters) P –> E 3100 VDC for 2 sec (690 V filters) P –> P 3000 VDC for 2 sec (690 V filters) FN 258 L and FN 258 P filters help to fulfill tough requirements in respect of leakage current limitation and provide an excellent solution to overcome problems with nuisance tripping of sensitive earth leakage detectors Typical applications Three-phase variable speed drives and power drive systems (PDS) IT power distribution networks (FN 258 HVIT) Protection category Overload capability IP 20 4x rated current at switch on, 1.5x rated current for 1 minute, once per hour Applications comprising energy conversion devices (inverters, converters) Temperature range (operation and storage) Flammability corresponding to Design corresponding to MTBF @ 50°C/400 V (Mil-HB-217F) -25°C to +100°C (25/100/21) Process automation equipment UL 94 V-2 or better Three-phase power supplies and UPS UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Applications with low-leakage current requirements (FN 258 L and FN 258 P) 220,000 hours Typical electrical schematic 2 EMC/EMI Products Schaffner Group 2016 Datasheets Filter selection table Filter* Rated current Typical drive Leakage current*** Power loss Input Output @ 50°C (40°C) power rating** @ 440 VAC/50 Hz @ 25°C/50 Hz connections connections Weight [A] [kW] [mA] [W] 7 (7.7) 4 16.5 9 -29 -07 -29 FN 258-16-.. 16 (17.5) 7.5 18.3 20 -29 -07 -29 1.4 FN 258-30-.. 30 (33) 15 24.2 21 -33 -07 -33 1.7 FN 258-42-.. 42 (46) 22 25.8 30 -33 -07 -33 2.5 FN 258-55-.. 55 (60) 30 25.8 30 -34 -07 -34 2.9 FN 258-75-34 75 (82) 37 25.8 24 -34 -34 3.9 FN 258-100-35 100 (110) 55 25.8 51 -35 -35 5.5 FN 258-130-35 130 (143) 75 30.0 50 -35 -35 6.9 FN 258-180-.. 180 (197) 90 30.0 73 -40 -07 -40 11.0 FN 258-250-.. 250 (275) 132 30.0 79 -40 -07 -40 12.0 7 (7.7) 5.5 13.0 9 -29 -29 1.0 FN 258 HV-16-29 16 (17.5) 11 19.0 20 -29 -29 1.5 FN 258 HV-30-33 30 (33) 22 19.0 21 -33 -33 1.8 FN 258 HV-42-33 42 (46) 30 21.6 30 -33 -33 2.6 FN 258 HV-55-34 55 (60) 45 21.6 30 -34 -34 3.0 FN 258 HV-75-34 75 (82) 55 21.6 24 -34 -34 4.3 FN 258 HV-100-35 100 (110) 90 21.6 51 -35 -35 5.6 FN 258 HV-130-35 130 (143) 110 25.0 50 -35 -35 7.1 7 (7.7) 5.5 13.0 9 -29 -29 1.0 FN 258-7-.. FN 258 HV-7-29 FN 258 HVIT-7-29 [kg] 1.0 FN 258 HVIT-16-29 16 (17.5) 11 19.0 20 -29 -29 1.5 FN 258 HVIT-30-33 30 (33) 22 19.0 21 -33 -33 1.8 FN 258 HVIT-42-33 42 (46) 30 21.6 30 -33 -33 2.6 FN 258 HVIT-55-34 55 (60) 45 21.6 30 -34 -34 3.0 FN 258 HVIT-75-34 75 (82) 55 21.6 24 -34 -34 4.3 FN 258 HVIT-100-35 100 (110) 90 21.6 51 -35 -35 5.6 FN 258 HVIT-130-35 130 (143) 110 25.0 50 -35 -35 7.1 7 (7.7) 4 0.8 9 -29 -29 1.0 FN 258 L-16-.. 16 (17.5) 7.5 0.8 20 -29 -07 -29 1.4 FN 258 L-30-.. 30 (33) 15 0.8 21 -33 -07 -33 1.7 FN 258 L-42-.. 42 (46) 22 0.7 30 -33 -07 -33 2.5 FN 258 L-55-.. 55 (60) 30 0.7 30 -34 -07 -34 2.9 FN 258 L-75-34 75 (82) 37 0.7 24 -34 -34 3.9 FN 258 L-100-35 100 (110) 55 0.7 51 -35 -35 5.5 FN 258 L-130-35 130 (143) 75 0.7 50 -35 -35 6.9 FN 258 L-180-.. 180 (197) 90 0.7 73 -40 -40 11.0 FN 258 L-250-07 250 (275) 132 0.7 79 -40 -07 7 (7.7) 4 3.3 9 -29 -07 -29 FN 258 P-16-.. 16 (17.5) 7.5 3.3 20 -29 -07 -29 1.4 FN 258 P-30-.. 30 (33) 15 3.3 21 -33 -07 -33 1.7 FN 258 P-42-.. 42 (46) 22 3.5 30 -33 -07 -33 2.5 FN 258 P-55-.. 55 (60) 30 3.5 30 -34 -07 -34 2.9 FN 258 P-75-34 75 (82) 37 3.5 24 -34 -34 3.9 FN 258 P-100-35 100 (110) 55 3.5 51 -35 -35 5.5 FN 258 P-130-35 130 (143) 75 3.5 50 -35 -35 6.9 FN 258 P-180-.. 180 (197) 90 3.5 73 -40 -07 -40 11.0 FN 258 P-250-07 250 (275) 132 3.6 79 -40 -07 FN 258 L-7-.. FN 258 P-7-.. -07 -07 12.0 ***To compile a complete part number, please replace the -.. with the required output connection style. ***Calculated at rated current, 440 VAC (FN 258)/690 VAC (FN 258 HV) and cos phi=0.8. The exact value depends upon the efficiency of the drive, the motor and the entire ***application. ***Maximum leakage under normal operating conditions (FN 258 at 440 V, FN 258 HV at 690 V). Note: if two phases are interrupted, worst case leakage could reach 5.7 times ***higher levels. 1.0 12.0 3 EMC/EMI Products Schaffner Group Datasheets Typical filter attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym 7 to 30 A types 42 to 100 A types 130 A types 180 and 250 A types Note: typical attenuation performance of FN 258 standard filters. The behavior of FN 258 HV, FN 258 HVIT, FN 258 P and FN 258 L may be slightly different. Mechanical data 7 to 55 A types (-07) 7 to 130 A types (-29, -33, -34, -35) 180 and 250 A types (-07) 180 and 250 A types (-40) Note: in favour of a better readability, connectors and earth studs are not shown in the horizontal projection. 2016 4 EMC/EMI Products Schaffner Group Datasheets 2016 Dimensions 7A 16 A 30 A 42 A 55 A 75 A 100 A 130 A 180 A A 255 305 335 329 329 329 379 439 438 250 A 478 B 50 55 60 70 80 80 90 110 110 110 C 126 142 150 185 185 220 220 240 240 240 D 225 275 305 300 300 300 350 400 400 440 E 240 290 320 314 314 314 364 414 413 453 F 25 30 35 45 55 55 65 80 80 80 G 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 1 1 1 1.5 1.5 1.5 1.5 3 4 4 I 10.9 10.9 25 25 39 39 45 45 51 51 J M5 M5 M5 M6 M6 M6 M10 M10 M10 M10 K 25 27.5 30 35 40 40 45 55 55 55 L 85 100 110 130 105 140 130 140 110 110 X* AWG 16 AWG 14 AWG 10 AWG 8 AWG 6 50 mm2 70 mm2 Y* 300 ±10 300 ±10 400 ±10 500 ±10 500 ±10 500 ±10 500 ±10 Z* 9 9 9 12 12 15 15 H * Filters with output wire connections (-07) only. All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Filter input/output connector cross sections Solid wire Recommended torque -33 -34 -35 -40 6 mm2 16 mm2 35 mm2 50 mm2 95 mm2 4 mm2 10 mm2 25 mm2 50 mm2 95 mm2 AWG 10 AWG 6 AWG 2 AWG 1/0 AWG 4/0 0.6-0.8 Nm 1.5-1.8 Nm 4.0-4.5 Nm 7-8 Nm 17-20 Nm Flex wire AWG type wire -29 Please visit www.schaffner.com to find more details on filter connectors. 5 EMC/EMI Products Schaffner Group Datasheets Headquarters, global innovation and development Sales and application centers Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 F +41 32 681 66 30 info@schaffner.com http://www.schaffner.com China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai T +86 21 3813 9500 cschina@schaffner.com http://www.schaffner.com.cn Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Tegeluddsvägen 76, 2tr 115 28 Stockholm T +46 8 5050 2425 swedensales@schaffner.com http://www.schaffner.com France Schaffner EMC S.A.S. 112 Quai de Bezons 95100 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com India Schaffner India Pvt. Ltd Unit 59, Level, Mfar Greenheart 7 Manyata Tech Park, Hebbal Outer Ring Road 560045 Bangalore T +91 80 6781 9805 F +91 80 6781 9998 indiasales@schaffner.com To find your local partner within Schaffner‘s global network: www.schaffner.com © 2016 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifications are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Galileo Galilei 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45 /47 F +39 02 61 23 943 italysales@schaffner.com Japan Schaffner EMC K.K. 1-32-12, Kamiuma, Setagaya-ku 7F Mitsui-seimei Sangenjaya Bldg. 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com http://www.schaffner.jp Singapore Schaffner EMC Pte Ltd. #05-09, Kg Ubi Ind. Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 switzerlandsales@schaffner.com Taiwan R.O.C. Schaffner EMV Ltd. 20 Floor-2, No 97, Section 1, XinTai 5th Road 22175 XiZhi District New Taipei City 22175 T +886 2 2697 5500 F +886 2 2697 5533 taiwansales@schaffner.com http://www.schaffner.tw Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 5 Ashville Way, Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com USA Schaffner EMC Inc. 52 Mayfield Avenue 08837 Edison, New Jersey T +1 800 367 5566 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com http://www.schaffnerusa.com Schaffner North America 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 Schaffner North America 823 Fairview Road 24382 Wytheville, Virginia T +1 276 228 7943 F +1 276 228 7258 2016
FN258-30/07 价格&库存
很抱歉,暂时无法提供与“FN258-30/07”相匹配的价格&库存,您可以联系我们找货
