FN284B-6-06.
FN284B-6-06.
    SCHAFFNER(夏弗纳)
    FN284B-6-06.
FN284B-6-06. 数据手册
EMC/EMI Products > FN 280 IEC Inlet Filters FN 280 Compact Filtered Power Entry Module n n n n n n n Rated currents up to 10A Single or dual-fuse holder Fuses Ø5 x 20mm 2-pole rocker switch General purpose application Optional earth line choke (E type) Optional medical version (B type) Technical specifications Maximum continuous operating voltage: Operating frequency: Rated currents: High potential test voltage: Protection category: Temperature range (operation and storage): Design corresponding to: Flammability corresponding to: MTBF @ 40°C/230V (Mil-HB-217F): Approvals Typical electrical schematic 250VAC, 50/60Hz 50 to 400Hz 1 to 10A @ 40°C max. P –> PE 2000VAC for 2 sec (standard types) P –> PE 2500VAC for 2 sec (B types) P –> N 760VAC for 2 sec IP40 according to IEC 60529 -25°C to +85°C (25/85/21) UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 UL 94V-2 or better 1,500,000 hours Standard types 1 or 2 fuses (Ø5 x 20mm) max. 250V ~ (text is print. below fuse symbol) N N‘ PE PE Cx Electrical specifications: Mechanical life: Switch ratings: USA (UL) and Canada (C-UL): Europe (ENEC): * 2-pole, dark not illuminated Marking I - 0 Inrush current 82A 6,000 on-off operations according to UL 1054, TV 5 10,000 on-off operations according to ENEC 50,000 cycles 2xL1 2xCy N‘ PE PE P P‘ Line Load E types Cx Fuse holder: Marking: Rocker switch description: Function: R N R 2xL1 2xCy P P‘ Line Load L2 10A, 125VAC; 10A, 250VAC; 1/3HP 10A (4A), 250VAC* Value in () relates to the inductive current charge: cos g = 0.65 Features and benefits Typical applications The FN 280 power entry module combines n n an IEC inlet, a mains filter with single or dual- based on chokes with high saturation equipment fuse holder and a 2-pole rocker switch in a resistance and excellent thermal behavior. n Consumer goods small form factor. Choosing FN 280 product n Rear/front or snap-in mounting. n EDP and office equipment line brings you the rapid availability of a n Single or dual-fuse holder. n Single-phase power supplies, switch-mode standard filter associated with the necessary n 2-pole rocker switch. power supplies safety acceptances. Standard IEC connector n Custom-specific versions are available on n Test and measurement equipment filters are a practical solution helping you request. n Medical equipment to pass EMI system approval in a short time. A wide selection on amperage ratings, fuse options, mounting possibilities and filters for medical applications are designed to offer you the desired solution. High conducted attenuation performance, Portable electrical and electronic 2 EMC/EMI Products > FN 280 Filter selection table Filter Rated current @ 40°C (25°C) Leakage current* @ 230VAC/50Hz Inductance L1 L2 FN FN FN FN FN 281-1-06 281-2-06 281-4-06 281-6-06 281-10-06 [A] 1 (1.2) 2 (2.4) 4 (4.8) 6 (7.2) 10 (11.6) [μA] 373 373 373 373 373 [mH] 7.5 2 1 0.45 0.34 FN FN FN FN FN 282-1-06 282-2-06 282-4-06 282-6-06 282-10-06 1 (1.2) 2 (2.4) 4 (4.8) 6 (7.2) 10 (11.6) 373 373 373 373 373 FN FN FN FN FN 283-1-06 283-2-06 283-4-06 283-6-06 283-10-06 1 (1.2) 2 (2.4) 4 (4.8) 6 (7.2) 10 (11.6) FN FN FN FN FN 284-1-06 284-2-06 284-4-06 284-6-06 284-10-06 FN FN FN FN FN [mH] Capacitance Cx Cy Resistance Output R connections Fuses** Weight [nF] 220 220 220 220 220 [nF] 2.2 2.2 2.2 2.2 2.2 [kΩ] 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 [Qty] 1 1 1 1 1 [g] 90 90 90 90 90 7.5 2 1 0.45 0.34 220 220 220 220 220 2.2 2.2 2.2 2.2 2.2 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 2 2 2 2 2 90 90 90 90 90 373 373 373 373 373 7.5 2 1 0.45 0.34 220 220 220 220 220 2.2 2.2 2.2 2.2 2.2 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 1 1 1 1 1 90 90 90 90 90 1 (1.2) 2 (2.4) 4 (4.8) 6 (7.2) 10 (11.6) 373 373 373 373 373 7.5 2 1 0.45 0.34 220 220 220 220 220 2.2 2.2 2.2 2.2 2.2 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 2 2 2 2 2 90 90 90 90 90 285-1-06 285-2-06 285-4-06 285-6-06 285-10-06 1 (1.2) 2 (2.4) 4 (4.8) 6 (7.2) 10 (11.6) 373 373 373 373 373 7.5 2 1 0.45 0.34 220 220 220 220 220 2.2 2.2 2.2 2.2 2.2 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 1 1 1 1 1 90 90 90 90 90 FN FN FN FN FN 286-1-06 286-2-06 286-4-06 286-6-06 286-10-06 1 (1.2) 2 (2.4) 4 (4.8) 6 (7.2) 10 (11.6) 373 373 373 373 373 7.5 2 1 0.45 0.34 220 220 220 220 220 2.2 2.2 2.2 2.2 2.2 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 2 2 2 2 2 90 90 90 90 90 FN FN FN FN 283E-1-06 283E-2-06 283E-4-06 283E-6-06 1 2 4 6 (1.2) (2.4) (4.8) (7.2) 373 373 373 373 7.5 2 1 0.45 0.4 0.4 0.4 0.4 220 220 220 220 2.2 2.2 2.2 2.2 1000 1000 1000 1000 -06 -06 -06 -06 1 1 1 1 100 100 100 100 FN FN FN FN 284E-1-06 284E-2-06 284E-4-06 284E-6-06 1 2 4 6 (1.2) (2.4) (4.8) (7.2) 373 373 373 373 7.5 2 1 0.45 0.4 0.4 0.4 0.4 220 220 220 220 2.2 2.2 2.2 2.2 1000 1000 1000 1000 -06 -06 -06 -06 2 2 2 2 100 100 100 100 FN FN FN FN FN 282B-1-06 282B-2-06 282B-4-06 282B-6-06 282B-10-06 1 (1.2) 2 (2.4) 4 (4.8) 6 (7.2) 10 (11.6) 2 2 2 2 2 7.5 2 1 0.45 0.34 220 220 220 220 220 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 2 2 2 2 2 90 90 90 90 90 FN FN FN FN FN 284B-1-06 284B-2-06 284B-4-06 284B-6-06 284B-10-06 1 (1.2) 2 (2.4) 4 (4.8) 6 (7.2) 10 (11.6) 2 2 2 2 2 7.5 2 1 0.45 0.34 220 220 220 220 220 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 2 2 2 2 2 90 90 90 90 90 FN FN FN FN FN 286B-1-06 286B-2-06 286B-4-06 286B-6-06 286B-10-06 1 (1.2) 2 (2.4) 4 (4.8) 6 (7.2) 10 (11.6) 2 2 2 2 2 7.5 2 1 0.45 0.34 220 220 220 220 220 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 2 2 2 2 2 90 90 90 90 90 * Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. ** Filters are delivered without fuse. 3 EMC/EMI Products > FN 280 Product selector FN 28xx-yy-zz 06: Faston 6.3 x 0.8mm (spade/soldering) 1 to 10: Rated current Blank: Standard version E: Optional earth line choke B: Medical version (with bleed resistor and without Y2-capacitor) 1: Flange mounting version top/bottom, single-fuse 2: Flange mounting version top/bottom, dual-fuse 3: Flange mounting version left/right, single-fuse 4: Flange mounting version left/right, dual-fuse 5: Snap-in version, single-fuse 6: Snap-in version, dual-fuse For example: FN 281-6-06, FN 283B-04-06, FN 283E-1-06 Typical filter attenuation Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym; C = 0.1Ω/100Ω sym; D = 100Ω/0.1Ω sym 1A types 2 to 6A types 10A types 4 EMC/EMI Products > FN 280 Mechanical data FN 281 / FN 282 FN 283 / FN 284 A 6.3 x 0.8 S B IEC plug type C14 G C A C B IEC plug type C14 6.3 x 0.8 G S U U H J F H D I F E D I J E FN 285 / FN 286 Panel cut out A P 6.3 x 0.8 C14 M M R N B G C N S U R P C J E F D I Dimensions A B C D E F G H I J M N P R S * FN 281 FN 282 FN 283 FN 284 FN 285 FN 286 Tolerances 32 82 72 43.1 28.5 5.5 59.95 max. Ø3.5 13.4 22.5 R ≤ 2.5 60 29 M3 90° 32 82 72 43.1 28.5 5.5 59.95 max. Ø3.5 16.2 22.5 R ≤ 2.5 60 29 M3 90° 50 65 40 43.1 28.5 5.5 59.95 max. Ø3.3 13.4 22.5 R ≤ 2.5 60 29 M3 90° 50 65 40 43.1 28.5 5.5 59.95 max. Ø3.3 16.2 22.5 R ≤ 2.5 60 29 M3 90° 32 65 32 65 43.6 28.5 5 59.95 max. 43.6 28.5 5 59.95 max. ±0.3 ±0.3 ±0.1 ±0.3 ±0.25 ±0.3 13.9 22.5 R ≤ 2.5 61.5 +0.2/-0* 29 16.7 22.5 R ≤ 2.5 61.5 +0.2/-0* 29 For a panel thickness between 0.8 and 3mm All dimensions in mm; 1 inch = 25.4mm Tolerances according: ISO 2768-m / EN 22768-m ±0.3 +0.5/-0 +0.5/-0 Headquarters, global innovation and development center Schaffner Group Nordstrasse 11 4542 Luterbach Schweiz T +41 32 681 66 26 F +41 32 681 66 30 info@schaffner.com www.schaffner.com Sales and application centers China Schaffner EMC Ltd. Shanghai T20-3, No 565 Chuangye Road Pudong New Area Shanghai 201201 T +86 21 3813 9500 F +86 21 3813 9501 / 02 cschina@schaffner.com www.schaffner.com Spain Schaffner EMC España Calle Caléndula 93 Miniparc III, Edificio E El Soto de la Moraleja Alcobendas 28109 Madrid T +34 618 176 133 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 19 35 72 71 F +358 19 32 66 10 finlandsales@schaffner.com Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com France Schaffner EMC S.A.S. 112, Quai de Bezons 95103 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 F +41 32 681 66 41 sales@schaffner.ch Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com Taiwan Schaffner EMV Ltd. 6th Floor, No 413 Rui Guang Road Neihu District Taipei City 114 T +886 2 87525050 F +886 2 87518086 taiwansales@schaffner.com Italy Schaffner EMC S.r.l. Via Galileo Galilei, 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45/47 F +39 02 61 23 943 italysales@schaffner.com Japan Schaffner EMC K.K. Mitsui-Seimei Sangenjaya Bldg. 7F 1-32-12, Kamiuma, Setagaya-ku Tokyo 154-0011 T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp To find your local partner within Schaffner‘s global network, please go to www.schaffner.com © 2013 Schaffner Group Specifications are subject to change within notice. The latest version of the data sheets can be obtained from the website. All trademarks recognized. 04/2013 EN Schaffner is an ISO-registered company. Its products are designed and manufactured under the strict quality and environmental requirements of the ISO 9001 and ISO 14001 standards. This document has been carefully checked. However, Schaffner does not assume any liability for errors or inaccuracies. Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 05-09 Kampong Ubi Industrial Estate T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muang P.O. Box 14 Lamphun 51000 T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way Molly Millars Lane Wokingham Berkshire RG41 2PL T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com www.schaffner.uk.com USA Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey 08837 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffner.com/us
FN284B-6-06. 价格&库存
很抱歉,暂时无法提供与“FN284B-6-06.”相匹配的价格&库存,您可以联系我们找货
