FN9222SR-3-06-20
FN9222SR-3-06-20
    SCHAFFNER(夏弗纳)
FN9222SR-3-06-20 数据手册
DATASHEET IEC Inlet Filters FN 9222 General Performance IEC Inlet Filter Rated currents up to 20 A Approvals Excellent performance/size ratio Optional medical versions (B type) according to IEC/EN 60601-1 Snap-in versions (S and S1 type) Hot inlet versions (HI type) Optional overvoltage protection (Z type) (CQC except HI-types) Performance indicators The FN 9222 IEC inlet filter combines an IEC inlet and mains filter with excellent filter attenuation in a small form factor. Choosing the FN 9222 product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings, output connections, mounting possibilities and filters for medical applications are designed to offer you the desired solution. Features and benefits Exceptional conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Technical specifications Rear/front or snap-in mounting Maximum continuous operating voltage Operating frequency Rated currents Approvals by rated current 250 VAC, 50/60 Hz Wide mounting flanges available DC to 400 Hz FN 9222 B versions comply with the requirements of 1MOP acc. to IEC/EN 60601-1 for creepage and clearance, leakage current and high potential testing High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> N 250 VAC for 2 sec (all Z types) P –> N 1000 VAC for 2 sec (1 to 10 A types, not Z types) P –> PE 2500 VAC for 2 sec (B types) P –> N 1100 VDC for 2 sec (16 and 20 A types, not Z types) 1 to 20 A @ 50°C 1 to 10 A (ENEC, CQC) 16 A (ENEC, CQC) for 16 and 20 A types 1 to 20 A (UL, CSA) Protection category Temperature range (operation and storage) Design corresponding to IP 40 according to IEC 60529 Flammability corresponding to Surge pulse protection (Z type) UL 94 V-2 or better MTBF @ 40°C/230 V (Mil-HB-217F) ≤15 A: 3,040,000 hours ≥16 A: 2,256,000 hours -25°C to +85°C (25/85/21) UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (X to XX A, not Z types) Helps compliance to IEC61000-4-5 (Differential Mode only) 12 and 15 A types with hot inlet available Optional surge pulse protection Different output connections offering maximum flexibility for assembly Custom-specific versions are available on request Typical applications Portable electrical and electronic equipment Small to medium-sized machines and household equipment Single-phase power supplies, switch-mode power supplies Test and measurement equipment Medical equipment Rack mounting equipment 2 Schaffner Group EMC/EMI Products Datasheets 23 Oct 2019 Filter selection table Filter Rated current Leakage current* Inductance @ 50°C (25°C) @ 250 VAC/50 Hz L Capacitance Cx Cy Resistance R [kΩ] Output connections Weight (@ 120 VAC/60 Hz) [A] [mA] [mH] [µF] [nF] FN 9222 x-1-.. 1 (1.2) 0.31 (0.18) 12 0.1 2.2 -06 -07 40 FN 9222 x-3-.. 3 (3.5) 0.31 (0.18) 2.5 0.1 2.2 -06 -07 40 FN 9222 x-6-.. 6 (7.2) 0.31 (0.18) 0.78 0.1 2.2 -06 -07 40 FN 9222 x-8-.. 8 (10.6) 0.31 (0.18) 0.5 0.1 2.2 -06 -07 40 FN 9222 x-10-.. 10 (11.6) 0.31 (0.18) 0.225 0.1 2.2 -06 -07 40 FN 9222 x-12-.. 12 (12) 0.31 (0.18) 0.11 0.1 2.2 -06 -07 40 FN 9222 x-15-.. 15 (15) 0.31 (0.18) 0.075 0.1 2.2 -06 -07 40 FN 9222 x-12-..HI 12 (12) 0.31 (0.18) 0.11 0.1 2.2 -06 -07 40 FN 9222 x-15-..HI 15 (15) 0.31 (0.18) 0.075 0.1 2.2 -06 -07 40 FN 9222 xR-1-.. 1 (1.2) 0.31 (0.18) 12 0.1 2.2 1000 -06 -07 40 FN 9222 xR-3-.. 3 (3.5) 0.31 (0.18) 2.5 0.1 2.2 1000 -06 -07 40 FN 9222 xR-6-.. 6 (7.2) 0.31 (0.18) 0.78 0.1 2.2 1000 -06 -07 40 FN 9222 xR-8-.. 8 (10.6) 0.31 (0.18) 0.5 0.1 2.2 1000 -06 -07 40 FN 9222 xR-10-.. 10 (11.6) 0.31 (0.18) 0.225 0.1 2.2 1000 -06 -07 40 FN 9222 xR-12-.. 12 (12) 0.31 (0.18) 0.11 0.1 2.2 1000 -06 -07 40 FN 9222 xR-15-.. 15 (15) 0.31 (0.18) 0.075 0.1 2.2 1000 -06 -07 FN 9222 R-16-06 16 (18.5) 0.31 (0.18) 0.54 0.33 2.2 1000 -06 FN 9222 R-20-06 20 (23) 0.31 (0.18) 0.4 0.33 2.2 1000 -06 FN 9222 xR-12-..HI 12 (12) 0.31 (0.18) 0.11 0.1 2.2 1000 -06 -07 40 FN 9222 xR-15-..HI 15 (15) 0.31 (0.18) 0.075 0.1 2.2 1000 -06 -07 40 FN 9222 xB-1-.. 1 (1.2) 0.00 12 0.1 1000 -06 -07 40 FN 9222 xB-3-.. 3 (3.5) 0.00 2.5 0.1 1000 -06 -07 40 FN 9222 xB-6-.. 6 (7.2) 0.00 0.78 0.1 1000 -06 -07 40 FN 9222 xB-8-.. 8 (10.6) 0.00 0.5 0.1 1000 -06 -07 40 FN 9222 xB-10-.. 10 (11.6) 0.00 0.225 0.1 1000 -06 -07 40 FN 9222 xB-12-.. 12 (12) 0.00 0.11 0.1 1000 -06 -07 40 -07 FN 9222 xB-15-.. [g] 40 100 100 15 (15) 0.00 0.075 0.1 1000 -06 FN 9222 RB-16-06 16 (18.5) 0.00 0.54 0.33 1000 -06 100 FN 9222 RB-20-06 20 (23) 0.00 0.4 0.33 1000 -06 100 FN 9222 xB-12-..HI 12 (12) 0.00 0.11 0.1 1000 -06 -07 40 FN 9222 xB-15-..HI 15 (15) 0.00 0.075 0.1 1000 -06 -07 40 FN 9222 UZ-1-06 1 (1.2) 0.31 (0.18) 12 0.1 2.2 -06 43 FN 9222 UZ-3-06 3 (3.5) 0.31 (0.18) 2.5 0.1 2.2 -06 43 FN 9222 UZ-6-06 6 (7.2) 0.31 (0.18) 0.78 0.1 2.2 -06 43 FN 9222 UZ-8-06 8 (10.6) 0.31 (0.18) 0.5 0.1 2.2 -06 43 FN 9222 UZ-10-06 10 (11.6) 0.31 (0.18) 0.225 0.1 2.2 -06 43 FN 9222 UZ-12-06 12 (12) 0.31 (0.18) 0.11 0.1 2.2 -06 43 FN 9222 UZ-15-06 15 (15) 0.31 (0.18) 0.075 0.1 2.2 -06 43 * Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. 40 3 Schaffner Group EMC/EMI Products Product selector Datasheets Typical electrical schematic For example: FN 9222 E-15-06, FN 9222 ES1B-10-06-20, FN 9222 ER-12-06HI, FN 9222 EUB-8-06-20 Typical filter attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym 1 and 3 A types 6 to 10 A types 12 and 15 A types 16 and 20 A types 23 Oct 2019 4 Schaffner Group EMC/EMI Products Mechanical data FN 9222 1 to 15 A types FN 9222, 16 and 20 A types FN 9222 S FN 9222 S1 FN 9222-HI FN 9222 U -07 connection style Panel cut out Installation Datasheets 23 Oct 2019 5 Schaffner Group EMC/EMI Products Datasheets 23 Oct 2019 Dimensions FN 9222 FN 9222 U FN 9222 UZ FN 9222 S 1 to 8 A FN 9222 S1 10 to 15 A 16 and 20 A A 48 48 53 51.85 51.85 29.9 29.9 29.9 29.9 48 B 22.4 22.4 30 25 25 22.4 22.4 22.4 22.4 22.4 C 40 40 42 40 40 D 38.25 38.25 62 38.25 46.7 38.25 38.25 38.25 38.25 E 27.8 27.8 34.5 27.7 27.7 27.8 27.8 27.8 27.8 27.8 F 5.7 5.7 3.8 5.7 5.7 5.7 5.7 5.7 5.7 5.7 G 20.1 20.1 26.5 20.1 20.1 20.1 20.1 20.1 20.1 H Ø3.3 Ø3.3 Ø3.5 Ø3.3 Ø3.3 I 14 14 14 14 14 14 14 14 14 J 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 13.3 M R 3 R ≤3 R ≤1.5 R ≤3 R ≤3 R ≤1.5 R ≤ 1.5 R ≤1.5 R ≤1.5 R ≤3 N 21.5 21.5 27 21.5 21.5 20.8 20.8 21.9 21.9 21.5 P 28.5 28.5 34.7 28.5 28.5 29.4 29.4 28.5 28.5 R* M3 M3 M3 M3 M3 S 90° 90° 90° 90° 90° T** 1 to 8 A 10 to 15 A 20.1 14 28.5 M3 90° 0.7-1.5 0.7-1.5 1.5-2.2 1.5-2.2 1.5-2.2 1.5-2.2 X AWG 18 AWG 16 AWG 18 AWG 16 AWG 18 AWG 16 Y 160 160 160 160 160 160 160 Z 6 6 6 6 6 6 6 **Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm ** For selecting the panel thickness, please refer to the filter selector table. All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. ±0.2 38.25 Ø3.3 0.7-1.5 Tol. 12 and 15 A 40 0.7-1.5 T** 10 to 15 A FN 9222-HI 1 to 8 A AWG 16 +0.6/-0 +0.6/-0 6 Schaffner Group EMC/EMI Products Datasheets 23 Oct 2019 Accessories for IEC Inlet Filters and Power Entry Modules The accessories displayed are a selection of available accessories for IEC Inlet filters and IEC Power entry modules. As they are displayed in a general way there might be variants of the filters where the accessories are not available. For further information please ask your local Schaffner Sales Partner and visit our homepage https://www.schaffner.com/. Power Cor Cord d with LLock ocking ing Syst System em ffor or IInlet nlet FFilt ilters ers IL 13, IL 13 P P,, IL 19 The locking system has a tensile force of typical 200N. It is recommended to use it with flange mount filters. Lock Power Cords with IEC Inlets and Filters" Schaffner power cords with IEC lock guard against accidental disconnection of all electrical appliances with an IEC inlet. No exchange or modification of the IEC inlet or IEC inlet filter system is needed. Easy retrofit for all electronic equipments and devices. Link to Datasheet: Datasheet IEC C13/ C19 locking cable IB - IInsulating nsulating Boots There is a full range of insulating boots available from Schaffner that provide a physical cover for the exposed terminals on the back of IEC Inlet Filters. These boots fit the simplest non-fused and unswitched style up to the fully fused and switched IEC filtered inlet. The boots are made from a durable black PVC material that conforms to UL94-V0 flammability requirements. The boots slip easily over the back of the filter and reduce the risk of electrical shock to maintenance personnel whilst protecting the filter from environmental hazard such as the ingress of dust and moisture. IEC C13 R Re ewir wireable eable Connec Connecttor for individual P Po ower Cor Cord d with Lock ocking ing Syst System em Link to Datasheet: Datasheet IEC C13 rewireable The locking system has a tensile force of typical 300N. It is recommended to use it with flange mount filters. For details refer to our Application Note "Using IEC Lock Power Cords with IEC Inlets and Filters" Schaffner power connector with IEC lock guard against accidental disconnection of all electrical appliances with an IEC inlet. No exchange or modification of the IEC inlet or IEC inlet filter system is needed. Easy retrofit for all electronic equipments and devices. 7 Schaffner Group EMC/EMI Products Datasheets 23 Oct 2019 Headquarters, global innovation and development Sales and application centers Switzerland Schaffner Group Industrie Nord Nordstrasse 11e 4542 Luterbach T +41 32 681 66 26 info@schaffner.com China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai T +86 21 3813 9500 cschina@schaffner.com www.schaffner.com.cn Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 10 567 2855 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstorg 1 114 42 Stockholm T +46 8 5050 2425 swedensales@schaffner.com www.schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com India Schaffner India Pvt. Ltd REGUS WORLD TRADE CENTRE WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore T +91 80 67935355 indiasales@schaffner.com To find your local partner within Schaffner‘s global network: www.schaffner.com © 2018 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifications are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) T +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. Taiju-Seimei Sangenjaya Bldg. 1-32-12, Kamiuma, Setagaya-ku 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp Singapore Schaffner EMC Pte Ltd. #05-09, Kg Ubi Ind. Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach T +41 32 681 66 26 switzerlandsales@schaffner.com Taiwan R.O.C. Schaffner EMV Ltd. 20 Floor-2, No 97, Section 1, XinTai 5th Road 22175 XiZhi District New Taipei City 22175 T +886 2 2697 5500 F +886 2 2697 5533 taiwansales@schaffner.com www.schaffner.com.tw Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Binfield RG42 4JF Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com USA Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffnerusa.com Schaffner North America 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 Schaffner North America 823 Fairview Road 24382 Wytheville, Virginia T +1 276 228 7943 F +1 276 228 7258
FN9222SR-3-06-20 价格&库存
很抱歉,暂时无法提供与“FN9222SR-3-06-20”相匹配的价格&库存,您可以联系我们找货
