FN9244SR-6-07
FN9244SR-6-07
    SCHAFFNER(夏弗纳)
    Res Metal Film 2010 57.6 Ohm 0.05% 0.25W(1/4W) ±10ppm/C Molded SMD T/R
FN9244SR-6-07 数据手册
DATASHEET IEC Inlet Filters FN 9244 Excellent Performance EMC/EMI Filter Superior attenuation performance Optional earth line choke Approvals Complies with IEC/EN 60601-1 Snap-in versions (S and S1 type) Hot inlet versions (HI type) (CQC except HI-types) The FN 9244 IEC inlet filter combines an IEC inlet and mains filter with superior filter attenuation in a small form factor. Choosing the FN 9244 product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings, output connections, mounting possibilities and filters for medical applications are designed to offer you the desired solution. Features and benefits Technical specifications Maximum continuous operating voltage Operating frequency 250 VAC, 50/60 Hz dc to 400 Hz High potential test voltage 1 to 15 A (UL, CSA) P –> PE 2000 VAC for 2 sec (standard types) Protection category Temperature range (operation and storage) IP40 according to IEC 60529 -25 °C to +85 °C (25/85/21) Rated currents Approvals by rated current Design corresponding to Flammability corresponding to MTBF @ 40°C/230V (Mil-HB-217F) 1 to 15 A @ 50 °C max. 1 to 10 A (ENEC, CQC) P –> PE 2500 VAC for 2 sec (B types) P –> N 1000 VAC for 2 sec UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 UL 94 V-2 or better ≤8A: 2,035,000 hours ≤15A: 1,035,000 hours Exceptional conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior. Rear/front or snap-in mounting. Standard or wide mounting flange. Optional medical versions (B type) comply with the requirements of IEC/EN 60601-1 for creepage and clearance, leakage current and high potential testing. Optional earth line choke see FN 9244E data sheet. Custom-specific versions are available on request. Typical applications Portable electrical and electronic equipment Small to medium-sized machines and household equipment Single-phase power supplies, switch-mode power supplies Test and measurement equipment Medical devices (MDD) In-vitro diagnostic medical devices (IVDD) Rack mounting equipment 2 EMC/EMI Products Schaffner Group Datasheets 2014 Filter selection table Filter Rated current Leakage current* Inductance [A] [μA] 3 (3.5) 373 @ 50 °C (25 °C) FN 9244x-1-06 1 (1.2) FN 9244x-6-06 6 (7.2) FN 9244x-3-06 FN 9244x-8-06 8 (10.6) FN 9244x-10-06 10 (11.6) FN 9244x-15-06 15 (15) FN 9244x-12-06 FN 9244x-12-06HI FN 9244x-15-06HI FN 9244xR-1-06 FN 9244xR-3-06 FN 9244xR-6-06 FN 9244xR-8-06 373 373 Cy [mH] [μF] [nF] 13.45 0.1 2.2 59.53 0.1 2.2 -06 2.3 6 (7.2) 15 (15) 0.1 0.1 2.2 -06 2.2 -06 Weight [g] 38 38 38 38 38 38 0.4 0.1 2.2 -06 38 0.4 0.1 2.2 -06 38 373 59.53 0.1 2.2 1000 -06 38 373 4.1 0.1 2.2 1000 -06 38 1.02 0.1 2.2 1000 -06 373 373 373 373 13.45 2.3 12 (12) 373 0.58 12 (12) 373 0.58 15 (15) -06 1.02 1 (1.2) 8 (10.6) -06 -06 0.58 3 (3.5) [kΩ] Output connections 2.2 373 15 (15) 2.2 R 0.1 12 (12) 373 0.1 Resistance 4.1 0.58 FN 9244xR-15-06 FN 9244xR-15-06HI 373 Capacitance Cx 373 10 (11.6) FN 9244xR-12-06HI 373 L 12 (12) FN 9244xR-10-06 FN 9244xR-12-06 @ 250 VAC/50 Hz 373 373 0.1 0.1 0.1 0.1 2.2 2.2 2.2 2.2 -06 1000 1000 1000 -06 -06 -06 38 38 38 38 38 0.4 0.1 2.2 1000 -06 38 0.4 0.1 2.2 1000 -06 38 0.1 2.2 1000 -06 38 FN 9244xB-1-06 1 (1.2) 2 59.53 0.1 1000 -06 38 FN 9244xB-6-06 6 (7.2) 2 4.1 0.1 1000 -06 38 1.02 0.1 1000 -06 38 FN 9244xB-3-06 FN 9244xB-8-06 3 (3.5) 8 (10.6) FN 9244xB-10-06 10 (11.6) FN 9244xB-15-06 15 (15) FN 9244xB-12-06 FN 9244xB-12-06HI FN 9244xB-15-06HI 2 2 2 13.45 2.3 12 (12) 2 0.58 12 (12) 2 0.58 15 (15) 2 2 0.1 0.1 0.1 1000 1000 1000 -06 38 38 0.1 1000 -06 38 0.4 0.1 1000 -06 38 0.1 Typical filter attenuation Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym 6 to 10 A types -06 38 0.4 1000 * Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. 1 and 3 A types -06 12 and 15 A types -06 38 3 EMC/EMI Products Schaffner Group Product selector Typical electrical schematic For example: FN 9244B-15-06, FN 9244S1B-10-06-20, FN 9244R-12-06HI, FN 9244UB-8-06 Mechanical data FN 9244 FN 9244-HI FN 9244S FN 9244S1 Datasheets 2014 EMC/EMI Products 4 Schaffner Group FN 9244U Datasheets 2014 Installation Panel cut out Dimensions A B FN 9244 FN 9244U FN 92244S FN 92244S1 FN 9244-HI 22.5 25 22.4 22.4 22.5 38.25 38.4 38.4 48 51.85 29.9 29.9 48 C 40 ±0.2 40 ±0.2 E 27.8 27.8 27.8 27.8 27.8 20.1 20.1 20.1 20.1 14.1 14 14 D F G 38.4 5.5 20.1 5.5 H Ø 3.3 Ø 3.3 J 13.3 13.3 I 14 5.5 13.3 5.5 13.3 40 ±0.2 38.4 5.5 Ø 3.3 14 13.3 M R≤3 R≤3 R ≤ 1.5 R ≤ 1.5 R≤3 P 28.5 28.5 29.4 28.5 28.5 N R S T* 21.5 M3 90° 21.5 M3 90° T* * For selecting the panel thickness, please refer to the filter selector table. All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m / EN 22768-m Please visit www.schaffner.com to find more details on connectors. 20.8 0.7-1.5 1.5-2.2 21.9 0.7-1.5 1.5-2.2 21.5 M3 90° 5 EMC/EMI Products Headquarters, global innovation and development center Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 6816 626 F +41 32 6816 630 info@schaffner.com http://www.schaffner.com Schaffner Group Sales and application centers China Schaffner EMC Ltd. Shanghai T20-3, No 565 Chuangye Road Pudong New Area 201201 Shanghai T +86 21 3813 9500 F +86 21 3813 9501 / 02 cschina@schaffner.com http://www.schaffner.com.cn/ Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 19 35 72 71 finlandsales@schaffner.com France Schaffner EMC S.A.S. 112, Quai de Bezons Boîte postale 133 95103 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com Italy Schaffner EMC S.r.l. Via Galileo Galilei 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45/47 F +39 02 61 23 943 italysales@schaffner.com To nd your local partner within Schaffner‘s global network: www.schaffner.com © 2014 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published speci cations are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published speci cations. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Datasheets Japan Schaffner EMC K.K. 1-32-12, Kamiuma, Setagaya-ku 7F Mitsui-seimei Sangenjaya Bldg. 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com http://www.schaffner.jp Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 05-09 Kampong Ubi Industrial Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Spain Schaffner EMC España Calle Caléndula 93 Miniparc III, Edificio E El Soto de la Moraleja Alcobendas 28109 Madrid T +34 618 176 133 spainsales@schaffner.com Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 6816 626 F +41 32 6816 641 sales@schaffner.ch Taiwan R.O.C. Schaffner EMV Ltd. 6 Floor, No. 413 Rui Guang Road 114 Neihu District Taipei City T +886 2 87525050 F +886 2 87518086 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com http://www.schaffner.uk.com USA Schaffner EMC Inc. 52 Mayfield Avenue 08837 Edison, New Jersey T +1 800 367 5566 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com http://www.schaffner.com/us Schaffner MTC LLC 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 http://www.schaffner-mtc.com Schaffner Trenco LLC 2550 Brookpark Road 44134 Cleveland, Ohio T +1 216 741 5282 F +1 216 741 4860 www.schaffner-trenco.com 2014
FN9244SR-6-07 价格&库存
很抱歉,暂时无法提供与“FN9244SR-6-07”相匹配的价格&库存,您可以联系我们找货
