FN 282-4-06
FN 282-4-06
    SCHAFFNER(夏弗纳)
    Power Entry Module Filtered M 3 POS 250VAC 4A Switch/Fuse ST 1 Port
FN 282-4-06 数据手册
DATASHEET IEC Inlet Filters FN 280 Compact filtered power entry module Complies with IEC/EN 60601-1 Approvals Rated currents up to 10 A Single or dual-fuse holder Fuses Ø5 x 20 mm 2-pole rocker switch General purpose application Optional earth line choke (E type) Optional medical versions (B type) Performance indicators (CQC except HI-types) The FN 280 power entry module combines an IEC inlet, a mains filter with single or dual- fuse holder and a 2-pole rocker switch in a small form factor. Choosing FN 280 product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings, fuse options, mounting possibilities and filters for medical applications are designed to offer you the desired solution. Features and benefits High conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Technical specifications Rear/front or snap-in mounting Single or dual-fuse holder Maximum continuous operating voltage Operating frequency Rated currents High potential test voltage 250 V, 50/60 Hz Protection category Temperature range (operation and storage) Design corresponding to Flammability corresponding to MTBF @ 40°C/230 V (Mil-HB-217F) Fuse holder Marking Rocker switch description IP 40 according to IEC 60529 Portable electrical and electronic equipment -25°C to +85°C (25/85/21) Consumer goods UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 EDP and office equipment UL 94 V-2 or better 1,500,000 hours Single-phase power supplies, switch-mode power supplies 1 or 2 fuses (Ø5 x 20 mm) (certified to IEC 60127-6) Test and measurement equipment max. 250 V ~ (text is print. below fuse symbol) Medical equipment Function 2-pole, dark not illuminated Marking I - 0 Electrical specifications Inrush current 82 A 6,000 on-off operations according to UL 1054, TV5 10,000 on-off operations according to ENEC DC to 400 Hz 1 to 10 A @ 40°C max. P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 760 VAC for 2 sec Switch ratings USA (UL) and Canada (C-UL) Europe (ENEC) Mechanical life 10 A, 125 VAC; 10 A, 250 VAC; 1/3 HP 10 A (4 A), 250 VAC* 50,000 cycles * Value in () relates to the inductive current charge: cosφ = 0.65 2-pole rocker switch Custom-specific versions are available on request Typical applications Typical electrical schematic 2 Schaffner Group EMC/EMI Products Datasheets 2018 Filter selection table Filter Rated current Leakage current** Inductance Capacitance @ 40°C (25°C) @ 230 VAC/50 Hz L1 L2 Cx Cy [mH] Resistance Output R connections Fuses** Weight [A] [μA] [mH] [nF] [nF] [kΩ] [Qty] [g] FN 281-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 1 140 FN 281-2-06 2 (2.4) 373 2 220 2.2 1000 -06 1 140 FN 281-4-06 4 (4.8) 373 1 220 2.2 1000 -06 1 140 FN 281-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 1 140 10 (11.6) 373 0.34 220 2.2 1000 -06 1 140 FN 282-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 2 90 FN 282-2-06 2 (2.4) 373 2 220 2.2 1000 -06 2 90 FN 282-4-06 4 (4.8) 373 1 220 2.2 1000 -06 2 90 FN 281-10-06 FN 282-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 2 90 10 (11.6) 373 0.34 220 2.2 1000 -06 2 140 FN 283-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 1 140 FN 283-2-06 2 (2.4) 373 2 220 2.2 1000 -06 1 140 FN 283-4-06 4 (4.8) 373 1 220 2.2 1000 -06 1 140 FN 283-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 1 140 10 (11.6) 373 0.34 220 2.2 1000 -06 1 140 FN 284-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 2 90 FN 284-2-06 2 (2.4) 373 2 220 2.2 1000 -06 2 90 FN 284-4-06 4 (4.8) 373 1 220 2.2 1000 -06 2 90 FN 284-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 2 90 10 (11.6) 373 0.34 220 2.2 1000 -06 2 140 FN 285-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 1 140 FN 285-2-06 2 (2.4) 373 2 220 2.2 1000 -06 1 140 FN 285-4-06 4 (4.8) 373 1 220 2.2 1000 -06 1 140 FN 282-10-06 FN 283-10-06 FN 284-10-06 FN 285-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 1 140 10 (11.6) 373 0.34 220 2.2 1000 -06 1 140 FN 286-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 2 90 FN 286-2-06 2 (2.4) 373 2 220 2.2 1000 -06 2 90 FN 286-4-06 4 (4.8) 373 1 220 2.2 1000 -06 2 90 FN 286-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 2 90 FN 286-10-06 10 (11.6) 373 0.34 220 2.2 1000 -06 2 140 FN 283 E-1-06 1 (1.2) 373 7.5 0.4 220 2.2 1000 -06 1 140 FN 283 E-2-06 2 (2.4) 373 2 0.4 220 2.2 1000 -06 1 140 FN 283 E-4-06 4 (4.8) 373 1 0.4 220 2.2 1000 -06 1 140 FN 283 E-6-06 6 (7.2) 373 0.45 0.4 220 2.2 1000 -06 1 140 FN 284 E-1-06 1 (1.2) 373 7.5 0.4 220 2.2 1000 -06 2 90 FN 284 E-2-06 2 (2.4) 373 2 0.4 220 2.2 1000 -06 2 90 FN 284 E-4-06 4 (4.8) 373 1 0.4 220 2.2 1000 -06 2 90 FN 284 E-6-06 6 (7.2) 373 0.45 0.4 220 2.2 1000 -06 2 90 FN 282 B-1-06 1 (1.2) 2 7.5 220 1000 -06 2 90 FN 282 B-2-06 2 (2.4) 2 2 220 1000 -06 2 90 FN 282 B-4-06 4 (4.8) 2 1 220 1000 -06 2 90 FN 282 B-6-06 6 (7.2) 2 0.45 220 1000 -06 2 90 10 (11.6) 2 0.34 220 1000 -06 2 140 FN 285-10-06 FN 282 B-10-06 * ** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Filters are delivered without fuse. 3 Schaffner Group EMC/EMI Products Filter Datasheets 2018 Rated current Leakage current** Inductance Capacitance Resistance Output @ 40°C (25°C) @ 230 VAC/50 Hz L1 L2 Cx Cy R connections [A] [μA] [mH] [mH] [nF] [nF] [kΩ] FN 284 B-1-06 1 (1.2) 2 7.5 220 1000 -06 2 90 FN 284 B-2-06 2 (2.4) 2 2 220 1000 -06 2 90 FN 284 B-4-06 4 (4.8) 2 1 220 1000 -06 2 90 FN 284 B-6-06 6 (7.2) 2 0.45 220 1000 -06 2 90 10 (11.6) 2 0.34 220 1000 -06 2 140 FN 286 B-1-06 1 (1.2) 2 7.5 220 1000 -06 2 90 FN 286 B-2-06 2 (2.4) 2 2 220 1000 -06 2 90 FN 286 B-4-06 4 (4.8) 2 1 220 1000 -06 2 90 6 (7.2) 2 0.45 220 1000 -06 2 90 10 (11.6) 2 0.34 220 1000 -06 2 140 FN 284 B-10-06 FN 286 B-6-06 FN 286 B-10-06 * ** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Filters are delivered without fuse. Product selector For example: FN 281-6-06, FN 283 B-04-06, FN 283 E-1-06 Typical filter attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym 1 A types 2 to 6 A types 10 A types Fuses** Weight [Qty] [g] 4 Schaffner Group EMC/EMI Products Datasheets Mechanical data FN 281/FN 282 FN 283/FN 284 FN 285/FN 286 Panel cut out Dimensions FN 281 FN 282 FN 283 FN 284 FN 285 FN 286 Tolerances ±0.3 A 32 32 50 50 32 32 B 82 82 65 65 65 65 C 72 72 40 40 D 43.1 43.1 43.1 43.1 43.6 E 28.5 28.5 28.5 28.5 28.5 28.5 ±0.25 F 5.5 5.5 5.5 5.5 5 5 ±0.3 G 59.95 max. 59.95 max. 59.95 max. 59.95 max. 59.95 max. 59.95 max. H Ø3.5 Ø3.5 Ø3.3 Ø3.3 I 13.4 16.2 13.4 16.2 13.9 16.7 J 22.5 22.5 22.5 22.5 22.5 22.5 M R ≤2.5 R ≤2.5 R ≤2.5 R ≤2.5 R ≤2.5 R ≤2.5 N 60 60 60 60 61.5+0.2/-0* 61.5+0.2/-0* +0.5/-0 P 29 29 29 29 29 29 +0.5/-0 R M3 M3 M3 M3 S 90° 90° 90° 90° * For a panel thickness between 0.8 and 3 mm All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. ±0.3 ±0.1 43.6 ±0.3 ±0.3 2018 5 Schaffner Group EMC/EMI Products Datasheets Headquarters, global innovation and development Sales and application centers Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 info@schaffner.com www.schaffner.com China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai T +86 21 3813 9500 cschina@schaffner.com www.schaffner.com.cn Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Tegeluddsvägen 76, 2tr 115 28 Stockholm T +46 8 5050 2425 swedensales@schaffner.com www.schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com India Schaffner India Pvt. Ltd REGUS WORLD TRADE CENTRE WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore T +91 80 67935355 indiasales@schaffner.com To find your local partner within Schaffner‘s global network: www.schaffner.com © 2018 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifications are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) T +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. 1-32-12, Kamiuma, Setagaya-ku 7F Mitsui-seimei Sangenjaya Bldg. 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp Singapore Schaffner EMC Pte Ltd. #05-09, Kg Ubi Ind. Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 switzerlandsales@schaffner.com Taiwan R.O.C. Schaffner EMV Ltd. 20 Floor-2, No 97, Section 1, XinTai 5th Road 22175 XiZhi District New Taipei City 22175 T +886 2 2697 5500 F +886 2 2697 5533 taiwansales@schaffner.com www.schaffner.com.tw Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 5 Ashville Way, Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com USA Schaffner EMC Inc. 52 Mayfield Avenue 08837 Edison, New Jersey T +1 800 367 5566 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffnerusa.com Schaffner North America 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 Schaffner North America 823 Fairview Road 24382 Wytheville, Virginia T +1 276 228 7943 F +1 276 228 7258 2018
FN 282-4-06
物料型号:FN 280 器件简介:这是一款符合IEC/EN 60601-1标准的紧凑型过滤电源入口模块,适用于一般用途,可选配接地线滤波器和医疗版本。
引脚分配:具有单或双保险丝座,保险丝规格为Ø5 x 20 mm,2极摇臂开关。
参数特性:额定电流可达10A,最大连续操作电压为250V、50/60Hz,工作频率从DC到400Hz,具有优良的传导衰减性能。
功能详解:提供EMI系统快速认证的实用解决方案,具有多种电流等级、保险丝选项、安装方式和医用滤波器选择。
应用信息:适用于便携式电子设备、家电、办公设备、单相电源、开关电源、测试和测量设备以及医疗设备。
封装信息:FN 280系列提供多种安装方式,包括后部/前部或卡入式安装,单或双保险丝座和2极摇臂开关。
有关FN 280系列电源滤波器更详细参数和特性,请参考Schaffner集团提供的数据手册。
FN 282-4-06 价格&库存
很抱歉,暂时无法提供与“FN 282-4-06”相匹配的价格&库存,您可以联系我们找货
