FN2030-3-06
FN2030-3-06
    SCHAFFNER(夏弗纳)
    FN2030-3-06
FN2030-3-06 数据手册
DATASHEET Single-Stage Filters FN 2030 General Purpose EMI Filter with High Attenuation Performance Rated currents from 1 to 30 A High performance filter attenuation Approvals High differential-mode attenuation Optional medical versions (B type) Optional safety versions (A type) Optional overvoltage protection (Z type) Features and benefits FN 2030 filters are designed for easy and fast chassis mounting The FN 2030 filters are also available as B versions with no Y-capacitors for medical applications as well as A versions with low capacitance for safety critical applications with a requirement for low leakage currents All filters provide an exceptional conducted attenuation performance, based on chokes with high permeable core material and excellent thermal behavior The higher inductivity versus amperage offers increased attenuation performance with same form factor compared to FN 2010 and FN 2020 filter series All FN 2030 filters can be delivered with optional surge pulse protection. FN 2030 filters are also available as two- stage filters (FN 2090 series) for very noisy environment Various terminal options allow you to select the desired connection style Technical specifications Operating voltage 110/250 VAC, 50/60 Hz Rated currents High potential test voltage 1 to 30 A @ 40 °C max. P –> PE 2000 VAC for 2 sec (standard types) Operating frequency Temperature range (operation and storage) Design corresponding to Flammability corresponding to Surge pulse protection (optional) MTBF @ 40°C/230V (Mil-HB-217F) dc to 400 Hz P –> N 1100 VDC for 2 sec P –> PE 2500 VAC for 2 sec (B types) -25 °C to +100 °C (25/100/21) UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 UL 94 V-2 or better 2kV, IEC 61000-4-5 2,200,000 hours (1 to 10 A types) 1,200,000 hours (12 to 30 A types) Typical application Electrical and electronic equipment Consumer goods Household equipment Medical equipment Electronic data processing equipment Office automation and datacom equipment Various noisy applications requiring high filter performance Typical electrical schematic EMC/EMI Products Schaffner Group Datasheets 2014 Filter selection table Filter* Rated current Leakage current** Inductance [A] [mA] FN 2030-3-.. 3 (3.4) FN 2030-6-.. 6 (6.7) @ 40 °C (25 °C) (1.1) FN 2030-1-.. 4 (4.5) FN 2030-4-.. FN 2030-8-.. 8 (8.9) FN 2030-10-.. 10 (11.2) FN 2030-16-.. 16 (17.9) FN 2030-12-.. FN 2030-20-.. FN 2030-30-08 @ 230 VAC/50 Hz 12 (13.4) 20 (22.4) 30 (33.5) Capacitance Resistance Input/Output Cy [mH] [μF] [nF] [kΩ] 0.52 14 0.33 3.3 1000 -06 -07 87 0.73 8 0.47 4.7 680 -06 -07 100 8 0.47 4.7 680 -06 -07 0.52 0.73 0.73 0.87 0.87 0.87 0.87 20 14 8 4 4 4 2 0.22 0.33 0.47 1.0 1.0 1.0 1.0 2.2 3.3 4.7 R 1000 1000 680 connections -06 -06 -06 10 330 -06 10 330 -06 10 10 330 330 -06 -07 0.47 1000 -06 -07 FN 2030A-4-.. 4 (4.5) 0.074 14 0.33 0.47 1000 -06 -07 6 (6.7) FN 2030A-6-.. FN 2030A-8-.. 8 (8.9) FN 2030A-10-.. 10 (11.2) FN 2030A-16-.. 16 (17.9) FN 2030A-12-.. FN 2030A-20-.. FN 2030A-30-08 12 (13.4) 20 (22.4) 30 (33.5) 0.074 0.074 0.074 0.074 0.074 0.074 0.074 0.47 8 0.47 0.47 8 0.47 0.47 8 4 4 4 2 0.47 0.47 1000 -06 -06 -07 680 -06 -07 -06 1.0 0.47 330 -06 1.0 0.47 330 -06 1.0 1.0 0.47 0.47 330 330 -06 -08 285 326 87 92 100 -07 170 196 -07 -07 225 58 -07 680 680 196 185 -08 0.22 0.33 170 -07 20 14 92 -07 0.074 0.074 58 -07 1 (1.1) 3 (3.4) [g] -07 FN 2030A-1-.. FN 2030A-3-.. Weight Cx 0.34 L 185 -08 -08 225 285 326 FN 2030B-1-.. 1 (1.1) 0.002 20 0.22 1000 -06 -07 58 FN 2030B-4-.. 4 (4.5) 0.002 14 0.33 1000 -06 -07 92 3 (3.4) FN 2030B-3-.. 6 (6.7) FN 2030B-6-.. FN 2030B-8-.. 8 (8.9) FN 2030B-10-.. 10 (11.2) FN 2030B-16-.. 16 (17.9) FN 2030B-12-.. FN 2030B-20-.. FN 2030B-30-08 12 (13.4) 20 (22.4) 30 (33.5) 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 14 0.33 8 0.47 8 0.47 8 4 4 4 2 0.47 1000 -06 680 -06 -07 680 -06 -07 680 -06 1.0 330 -06 1.0 330 -06 1.0 1.0 -07 330 330 -06 87 100 -07 170 196 -07 -07 185 -08 -08 225 285 326 * To compile a complete part number, please replace the -.. with the required I/O connection style. For surge pulse protection, please add Z (e.g. FN 2030Z-10-06, FN 2030BZ-2008). ** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Typical filter attenuation Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym 1 to 4 A types 6 to 10 A types 12 to 20 A types 30 A types EMC/EMI Products Schaffner Group Datasheets Mechanical data Connection style -06, 1 A types Connection style -06, 8 to 20 A types Connection style -06, 3 to 6 A types Connection style -07, 8 to 16 A types (same dimensions as style -06) Connection style -07, 1 to 6 A types (same dimensions as style -06) Connection style -08, 20 and 30 A types 2014 EMC/EMI Products Schaffner Group Datasheets 2014 Dimensions 1A 3A 4A 6A 8A 10 A 12 A 16 A 20 A 30 A Tolerances A 64 71 71 71 85 85 85 85 85 85 ±0.5 C 24.3 22.3 30.3 30.3 30.3 40.3 40.3 40.3 ±0.5 E 32.5 44.5 49.8 49.8 49.8 49.8 49.8 49.8 B D F G H 35 46.6 46.6 46.6 43.5 50.5 50.5 50.5 21 N Connection style -07 O P AWG type wire Wire length Connection style -08 61 21 61 21 64.8 75 27 54 64.8 75 27 54 64.8 75 27 54 64.8 75 27 54 64.8 75 27 54 64.8 12.3 12.3 12.3 12.3 12.3 21.8 25.25 25.25 25.25 19.9 19.9 19.9 11.4 11.4 11.4 6.3 6.3 6.3 6.3 5.3 0.7 0.7 5.3 0.7 16.8 5.3 0.7 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 8.3 8.3 8.3 8.3 AWG 20 AWG 20 AWG 20 AWG 18 21.8 140 N All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m / EN 22768-m 14 140 14 140 14 140 20.8 5.3 6.3 0.7 6.3 x 0.8 8.3 14.9 AWG 18 140 20.8 5.3 6.3 0.7 6.3 x 0.8 8.3 14.9 AWG 18 140 20.8 5.3 6.3 0.7 6.3 x 0.8 8.3 14.9 AWG 16 140 29.8 5.3 6.3 0.7 6.3 x 0.8 29.8 5.3 6.3 0.7 ±0.5 ±0.5 27 12.3 16.8 ±0.5 ±0.3 10.8 16.8 ±0.5 75 10.8 5.3 Connection style -06 21 44.5 54 10.8 K M 61 22.3 9.3 15.3 L 44.5 54 I J 22.3 29.8 5.3 ±0.2 ±0.5 ±0.5 6.3 0.7 6.3 x 0.8 8.3 ±0.5 14.9 ±0.5 AWG 16 140 M4 M4
FN2030-3-06 价格&库存
很抱歉,暂时无法提供与“FN2030-3-06”相匹配的价格&库存,您可以联系我们找货
FN2030-3-06
    • 50+131.58404
    库存:1105
