FN282-10-06.
FN282-10-06.
    SCHAFFNER(夏弗纳)
    SCHAFFNER - FN282-10-06. - POWER ENTRY MODULE
FN282-10-06. 数据手册
DATASHEET IEC Inlet Filters FN 280 Compact filtered power entry module Complies with IEC/EN 60601-1 Rated currents up to 10 A Approvals Single or dual-fuse holder Fuses Ø 5 x 20 mm 2-pole rocker switch General purpose application Optional earth line choke (E type) Optional medical versions (B type) (CQC except HI-types) The FN 280 power entry module combines an IEC inlet, a mains filter with single or dual- fuse holder and a 2-pole rocker switch in a small form factor. Choosing FN 280 product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings, fuse options, mounting possibilities and filters for medical applications are designed to offer you the desired solution. Features and benefits High conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Rear/front or snap-in mounting Single or dual-fuse holder Technical specifications 2-pole rocker switch Maximum continuous operating voltage 250 V, 50/60 Hz High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> N 760 VAC for 2 sec Operating frequency Rated currents 50 to 400 Hz 1 to 10 A @ 40 °C max. Protection category P –> PE 2500 VAC for 2 sec (B types) IP40 according to IEC 60529 Flammability corresponding to MTBF @ 40°C/230V (Mil-HB-217F) UL 94 V-2 or better 1,500,000 hours Temperature range (operation and storage) Design corresponding to Fuse holder Marking Rocker switch description Function Electrical specifications Mechanical life: Switch ratings USA (UL) and Canada (C-UL) Europe (ENEC) Operating frequency -25 °C to +85 °C (25/85/21) UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 1 or 2 fuses (Ø5 x 20mm) max. 250 V ~ (text is print. below fuse symbol) 2-pole, dark not illuminated Marking I - 0 Inrush current 82 A 6,000 on-off operations according to UL 1054, TV5 10,000 on-off operations according to ENEC 50,000 cycles 10 A, 125 VAC; 10 A, 250 VAC; 1/3 HP 10 A (4 A), 250 VAC* 50 to 400 Hz * Value in () relates to the inductive current charge: cosφ = 0.65 Custom-specific versions are available on request Typical applications Portable electrical and electronic equipment Consumer goods EDP and office equipment Single-phase power supplies, switch-mode power supplies Test and measurement equipment Medical equipment EMC/EMI Products 2 Schaffner Group Datasheets 2014 Filter selection table Filter FN 281-1-06 FN 281-2-06 FN 281-4-06 FN 281-6-06 FN 281-10-06 Rated current Leakage current** 1 (1.2) 373 @ 40 °C (25 °C) [A] 2 (2.4) 4 (4.8) 6 (7.2) 10 (11.6) L1 [mH] Cy [nF] 373 2 220 373 0.45 220 7.5 373 373 1 (1.2) 373 FN 282-4-06 4 (4.8) 373 FN 282-6-06 FN 282-10-06 2 (2.4) 6 (7.2) 10 (11.6) 373 373 1 140 7.5 373 373 2.2 1000 -06 2 7.5 373 373 1 220 0.34 220 220 2.2 2.2 2.2 1000 1000 1000 -06 -06 -06 2 2 1 140 140 90 90 90 90 140 140 2 220 2.2 1000 -06 1 140 373 0.45 220 2.2 1000 -06 1 140 7.5 373 373 1 220 0.34 220 220 2.2 2.2 2.2 1000 1000 1000 -06 -06 -06 1 1 2 2 220 2.2 1000 -06 2 373 0.45 220 2.2 1000 -06 2 7.5 373 373 1 220 0.34 220 0.4 220 2.2 2.2 2.2 1000 1000 1000 -06 -06 -06 2 2 1 140 140 90 90 90 90 140 140 2 0.4 220 2.2 1000 -06 1 140 373 0.45 0.4 220 2.2 1000 -06 1 140 7.5 4 (4.8) 373 373 1 0.4 0.4 220 220 2.2 2.2 1000 1000 -06 -06 1 2 140 90 2 0.4 220 2.2 1000 -06 2 90 373 0.45 0.4 220 2.2 1000 -06 2 90 7.5 FN 282B-1-06 1 (1.2) 2 FN 282B-4-06 4 (4.8) 2 * ** 2 220 FN 284E-4-06 10 (11.6) -06 1 0.45 373 FN 282B-10-06 1000 -06 373 1 (1.2) 6 (7.2) 2.2 1000 1 2 FN 284E-1-06 FN 282B-6-06 220 2.2 -06 -06 373 2 (2.4) 220 1000 1000 4 (4.8) FN 282B-2-06 0.34 2.2 2.2 FN 283E-4-06 6 (7.2) 220 220 373 FN 284E-6-06 1 2 1 (1.2) 2 (2.4) 140 -06 FN 283E-1-06 FN 284E-2-06 1 90 140 1000 10 (11.6) 6 (7.2) -06 2 2.2 FN 286-10-06 FN 283E-6-06 1000 -06 90 220 373 2 (2.4) 2.2 1000 2 0.45 4 (4.8) FN 283E-2-06 220 2.2 -06 373 FN 286-4-06 6 (7.2) 220 1000 140 373 FN 286-6-06 0.34 2.2 1 1 (1.2) 2 (2.4) 220 -06 FN 286-1-06 FN 286-2-06 1 90 90 1000 373 10 (11.6) 2 140 2.2 4 (4.8) FN 285-10-06 -06 140 220 FN 285-4-06 6 (7.2) 1000 [g] 140 2 373 FN 285-6-06 2.2 7.5 373 1 (1.2) 2 (2.4) 140 1 2 FN 285-1-06 FN 285-2-06 1 -06 -06 373 10 (11.6) -06 1000 1000 4 (4.8) FN 284-10-06 1000 2.2 2.2 FN 284-4-06 6 (7.2) 2.2 1 220 373 FN 284-6-06 140 1 0.45 1 (1.2) 2 (2.4) 1 -06 [Qty] 373 FN 284-1-06 FN 284-2-06 -06 1000 -06 2 373 10 (11.6) 220 1000 2.2 1000 -06 4 (4.8) FN 283-10-06 220 Weight 2.2 2.2 1000 FN 283-4-06 6 (7.2) 0.34 Fuses** connections 2.2 373 FN 283-6-06 220 Output R [kΩ] 220 1 (1.2) 2 (2.4) 1 220 Resistance 2 FN 283-1-06 FN 283-2-06 7.5 L2 [mH] Capacitance Cx [nF] FN 282-1-06 FN 282-2-06 Inductance @ 230 VAC/50 Hz [μA] 2 2 2 1 0.4 220 220 2.2 1000 1000 -06 -06 2 2 90 90 2 220 1000 -06 2 90 0.45 220 1000 -06 2 90 1 0.34 220 220 1000 1000 Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Filters are delivered without fuse. -06 -06 2 2 90 140 EMC/EMI Products 3 Filter FN 284B-1-06 FN 284B-2-06 FN 284B-4-06 FN 284B-6-06 FN 284B-10-06 Schaffner Group Rated current Leakage current** 1 (1.2) 2 @ 40°C (25°C) [A] L1 [mH] 2 2 2 0.45 7.5 2 (2.4) 4 (4.8) 2 6 (7.2) 10 (11.6) 2 FN 286B-1-06 1 (1.2) 2 FN 286B-4-06 4 (4.8) 2 FN 286B-2-06 FN 286B-6-06 FN 286B-10-06 * ** Inductance @ 230VAC/50Hz [μA] 2 (2.4) 2 6 (7.2) 2 10 (11.6) 2 7.5 1 0.34 L2 [mH] Capacitance Cx [nF] Resistance Output [g] -06 2 90 -06 2 1000 220 1000 220 220 220 1000 1000 1000 -06 -06 -06 -06 2 2 2 2 2 220 1000 -06 2 0.45 220 1000 -06 2 1 0.34 220 220 Product selector For example: FN 281-6-06, FN 283B-04-06, FN 283E-1-06 Typical filter attenuation Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym 2 to 6 A types [Qty] 220 1000 1000 Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Filters are delivered without fuse. 1 A types Weight connections 1000 10 A types 2014 Fuses** R [kΩ] 220 Cy [nF] Datasheets -06 -06 2 2 90 90 90 140 90 90 90 90 140 EMC/EMI Products 4 Schaffner Group Datasheets 2014 Mechanical data FN 281 / FN 282 FN 283 / FN 284 FN 285 / FN 286 Panel cut out Dimensions FN 281 FN 282 FN 283 FN 284 FN 285 FN 286 Tolerances A 32 32 50 50 32 32 ±0.3 C 72 72 40 40 82 B 43.1 D 43.1 28.5 E 5.5 F G I 28.5 5.5 65 43.1 28.5 5.5 65 43.1 28.5 5.5 5 43.6 28.5 5 59.95 max. 59.95 max. 59.95 max. 13.4 16.2 13.4 16.2 13.9 16.7 22.5 Ø 3.5 22.5 Ø 3.3 22.5 Ø 3.3 22.5 R ≤ 2.5 R ≤ 2.5 R ≤ 2.5 P 29 29 29 29 S 28.5 59.95 max. R ≤ 2.5 R 43.6 65 59.95 max. M N 65 59.95 max. Ø 3.5 H J 82 60 M3 90° 60 M3 90° * For a panel thickness between 0.8 and 3 mm All dimensions in mm; 1 inch = 25.4mm Tolerances according: ISO 2768-m / EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. 60 M3 90° 60 M3 90° 22.5 R ≤ 2.5 61.5+0.2/-0* 29 22.5 R ≤ 2.5 61.5+0.2/-0* 29 ±0.3 ±0.1 ±0.3 ±0.25 ±0.3 ±0.3 +0.5/-0 +0.5/-0
FN282-10-06. 价格&库存
很抱歉,暂时无法提供与“FN282-10-06.”相匹配的价格&库存,您可以联系我们找货
