FN2340Y-10-06
FN2340Y-10-06
    SCHAFFNER(夏弗纳)
    Power Line Filter 0Hz to 400Hz 10A 250VAC Faston Flange Mount
FN2340Y-10-06 数据手册
Single-phase chassis-mounting filter FN 2340 • Current ratings from 2 to 20A • Improved differential mode performance • UL-rated materials • Nennströme von 2 bis 20A • Erhöhte symmetrische Dämpfung • UL konformes Material • Courants de service de 2 à 20A • Bonne atténuation en mode différentiel • Matériaux UL Filter selection table Filter Approvals Conn. / Housing Current ratings @40°C (25°C) A Resistance Weight L mH Inductance L1 µH Cx µF Capacitance Cy nF R MΩ g FN2340Y-2-06 Fast-on H1 2 ( 2.25 ) 0.52 - 0.1 5.5 1 85 FN2340Y-3-06 Fast-on H2 3 ( 3.35 ) 1.7 - 0.1 5.5 1 115 FN2340Y-5-06 Fast-on H2 5 ( 5.6 ) 0.54 - 0.1 5.5 1 115 FN2340Y-10-06 Fast-on J1 10 ( 11.2 ) 0.54 - 0.1 5.5 1 125 FN2340Y-20-06 Fast-on K2 20 ( 22.4 ) 0.43 - 0.1 5.5 1 230 FN2340Y-20-10 Screw K2 20 ( 22.4 ) 0.43 - 0.1 5.5 1 255 Additional specifications Filter type Maximum operating voltage All types Operating frequency VAC Hz Hz 250 50/60 DC to 400 2000 MTBF at 40°C, 230V, per Mil-HB-217F: 3,000,000 hours. Electrical schematic 2xL P’ LINE R Cx N’ N E 2 x Cy 118 LOAD P Cx Hipot test voltage PN→E VAC Maximum leakage P→N VAC @ 230VAC/50Hz 760 0.94 Temperature range mA -25°C - +100°C FN 2340 insertion loss Per CISPR 17; A = 50Ω/50Ω sym, B = 50Ω/50Ω asym, C = 0.1Ω/100Ω sym, D = 100Ω/0.1Ω sym 2 amp types 3 amp types dB dB 70 5 amp types dB A 10 amp types dB A 70 70 70 60 60 60 60 50 50 50 50 40 40 40 40 30 30 A C/D 20 C/D 30 20 10 10 30 C/D 20 B A 20 B 10 10 C/D B B 0 0 0 0 -10 -10 - 10 - 10 -20 10 k 100 k 1M 10M -20 10k 100k 1M -20 10 k 10M 100 k 1M -20 10 k 10M 100 k 1M 10M 20 amp types dB 70 60 A 50 40 30 20 B 10 C/D 0 -10 -20 10 k 100 k 1M 10M Mechanical data -20A (-10) P D D P N O N B O O N M D C C P -3A, -5A C -2A, -10A, -20A (-06) M M F A F A B UNC 8-32 F A B Housings H1, J1, K2 Housing H2 Housing K2 FN2340Y 2A A B C D F M N O P 3A 5A Tol. 10A 20A (-06 ) 71 46.6 [ mm ] 83 ± 0.5 ± 0.5 ± 0.5 ± 0.5 ± 0.3 ± 0.1 ± 0.1 ± 0.1 ±1 85 54 40 64 75 50.5 22.3 20A (-10) 29.3 50.5 61 5.3 6.3 0.7 67.6 74 73.6 72 All dimensions in mm; 1 inch = 25.4mm. 119
FN2340Y-10-06 价格&库存
很抱歉,暂时无法提供与“FN2340Y-10-06”相匹配的价格&库存,您可以联系我们找货
