DATASHEET
Single-Stage Filters FN 2030
General Purpose EMI Filter with High Attenuation Performance
Rated currents from 1 to 30 A
High performance filter attenuation
Approvals
High differential-mode attenuation
Optional medical versions (B type)
Optional safety versions (A type)
Optional overvoltage protection (Z type)
Features and benefits
FN 2030 filters are designed for easy and fast chassis
mounting
The FN 2030 filters are also available as B versions
with no Y-capacitors for medical applications as well
as A versions with low capacitance for safety critical
applications with a requirement for low leakage
currents
All filters provide an exceptional conducted
attenuation performance, based on chokes with
high permeable core material and excellent thermal
behavior
The higher inductivity versus amperage offers
increased attenuation performance with same form
factor compared to FN 2010 and FN 2020 filter series
All FN 2030 filters can be delivered with optional
surge pulse protection. FN 2030 filters are also
available as two- stage filters (FN 2090 series) for very
noisy environment
Various terminal options allow you to select the
desired connection style
Technical specifications
Operating voltage
110/250 VAC, 50/60 Hz
Rated currents
High potential test voltage
1 to 30 A @ 40 °C max.
P –> PE 2000 VAC for 2 sec (standard types)
Operating frequency
Temperature range (operation and storage)
Design corresponding to
Flammability corresponding to
Surge pulse protection (optional)
MTBF @ 40°C/230V (Mil-HB-217F)
dc to 400 Hz
P –> N 1100 VDC for 2 sec
P –> PE 2500 VAC for 2 sec (B types)
-25 °C to +100 °C (25/100/21)
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
UL 94 V-2 or better
2kV, IEC 61000-4-5
2,200,000 hours (1 to 10 A types)
1,200,000 hours (12 to 30 A types)
Typical application
Electrical and electronic equipment
Consumer goods
Household equipment
Medical equipment
Electronic data processing equipment
Office automation and datacom equipment
Various noisy applications requiring high filter
performance
Typical electrical schematic
EMC/EMI Products
Schaffner Group
Datasheets
2014
Filter selection table
Filter*
Rated current
Leakage current**
Inductance
[A]
[mA]
FN 2030-3-..
3 (3.4)
FN 2030-6-..
6 (6.7)
@ 40 °C (25 °C)
(1.1)
FN 2030-1-..
4 (4.5)
FN 2030-4-..
FN 2030-8-..
8 (8.9)
FN 2030-10-..
10 (11.2)
FN 2030-16-..
16 (17.9)
FN 2030-12-..
FN 2030-20-..
FN 2030-30-08
@ 230 VAC/50 Hz
12 (13.4)
20 (22.4)
30 (33.5)
Capacitance
Resistance
Input/Output
Cy
[mH]
[μF]
[nF]
[kΩ]
0.52
14
0.33
3.3
1000
-06
-07
87
0.73
8
0.47
4.7
680
-06
-07
100
8
0.47
4.7
680
-06
-07
0.52
0.73
0.73
0.87
0.87
0.87
0.87
8
4
4
4
2
0.22
0.33
0.47
1.0
1.0
1.0
1.0
2.2
3.3
4.7
R
1000
1000
680
connections
-06
-06
-06
10
330
-06
10
330
-06
10
10
330
330
-06
-07
0.47
1000
-06
-07
FN 2030A-4-..
4 (4.5)
0.074
14
0.33
0.47
1000
-06
-07
6 (6.7)
FN 2030A-6-..
FN 2030A-8-..
8 (8.9)
FN 2030A-10-..
10 (11.2)
FN 2030A-16-..
16 (17.9)
FN 2030A-12-..
FN 2030A-20-..
FN 2030A-30-08
12 (13.4)
20 (22.4)
30 (33.5)
0.074
0.074
0.074
0.074
0.074
0.074
0.074
0.47
8
0.47
0.47
8
0.47
0.47
8
4
4
4
2
0.47
0.47
1000
-06
-06
-07
680
-06
-07
-06
1.0
0.47
330
-06
1.0
0.47
330
-06
1.0
1.0
0.47
0.47
330
330
-06
-08
285
326
87
92
100
-07
170
196
-07
-07
225
58
-07
680
680
196
185
-08
0.22
0.33
170
-07
92
-07
0.074
0.074
58
-07
1 (1.1)
3 (3.4)
[g]
-07
FN 2030A-1-..
FN 2030A-3-..
Weight
Cx
0.34
L
185
-08
-08
225
285
326
FN 2030B-1-..
1 (1.1)
0.002
1000
-06
-07
58
FN 2030B-4-..
4 (4.5)
0.002
14
0.33
1000
-06
-07
92
3 (3.4)
FN 2030B-3-..
6 (6.7)
FN 2030B-6-..
FN 2030B-8-..
8 (8.9)
FN 2030B-10-..
10 (11.2)
FN 2030B-16-..
16 (17.9)
FN 2030B-12-..
FN 2030B-20-..
FN 2030B-30-08
12 (13.4)
20 (22.4)
30 (33.5)
0.002
0.002
0.002
0.002
0.002
0.002
0.002
0.002
14
0.33
8
0.47
8
0.47
8
4
4
4
2
0.47
1000
-06
680
-06
-07
680
-06
-07
680
-06
1.0
330
-06
1.0
330
-06
1.0
1.0
-07
330
330
-06
87
100
-07
170
196
-07
-07
185
-08
-08
225
285
326
* To compile a complete part number, please replace the -.. with the required I/O connection style. For surge pulse protection, please add Z (e.g. FN 2030Z-10-06, FN 2030BZ-2008).
** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level.
Typical filter attenuation
Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym
1 to 4 A types
6 to 10 A types
12 to 20 A types
30 A types
EMC/EMI Products
Schaffner Group
Datasheets
Mechanical data
Connection style -06, 1 A types
Connection style -06, 8 to 20 A types
Connection style -06, 3 to 6 A types
Connection style -07, 8 to 16 A types (same dimensions as style -06)
Connection style -07, 1 to 6 A types (same dimensions as style -06)
Connection style -08, 20 and 30 A types
2014
EMC/EMI Products
Schaffner Group
Datasheets
2014
Dimensions
1A
3A
4A
6A
8A
10 A
12 A
16 A
20 A
30 A
Tolerances
A
64
71
71
71
85
85
85
85
85
85
±0.5
C
24.3
22.3
30.3
30.3
30.3
40.3
40.3
40.3
±0.5
E
32.5
44.5
49.8
49.8
49.8
49.8
49.8
49.8
B
D
F
G
H
35
46.6
46.6
46.6
43.5
50.5
50.5
50.5
21
N
O
P
AWG type wire
Wire length
61
21
61
21
64.8
75
27
54
64.8
75
27
54
64.8
75
27
54
64.8
75
27
54
64.8
75
27
54
64.8
12.3
12.3
12.3
12.3
12.3
21.8
25.25
25.25
25.25
19.9
19.9
19.9
11.4
11.4
11.4
6.3
6.3
6.3
6.3
5.3
0.7
0.7
5.3
0.7
16.8
5.3
0.7
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
8.3
8.3
8.3
8.3
AWG 20
AWG 20
AWG 20
AWG 18
21.8
140
N
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m / EN 22768-m
14
140
14
140
14
140
20.8
5.3
6.3
0.7
6.3 x 0.8
8.3
14.9
AWG 18
140
20.8
5.3
6.3
0.7
6.3 x 0.8
8.3
14.9
AWG 18
140
20.8
5.3
6.3
0.7
6.3 x 0.8
8.3
14.9
AWG 16
140
29.8
5.3
6.3
0.7
6.3 x 0.8
29.8
5.3
6.3
0.7
±0.5
±0.5
27
12.3
16.8
±0.5
±0.3
10.8
16.8
±0.5
75
10.8
5.3
21
44.5
54
10.8
K
M
61
22.3
9.3
15.3
L
44.5
54
I
J
22.3
29.8
5.3
±0.2
±0.5
±0.5
6.3
0.7
6.3 x 0.8
8.3
±0.5
14.9
±0.5
AWG 16
140
M4
M4
很抱歉,暂时无法提供与“FN2030-30-08”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+559.450401+72.79910
- 5+548.245305+71.34100
- 10+537.2914010+69.91560
- 国内价格 香港价格
- 1+293.350401+38.17250
- 10+270.1912010+35.15890
- 国内价格 香港价格
- 20+463.0608020+60.25630
- 40+453.7990040+59.05110
- 80+444.7237080+57.87010
