Single-phase chassis-mounting filter FN 2340
• Current ratings from 2 to 20A
• Improved differential mode performance
• UL-rated materials
• Nennströme von 2 bis 20A
• Erhöhte symmetrische Dämpfung
• UL konformes Material
• Courants de service de 2 à 20A
• Bonne atténuation en mode différentiel
• Matériaux UL
Filter selection table
Filter
Approvals
Conn. / Housing
Current ratings
@40°C (25°C)
A
Resistance
Weight
L
mH
Inductance
L1
µH
Cx
µF
Capacitance
Cy
nF
R
MΩ
g
FN2340Y-2-06
Fast-on
H1
2
( 2.25 )
0.52
0.1
5.5
1
85
FN2340Y-3-06
Fast-on
H2
3
( 3.35 )
1.7
0.1
5.5
1
115
FN2340Y-5-06
Fast-on
H2
5
( 5.6 )
0.54
0.1
5.5
1
115
FN2340Y-10-06
Fast-on
J1
10
( 11.2 )
0.54
0.1
5.5
1
125
FN2340Y-20-06
Fast-on
K2
0.43
0.1
5.5
1
230
FN2340Y-20-10
Screw
K2
0.43
0.1
5.5
1
255
Additional specifications
Filter type
Maximum
operating voltage
All types
Operating
frequency
VAC
Hz
Hz
250
50/60
DC to 400
2000
MTBF at 40°C, 230V, per Mil-HB-217F: 3,000,000 hours.
Electrical schematic
2xL
P’
LINE
R
Cx
N’
N
E
2 x Cy
118
LOAD
P
Cx
Hipot test voltage
PN→E
VAC
Maximum leakage
P→N
VAC
@ 230VAC/50Hz
760
0.94
Temperature
range
mA
-25°C - +100°C
FN 2340 insertion loss
Per CISPR 17; A = 50Ω/50Ω sym, B = 50Ω/50Ω asym, C = 0.1Ω/100Ω sym, D = 100Ω/0.1Ω sym
2 amp types
3 amp types
dB
dB
70
5 amp types
dB
A
10 amp types
dB
A
70
70
70
60
60
60
60
50
50
50
50
40
40
40
40
30
30
A
C/D
C/D
30
10
30
C/D
B
A
B
10
10
C/D
B
B
-10
- 10
- 10
-20
10 k
100 k
1M
10M
-20
10k
100k
1M
-20
10 k
10M
100 k
1M
-20
10 k
10M
100 k
1M
10M
20 amp types
dB
70
60
A
50
40
30
B
10
C/D
-20
10 k
100 k
1M
10M
Mechanical data
-20A (-10)
P
D
D
P
N
O
N
B
O
O
N
M
D
C
C
P
-3A, -5A
C
-2A, -10A, -20A (-06)
M
M
F
A
F
A
B
UNC 8-32
F
A
B
Housings H1, J1, K2
Housing H2
Housing K2
FN2340Y
2A
A
B
C
D
F
M
N
O
P
3A
5A
Tol.
10A
20A (-06 )
71
46.6
[ mm ]
83
± 0.5
± 0.5
± 0.5
± 0.5
± 0.3
± 0.1
± 0.1
± 0.1
±1
85
54
40
64
75
50.5
22.3
20A (-10)
29.3
50.5
61
5.3
6.3
0.7
67.6
74
73.6
72
All dimensions in mm; 1 inch = 25.4mm.
119
很抱歉,暂时无法提供与“FN2340Y-20-06”相匹配的价格&库存,您可以联系我们找货
