FN9222RB-20-06
FN9222RB-20-06
    SCHAFFNER(夏弗纳)
    AC Power Entry Modules 12A Surge Protect Wide Mounting Flange
FN9222RB-20-06 数据手册
General Performance IEC Inlet Filter IEC Inlet Filters FN 9222 Rated currents up to 20 A Excellent performance/size ratio Approvals Optional medical versions (B type) according to IEC/EN 60601-1 Snap-in versions (S and S1 type) Hot inlet versions (HI type) (CQC except HI-types) Optional overvoltage protection (Z type) The FN 9222 IEC inlet filter combines an IEC inlet and mains filter with excellent filter attenuation in a small form factor. Choosing the FN 9222 product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings, output connections, mounting possibilities and filters for medical applications are designed to offer you the desired solution. Features and benefits Exceptional conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Rear/front or snap-in mounting Wide mounting flanges available Technical specifications Maximum continuous operating voltage Operating frequency Rated currents Approvals by rated current High potential test voltage Protection category Temperature range (operation and storage) Design corresponding to Flammability corresponding to Surge pulse protection (optional) MTBF @ 40°C/230V (Mil-HB-217F) 250 VAC, 50/60 Hz dc to 400 Hz 1 to 20 A @ 50 °C 1 to 10 A (ENEC, CQC) 16 A (ENEC, CQC) for 16 and 20 A types 1 to 20 A (UL, CSA) P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 1000 VAC for 2 sec (1 to 10 A types, not Z types) Optional medical versions (B type) comply with the requirements of IEC/EN 60601-1 for creepage and clearance, leakage current and high potential testing 12 and 15 A types with hot inlet available Optional surge pulse protection Different output connections offering maximum flexibility for assembly Custom-specific versions are available on request Typical applications P –> N 250 VAC for 2 sec (all Z types) P –> N 1100 VDC for 2 sec (16 and 20 A types, not Z types) Portable electrical and electronic equipment UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (X to XX A, not Z types) UL 94 V-2 or better Test and measurement equipment IP40 according to IEC 60529 -25 °C to +85 °C (25/85/21) 2 kV, IEC 61000-4-5 ≤15 A: 3,040,000 hours ≥16 A: 2,256,000 hours Small to medium-sized machines and household equipment Single-phase power supplies, switch-mode power supplies Medical equipment Rack mounting equipment 2 EMC/EMI Products Schaffner Group Datasheets 2014 Filter selection table Filter Rated current Leakage current* Inductance [A] [µA] 3 (3.5) 373 @ 50 °C (25 °C) FN 9222x-1-.. 1 (1.2) FN 9222x-6-.. 6 (7.2) FN 9222x-3-.. FN 9222x-8-.. 8 (10.6) FN 9222x-10-.. 10 (11.6) FN 9222x-15-.. 15 (15) FN 9222x-12-.. FN 9222x-12-..HI FN 9222x-15-..HI @ 250 VAC/50 Hz 373 Cy [mH] [µF] [nF] 2.5 0.1 2.2 12 0.78 373 0.225 373 0.075 373 0.075 373 373 12 (12) 373 Capacitance Cx 373 12 (12) 15 (15) L 0.5 0.1 0.1 0.1 0.1 2.2 Resistance R Output connections [kΩ] -06 -07 -06 -07 -06 2.2 2.2 -06 2.2 -06 0.11 0.1 2.2 -06 -07 40 12 0.1 2.2 1000 -06 -07 40 0.1 2.2 1000 -06 -07 40 0.1 0.1 2.2 -06 2.2 -06 0.78 373 0.225 373 0.075 20 (23) 373 0.4 0.33 2.2 1000 -06 15 (15) 373 0.075 0.1 2.2 1000 -06 FN 9222xR-10-.. FN 9222xR-12-.. FN 9222xR-15-.. FN 9222xR-16-06 FN 9222xR-20-06 FN 9222xR-12-..HI FN 9222xR-15-..HI 10 (11.6) 12 (12) 373 16 (18.5) 373 15 (15) 12 (12) 373 FN 9222xB-1-.. 1 (1.2) 2 FN 9222xB-6-.. 6 (7.2) FN 9222xB-3-.. FN 9222xB-8-.. FN 9222xB-15-..HI -06 0.11 0.1 2.2 1000 -06 0.54 0.33 2.2 1000 -06 0.11 0.1 0.1 2.2 2.2 1000 1000 -06 -07 -07 -07 -07 -06 -07 -07 40 40 40 40 40 100 100 40 40 2 0.78 0.1 1000 -06 -07 40 2 0.225 2 0.075 20 (23) 2 0.4 0.33 1000 -06 15 (15) 2 0.075 0.1 1000 -06 8 (10.6) 12 (12) 16 (18.5) 12 (12) 2 2 2 2 373 FN 9222UZ-6-06 6 (7.2) 3 (3.5) 8 (10.6) FN 9222UZ-10-06 10 (11.6) FN 9222UZ-15-06 15 (15) FN 9222UZ-12-06 1000 -06 -07 40 1 (1.2) FN 9222UZ-8-06 2.2 1000 -06 -07 2 FN 9222UZ-1-06 FN 9222UZ-3-06 0.1 2.2 1000 -06 15 (15) FN 9222xB-12-..HI 0.1 2.2 40 1000 FN 9222xB-15-.. FN 9222xB-20-06 0.5 0.1 -07 40 0.1 10 (11.6) FN 9222xB-16-06 2.5 -07 12 3 (3.5) FN 9222xB-10-.. FN 9222xB-12-.. 40 40 373 373 40 -07 6 (7.2) 8 (10.6) 40 -06 FN 9222xR-6-.. FN 9222xR-8-.. 40 2.2 373 373 -07 40 0.1 1 (1.2) 3 (3.5) -07 [g] 0.11 FN 9222xR-1-.. FN 9222xR-3-.. -07 Weight 12 (12) 2.5 0.5 0.11 0.54 0.11 0.1 1000 0.1 1000 0.1 1000 0.1 1000 0.1 1000 0.33 1000 0.1 1000 -06 -06 -06 -06 -06 -06 -06 -07 -07 -07 -07 -07 -07 -07 40 40 40 40 40 100 100 40 40 12 0.1 2.2 -06 43 373 0.78 0.1 2.2 -06 43 373 0.225 373 0.075 373 373 373 2.5 0.5 0.11 0.1 0.1 0.1 0.1 0.1 2.2 2.2 2.2 2.2 2.2 * Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. -06 -06 -06 -06 -06 43 43 43 43 43 3 EMC/EMI Products Schaffner Group Product selector Typical electrical schematic For example: FN 9222E-15-06, FN 9222ES1B-10-06-20, FN 9222ER-12-06HI, FN 9222EUB-8-06-20 Typical filter attenuation Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym 1 and 3 A types 6 to 10 A types 12 and 15A types 16 and 20 A types Datasheets 2014 4 EMC/EMI Products Schaffner Group Mechanical data FN 9222 1 to 15 A types FN 9222, 16 and 20 A types FN 9222S FN 9222S1 FN 9222-HI FN 9222 U -07 connection style Panel cut out Installation Datasheets 2014 5 EMC/EMI Products Schaffner Group Datasheets 2014 Dimensions FN 9222 1 to 8 A A B 48 22.5 FN 9222U FN 9222UZ 53 51.85 51.85 10 to 15 A 16 and 20 A 48 22.5 30 25 FN 9222S 1 to 8 A 29.9 10 to 15 A 29.9 FN 9222S1 1 to 8 A 29.9 10 to 15 A 29.9 25 22.4 22.4 22.4 22.4 46.8 38.4 38.4 38.4 38.4 FN 9222-HI 12 and 15 A 48 22.5 C 40 ±0.2 40 ±0.2 42 ±0.2 40 ±0.2 40 ±0.2 E 27.8 27.8 34 27.8 27.8 27.8 27.8 27.8 27.8 27.8 20.1 20.1 20.1 20.1 20.1 20.1 20.1 14 14 14 14 14 D F G H I J 38.4 5.5 20.1 Ø 3.3 14 13.3 38.4 5.5 20.1 Ø 3.3 14 13.3 66 4 26.5 Ø 3.5 14 13.3 38.25 5.5 Ø 3.3 14.1 13.3 5.5 Ø 3.3 13.3 5.5 13.3 5.5 13.3 5.5 13.3 5.5 13.3 40 ±0.2 38.4 5.5 Ø3.3 14 13.3 M R≤3 R≤3 R≤3 R≤3 R≤3 R ≤ 1.5 R ≤ 1.5 R ≤ 1.5 R ≤ 1.5 R≤3 P 28.5 28.5 34.7 28.5 28.5 29.4 29.4 28.5 28.5 28.5 90° 90° N R S T* T* 21.5 M3 90° 21.5 M3 27 M3 21.5 M3 90° 21.5 M3 90° 20.8 20.8 21.9 21.9 0.7-1.5 0.7-1.5 0.7-1.5 0.7-1.5 1.5-2.2 1.5-2.2 1.5-2.2 1.5-2.2 21.5 M3 90° X AWG 18 AWG 16 AWG 18 AWG 16 AWG 18 AWG 16 AWG 16 Z 6 6 6 6 6 6 6 Y 160 160 * For selecting the panel thickness, please refer to the filter selector table. All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m / EN 22768-m 160 160 160 160 160 6 EMC/EMI Products Headquarters, global innovation and development center Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 6816 626 F +41 32 6816 630 info@schaffner.com http://www.schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3, No 565 Chuangye Road Pudong New Area 201201 Shanghai T +86 21 3813 9500 F F +86 21 3813 9501 / 02 cschina@schaffner.com http://www.schaffner.com.cn/ France Schaffner EMC S.A.S. 112, Quai de Bezons Boîte postale 133 95103 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com Italy Schaffner EMC S.r.l. Via Galileo Galilei 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45/47 F +39 02 61 23 943 italysales@schaffner.com © 2014 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published speci cations are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published speci cations. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. 2014 Sales and application centers Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 19 35 72 71 finlandsales@schaffner.com To nd your local partner within Schaffner‘s global network, please go to: www.schaffner.com Datasheets Japan Schaffner EMC K.K. 1-32-12, Kamiuma, Setagaya-ku 7F Mitsui-seimei Sangenjaya Bldg. 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com http://www.schaffner.jp Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 05-09 Kampong Ubi Industrial Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Spain Schaffner EMC España Edificio E, Alcobendas El Soto de la Moraleja Alcobendas 28109 Madrid T +34 618 176 133 spainsales@schaffner.com Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 6816 626 F +41 32 6816 641 sales@schaffner.ch Taiwan R.O.C. Schaffner EMV Ltd. 6 Floor, No. 413 Rui Guang Road 114 Neihu District Taipei City T +886 2 87525050 F +886 2 87518086 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com http://www.schaffner.uk.com USA Schaffner EMC Inc. 52 Mayfield Avenue 08837 Edison, New Jersey T +1 800 367 5566 T +732 225 9533 F +732 225 4789 usasales@schaffner.com http://www.schaffner.com/us Schaffner MTC LLC 6722 Thirlane Road 24019 Roanoke, Virginia T +276 228 7943 F +276 228 7953 http://www.schaffnerusa.com Schaffner Trenco LLC 2550 Brookpark Road 44134 Cleveland, Ohio T +216 741 5282 F +216 741 4860 www.schaffner-trenco.com
FN9222RB-20-06 价格&库存
很抱歉,暂时无法提供与“FN9222RB-20-06”相匹配的价格&库存,您可以联系我们找货
