FN9280EB-10-100
FN9280EB-10-100
    SCHAFFNER(夏弗纳)
    n/a
FN9280EB-10-100 数据手册
DATA SHEET IEC Inlet Filters FN 9280 Ultra Compact and Versatile Filtered Power Entry Module Single stage filter Approvals Ultra compact design Rated currents up to 10 A dual-fuse holder Fuses Ø5x20 mm 2-pole rocker switch Good attenuation performance Faston or spring cage terminals (CQC except HI-types; Patent US 20110227692/US 8766761; CN ZL201080069589.0) Check the video of our IEC Inlet Filters FN 9280 and FN 9290 on Youtube! Performance indicators Choosing FN 9280/90 product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances and a high attenuation performance. For higher attenuation performance the FN 9290 family with a dual stage filter and identical panel cut-out can be used. Standard IEC connector filters are a practical solution to pass EMI system approval in a short time. A wide selection of amperage ratings, mounting possibilities and also filters for medical applications are designed to offer you the best solution. Features and benefits Good conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Technical specifications Mechanical life 50,000 cycles High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 760 VAC for 2 sec MTBF @ 40°C/230 V (Mil-HB-217F) >1,000,000 hours Temperature range (operation and storage) – 25°C to +85°C (25/85/21) Design corresponding to UL 1283, CSA 22.2 No. 8 1986, EN 60939, EN 60950, EN 60601-1, UL 544, EN 60320 Flammability corresponding to UL 94 V-2 or better Maximum continuous operating voltage 250 VAC, 50/60 Hz Rated currents 1 to 10 A @ 40°C max. Operating frequency DC to 400 Hz Switch ratings USA (UL) and Canada (C-UL) 10 A, 125 VAC; 10 A, 250 VAC; 1/3 HP Europe (ENEC) 10 A (4 A), 250 VAC** Electrical specifications Inrush current 82 A 6,000 on-off operations according to UL 1054 10,000 on-off operations according to ENEC Leakage current Standard:
FN9280EB-10-100 价格&库存
很抱歉,暂时无法提供与“FN9280EB-10-100”相匹配的价格&库存,您可以联系我们找货
