DATASHEET
3-Phase Filters FN 3270
Compact EMC/RFI Filter for Industrial Motor Drive Applications
Very compact and light weight design requiring
minimum space
Approvals
Easy, time-saving installation and contacting
Protective covers as optional accessory available
Attenuation performance according to EN 618003/A11
Features and benefits
An extremely compact and light weight filter design
requiring minimum mounting space in installations
and cabinets
Simple and time-saving installation with good
accessibility for automatic and hand tools
Solid, touch-safe terminal blocks, for all filters from
10 to 100 A, offering sufficient contacting cross
section according to the EN 60204-1 installation
standard
Optionally available transparent protective covers
for all filters with busbars from 150 to 1000 A, to
protect the installer, operator or inspector from
undeliberate touching of life conductors. They can
easily be retrofitted even if the filter is already
installed and connected
These EMC filters provide the attenuation
performance needed to fulfill EN 61800-3/A11
Guaranteed filter performance under fullload
operating conditions
Technical specifications
Design corresponding to
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
Maximum continuous operating voltage
P –> P 2250 VDC for 2 sec
3x 520/300 VAC (480 VAC +10% possible)
Flammability corresponding to
High potential test voltage
MTBF @ 50°C/400V (Mil-HB-217F)
Operating frequency
Overload capability
Protection category
Rated currents
Temperature range (operation and storage)
UL 94 V-2 or better
P –> E 2750 VDC for 2 sec
>320,000 hours
dc to 60 Hz
4x rated current at switch on,
1.5x rated current for 1 minute, once per hour
IP20 (10 to 100 A)
IP00 (150 to 1000 A)
10 to 1000 A @ 50 °C
15 different filter models allow the specific choice
and deployment for most industrial applications
Typical applications
Variable speed electrical power drive systems/motor
drives for mainly industrial purpose
Various industrial applications comprising
frequency inverters, motor drives and servo drives
Typical electrical schematic (up to 100A)
-25 °C to +100 °C (25/100/21)
Typical electrical schematic (>100A)
La
L1
Lb
Lc
L2
L2'
L3
L3'
Cx
R1
Cx
Le
R1
Cx
Cy
PE
L1'
R2
Cy
R1
R2
Cy
R2
2
EMC/EMI Products
Schaffner Group
Datasheets
2015
Filter selection table
Filter
Rated current
@ 50 °C (40 °C)
Typical drive
power rating*
Leakage current**
@ 480 VAC/50 Hz
Power loss
@ 25 °C/50 Hz
[A]
[kW]
[mA]
[W]
20 (22)
11
26.4
4.1
–44
0.5
30
29.4
12.8
–34
1.2
29.4
13.5
FN 3270H-10-44
10 (11)
FN 3270H-35-33
35 (38)
FN 3270H-20-44
50 (55)
FN 3270H-50-34
65 (71)
FN 3270H-65-34
80 (88)
FN 3270H-80-35
5.5
22
37
45
FN 3270H-100-35
100 (110)
FN 3270H-200-99
200 (219)
110
320 (350)
160
150 (164)
FN 3270H-150-99
250 (274)
FN 3270H-250-99
FN 3270H-320-99
400 (438)
FN 3270H-400-99
600 (657)
FN 3270H-600-99
FN 3270H-800-99
FN 3270H-1000-99
800 (876)
1000 (1095)
55
75
132
220
315
400
560
26.4
29.4
29.4
29.4
59.5
2.4
6.8
13.5
17.1
7.5
59.5
13.2
59.5
12.2
59.5
59.5
59.5
59.5
59.5
20.6
19.2
35.6
51.8
81.0
Input/Output
connections
–44
Weight
Protective
covers***
[kg]
Order code
0.4
–33
0.7
–34
1.3
–35
–35
2.2
2.6
–99
6.1
801916
–99
6.1
801916
–99
–99
–99
–99
–99
–99
6.1
7.2
7.2
7.7
15.8
15.8
*** Calculated at rated current, 480 VAC and cos phi = 0.8. The exact value depends upon the efficiency of the drive, the motor and the entire application.
*** Maximum leakage under normal operating conditions. Note: if two phases are interrupted, worst case leakage could reach 5.2 times higher levels.
*** Please contact your local Schaffner partner to order the optional protective covers with the order code in the table above.
Typical filter attenuation
Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym
10 and 20 A types
35 to 65 A types
80 and 100 A types
150 to 1000 A types
801916
801916
801916
801916
806275
806275
EMC/EMI Products
3
Schaffner Group
Datasheets
2015
Mechanical data
10 to 100 A types
150 to 1000 A types
Dimensions
A
10 A
20 A
35 A
50 A
65 A
80 A
100 A
150 A
200 A
250 A
320 A
400 A
600 A
800 A
1000 A
58
58
70
85
85
95
95
200
200
200
200
200
200
190
190
200
240
240
240
240
240
240
75
165
165
165
165
165
165
150
B
58
C
D
120
150
58
120
160
68
130
170
80
140
170
80
140
E
132.5
132.5
142.5
152.5
152.5
G
4.5
4.5
5.5
5.5
5.5
I
10.9
10.9
25
39
39
F
H
J
K
L
M
42
1
M4
20.5
42
1
50
1
65
1
65
200
90
170
182.5
75
5.5
230
90
212.5
86
275
300
86
275
300
300
86
86
275
275
300
300
86
275
370
86
125
125
275
345
345
310
155
Ø 11
Ø 11
Ø 11
Ø 11
Ø 11
Ø 11
45
40
40
40
40
40
40
50
50
2
2
2
2
2
2
3
M4
M5
M6
M6
M8
M8
M10
M10
M10
M10
M10
M10
M12
20.5
15
16
16
37
37
37
37
37
37
67
92
92
92
92
92
92
138
67
380
380
380
380
610
610
93
93
93
93
93
93
132
132
60
60
60
8
8
211
211
211
211
211
211
26.5
26.5
26.5
26.5
26.5
V
25
25
60
3
60
3
60
60
3
6
60
6
X
10
10
10
12.5
12.5
12.5
Z
Ø9
Ø9
Ø9
Ø 11
Ø 11
Ø 11
Y
M12
380
26.5
W
138
3
380
P
U
155
Ø 11
1.5
O
310
Ø 11
1.5
N
370
5.5
1
45
300
37
37
37
37
37
37
201
29
40
Ø 13.5
201
29
40
8
Ø 13.5
All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m / EN 22768-m
Filter input/output connector cross sections
Solid wire
Flex wire
AWG type wire
Recommended torque
Please visit www.schaffner.com to find more details on filter connectors.
-33
-34
-35
-44
16 mm2
35 mm2
50 mm2
10 mm2
AWG 2
AWG 1/0
10 mm2
AWG 6
1.5-1.8 Nm
25 mm2
4.0-4.5 Nm
50 mm2
7-8 Nm
6 mm2
AWG 8
1.5-1.8 Nm
4
EMC/EMI Products
Headquarters, global
innovation and development
center
Switzerland
Schaffner Group
Nordstrasse 11
4542 Luterbach
T +41 32 6816 626
F +41 32 6816 630
info@schaffner.com
http://www.schaffner.com
Schaffner Group
Sales and application centers
China
Schaffner EMC Ltd. Shanghai
T20-3, No 565 Chuangye Road
Pudong New Area
201201 Shanghai
T +86 21 3813 9500
F +86 21 3813 9501 / 02
cschina@schaffner.com
http://www.schaffner.com.cn/
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 19 35 72 71
finlandsales@schaffner.com
France
Schaffner EMC S.A.S.
112 Quai de Bezons
Boîte postale 133
95100 Argenteuil
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
F +49 721 569110
germanysales@schaffner.com
Italy
Schaffner EMC S.r.l.
Via Galileo Galilei 47
20092 Cinisello Balsamo (MI)
T +39 02 66 04 30 45/47
F +39 02 61 23 943
italysales@schaffner.com
To nd your local partner within Schaffner‘s
global network: www.schaffner.com
© 2014 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published speci cations are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never be
operated
outside
their
published
speci cations. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Datasheets
Japan
Schaffner EMC K.K.
1-32-12, Kamiuma, Setagaya-ku
7F Mitsui-seimei Sangenjaya Bldg.
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
http://www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1
05-09 Kampong Ubi Industrial Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E,
Alcobendas
El Soto de la Moraleja
Alcobendas
28109 Madrid
M +34 618 176 133
T +34 917 912 900
F +34 917 912 901
spainsales@schaffner.com
Sweden
Schaffner EMC AB
Turebergstorg 1, 6
19147 Sollentuna
T +46 8 5792 1121 / 22
F +46 8 92 96 90
swedensales@schaffner.com
Switzerland
Schaffner EMV AG
Nordstrasse 11
4542 Luterbach
T +41 32 6816 626
F +41 32 6816 641
sales@schaffner.ch
Taiwan R.O.C.
Schaffner EMV Ltd.
6 Floor, No. 413
Rui Guang Road
114 Neihu District Taipei City
T +886 2 87525050
F +886 2 87518086
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
UK
Schaffner Ltd.
5 Ashville Way
Molly Millars Lane
Wokingham
RG41 2PL Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
http://www.schaffner.uk.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
08837 Edison, New Jersey
T +1 800 367 5566
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
http://www.schaffner.com/us
Schaffner MTC LLC
6722 Thirlane Road
24019 Roanoke, Virginia
T +1 276 228 7943
F +1 276 228 7953
http://www.schaffner-mtc.com
Schaffner Trenco LLC
2550 Brookpark Road
44134 Cleveland, Ohio
T +1 216 741 5282
F +1 216 741 4860
www.schaffner-trenco.com
2015
很抱歉,暂时无法提供与“FN3270H-800-99”相匹配的价格&库存,您可以联系我们找货
