DATASHEET
IEC Inlet Filters FN 9264
Compact filtered power entry module
Compact size
Rated currents up to 10 A
Approvals
Complies with IEC/EN 60601-1
High quality 2-pole rocker switch
Good attenuation performance
Snap-in versions (S type)
(CQC except HI-types)
Features and benefits
Excellent conducted attenuation performance,
based on chokes with high saturation resistance
and good thermal behavior
High quality 2-pole rocker switch for all-pole
disconnection
Faston terminals for easy assembly
Medical version (B type) according IEC/EN60601-1
As flange mount and snap-in types available
Typical applications
Portable electrical and electronic equipment
EDP and office equipment
Technical specifications
Single-phase power supplies
Maximum continuous operating voltage
250 VAC, 50/60 Hz
Rated currents
High potential test voltage for capacitors
1 to 10 A @ 40 °C max.
P –> PE 2000 VAC for 2 sec (Standard)
Operating frequency
Protection category
Temperature range (operation and storage)
Design corresponding to
Flammability corresponding to
MTBF @ 40°C/230V (Mil-HB-217F)
Rocker switch description
Function
Electrical specifications
Switch ratings
Europe (ENEC)
USA (UL)
50 to 400 Hz
P –> PE 2500 VAC for 2 sec (B-types)
P –> N 760 VAC for 2 sec
IP40 according to IEC 60529
-25 °C to +85 °C (25/85/21)
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
UL 94 V-2 or better
≥ 616,000 hours
2-pole, dark not illuminated
Marking I – 0
Inrush current 100 A
50,000 on-off operations for 10 A according to EN
610581-1
10 A (4 A), 250 VAC* 5E4
20 A, 125 VAC 1 HP; 250 VAC 2 HP;
16 A (4 A), 250 VAC* 1E4
* Value in () relates to the inductive current charge: cosφ = 0.65
Switch-mode power supplies
Test and measurement equipment
Medical electrical devices (MD) and In-Vitro
Diagnostic (IVD) medical devices
2
EMC/EMI Products
Schaffner Group
Datasheets
2014
Filter selection table
Filter
Rated current
@ 40°C (25°C)
Leakage current*
Inductance
[μA]
373/2**
@ 250VAC/50Hz
[A]
FN 9264-xx-1-06-y
1 (1.2)
373/2**
FN 9264-xx-4-06-y
4 (4.6)
373/2**
FN 9264-xx-2-06-y
FN 9264-xx-6-06-y
FN 9264-xx-10-06-y
2 (2.3)
6 (6.9)
10 (11.5)
373/2**
373/2**
L
Capacitance
Resistance
Cx
Cy**
[mH]
[μF]
[nF]
[kΩ]
2.7
0.1
2.2
1000
5.15
0.1
2.2
R
1000
For example: FN 9264-1-06, FN 9264B-6-06, FN 9264SB-4-06-30
-06
-06
Weight
[g]
55
55
1
0.1
2.2
1000
-06
55
0.21
0.1
2.2
1000
-06
55
0.3
0.1
2.2
1000
* Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level.
** B types without Y2-capacitors
Product selector
Output
connections
Typical electrical schematic
-06
55
3
EMC/EMI Products
Schaffner Group
Datasheets
2014
Typical filter attenuation
Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym
1 A types
2 A types
4 A types
6 A types
dB
dB
dB
dB
90
90
90
90
80
80
A
70
60
50
80
70
70
60
60
B
50
B
40
A
80
A
70
B
50
50
40
40
40
30
30
30
30
10
10
10
10k
100k
1M
10M
100M
10k
100k
1M
10M
100M
10k
100k
1M
10M
A
60
100M
10k
B
100k
10 A types
dB
90
80
70
A
60
50
40
B
30
10k
100k
1 B types
10 B types
1M
10M
100M
2 B types
4 B types
6 B types
1M
10M
100M
4
EMC/EMI Products
Schaffner Group
Mechanical data
FN 9264
Panel cut out
FN 9264S
Panel cut out
Installation
Datasheets
2014
5
EMC/EMI Products
Headquarters, global
innovation and development
center
Switzerland
Schaffner Group
Nordstrasse 11
4542 Luterbach
T +41 32 6816 626
F +41 32 6816 630
info@schaffner.com
http://www.schaffner.com
Schaffner Group
Sales and application centers
China
Schaffner EMC Ltd. Shanghai
T20-3, No 565 Chuangye Road
Pudong New Area
201201 Shanghai
T +86 21 3813 9500
F +86 21 3813 9501 / 02
cschina@schaffner.com
http://www.schaffner.com.cn/
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 19 35 72 71
finlandsales@schaffner.com
France
Schaffner EMC S.A.S.
112, Quai de Bezons
Boîte postale 133
95103 Argenteuil
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
F +49 721 569110
germanysales@schaffner.com
Italy
Schaffner EMC S.r.l.
Via Galileo Galilei 47
20092 Cinisello Balsamo (MI)
T +39 02 66 04 30 45/47
F +39 02 61 23 943
italysales@schaffner.com
To nd your local partner within Schaffner‘s
global network: www.schaffner.com
© 2014 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published speci cations are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never be
operated
outside
their
published
speci cations. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Datasheets
Japan
Schaffner EMC K.K.
1-32-12, Kamiuma, Setagaya-ku
7F Mitsui-seimei Sangenjaya Bldg.
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
http://www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1
05-09 Kampong Ubi Industrial Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93
Miniparc III, Edificio E
El Soto de la Moraleja
Alcobendas
28109 Madrid
T +34 618 176 133
spainsales@schaffner.com
Sweden
Schaffner EMC AB
Turebergstorg 1, 6
19147 Sollentuna
T +46 8 5792 1121 / 22
F +46 8 92 96 90
swedensales@schaffner.com
Switzerland
Schaffner EMV AG
Nordstrasse 11
4542 Luterbach
T +41 32 6816 626
F +41 32 6816 641
sales@schaffner.ch
Taiwan R.O.C.
Schaffner EMV Ltd.
6 Floor, No. 413
Rui Guang Road
114 Neihu District Taipei City
T +886 2 87525050
F +886 2 87518086
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
UK
Schaffner Ltd.
5 Ashville Way
Molly Millars Lane
Wokingham
RG41 2PL Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
http://www.schaffner.uk.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
08837 Edison, New Jersey
T +1 800 367 5566
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
http://www.schaffner.com/us
Schaffner MTC LLC
6722 Thirlane Road
24019 Roanoke, Virginia
T +1 276 228 7943
F +1 276 228 7953
http://www.schaffner-mtc.com
Schaffner Trenco LLC
2550 Brookpark Road
44134 Cleveland, Ohio
T +1 216 741 5282
F +1 216 741 4860
www.schaffner-trenco.com
2014
很抱歉,暂时无法提供与“FN9264SB-10-06”相匹配的价格&库存,您可以联系我们找货
