1151-047
1151-047
    SCHAFFNER(夏弗纳)
1151-047 数据手册
3-phase filters FN 3270 Compact three-phase EMC/RFI filter for industrial motor drive applications ■ ■ ■ ■ Very compact and light weight design requiring minimum space Easy, time-saving installation and contacting Protective covers as optional accessory available Attenuation performance according to EN 61800-3/A11 Technical specifications Maximum continuous operating voltage: Operating frequency: Rated currents: High potential test voltage: Protection category: Overload capability: Temperature range (operation and storage): Flammability corresponding to: Design corresponding to: MTBF @ 50°C/400V (Mil-HB-217F): Typical electrical schematic 3x 520/300VAC (480VAC +10% possible) dc to 60Hz 10 to 1000A @ 50°C P –> E 2750VDC for 2 sec P –> P 2250VDC for 2 sec IP20 (10 to 100A) IP00 (150 to 1000A) 4x rated current at switch on, 1.5x rated current for 1 minute, once per hour -25°C to +100°C (25/100/21) UL 94V-2 or better UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 >320,000 hours ■ An extremely compact and light weight or inspector from undeliberate touching of filter design requiring minimum mounting life conductors. They can easily be retro- space in installations and cabinets. fitted even if the filter is already installed Simple and time-saving installation with and connected. good accessibility for automatic and hand ■ tools. ■ Solid, touch-safe terminal blocks, for all filters from 10 to 100A, offering sufficient ■ L2 L2‘ L3 L3‘ Cx Cx R1 Cy R2 PE PE Line Load Variable speed electrical power drive systems/motor drives for mainly industrial purpose ■ Various industrial applications comprising frequency inverters, motor drives and servo drives Guaranteed filter performance under fullload operating conditions. ■ ■ These EMC filters provide the attenuation 15 different filter models allow the specific Optionally available transparent protective choice and deployment for most industrial covers for all filters with busbars from 150 applications. to 1000A, to protect the installer, operator L1‘ performance needed to fulfill EN 61800-3/A11. ■ contacting cross section according to the EN 60204-1 installation standard. L L1 Typical applications Features and benefits ■ Approvals > Components > FN 3270 Filter selection table Filter FN FN FN FN FN FN FN FN FN FN FN FN FN FN FN Rated current @ 50°C (40°C) Typical drive power rating* Leakage current** @ 480VAC/50Hz Power loss @ 25°C/50Hz [A] 10 (11) 20 (22) 35 (38) 50 (55) 65 (71) 80 (88) 100 (110) 150 (164) 200 (219) 250 (274) 320 (350) 400 (438) 600 (657) 800 (876) 1000 (1095) [kW] 5.5 11 22 30 37 45 55 75 110 132 160 220 315 400 560 [mA] 26.4 26.4 29.4 29.4 29.4 29.4 29.4 59.5 59.5 59.5 59.5 59.5 59.5 59.5 59.5 [W] 2.4 4.1 6.8 12.8 13.5 13.5 17.1 7.5 13.2 20.6 12.2 19.2 35.6 51.8 81.0 3270H-10-44 3270H-20-44 3270H-35-33 3270H-50-34 3270H-65-34 3270H-80-35 3270H-100-35 3270H-150-99 3270H-200-99 3270H-250-99 3270H-320-99 3270H-400-99 3270H-600-99 3270H-800-99 3270H-1000-99 Input/Output connections -44 -44 -33 -34 -34 -35 -35 -99 -99 -99 -99 -99 -99 -99 -99 * Calculated at rated current, 480VAC and cos phi = 0.8. The exact value depends upon the efficiency of the drive, the motor and the entire application. ** Maximum leakage under normal operating conditions. Note: if two phases are interrupted, worst case leakage could reach 5.2 times higher levels. Weight Protective covers*** [kg] 0.4 0.5 0.7 1.2 1.3 2.2 2.6 6.1 6.1 6.1 7.2 7.2 7.7 15.8 15.8 Order code *** Please contact your local Schaffner partner to order the optional protective covers with the order code in the table above. Typical filter attenuation Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym; C = 0.1Ω/100Ω sym; D = 100Ω/0.1Ω sym 10 and 20A types 35 to 65A types 80 and 100A types 150 to 1000A types 1151-047 1151-047 1151-047 1151-047 1151-047 1151-047 1151-049 1151-049 > Components > FN 3270 Mechanical data 10 to 100A types 150 to 1000A types D I B M D I L K L A N H A B H J O C C J P U U G W G Z F F V X E Y E Dimensions A B C D E F G H I J K L M N O P U V W X Y Z 10A 20A 35A 50A 65A 80A 100A 150A 200A 250A 320A 400A 600A 800A 1000A 150 58 58 120 132.5 42 4.5 1 21.9 M4 150 58 58 120 132.5 42 4.5 1 21.9 M4 160 70 68 130 142.5 50 5.5 1 25 M5 170 85 80 140 152.5 65 5.5 1 39 M6 170 85 80 140 152.5 65 5.5 1 39 M6 200 95 90 170 182.5 75 5.5 1.5 45 M8 230 95 90 200 212.5 75 5.5 1.5 45 M8 20.5 20.5 20 15 15 16 16 300 200 86 240 275 165 Ø11 2 40 M10 92 37 380 211 93 26.5 60 20 3 10 37 Ø9 300 200 86 240 275 165 Ø11 2 40 M10 92 37 380 211 93 26.5 60 20 3 10 37 Ø9 300 200 86 240 275 165 Ø11 2 40 M10 92 37 380 211 93 26.5 60 20 3 10 37 Ø9 300 200 86 240 275 165 Ø11 2 40 M10 92 37 380 211 93 26.5 60 25 6 12.5 37 Ø11 300 200 86 240 275 165 Ø11 2 40 M10 92 37 380 211 93 26.5 60 25 6 12.5 37 Ø11 300 200 86 240 275 165 Ø11 2 40 M10 92 37 380 211 93 26.5 60 25 8 12.5 37 Ø11 370 190 125 310 345 155 Ø11 3 50 M12 138 67 610 201 132 29 60 40 8 20 47 Ø13.5 370 190 125 310 345 155 Ø11 3 50 M12 138 67 610 201 132 29 60 40 8 20 47 Ø13.5 All dimensions in mm; 1 inch = 25.4mm Tolerances according: ISO 2768-m / EN 22768-m Filter input/output connector cross sections Solid wire Flex wire AWG type wire Recommended torque -33 -34 -35 -44 16mm2 10mm2 AWG 6 1.5 - 1.8Nm 35mm2 25mm2 AWG 2 4.0 - 4.5Nm 50mm2 50mm2 AWG 1/0 7 - 8Nm 10mm2 6mm2 AWG 8 1.5 - 1.8Nm Please visit www.schaffner.com to find more details on filter connectors. Your local partner: To find your local partner within Schaffner’s global network, please go to www.schaffner.com May 2008
1151-047 价格&库存
很抱歉,暂时无法提供与“1151-047”相匹配的价格&库存,您可以联系我们找货
