FN9264SB-4-06
FN9264SB-4-06
    SCHAFFNER(夏弗纳)
    SCHAFFNER  FN9264SB-4-06  IEC FILTER 4A MEDICAL SNAP FIT
FN9264SB-4-06 数据手册
DATASHEET IEC Inlet Filters FN 9264 Compact filtered power entry module Compact size Rated currents up to 10 A Approvals Complies with IEC/EN 60601-1 High quality 2-pole rocker switch Good attenuation performance Snap-in versions (S type) (CQC except HI-types) Features and benefits Excellent conducted attenuation performance, based on chokes with high saturation resistance and good thermal behavior High quality 2-pole rocker switch for all-pole disconnection Faston terminals for easy assembly Medical version (B type) according IEC/EN60601-1 As flange mount and snap-in types available Typical applications Portable electrical and electronic equipment EDP and office equipment Technical specifications Single-phase power supplies Maximum continuous operating voltage 250 VAC, 50/60 Hz Rated currents High potential test voltage for capacitors 1 to 10 A @ 40 °C max. P –> PE 2000 VAC for 2 sec (Standard) Operating frequency Protection category Temperature range (operation and storage) Design corresponding to Flammability corresponding to MTBF @ 40°C/230V (Mil-HB-217F) Rocker switch description Function Electrical specifications Switch ratings Europe (ENEC) USA (UL) 50 to 400 Hz P –> PE 2500 VAC for 2 sec (B-types) P –> N 760 VAC for 2 sec IP40 according to IEC 60529 -25 °C to +85 °C (25/85/21) UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 UL 94 V-2 or better ≥ 616,000 hours 2-pole, dark not illuminated Marking I – 0 Inrush current 100 A 50,000 on-off operations for 10 A according to EN 610581-1 10 A (4 A), 250 VAC* 5E4 20 A, 125 VAC 1 HP; 250 VAC 2 HP; 16 A (4 A), 250 VAC* 1E4 * Value in () relates to the inductive current charge: cosφ = 0.65 Switch-mode power supplies Test and measurement equipment Medical electrical devices (MD) and In-Vitro Diagnostic (IVD) medical devices 2 EMC/EMI Products Schaffner Group Datasheets 2014 Filter selection table Filter Rated current @ 40°C (25°C) Leakage current* Inductance [μA] 373/2** @ 250VAC/50Hz [A] FN 9264-xx-1-06-y 1 (1.2) 373/2** FN 9264-xx-4-06-y 4 (4.6) 373/2** FN 9264-xx-2-06-y FN 9264-xx-6-06-y FN 9264-xx-10-06-y 2 (2.3) 6 (6.9) 10 (11.5) 373/2** 373/2** L Capacitance Resistance Cx Cy** [mH] [μF] [nF] [kΩ] 2.7 0.1 2.2 1000 5.15 0.1 2.2 R 1000 For example: FN 9264-1-06, FN 9264B-6-06, FN 9264SB-4-06-30 -06 -06 Weight [g] 55 55 1 0.1 2.2 1000 -06 55 0.21 0.1 2.2 1000 -06 55 0.3 0.1 2.2 1000 * Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. ** B types without Y2-capacitors Product selector Output connections Typical electrical schematic -06 55 3 EMC/EMI Products Schaffner Group Datasheets 2014 Typical filter attenuation Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym 1 A types 2 A types 4 A types 6 A types dB dB dB dB 90 90 90 90 80 80 A 70 60 50 80 70 70 60 60 B 50 B 40 A 80 A 70 B 50 50 40 40 40 30 30 30 30 20 20 20 20 10 10 10 10 0 10k 100k 1M 10M 100M 0 10k 100k 1M 10M 100M 0 10k 100k 1M 10M A 60 100M 0 10k B 100k 10 A types dB 90 80 70 A 60 50 40 B 30 20 10 0 10k 100k 1 B types 10 B types 1M 10M 100M 2 B types 4 B types 6 B types 1M 10M 100M 4 EMC/EMI Products Schaffner Group Mechanical data FN 9264 Panel cut out FN 9264S Panel cut out Installation Datasheets 2014 5 EMC/EMI Products Headquarters, global innovation and development center Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 6816 626 F +41 32 6816 630 info@schaffner.com http://www.schaffner.com Schaffner Group Sales and application centers China Schaffner EMC Ltd. Shanghai T20-3, No 565 Chuangye Road Pudong New Area 201201 Shanghai T +86 21 3813 9500 F +86 21 3813 9501 / 02 cschina@schaffner.com http://www.schaffner.com.cn/ Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 19 35 72 71 finlandsales@schaffner.com France Schaffner EMC S.A.S. 112, Quai de Bezons Boîte postale 133 95103 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com Italy Schaffner EMC S.r.l. Via Galileo Galilei 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45/47 F +39 02 61 23 943 italysales@schaffner.com To nd your local partner within Schaffner‘s global network: www.schaffner.com © 2014 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published speci cations are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published speci cations. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Datasheets Japan Schaffner EMC K.K. 1-32-12, Kamiuma, Setagaya-ku 7F Mitsui-seimei Sangenjaya Bldg. 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com http://www.schaffner.jp Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 05-09 Kampong Ubi Industrial Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Spain Schaffner EMC España Calle Caléndula 93 Miniparc III, Edificio E El Soto de la Moraleja Alcobendas 28109 Madrid T +34 618 176 133 spainsales@schaffner.com Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 6816 626 F +41 32 6816 641 sales@schaffner.ch Taiwan R.O.C. Schaffner EMV Ltd. 6 Floor, No. 413 Rui Guang Road 114 Neihu District Taipei City T +886 2 87525050 F +886 2 87518086 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com http://www.schaffner.uk.com USA Schaffner EMC Inc. 52 Mayfield Avenue 08837 Edison, New Jersey T +1 800 367 5566 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com http://www.schaffner.com/us Schaffner MTC LLC 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 http://www.schaffner-mtc.com Schaffner Trenco LLC 2550 Brookpark Road 44134 Cleveland, Ohio T +1 216 741 5282 F +1 216 741 4860 www.schaffner-trenco.com 2014
FN9264SB-4-06 价格&库存
很抱歉,暂时无法提供与“FN9264SB-4-06”相匹配的价格&库存,您可以联系我们找货
FN9264SB-4-06
    • 1+223.52760
    • 180+89.18640
    • 480+86.20560
    • 1020+84.73680
