FN3258-55-34
FN3258-55-34
    SCHAFFNER(夏弗纳)
    FN3258-55-34
FN3258-55-34 数据手册
DATASHEET 3-Phase Filters FN 3258 Ultra-compact EMC/RFI Filter for Motor Drives Applications New: solid safety connector blocks available for the whole range Approvals Exceptional attenuation performance from 150 kHz to 30 MHz Excellent saturation resistance up to 50 m cable length Most compact and slim filter design in its class Features and benefits Performance indicators The extremely compact and slim filter design allows a trouble-free installation even where the available mounting space is minimal With new additional filter types providing safety terminal blocks, the most preferred connection style can be chosen fast and easy. This helps to stay in line with the electrical connection concept of a given application FN 3258 filters ensure compliance with Class A limits according to EN 55011 up to 50 m cable length and beyond. Further they can contribute significantly to meet conducted emission limits according to Class B Filter operation on the mains input side of consumers increases their reliability and conducted immunity significant Technical specifications Maximum continuous operating voltage 3x 480/277 VAC (FN 3258) 3x 520/300 VAC (FN 3258 H) Operating frequency Rated currents High potential test voltage DC to 60 Hz Protection category Overload capability IP 20 Temperature range (operation and storage) Flammability corresponding to Design corresponding to MTBF @ 50°C/400 V (Mil-HB-217F) -25°C to +100°C (25/100/21) 7 to 180 A @ 50°C P –> E 2650 / 2750 VDC for 2 sec (FN 3258 / FN 3258H) P –> P 2100 / 2250 VDC for 2 sec (FN 3258 / FN 3258H) 1.5x rated current for 1 minute, once per hour 4x rated current at switch on, UL 94 V-2 or better UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 300,000 hours Chokes with exceptional saturation resistance and excellent thermal behavior are a vital part of FN 3258 design. Thus, all filters retain the expected filter performance even in very noisy applications and under full load conditions Typical applications Three-phase variable speed motor drives, servo drives, inverters and converters Applications comprising energy conversion devices like machines or process automation equipment HVAC equipment, elevators, power supplies, UPS and further three-phase applications Typical electrical schematic 2 EMC/EMI Products Schaffner Group Datasheets 11 Oct 2018 Filter selection table Filter FN 3258-7-44 Typical drive Leakage current** Power loss Input/Output power rating* @ 480/520 VAC/50 Hz @ 25°C/50 Hz connections [kW] [mA] [W] Rated current @ 50°C (40°C) [A] Weight [kg] 7 (7.7) 4 4.3 3.8 -44 0.5 FN 3258-16-44 16 (17.5) 7.5 4.3 6.1 -44 0.8 FN 3258-30-33 30 (32.9) 15 4.3 11.8 -33 1.2 FN 3258-42-33 42 (46.0) 22 4.3 15.7 -33 1.4 FN 3258-55-34 55 (60.2) 30 4.3 25.9 -34 2.0 FN 3258-75-34 75 (82.2) 37 4.3 32.2 -34 2.7 FN 3258-100-35 100 (109.5) 55 4.3 34.5 -35 4.3 FN 3258-130-35 130 (142.4) 75 4.3 43.1 -35 4.5 FN 3258-180-40 180 (197.1) 90 4.3 58.3 -40 6.0 FN 3258 H-7-44 7 (7.7) 4 4.7 3.8 -44 0.5 FN 3258 H-16-44 16 (17.5) 7.5 4.7 6.1 -44 0.8 FN 3258 H-30-33 30 (32.9) 18.5 4.7 11.8 -33 1.2 FN 3258 H-42-33 42 (46.0) 22 4.7 15.7 -33 1.4 FN 3258 H-55-34 55 (60.2) 37 4.7 25.9 -34 2.0 FN 3258 H-75-34 75 (82.2) 45 4.7 32.2 -34 2.7 FN 3258 H-100-35 100 (109.5) 55 4.7 34.5 -35 4.3 FN 3258 H-130-35 130 (142.4) 75 4.7 43.1 -35 4.5 FN 3258 H-180-40 180 (197.1) 110 4.7 58.3 -40 6.0 * Calculated at rated current, 440 VAC (FN 3258)/480 VAC (FN 3258 H) and cos phi=0.8. The exact value depends upon the efficiency of the drive, the motor and the entire application. ** Standardized calculated leakage current acc. IEC60939 under normal operating conditions (FN 3258 at 480 VAC and FN 3258H at 520 VAC). Typical filter attenuation Per CISPR 17; A=50/50 sym; B=50/50 asym; C=0.1/100 sym; D=100/0.1 sym 7 to 42 A types 55 to 100 A types 130 and 180 A types 3 EMC/EMI Products Schaffner Group Datasheets 11 Oct 2018 Mechanical data Note: in favour of a better readability, connectors and earth studs are not shown in the horizontal projection. Dimensions 7A 16 A 30 A 42 A 55 A 75 A 100 A 130 A A 190 250 270 310 250 270 270 270 180 A 380 B 40 45 50 50 85 80 90 90 120 C 70 70 85 85 90 135 150 150 170 D 160 220 240 280 220 240 240 240 350 E 180 235 255 295 235 255 255 255 365 F 20 25 30 30 60 60 65 65 102 G 4.5 5.4 5.4 5.4 5.4 6.5 6.5 6.5 6.5 H 1 1 1 1 1 1.5 1.5 1.5 1.5 I 22 22 25 25 39 39 45 45 51 J M5 M5 M5 M6 M6 M6 M10 M10 M10 K 20 22.5 25 25 42.5 40 45 45 60 L2 29.5 29.5 39.5 37.5 26.5 70.5 64 64 47 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Filter input/output connector cross sections -33 -34 -35 -40 -44 Solid wire 16 mm2 35 mm2 50 mm2 95 mm2 10 mm2 Flex wire 10 mm2 25 mm2 50 mm2 95 mm2 6 mm2 AWG type wire AWG 6 AWG 2 AWG 1/0 AWG 4/0 AWG 8 Recommended torque 1.5-1.8 Nm 4.0-4.5 Nm 7-8 Nm 17-20 Nm 1.5-1.8 Nm Please visit www.schaffner.com to find more details on filter connectors. 4 EMC/EMI Products Schaffner Group Datasheets 11 Oct 2018 Headquarters, global innovation and development Sales and application centers Switzerland Schaffner Group Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 info@schaffner.com www.schaffner.com China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai T +86 21 3813 9500 cschina@schaffner.com www.schaffner.com.cn Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Tegeluddsvägen 76, 2tr 115 28 Stockholm T +46 8 5050 2425 swedensales@schaffner.com www.schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com India Schaffner India Pvt. Ltd REGUS WORLD TRADE CENTRE WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore T +91 80 67935355 indiasales@schaffner.com To find your local partner within Schaffner‘s global network: www.schaffner.com © 2018 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifications are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) T +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. 1-32-12, Kamiuma, Setagaya-ku 7F Mitsui-seimei Sangenjaya Bldg. 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp Singapore Schaffner EMC Pte Ltd. #05-09, Kg Ubi Ind. Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 switzerlandsales@schaffner.com Taiwan R.O.C. Schaffner EMV Ltd. 20 Floor-2, No 97, Section 1, XinTai 5th Road 22175 XiZhi District New Taipei City 22175 T +886 2 2697 5500 F +886 2 2697 5533 taiwansales@schaffner.com www.schaffner.com.tw Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 5 Ashville Way, Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com USA Schaffner EMC Inc. 52 Mayfield Avenue 08837 Edison, New Jersey T +1 800 367 5566 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffnerusa.com Schaffner North America 6722 Thirlane Road 24019 Roanoke, Virginia T +1 276 228 7943 F +1 276 228 7953 Schaffner North America 823 Fairview Road 24382 Wytheville, Virginia T +1 276 228 7943 F +1 276 228 7258
FN3258-55-34 价格&库存
很抱歉,暂时无法提供与“FN3258-55-34”相匹配的价格&库存,您可以联系我们找货
FN3258-55-34
  • 1+3417.480921+442.68331
