DATASHEET
EMC/EMI Products FN 9222
General Performance IEC Inlet Filter
Rated currents up to 20 A
Approvals
Excellent performance/size ratio
Optional medical versions (B type) according to
IEC/EN 60601-1
Snap-in versions (S and S1 type)
Hot inlet versions (HI type)
Optional overvoltage protection (Z type)
(CQC except HI-types)
Performance indicators
The FN 9222 IEC inlet filter combines an IEC inlet and
mains filter with excellent filter attenuation in a small
form factor. Choosing the FN 9222 product line
brings you the rapid availability of a standard filter
associated with the necessary safety acceptances.
Standard IEC connector filters are a practical solution
helping you to pass EMI system approval in a short
time. A wide selection on amperage ratings, output
connections, mounting possibilities and filters for
medical applications are designed to offer you the
desired solution.
Features and benefits
Exceptional conducted attenuation performance,
based on chokes with high saturation resistance
and excellent thermal behavior
Technical specifications
Rear/front or snap-in mounting
Maximum continuous operating voltage
Operating frequency
Rated currents
Approvals by rated current
250 VAC, 50/60 Hz
Wide mounting flanges available
DC to 400 Hz
Optional medical versions (B type) comply with the
requirements of IEC/EN 60601-1 for creepage and
clearance, leakage current and high potential
testing
High potential test voltage
P –> PE 2000 VAC for 2 sec (standard types)
P –> N 250 VAC for 2 sec (all Z types)
P –> N 1000 VAC for 2 sec (1 to 10 A types, not Z types)
P –> PE 2500 VAC for 2 sec (B types)
P –> N 1100 VDC for 2 sec (16 and 20 A types, not Z
types)
1 to 20 A @ 50°C
1 to 10 A (ENEC, CQC)
16 A (ENEC, CQC) for 16 and 20 A types
1 to 20 A (UL, CSA)
Protection category
Temperature range (operation and storage)
Design corresponding to
IP 40 according to IEC 60529
Flammability corresponding to
Surge pulse protection (Z type)
UL 94 V-2 or better
MTBF @ 40°C/230 V (Mil-HB-217F)
≤15 A: 3,040,000 hours
≥16 A: 2,256,000 hours
-25°C to +85°C (25/85/21)
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (X to XX A,
not Z types)
Helps compliance to IEC61000-4-5 (Differential Mode
only)
12 and 15 A types with hot inlet available
Optional surge pulse protection
Different output connections offering maximum
flexibility for assembly
Custom-specific versions are available on request
Typical applications
Portable electrical and electronic equipment
Small to medium-sized machines and household
equipment
Single-phase power supplies, switch-mode power
supplies
Test and measurement equipment
Medical equipment
Rack mounting equipment
2
Schaffner Group
EMC/EMI Products
Datasheets
11 Oct 2018
Filter selection table
Filter
Rated current
Leakage current*
Inductance
@ 50°C (25°C)
@ 250 VAC/50 Hz
L
Capacitance
Cx
Cy
Resistance
R
[kΩ]
Output connections
Weight
(@ 120 VAC/60 Hz)
[A]
[mA]
[mH]
[µF]
[nF]
FN 9222 x-1-..
1 (1.2)
0.31 (0.18)
12
0.1
2.2
-06
-07
40
FN 9222 x-3-..
3 (3.5)
0.31 (0.18)
2.5
0.1
2.2
-06
-07
40
FN 9222 x-6-..
6 (7.2)
0.31 (0.18)
0.78
0.1
2.2
-06
-07
40
FN 9222 x-8-..
8 (10.6)
0.31 (0.18)
0.5
0.1
2.2
-06
-07
40
FN 9222 x-10-..
10 (11.6)
0.31 (0.18)
0.225
0.1
2.2
-06
-07
40
FN 9222 x-12-..
12 (12)
0.31 (0.18)
0.11
0.1
2.2
-06
-07
40
FN 9222 x-15-..
15 (15)
0.31 (0.18)
0.075
0.1
2.2
-06
-07
40
FN 9222 x-12-..HI
12 (12)
0.31 (0.18)
0.11
0.1
2.2
-06
-07
40
FN 9222 x-15-..HI
15 (15)
0.31 (0.18)
0.075
0.1
2.2
-06
-07
40
FN 9222 xR-1-..
1 (1.2)
0.31 (0.18)
12
0.1
2.2
1000
-06
-07
40
FN 9222 xR-3-..
3 (3.5)
0.31 (0.18)
2.5
0.1
2.2
1000
-06
-07
40
FN 9222 xR-6-..
6 (7.2)
0.31 (0.18)
0.78
0.1
2.2
1000
-06
-07
40
FN 9222 xR-8-..
8 (10.6)
0.31 (0.18)
0.5
0.1
2.2
1000
-06
-07
40
FN 9222 xR-10-..
10 (11.6)
0.31 (0.18)
0.225
0.1
2.2
1000
-06
-07
40
FN 9222 xR-12-..
12 (12)
0.31 (0.18)
0.11
0.1
2.2
1000
-06
-07
40
FN 9222 xR-15-..
15 (15)
0.31 (0.18)
0.075
0.1
2.2
1000
-06
-07
FN 9222 R-16-06
16 (18.5)
0.31 (0.18)
0.54
0.33
2.2
1000
-06
FN 9222 R-20-06
20 (23)
0.31 (0.18)
0.4
0.33
2.2
1000
-06
FN 9222 xR-12-..HI
12 (12)
0.31 (0.18)
0.11
0.1
2.2
1000
-06
-07
40
FN 9222 xR-15-..HI
15 (15)
0.31 (0.18)
0.075
0.1
2.2
1000
-06
-07
40
FN 9222 xB-1-..
1 (1.2)
0.00
12
0.1
1000
-06
-07
40
FN 9222 xB-3-..
3 (3.5)
0.00
2.5
0.1
1000
-06
-07
40
FN 9222 xB-6-..
6 (7.2)
0.00
0.78
0.1
1000
-06
-07
40
FN 9222 xB-8-..
8 (10.6)
0.00
0.5
0.1
1000
-06
-07
40
FN 9222 xB-10-..
10 (11.6)
0.00
0.225
0.1
1000
-06
-07
40
FN 9222 xB-12-..
12 (12)
0.00
0.11
0.1
1000
-06
-07
40
-07
FN 9222 xB-15-..
[g]
40
100
100
15 (15)
0.00
0.075
0.1
1000
-06
FN 9222 RB-16-06
16 (18.5)
0.00
0.54
0.33
1000
-06
100
FN 9222 RB-20-06
20 (23)
0.00
0.4
0.33
1000
-06
100
FN 9222 xB-12-..HI
12 (12)
0.00
0.11
0.1
1000
-06
-07
40
FN 9222 xB-15-..HI
15 (15)
0.00
0.075
0.1
1000
-06
-07
40
FN 9222 UZ-1-06
1 (1.2)
0.31 (0.18)
12
0.1
2.2
-06
43
FN 9222 UZ-3-06
3 (3.5)
0.31 (0.18)
2.5
0.1
2.2
-06
43
FN 9222 UZ-6-06
6 (7.2)
0.31 (0.18)
0.78
0.1
2.2
-06
43
FN 9222 UZ-8-06
8 (10.6)
0.31 (0.18)
0.5
0.1
2.2
-06
43
FN 9222 UZ-10-06
10 (11.6)
0.31 (0.18)
0.225
0.1
2.2
-06
43
FN 9222 UZ-12-06
12 (12)
0.31 (0.18)
0.11
0.1
2.2
-06
43
FN 9222 UZ-15-06
15 (15)
0.31 (0.18)
0.075
0.1
2.2
-06
43
* Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level.
40
3
Schaffner Group
EMC/EMI Products
Product selector
Datasheets
Typical electrical schematic
For example: FN 9222 E-15-06, FN 9222 ES1B-10-06-20, FN 9222 ER-12-06HI, FN 9222 EUB-8-06-20
Typical filter attenuation
Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym
1 and 3 A types
6 to 10 A types
12 and 15 A types
16 and 20 A types
11 Oct 2018
4
Schaffner Group
EMC/EMI Products
Mechanical data
FN 9222 1 to 15 A types
FN 9222, 16 and 20 A types
FN 9222 S
FN 9222 S1
FN 9222-HI
FN 9222 U
-07 connection style
Panel cut out
Installation
Datasheets
11 Oct 2018
5
Schaffner Group
EMC/EMI Products
Datasheets
11 Oct 2018
Dimensions
FN 9222
FN 9222 U
FN 9222 UZ
FN 9222 S
1 to 8 A
FN 9222 S1
10 to 15 A
16 and 20 A
A
48
48
53
51.85
51.85
29.9
29.9
29.9
29.9
48
B
22.4
22.4
30
25
25
22.4
22.4
22.4
22.4
22.4
C
40
40
42
40
40
D
38.25
38.25
62
38.25
46.7
38.25
38.25
38.25
38.25
E
27.8
27.8
34.5
27.7
27.7
27.8
27.8
27.8
27.8
27.8
F
5.7
5.7
3.8
5.7
5.7
5.7
5.7
5.7
5.7
5.7
G
20.1
20.1
26.5
20.1
20.1
20.1
20.1
20.1
20.1
H
Ø3.3
Ø3.3
Ø3.5
Ø3.3
Ø3.3
I
14
14
14
14
14
14
14
14
14
J
13.3
13.3
13.3
13.3
13.3
13.3
13.3
13.3
13.3
13.3
M
R 3
R ≤3
R ≤3
R ≤3
R ≤3
R ≤1.5
R ≤ 1.5
R ≤1.5
R ≤1.5
R ≤3
N
21.5
21.5
27
21.5
21.5
20.8
20.8
21.9
21.9
21.5
P
28.5
28.5
34.7
28.5
28.5
29.4
29.4
28.5
28.5
R*
M3
M3
M3
M3
M3
S
90°
90°
90°
90°
90°
T**
1 to 8 A
10 to 15 A
20.1
14
28.5
M3
90°
0.7-1.5
0.7-1.5
1.5-2.2
1.5-2.2
1.5-2.2
1.5-2.2
X
AWG 18
AWG 16
AWG 18
AWG 16
AWG 18
AWG 16
Y
160
160
160
160
160
160
160
Z
6
6
6
6
6
6
6
**Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm
** For selecting the panel thickness, please refer to the filter selector table.
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on filter connectors.
±0.2
38.25
Ø3.3
0.7-1.5
Tol.
12 and 15 A
40
0.7-1.5
T**
10 to 15 A
FN 9222-HI
1 to 8 A
AWG 16
+0.6/-0
+0.6/-0
6
Schaffner Group
EMC/EMI Products
Datasheets
11 Oct 2018
Accessories for IEC Inlet Filters and Power Entry Modules
The accessories displayed are a selection of available accessories for IEC Inlet filters and IEC Power entry modules. As they are displayed in a general way there might
be variants of the filters where the accessories are not available.
For further information please ask your local Schaffner Sales Partner and visit our homepage https://www.schaffner.com/.
Power Cor
Cord
d with LLock
ocking
ing
Syst
System
em ffor
or IInlet
nlet FFilt
ilters
ers IL 13, IL
13 P
P,, IL 19
The locking system has a tensile force
of typical 200N.
It is recommended to use it with
flange mount filters.
Lock Power Cords with IEC Inlets and
Filters"
Schaffner power cords with IEC lock
guard against
accidental disconnection of all
electrical appliances
with an IEC inlet. No exchange or
modification of the
IEC inlet or IEC inlet filter system is
needed. Easy
retrofit for all electronic equipments
and devices.
Link to Datasheet: Datasheet IEC C13/
C19 locking cable
IB - IInsulating
nsulating Boots
There is a full range of insulating boots
available from Schaffner that provide a
physical cover for the exposed
terminals on the back of IEC Inlet
Filters.
These boots fit the simplest non-fused
and unswitched style up to the fully
fused and switched IEC filtered inlet.
The boots are made from a durable
black PVC material that conforms to
UL94-V0 flammability requirements.
The boots slip easily over the back of
the filter and reduce the risk of
electrical shock to maintenance
personnel whilst protecting the filter
from environmental hazard such as
the ingress of dust and moisture.
IEC C13 R
Re
ewir
wireable
eable Connec
Connecttor
for individual P
Po
ower Cor
Cord
d with
Lock
ocking
ing Syst
System
em
rewireable
of typical 300N. It is recommended to
use it with flange mount filters. For
details refer to our Application Note
"Using IEC Lock Power Cords with IEC
Inlets and Filters" Schaffner power
connector with IEC lock guard against
electrical appliances with an IEC inlet.
No exchange or modification of the
needed. Easy retrofit for all electronic
equipments and devices.
7
Schaffner Group
EMC/EMI Products
Datasheets
11 Oct 2018
Headquarters, global
innovation and development
Sales and application centers
Switzerland
Schaffner Group
Nordstrasse 11
4542 Luterbach
T +41 32 681 66 26
info@schaffner.com
www.schaffner.com
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road,
Pudong district
201201 Shanghai
T +86 21 3813 9500
cschina@schaffner.com
www.schaffner.com.cn
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E
El Soto de Moraleja, Alcobendas
28109 Madrid
T +34 917 912 900
F +34 917 912 901
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Tegeluddsvägen 76, 2tr
115 28 Stockholm
T +46 8 5050 2425
swedensales@schaffner.com
www.schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875 Bezons
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
F +49 721 569110
germanysales@schaffner.com
India
Schaffner India Pvt. Ltd
REGUS WORLD TRADE CENTRE
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055 Bangalore
T +91 80 67935355
indiasales@schaffner.com
To find your local partner within Schaffner‘s
global network: www.schaffner.com
© 2018 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published specifications are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never
be operated outside their published
specifications. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900 Monza (MB)
T +39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
1-32-12, Kamiuma, Setagaya-ku
7F Mitsui-seimei Sangenjaya Bldg.
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
#05-09, Kg Ubi Ind. Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Switzerland
Schaffner EMV AG
Nordstrasse 11
4542 Luterbach
T +41 32 681 66 26
switzerlandsales@schaffner.com
Taiwan R.O.C.
Schaffner EMV Ltd.
20 Floor-2, No 97, Section 1, XinTai 5th Road
22175 XiZhi District New Taipei City 22175
T +886 2 2697 5500
F +886 2 2697 5533
taiwansales@schaffner.com
www.schaffner.com.tw
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
5 Ashville Way, Molly Millars Lane
Wokingham
RG41 2PL Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
08837 Edison, New Jersey
T +1 800 367 5566
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
www.schaffnerusa.com
Schaffner North America
6722 Thirlane Road
24019 Roanoke, Virginia
T +1 276 228 7943
F +1 276 228 7953
823 Fairview Road
24382 Wytheville, Virginia
T +1 276 228 7943
F +1 276 228 7258
