FN9280B-10-06
FN9280B-10-06
    SCHAFFNER(夏弗纳)
    Module
FN9280B-10-06 数据手册
EMC and Power Quality  IEC Inlet Filters FN 9280 & FN 9290 Series Ultra Compact and Versatile Filtered Power Entry Module I  Single stage filter FN 9280 I  Dual stage filter FN 9290 I Ultra compact design I Rated currents up to 10A I Dual fuse holder I 2-pole rocker switch I Good attenuation performance I Faston or spring cage terminals Fuse holder included Approvals (CQC, approval pending) Typical electrical schematic FN 9280 Standard types (B types without Cy) Technical specifications Maximum continuous operating voltage: Operating frequency: Rated currents: High potential test voltage: Leakage current: Protection category: Terminals: Spring cage wire range: Temperature range (operation and storage): Design corresponding to: Flammability corresponding to: MTBF @ 40°C/230V (Mil-HB-217F): Fuse holder: Rocker switch: Electrical specifications: Mechanical life: Switch ratings: USA (UL) and Canada (C-UL) Europe (ENEC) 250 VAC, 50/60 Hz 50 to 400 Hz 1 to 10A* @ 40°C P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 760 VAC for 2 sec Standard: FN 9280/FN 9290 FN 9280 Series Filter selection table Filter* Rated current @ 40°C Leakage current** @ 250V ~/50Hz Inductance L1 L2 Capacitance Cx Cy [uA] [mH] 311 10.9 0 220 311 4.4 0 220 311 1.7 0 220 311 0.78 0 220 311 0.32 0 220 Resistance R Output connections Weight FN 9280-1-.. FN 9280-2-.. FN 9280-4-.. FN 9280-6-.. FN 9280-10-.. [A] 1 2 4 6 10 [nF] [kOhm] [g] 2.2 1000 -06 -100 101 2.2 1000 -06 -100 102 2.2 1000 -06 -100 105 2.2 1000 -06 -100 104 2.2 1000 -06 -100 106 FN FN FN FN FN 9280B-1-.. 9280B-2-.. 9280B-4-.. 9280B-6-.. 9280B-10-.. 1 2 4 6 10 2 2 2 2 2 10.9 4.4 1.7 0.78 0.32 0 0 0 0 0 220 220 220 220 220 0 0 0 0 0 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -100 -100 -100 -100 -100 101 102 105 104 106 FN FN FN FN FN 9289-1-.. 9289-2-.. 9289-4-.. 9289-6-.. 9289-10-.. 1 2 4 6 10 311 311 311 311 311 10.9 4.4 1.7 0.78 0.32 0 0 0 0 0 220 220 220 220 220 2.2 2.2 2.2 2.2 2.2 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -100 -100 -100 -100 -100 101 102 105 104 106 FN FN FN FN FN 9289B-1-.. 9289B-2-.. 9289B-4-.. 9289B-6-.. 9289B-10-.. 1 2 4 6 10 2 2 2 2 2 10.9 4.4 1.7 0.78 0.32 0 0 0 0 0 220 220 220 220 220 0 0 0 0 0 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -100 -100 -100 -100 -100 101 102 105 104 106 FN FN FN FN FN 9280E-1-.. 9280E-2-.. 9280E-4-.. 9280E-6-.. 9280E-10-.. 1 2 4 6 10 311 311 311 311 311 10.9 4.4 1.66 0.78 0.32 0.4 0.4 0.4 0.4 0.4 220 220 220 220 220 2.2 2.2 2.2 2.2 2.2 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -100 -100 -100 -100 -100 135 136 137 138 139 FN FN FN FN FN 9280BE-1-.. 9280BE-2-.. 9280BE-4-.. 9280BE-6-.. 9280BE-10-.. 1 2 4 6 10 2 2 2 2 2 10.9 4.4 1.66 0.78 0.32 0.4 0.4 0.4 0.4 0.4 220 220 220 220 220 0 0 0 0 0 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -100 -100 -100 -100 -100 135 136 137 138 139 FN FN FN FN FN 9289E-1-.. 9289E-2-.. 9289E-4-.. 9289E-6-.. 9289E-10-.. 1 2 4 6 10 311 311 311 311 311 10.9 4.4 1.66 0.78 0.32 0.4 0.4 0.4 0.4 0.4 220 220 220 220 220 2.2 2.2 2.2 2.2 2.2 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -100 -100 -100 -100 -100 135 136 137 138 139 FN FN FN FN FN 9289BE-1-.. 9289BE-2-.. 9289BE-4-.. 9289BE-6-.. 9289BE-10-.. 1 2 4 6 10 2 2 2 2 2 10.9 4.4 1.66 0.78 0.32 0.4 0.4 0.4 0.4 0.4 220 220 220 220 220 0 0 0 0 0 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -100 -100 -100 -100 -100 135 136 137 138 139 * To compile a complete part number, please replace the -.. with the required output connection style (e.g. FN 9289-1-06, FN 9282-4-100 ** Maximum leakage current under normal conditions according to IEC 60939-1 Ed. 3 at 250V AC. 3 EMC components > FN 9280/FN 9290 FN 9290 Series Filter selection table Filter* Rated current Leakage current** @ 40°C @ 250V ~/50Hz Inductance L1 L2 [uA] 311 10.9 311 4.4 311 1.7 311 0.78 311 0.32 Cx Capacitance Cy1 Cy2 [mH] 10.9 220 4.4 220 1.7 220 0.78 220 0.32 220 Resistance R Output connections Weight FN 9290-1-.. FN 9290-2-.. FN 9290-4-.. FN 9290-6-.. FN 9290-10-.. [A] 1 2 4 6 10 FN FN FN FN FN 9290B-1-.. 9290B-2-.. 9290B-4-.. 9290B-6-.. 9290B-10-.. 1 2 4 6 10 2 2 2 2 2 10.9 4.4 1.7 0.78 0.32 10.9 4.4 1.7 0.78 0.32 220 220 220 220 220    0    0    0    0    0 0 0 0 0 0 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -100 -100 -100 -100 -100 147 148 148 153 154 FN FN FN FN FN 9299-1-.. 9299-2-.. 9299-4-.. 9299-6-.. 9299-10-.. 1 2 4 6 10 311 311 311 311 311 10.9 4.4 1.7 0.78 0.32 10.9 4.4 1.7 0.78 0.32 220 220 220 220 220 1.5 1.5 1.5 1.5 1.5 0.47 0.47 0.47 0.47 0.47 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -100 -100 -100 -100 -100 147 148 148 153 154 FN FN FN FN FN 9299B-1-.. 9299B-2-.. 9299B-4-.. 9299B-6-.. 9299B-10-.. 1 2 4 6 10 2 2 2 2 2 10.9 4.4 1.7 0.78 0.32 10.9 4.4 1.7 0.78 0.32 220 220 220 220 220    0    0    0    0    0 0 0 0 0 0 1000 1000 1000 1000 1000 -06 -06 -06 -06 -06 -100 -100 -100 -100 -100 147 148 148 153 154 1.5 1.5 1.5 1.5 1.5 [nF] [kOhm] [g] 0.47 1000 -06 -100 147 0.47 1000 -06 -100 148 0.47 1000 -06 -100 148 0.47 1000 -06 -100 153 0.47 1000 -06 -100 154 * To compile a complete part number, please replace the -.. with the required output connection style (e.g. FN 9289-1-06, FN 9282-4-100 ** Maximum leakage current under normal conditions according to IEC 60939-1 Ed. 3 at 250V AC. Product selector: FN 92vww-xx-yy-zz Blank: Snap in range   1.0 to 2.5 mm Optional: 30: Snap in range >2.5 to 3.5 mm 06: Fast-On 6.3 x 0.8 mm (spade/soldering) 100: Spring cage 1 to 10: Rated current [A] Blank: B: Optional: E: BE: Standard version Medical version (without Y2-capacitor) Earth line choke Medical version (without YZ-capacitor) with earth line choke 0: 9: Optional: 1: 2: 3: 4: 8: Flange version vertical/horizontal/front/rear mounting set Snap-in version, snapper on horizontal side (top / bottom) Rear Flange mounting (top / bottom) Front Flange mounting (top / bottom) Rear Flange mounting (left / right) Front Flange mounting (left / right) Snap-in version, snapper on vertical side (left / right) 8: 9: Single stage filter Dual stage filter All FN 9280/FN 9290 are equipped with a dual fuse holder with a spare fuse holder. Note: All FN 9280/FN 9280B/FN 9289/FN 9289B/FN 9290/FN 9290B/FN 9299/FN 9299B are stock types from our distribution partners. Order Examples: FN 9280B-6-100: Medical version of single stage, dual fuse EMC/EMI filter, flange set for vertical/horizontal/front/rear mounting, 6A, spring cage t­erminals, from stock available. FN 9298-6-06-30: Dual stage, dual fuse EMC/EMI filter, snap-in version, snappers for snap-in panel thickness range >2.5 to 3.5 mm, snapper on vertical side, 6A, fast-on terminals, non-stock order type 4 EMC components > FN 9280/FN 9290 FN 9280 Series | Typical filter attenuation | Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym 1A types 2A types 4 – 6A types 10A types B A FN 9280B Series | Typical filter attenuation | Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym 1A types 2A types 10A types 4 – 6A types A B FN 9280E Series | Typical filter attenuation | Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym 1A types 2A types 10A types 4 – 6A types B 6A FN 9280BE Series | Typical filter attenuation | Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym 1A types 2A types 4 – 6A types 10A types A B 5 EMC components > FN 9280/FN 9290 FN 9290 Series | Typical filter attenuation | Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym 1A types 2A types 4 – 6A types 10A types B A FN 9290B Series | Typical filter attenuation | Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym 1A types 2A types 4 – 6A types 10A types B A 6 EMC components > FN 9280/FN 9290 Mechanical Data: FN 9280-x-06 / FN 9280B-x-06: FN 9280-X-100 / FN 9280B-X-100: Dimensions (mm) assembly instructions see on last page FN 9283 / FN 9284 FN 9289-x-06 / FN 9289B-x-06: Panel cutout: FN 9281 / FN 9282 FN 9289-x-100 / FN 9289B-x-100: Panel cutout: Dimensions (mm) 7 EMC components > FN 9280/FN 9290 FN 9290-x-06 / FN 9290B-x-06 / FN 9280E-x-06 / FN 9280BE-x-06: FN 9290-x-100 / FN 9290B-x-100 / FN 9280E-x-100 / FN 9280BE-x-100: assembly instructions see on last page Dimensions (mm) FN 9293 / FN 9294 FN 9291 / FN 9292 FN 9299-x-06 / FN 9299B-x-06 / FN 9289E-x-06 / FN 9889BE-x-06: Panel cutout: FN 9299-x-100 / FN 9299B-x-100 / FN 9289E-x-100 / FN 9289BE-x-100: Panel cutout: Dimensions (mm) 8 EMC components > FN 9280/FN 9290 Assembly Instructions: REAR MOUNTING FRONT MOUNTING or M3 or M3 Recommended screw: Panhead tapping screw d x l 3,9 x 9,5 mm Terminal -100 clamping range, solid wire / flex wire 0,20 mm² –1,5 mm², AWG24 – AWG16 operating force of slider max. 40N recommended stripped length 8mm Recommended screw: Countersunk screw M3X14 DIN963A Push the knob above the terminal to insert the wire. Removal of the combined switch / fuse holder unit An additional fuse mark on the switch indicates the fuses holders behind the switch. The red frame shows the outline of the removable unit. With a simple tool like a Swiss Army knife or a screwdriver No 1 or smaller the unit (1) can be removed from the filter. On the topside (2) behind the switch there are two fuse holders for each live connection. On the bottom side (3) is a clip to Fuses are not in the scope of delivery. carry an additional spare fuse. Your local partner: To find your local partner within Schaffner’s global network, please go to www.schaffner.com August 2012 Headquarters, global innovation and development center Schaffner Group Nordstrasse 11 4542 Luterbach Switzerland T +41 32 681 66 26 F +41 32 681 66 30 info@schaffner.com www.schaffner.com Sales and application centers China Schaffner EMC Ltd. Shanghai T20-3, No 565 Chuangye Road Pudong New Area Shanghai 201201 T +86 21 3813 9500 F +86 21 3813 9501 / 02 cschina@schaffner.com www.schaffner.com Spain Schaffner EMC España Calle Caléndula 93 Miniparc III, Edificio E El Soto de la Moraleja Alcobendas 28109 Madrid T +34 618 176 133 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 19 35 72 71 F +358 19 32 66 10 finlandsales@schaffner.com Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com France Schaffner EMC S.A.S. 112, Quai de Bezons 95103 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 F +41 32 681 66 41 sales@schaffner.ch Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com Taiwan Schaffner EMV Ltd. 6th Floor, No 413 Rui Guang Road Neihu District Taipei City 114 T +886 2 87525050 F +886 2 87518086 taiwansales@schaffner.com Italy Schaffner EMC S.r.l. Via Galileo Galilei, 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45/47 F +39 02 61 23 943 italysales@schaffner.com Japan Schaffner EMC K.K. Mitsui-Seimei Sangenjaya Bldg. 7F 1-32-12, Kamiuma, Setagaya-ku Tokyo 154-0011 T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp To find your local partner within Schaffner‘s global network, please go to www.schaffner.com © 2012 Schaffner Group Specifications are subject to change within notice. The latest version of the data sheets can be obtained from the website. All trademarks recognized. 10/2012 EN Schaffner is an ISO-registered company. Its products are designed and manufactured under the strict quality and environnmental requirements of the ISO 9001 and ISO 14001 standards. This document has been carefully checked. However, Schaffner does not assume any liability for errors or inaccuracies. Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 05-09 Kampong Ubi Industrial Estate T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muang P.O. Box 14 Lamphun 51000 T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way Molly Millars Lane Wokingham Berkshire RG41 2PL T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com www.schaffner.uk.com USA Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey 08837 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffner.com/us
FN9280B-10-06 价格&库存
很抱歉,暂时无法提供与“FN9280B-10-06”相匹配的价格&库存,您可以联系我们找货
FN9280B-10-06
    • 1+342.16560
    • 200+136.53360
    • 480+131.96520
    • 1000+129.71880
    FN9280B-10-06
      • 1+343.69673
      • 10+336.83334
      • 20+326.72391
      库存:52
